INTERP_KERNEL::ComposedEdge Class Reference
#include <InterpKernelGeo2DComposedEdge.hxx>
Inheritance diagram for INTERP_KERNEL::ComposedEdge:
INTERPKERNEL_EXPORT void applyGlobalSimilarity (double xBary, double yBary, double dimChar)
INTERPKERNEL_EXPORT void applyGlobalSimilarity2 (ComposedEdge *other, double xBary, double yBary, double dimChar)
INTERPKERNEL_EXPORT void applySimilarity (double xBary, double yBary, double dimChar)
INTERPKERNEL_EXPORT void applySimilarityOnMyEdges (double xBary, double yBary, double dimChar) const
INTERPKERNEL_EXPORT void applySimilarityOnMyEdgesIfNotAlreadyHit (double xBary, double yBary, double dimChar) const
INTERPKERNEL_EXPORT void applySimilarityOnMyNodes (double xBary, double yBary, double dimChar) const
INTERPKERNEL_EXPORT void applySimilarityOnMyNodesIfNotAlreadyHit (double xBary, double yBary, double dimChar) const
ElementaryEdge * back () const
INTERPKERNEL_EXPORT bool changeEndNodeWith (Node *node) const
INTERPKERNEL_EXPORT bool changeStartNodeWith (Node *node) const
INTERPKERNEL_EXPORT void clear ()
INTERPKERNEL_EXPORT ComposedEdge * clone () const
bool completed () const
 ComposedEdge ()
INTERPKERNEL_EXPORT ComposedEdge (const ComposedEdge &other)
 ComposedEdge (int sz)
INTERPKERNEL_EXPORT void dispatchPerimeter (double &partConsidered) const
INTERPKERNEL_EXPORT double dispatchPerimeterAdv (const ComposedEdge &father, std::vector< double > &result) const
INTERPKERNEL_EXPORT void dispatchPerimeterExcl (double &partConsidered, double &commonPart) const
INTERPKERNEL_EXPORT void dumpInXfigFile (std::ostream &stream, int resolution, const Bounds &box) const
INTERPKERNEL_EXPORT void dumpToCout (const std::map< INTERP_KERNEL::Node *, int > &mapp) const
bool empty () const
INTERPKERNEL_EXPORT void fillBounds (Bounds &output) const
ElementaryEdge * front () const
INTERPKERNEL_EXPORT void getAllNodes (std::set< Node * > &output) const
INTERPKERNEL_EXPORT double getArea () const
INTERPKERNEL_EXPORT void getBarycenter (double *bary) const
INTERPKERNEL_EXPORT void getBarycenter (double *bary, double &weigh) const
INTERPKERNEL_EXPORT void getBarycenterGeneral (double *bary) const
INTERPKERNEL_EXPORT double getCommonLengthWith (const ComposedEdge &other) const
INTERPKERNEL_EXPORT bool getDirection () const
INTERPKERNEL_EXPORT Node * getEndNode () const
INTERPKERNEL_EXPORT double getHydraulicDiameter () const
INTERPKERNEL_EXPORT double getPerimeter () const
INTERPKERNEL_EXPORT Node * getStartNode () const
INTERPKERNEL_EXPORT void initEdgeHitStatus () const
INTERPKERNEL_EXPORT void initLocations () const
INTERPKERNEL_EXPORT void initNodeHitStatus () const
INTERPKERNEL_EXPORT bool intresincEqCoarse (const Edge *other) const
INTERPKERNEL_EXPORT bool isInOrOut (Node *nodeToTest) const
INTERPKERNEL_EXPORT bool isInOrOut2 (Node *nodeToTest) const
INTERPKERNEL_EXPORT bool isNodeIn (Node *n) const
INTERPKERNEL_EXPORT double normalize (ComposedEdge *other, double &xBary, double &yBary)
INTERPKERNEL_EXPORT double normalizeExt (ComposedEdge *other, double &xBary, double &yBary)
INTERPKERNEL_EXPORT double normalizeMe (double &xBary, double &yBary)
INTERPKERNEL_EXPORT ElementaryEdge * operator[] (int i) const
INTERPKERNEL_EXPORT bool presenceOfOn () const
INTERPKERNEL_EXPORT bool presenceOfQuadraticEdge () const
INTERPKERNEL_EXPORT void pushBack (ComposedEdge *elem)
INTERPKERNEL_EXPORT void pushBack (Edge *edge, bool direction=true)
INTERPKERNEL_EXPORT void pushBack (ElementaryEdge *elem)
int recursiveSize () const
void resize (int i)
INTERPKERNEL_EXPORT void reverse ()
INTERPKERNEL_EXPORT void setValueAt (int i, Edge *e, bool direction=true)
int size () const
INTERPKERNEL_EXPORT void unApplyGlobalSimilarityExt (ComposedEdge &other, double xBary, double yBary, double fact)
INTERPKERNEL_EXPORT void unApplySimilarityOnMyEdges (double xBary, double yBary, double dimChar) const
INTERPKERNEL_EXPORT void unApplySimilarityOnMyEdgesIfNotAlreadyHit (double xBary, double yBary, double dimChar) const
INTERPKERNEL_EXPORT void unApplySimilarityOnMyNodes (double xBary, double yBary, double dimChar) const
INTERPKERNEL_EXPORT void unApplySimilarityOnMyNodesIfNotAlreadyHit (double xBary, double yBary, double dimChar) const
static void Delete (ComposedEdge *pt)
static INTERPKERNEL_EXPORT void InitLocationsWithOther (const ComposedEdge &first, const ComposedEdge &other)
static void SoftDelete (ComposedEdge *pt)
INTERPKERNEL_EXPORT ~ComposedEdge ()
std::list< ElementaryEdge * > _sub_edges
Friends
class IteratorOnComposedEdge
A set of quadratic or linear edges, described mainly by their connectivity The set is assumed to be connected, but not necessarily closed (i.e. not necessarily forming a closed polygon). Some methods however requires a closed form.
◆ ComposedEdge() [1/3]
◆ ComposedEdge() [2/3]
ComposedEdge::ComposedEdge ( const ComposedEdge &  other)
References _sub_edges.
◆ ComposedEdge() [3/3]
INTERP_KERNEL::ComposedEdge::ComposedEdge ( int  sz)
◆ ~ComposedEdge()
ComposedEdge::~ComposedEdge ( )
◆ Delete()
◆ SoftDelete()
◆ reverse()
◆ recursiveSize()
◆ presenceOfOn()
bool ComposedEdge::presenceOfOn ( ) const
◆ presenceOfQuadraticEdge()
bool ComposedEdge::presenceOfQuadraticEdge ( ) const
◆ initLocations()
void ComposedEdge::initLocations ( ) const
◆ InitLocationsWithOther()
void ComposedEdge::InitLocationsWithOther ( const ComposedEdge &  first,
Reset the status of all edges (OUT, IN, ON) because they were potentially assigned by the previous candidate processing.
References _sub_edges, and initLocations().
◆ clone()
ComposedEdge * ComposedEdge::clone ( ) const
References ComposedEdge().
◆ isNodeIn()
bool ComposedEdge::isNodeIn ( Node *  n) const
◆ getArea()
double ComposedEdge::getArea ( ) const
This method computes the area of 'this'. By definition :
Area=\int_{Polygon} dS
Thanks to Green's theorem we have.
\int_{Polygon} x \cdot dS=\sum_{0 \leq i < nb of edges} -\int_{Edge_{i}}ydx=\sum_{0 \leq i < nb of edges}
AreaOfZone_{Edge_{i}}
Where $ AreaOfZone_{i} $ is computed virtually by INTERP_KERNEL::Edge::getAreaOfZone with following formula :
AreaOfZone_{i}=\int_{Edge_{i}} -ydx
Referenced by getHydraulicDiameter().
◆ getPerimeter()
double ComposedEdge::getPerimeter ( ) const
◆ getHydraulicDiameter()
double ComposedEdge::getHydraulicDiameter ( ) const
References getArea(), and getPerimeter().
◆ getBarycenter() [1/2]
void ComposedEdge::getBarycenter ( double *  bary) const
This method computes barycenter of 'this' by returning xG in bary[0] and yG in bary[1]. By definition :
Area \cdot x_{G}=\int_{Polygon} x \cdot dS
Area \cdot y_{G}=\int_{Polygon} y \cdot dS
\int_{Polygon} x \cdot dS=\sum_{0 \leq i < nb of edges} -\int_{Edge_{i}}yxdx
\int_{Polygon} y \cdot dS=\sum_{0 \leq i < nb of edges} -\int_{Edge_{i}}\frac{y^{2}}{2}dx
Area is computed using the same principle than described in INTERP_KERNEL::ComposedEdge::getArea method. $ -\int_{Edge_{i}}yxdx $ and $ -\int_{Edge_{i}}\frac{y^{2}}{2}dx $ are computed virtually with INTERP_KERNEL::Edge::getBarycenterOfZone.
Referenced by getBarycenterGeneral().
◆ getBarycenterGeneral()
void ComposedEdge::getBarycenterGeneral ( double *  bary) const
Idem ComposedEdge::getBarycenter except that the special case where _sub_edges==1 is dealt here.
References _sub_edges, and getBarycenter().
◆ normalizeMe()
double ComposedEdge::normalizeMe ( double &  xBary,
double &  yBary
◆ normalize()
double ComposedEdge::normalize ( ComposedEdge *  other,
double &  xBary,
double &  yBary
◆ normalizeExt()
double ComposedEdge::normalizeExt ( ComposedEdge *  other,
double &  xBary,
double &  yBary
◆ unApplyGlobalSimilarityExt()
void ComposedEdge::unApplyGlobalSimilarityExt ( ComposedEdge &  other,
double  xBary,
double  yBary,
double  fact
◆ fillBounds()
◆ applySimilarity()
void ComposedEdge::applySimilarity ( double  xBary,
double  yBary,
double  dimChar
WARNING : applies similarity ONLY on edges without any change on Nodes. To perform a global similarity call applyGlobalSimilarity.
◆ applyGlobalSimilarity()
void ComposedEdge::applyGlobalSimilarity ( double  xBary,
double  yBary,
double  dimChar
Perform Similarity transformation on all elements of this Nodes and Edges.
References _sub_edges, and getAllNodes().
Referenced by INTERP_KERNEL::QuadraticPolygon::isButterflyAbs(), normalize(), and normalizeMe().
◆ applyGlobalSimilarity2()
void ComposedEdge::applyGlobalSimilarity2 ( ComposedEdge *  other,
double  xBary,
double  yBary,
double  dimChar
Perform Similarity transformation on all elements of this Nodes and Edges on 'this' and 'other'. Nodes can be shared between 'this' and 'other'.
References applySimilarityOnMyEdges(), applySimilarityOnMyEdgesIfNotAlreadyHit(), applySimilarityOnMyNodes(), applySimilarityOnMyNodesIfNotAlreadyHit(), initEdgeHitStatus(), and initNodeHitStatus().
Referenced by normalizeExt().
◆ dispatchPerimeter()
void ComposedEdge::dispatchPerimeter ( double &  partConsidered) const
This method append to param 'partConsidered' the part of length of subedges IN or ON.
partConsideredINOUT param.
References _sub_edges, INTERP_KERNEL::FULL_IN_1, and INTERP_KERNEL::FULL_ON_1.
Referenced by INTERP_KERNEL::QuadraticPolygon::intersectForPerimeterAdvanced().
◆ dispatchPerimeterExcl()
void ComposedEdge::dispatchPerimeterExcl ( double &  partConsidered,
double &  commonPart
Idem dispatchPerimeterExcl except that when a subedge is declared as ON this subedge is counted in commonPart.
Referenced by INTERP_KERNEL::QuadraticPolygon::intersectForPerimeter().
◆ dispatchPerimeterAdv()
INTERPKERNEL_EXPORT double INTERP_KERNEL::ComposedEdge::dispatchPerimeterAdv ( const ComposedEdge &  father,
std::vector< double > &  result
◆ getAllNodes()
void ComposedEdge::getAllNodes ( std::set< Node * > &  output) const
Referenced by applyGlobalSimilarity(), isInOrOut(), and isInOrOut2().
◆ initNodeHitStatus()
void ComposedEdge::initNodeHitStatus ( ) const
◆ applySimilarityOnMyNodes()
void ComposedEdge::applySimilarityOnMyNodes ( double  xBary,
double  yBary,
double  dimChar
Referenced by applyGlobalSimilarity2().
◆ unApplySimilarityOnMyNodes()
void ComposedEdge::unApplySimilarityOnMyNodes ( double  xBary,
double  yBary,
double  dimChar
Referenced by unApplyGlobalSimilarityExt().
◆ applySimilarityOnMyNodesIfNotAlreadyHit()
void ComposedEdge::applySimilarityOnMyNodesIfNotAlreadyHit ( double  xBary,
double  yBary,
double  dimChar
◆ unApplySimilarityOnMyNodesIfNotAlreadyHit()
void ComposedEdge::unApplySimilarityOnMyNodesIfNotAlreadyHit ( double  xBary,
double  yBary,
double  dimChar
◆ initEdgeHitStatus()
void ComposedEdge::initEdgeHitStatus ( ) const
◆ applySimilarityOnMyEdges()
void ComposedEdge::applySimilarityOnMyEdges ( double  xBary,
double  yBary,
double  dimChar
◆ unApplySimilarityOnMyEdges()
void ComposedEdge::unApplySimilarityOnMyEdges ( double  xBary,
double  yBary,
double  dimChar
◆ applySimilarityOnMyEdgesIfNotAlreadyHit()
void ComposedEdge::applySimilarityOnMyEdgesIfNotAlreadyHit ( double  xBary,
double  yBary,
double  dimChar
◆ unApplySimilarityOnMyEdgesIfNotAlreadyHit()
void ComposedEdge::unApplySimilarityOnMyEdgesIfNotAlreadyHit ( double  xBary,
double  yBary,
double  dimChar
◆ getBarycenter() [2/2]
void ComposedEdge::getBarycenter ( double *  bary,
double &  weigh
◆ completed()
bool INTERP_KERNEL::ComposedEdge::completed ( ) const
◆ setValueAt()
void ComposedEdge::setValueAt ( int  i,
Edge *  e,
bool  direction = true
◆ getCommonLengthWith()
double ComposedEdge::getCommonLengthWith ( const ComposedEdge &  other) const
◆ clear()
void ComposedEdge::clear ( )
◆ empty()
bool INTERP_KERNEL::ComposedEdge::empty ( ) const
◆ front()
ElementaryEdge * INTERP_KERNEL::ComposedEdge::front ( ) const
◆ back()
ElementaryEdge * INTERP_KERNEL::ComposedEdge::back ( ) const
◆ resize()
void INTERP_KERNEL::ComposedEdge::resize ( int  i)
◆ pushBack() [1/3]
◆ pushBack() [2/3]
void ComposedEdge::pushBack ( ElementaryEdge *  elem)
◆ pushBack() [3/3]
void ComposedEdge::pushBack ( ComposedEdge *  elem)
◆ size()
◆ operator[]()
ElementaryEdge * ComposedEdge::operator[] ( int  i) const
◆ getEndNode()
◆ getStartNode()
Node * ComposedEdge::getStartNode ( ) const
◆ changeEndNodeWith()
bool ComposedEdge::changeEndNodeWith ( Node *  node) const
◆ changeStartNodeWith()
bool ComposedEdge::changeStartNodeWith ( Node *  node) const
◆ dumpInXfigFile()
void ComposedEdge::dumpInXfigFile ( std::ostream &  stream,
int  resolution,
const Bounds &  box
◆ dumpToCout()
void ComposedEdge::dumpToCout ( const std::map< INTERP_KERNEL::Node *, int > &  mapp) const
◆ isInOrOut()
bool ComposedEdge::isInOrOut ( Node *  nodeToTest) const
This method makes the hypothesis that nodeToTest can be either IN or OUT.
See also
ComposedEdge::isInOrOut2
References fillBounds(), getAllNodes(), and INTERP_KERNEL::ON_1.
Referenced by INTERP_KERNEL::QuadraticPolygon::haveIAChanceToBeCompletedBy(), and INTERP_KERNEL::ElementaryEdge::locateFullyMySelfAbsolute().
◆ isInOrOut2()
bool ComposedEdge::isInOrOut2 ( Node *  nodeToTest) const
This method is close to ComposedEdge::isInOrOut behaviour except that here EPSILON is taken into account to detect if it is IN or OUT. If nodeToTest is close to an edge in this, true will be returned even if it is outside informatically from this.
See also
References getAllNodes(), and INTERP_KERNEL::ON_1.
◆ getDirection()
bool ComposedEdge::getDirection ( ) const
◆ intresincEqCoarse()
bool ComposedEdge::intresincEqCoarse ( const Edge *  other) const
◆ IteratorOnComposedEdge
friend class IteratorOnComposedEdge
friend
◆ _sub_edges
