INTERP_KERNEL::Edge Class Referenceabstract
#include <InterpKernelGeo2DEdge.hxx>
Inheritance diagram for INTERP_KERNEL::Edge:
Collaboration diagram for INTERP_KERNEL::Edge:
void addSubEdgeInVector (Node *start, Node *end, ComposedEdge &vec) const
virtual void applySimilarity (double xBary, double yBary, double dimChar)
template<INTERP_KERNEL::TypeOfMod4QuadEdge type>
INTERP_KERNEL::Edge * BuildEdgeFrom (Node *start, Node *middle, Node *end)
virtual Edge * buildEdgeLyingOnMe (Node *start, Node *end, bool direction=true) const =0
virtual Node * buildRepresentantOfMySelf () const =0
bool changeEndNodeWith (Node *otherEndNode) const
bool changeEndNodeWithAndKeepTrack (Node *otherEndNode, std::vector< Node * > &track) const
bool changeStartNodeWith (Node *otherStartNode) const
bool changeStartNodeWithAndKeepTrack (Node *otherStartNode, std::vector< Node * > &track) const
void declareIn () const
void declareOn () const
void declareOut () const
bool decrRef ()
virtual void dumpInXfigFile (std::ostream &stream, bool direction, int resolution, const Bounds &box) const =0
void dumpToCout (const std::map< INTERP_KERNEL::Node *, int > &mapp, int index) const
virtual void dynCastFunction (const EdgeLin *&seg, const EdgeArcCircle *&arcSeg) const =0
 Edge (double sX, double sY, double eX, double eY)
 Edge (Node *start, Node *end, bool direction=true)
void fillGlobalInfoAbs (bool direction, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, std::vector< mcIdType > &edgesThis, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > mapAddCoo) const
void fillGlobalInfoAbs2 (const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, short skipStartOrEnd, std::vector< mcIdType > &edgesOther, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > &mapAddCoo) const
void fillXfigStreamForLoc (std::ostream &stream) const
virtual double getAreaOfZone () const =0
virtual void getBarycenter (double *bary) const =0
virtual void getBarycenterOfZone (double *bary) const =0
const Bounds & getBounds () const
virtual double getCharactValue (const Node &node) const =0
virtual double getCharactValueBtw0And1 (const Node &node) const =0
virtual double getCurveLength () const =0
virtual double getDistanceToPoint (const double *pt) const =0
Node * getEndNode () const
bool getHitStatus () const
TypeOfEdgeLocInPolygon getLoc () const
virtual void getMiddleOfPoints (const double *p1, const double *p2, double *mid) const =0
virtual void getMiddleOfPointsOriented (const double *p1, const double *p2, double *mid) const
Node * getNode (TypeOfLocInEdge where) const
void getNormalVector (double *vectOutput) const
Node * getStartNode () const
virtual TypeOfFunction getTypeOfFunc () const =0
void hitMeAfter (double xBary, double yBary, double dimChar)
void hitMeAlone (double xBary, double yBary, double dimChar)
void incrRef () const
void initHitStatus () const
void initLocs () const
bool intersectWith (const Edge *other, MergePoints &commonNode, ComposedEdge &outVal1, ComposedEdge &outVal2) const
bool isEqual (const Edge &other) const
virtual bool isIn (double characterVal) const =0
virtual bool isLower (double val1, double val2) const =0
virtual bool isNodeLyingOn (const double *coordOfNode) const =0
void setEndNodeWithoutChange (Node *newEnd)
void setStartNodeWithoutChange (Node *newStart)
void sortIdsAbs (const std::vector< INTERP_KERNEL::Node * > &addNodes, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapp1, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapp2, std::vector< mcIdType > &edgesThis)
bool sortSubNodesAbs (const double *coo, std::vector< mcIdType > &subNodes)
virtual void unApplySimilarity (double xBary, double yBary, double dimChar)
void unHitMeAfter (double xBary, double yBary, double dimChar)
void unHitMeAlone (double xBary, double yBary, double dimChar)
virtual void update (Node *m)=0
static Edge * BuildEdgeFrom (Node *start, Node *end)
template<TypeOfMod4QuadEdge type>
static Edge * BuildEdgeFrom (Node *start, Node *middle, Node *end)
static Edge * BuildEdgeFrom3Points (const double *start, const double *middle, const double *end)
static Edge * BuildFromXfigLine (std::istream &str)
static EdgeIntersector * BuildIntersectorWith (const Edge *e1, const Edge *e2)
static void Interpolate1DLin (const std::vector< double > &distrib1, const std::vector< double > &distrib2, std::map< int, std::map< int, double > > &result)
static bool IntersectOverlapped (const Edge *f1, const Edge *f2, EdgeIntersector *intersector, MergePoints &commonNode, ComposedEdge &outValForF1, ComposedEdge &outValForF2)
 Edge ()
virtual ~Edge ()
static int CombineCodes (TypeOfLocInEdge code1, TypeOfLocInEdge code2)
static bool Intersect (const Edge *f1, const Edge *f2, EdgeIntersector *intersector, MergePoints &commonNode, ComposedEdge &outValForF1, ComposedEdge &outValForF2)
static bool SplitOverlappedEdges (const Edge *e1, const Edge *e2, Node *nS, Node *nE, bool direction, int code, ComposedEdge &outVal1, ComposedEdge &outVal2)
Bounds _bounds
unsigned char _cnt
Node * _end
bool _hit
TypeOfEdgeLocInPolygon _loc
Node * _start
Static Protected Attributes
static const int OFFSET_FOR_TYPEOFLOCINEDGE = 8
Deal with an oriented edge of a polygon. An Edge is defined with a start node, an end node and an equation of 1D curve. All other attributes are mutable because they don't impact these 3 invariant attributes. To be exact start and end nodes can change (address) but their location remain the same (at precision).
◆ Edge() [1/3]
INTERP_KERNEL::Edge::Edge ( Node *  start,
Node *  end,
bool  direction = true
◆ Edge() [2/3]
Edge::Edge ( double  sX,
double  sY,
double  eX,
double  eY
◆ Edge() [3/3]
INTERP_KERNEL::Edge::Edge ( )
◆ ~Edge()
Edge::~Edge ( )
◆ getLoc()
◆ incrRef()
◆ decrRef()
◆ initLocs()
void INTERP_KERNEL::Edge::initLocs ( ) const
◆ declareOn()
◆ declareIn()
◆ declareOut()
◆ initHitStatus()
void INTERP_KERNEL::Edge::initHitStatus ( ) const
◆ getHitStatus()
bool INTERP_KERNEL::Edge::getHitStatus ( ) const
◆ hitMeAlone()
void INTERP_KERNEL::Edge::hitMeAlone ( double  xBary,
double  yBary,
double  dimChar
◆ unHitMeAlone()
void INTERP_KERNEL::Edge::unHitMeAlone ( double  xBary,
double  yBary,
double  dimChar
◆ hitMeAfter()
void INTERP_KERNEL::Edge::hitMeAfter ( double  xBary,
double  yBary,
double  dimChar
◆ unHitMeAfter()
void INTERP_KERNEL::Edge::unHitMeAfter ( double  xBary,
double  yBary,
double  dimChar
◆ getBounds()
◆ fillXfigStreamForLoc()
void Edge::fillXfigStreamForLoc ( std::ostream &  stream) const
◆ getNode()
Node * INTERP_KERNEL::Edge::getNode ( TypeOfLocInEdge  where) const
◆ getStartNode()
◆ getEndNode()
◆ setEndNodeWithoutChange()
void INTERP_KERNEL::Edge::setEndNodeWithoutChange ( Node *  newEnd)
◆ setStartNodeWithoutChange()
void INTERP_KERNEL::Edge::setStartNodeWithoutChange ( Node *  newStart)
◆ changeStartNodeWith()
◆ changeStartNodeWithAndKeepTrack()
bool Edge::changeStartNodeWithAndKeepTrack ( Node *  otherStartNode,
std::vector< Node * > &  track
◆ changeEndNodeWith()
◆ changeEndNodeWithAndKeepTrack()
bool Edge::changeEndNodeWithAndKeepTrack ( Node *  otherEndNode,
◆ addSubEdgeInVector()
void Edge::addSubEdgeInVector ( Node *  start,
Node *  end,
ComposedEdge &  vec
Precondition : 'start' and 'end' are lying on the same curve than 'this'. Add in vec the sub edge lying on this. If 'start' is equal (by pointer) to '_end' and 'end' is equal to '_end' too nothing is added. If 'start' is equal (by pointer) to '_start' and 'end' is equal to '_start' too nothing is added. If 'start' is equal (by pointer) to '_start' and 'end' is equal to '_end' this is added in vec.
References _end, _start, buildEdgeLyingOnMe(), incrRef(), and INTERP_KERNEL::ComposedEdge::pushBack().
Referenced by Intersect().
◆ getNormalVector()
void Edge::getNormalVector ( double *  vectOutput) const
Retrieves a vector 'vectOutput' that is normal to 'this'. 'vectOutput' is normalized.
References _end, _start, and INTERP_KERNEL::Node::norm().
◆ BuildIntersectorWith()
EdgeIntersector * Edge::BuildIntersectorWith ( const Edge *  e1,
const Edge *  e2
References dynCastFunction(), and getTypeOfFunc().
Referenced by intersectWith().
◆ BuildFromXfigLine()
Edge * Edge::BuildFromXfigLine ( std::istream &  str)
◆ BuildEdgeFrom() [1/3]
Edge * Edge::BuildEdgeFrom ( Node *  start,
Node *  end
◆ BuildEdgeFrom() [2/3]
static Edge * INTERP_KERNEL::Edge::BuildEdgeFrom ( Node *  start,
Node *  middle,
Node *  end
◆ BuildEdgeFrom3Points()
Edge * Edge::BuildEdgeFrom3Points ( const double *  start,
const double *  middle,
const double *  end
◆ update()
virtual void INTERP_KERNEL::Edge::update ( Node *  m)
pure virtual
◆ getAreaOfZone()
virtual double INTERP_KERNEL::Edge::getAreaOfZone ( ) const
pure virtual
returns area between this and axe Ox delimited along Ox by _start and _end.
Implemented in INTERP_KERNEL::EdgeArcCircle, and INTERP_KERNEL::EdgeLin.
Referenced by INTERP_KERNEL::ElementaryEdge::getAreaOfZone().
◆ applySimilarity()
void Edge::applySimilarity ( double  xBary,
double  yBary,
double  dimChar
apply a similiraty transformation on 'this'
See Node::applySimilarity to see signification of params.
Reimplemented in INTERP_KERNEL::EdgeArcCircle.
References _bounds.
Referenced by INTERP_KERNEL::EdgeArcCircle::applySimilarity(), INTERP_KERNEL::ElementaryEdge::applySimilarity(), sortIdsAbs(), and sortSubNodesAbs().
◆ unApplySimilarity()
void Edge::unApplySimilarity ( double  xBary,
double  yBary,
double  dimChar
apply the inverse similiraty transformation on 'this'
References _bounds.
Referenced by INTERP_KERNEL::EdgeArcCircle::unApplySimilarity(), and INTERP_KERNEL::ElementaryEdge::unApplySimilarity().
◆ getCurveLength()
virtual double INTERP_KERNEL::Edge::getCurveLength ( ) const
pure virtual
◆ getBarycenter()
virtual void INTERP_KERNEL::Edge::getBarycenter ( double *  bary) const
pure virtual
◆ getBarycenterOfZone()
virtual void INTERP_KERNEL::Edge::getBarycenterOfZone ( double *  bary) const
pure virtual
◆ getMiddleOfPoints()
virtual void INTERP_KERNEL::Edge::getMiddleOfPoints ( const double *  p1,
const double *  p2,
double *  mid
pure virtual
return the middle of two points
Referenced by getMiddleOfPointsOriented().
◆ getMiddleOfPointsOriented()
void Edge::getMiddleOfPointsOriented ( const double *  p1,
const double *  p2,
double *  mid
return the middle of two points respecting the orientation defined by this (relevant for arc of circle). By default same as getMiddleOfPoints()
References getMiddleOfPoints().
◆ buildRepresentantOfMySelf()
virtual Node * INTERP_KERNEL::Edge::buildRepresentantOfMySelf ( ) const
pure virtual
Retrieves a point that is owning to this, well placed for IN/OUT detection of this. Typically midlle of this is returned.
Referenced by INTERP_KERNEL::QuadraticPolygon::haveIAChanceToBeCompletedBy(), and INTERP_KERNEL::ElementaryEdge::locateFullyMySelfAbsolute().
◆ isIn()
virtual bool INTERP_KERNEL::Edge::isIn ( double  characterVal) const
pure virtual
Given a magnitude specified by sub-type returns if in or not. See getCharactValue method.
Referenced by INTERP_KERNEL::IntersectElement::isIncludedByBoth(), INTERP_KERNEL::IntersectElement::isOnExtrForAnEdgeAndInForOtherEdge(), and SplitOverlappedEdges().
◆ isLower()
virtual bool INTERP_KERNEL::Edge::isLower ( double  val1,
double  val2
pure virtual
With the same magnitude as defined in 'isIn' method perform a compararison. Precondition : val1 and val2 are different and exactly INSIDE this.
Referenced by INTERP_KERNEL::IntersectElement::isLowerOnOther(), and INTERP_KERNEL::IntersectElement::operator<().
◆ getCharactValue()
virtual double INTERP_KERNEL::Edge::getCharactValue ( const Node &  node) const
pure virtual
◆ getCharactValueBtw0And1()
virtual double INTERP_KERNEL::Edge::getCharactValueBtw0And1 ( const Node &  node) const
pure virtual
node is expected to lay on 'this'. It returns a characteristic magnitude between 0 and 1.
Referenced by sortIdsAbs(), and sortSubNodesAbs().
◆ getDistanceToPoint()
virtual double INTERP_KERNEL::Edge::getDistanceToPoint ( const double *  pt) const
pure virtual
retrieves the distance to this : The min distance from pt and any point of this.
◆ isNodeLyingOn()
virtual bool INTERP_KERNEL::Edge::isNodeLyingOn ( const double *  coordOfNode) const
pure virtual
return if node with coords 'coordOfNode' is on this (with precision).
◆ getTypeOfFunc()
virtual TypeOfFunction INTERP_KERNEL::Edge::getTypeOfFunc ( ) const
pure virtual
◆ dynCastFunction()
virtual void INTERP_KERNEL::Edge::dynCastFunction ( const EdgeLin *&  seg,
const EdgeArcCircle *&  arcSeg
pure virtual
◆ intersectWith()
bool Edge::intersectWith ( const Edge *  other,
MergePoints &  commonNode,
ComposedEdge &  outVal1,
ComposedEdge &  outVal2
otherThe Edge with which we are going to intersect.
commonNodeOutput. The common nodes found during operation of intersecting.
outVal1Output filled in case true is returned. It specifies the new or not new edges by which 'this' is replaced after intersecting op.
outVal2Output filled in case true is returned. It specifies the new or not new edges by which 'other' is replaced after intersecting op. return true if the intersection between this.
References _bounds, BuildIntersectorWith(), getBounds(), and Intersect().
Referenced by MEDCoupling::MEDCouplingUMesh::conformize2D(), INTERP_KERNEL::QuadraticPolygon::isButterfly(), INTERP_KERNEL::QuadraticPolygon::splitAbs(), and INTERP_KERNEL::QuadraticPolygon::SplitPolygonsEachOther().
◆ IntersectOverlapped()
bool Edge::IntersectOverlapped ( const Edge *  f1,
const Edge *  f2,
EdgeIntersector *  intersector,
ComposedEdge &  outValForF1,
ComposedEdge &  outValForF2
◆ Interpolate1DLin()
void Edge::Interpolate1DLin ( const std::vector< double > &  distrib1,
const std::vector< double > &  distrib2,
std::map< int, std::map< int, double > > &  result
◆ dumpInXfigFile()
virtual void INTERP_KERNEL::Edge::dumpInXfigFile ( std::ostream &  stream,
bool  direction,
int  resolution,
const Bounds &  box
pure virtual
◆ dumpToCout()
◆ isEqual()
bool Edge::isEqual ( const Edge &  other) const
◆ sortSubNodesAbs()
bool Edge::sortSubNodesAbs ( const double *  coo,
std::vector< mcIdType > &  subNodes
This method takes in input nodes in subNodes (using coo)
[in,out]subNodesto be sorted
true if a reordering was necessary false if not.
References _end, _start, applySimilarity(), INTERP_KERNEL::Node::applySimilarity(), getBounds(), and getCharactValueBtw0And1().
Referenced by MEDCoupling::MEDCouplingUMesh::conformize2D().
◆ sortIdsAbs()
void Edge::sortIdsAbs ( const std::vector< INTERP_KERNEL::Node * > &  addNodes,
const std::map< INTERP_KERNEL::Node *, mcIdType > &  mapp1,
const std::map< INTERP_KERNEL::Node *, mcIdType > &  mapp2,
std::vector< mcIdType > &  edgesThis
Sort nodes so that they all lie consecutively on the edge that has been cut.
◆ buildEdgeLyingOnMe()
virtual Edge * INTERP_KERNEL::Edge::buildEdgeLyingOnMe ( Node *  start,
Node *  end,
pure virtual
◆ fillGlobalInfoAbs()
void Edge::fillGlobalInfoAbs ( bool  direction,
const std::map< INTERP_KERNEL::Node *, mcIdType > &  mapThis,
const std::map< INTERP_KERNEL::Node *, mcIdType > &  mapOther,
mcIdType  offset1,
mcIdType  offset2,
double  fact,
double  baryX,
double  baryY,
std::vector< mcIdType > &  edgesThis,
std::vector< double > &  addCoo,
◆ fillGlobalInfoAbs2()
void Edge::fillGlobalInfoAbs2 ( const std::map< INTERP_KERNEL::Node *, mcIdType > &  mapThis,
mcIdType  offset1,
mcIdType  offset2,
double  fact,
double  baryX,
double  baryY,
std::vector< mcIdType > &  edgesOther,
std::map< INTERP_KERNEL::Node *, mcIdType > &  mapAddCoo
◆ CombineCodes()
int Edge::CombineCodes ( TypeOfLocInEdge  code1,
staticprotected
◆ Intersect()
bool Edge::Intersect ( const Edge *  f1,
const Edge *  f2,
staticprotected
◆ SplitOverlappedEdges()
bool Edge::SplitOverlappedEdges ( const Edge *  e1,
const Edge *  e2,
Node *  nS,
Node *  nE,
bool  direction,
int  code,
staticprotected
The code 'code' is built by method combineCodes.
This method splits e1 and e2 into pieces as much sharable as possible. The precondition to the call of this method is that e1 and e2 have been declared as overlapped by corresponding intersector built from e1 and e2 type.
nSstart node of e2 with the SAME DIRECTION as e1. The pointer nS should be equal to start node of e2 or to its end node.
nEend node of e2 with the SAME DIRECTION as e1. The pointer nE should be equal to start node of e2 or to its end node.
directionis param that specifies if e2 and e1 have same directions (true) or opposed (false).
codeis the code returned by method Edge::combineCodes.
References buildEdgeLyingOnMe(), declareOn(), INTERP_KERNEL::END, getCharactValue(), getEndNode(), getStartNode(), incrRef(), INTERP_KERNEL::INSIDE, isIn(), OFFSET_FOR_TYPEOFLOCINEDGE, INTERP_KERNEL::OUT_AFTER, INTERP_KERNEL::OUT_BEFORE, INTERP_KERNEL::ComposedEdge::pushBack(), INTERP_KERNEL::ComposedEdge::resize(), INTERP_KERNEL::ComposedEdge::setValueAt(), and INTERP_KERNEL::START.
Referenced by IntersectOverlapped().
◆ BuildEdgeFrom() [3/3]
INTERP_KERNEL::Edge * INTERP_KERNEL::Edge::BuildEdgeFrom ( Node *  start,
Node *  middle,
Node *  end
◆ _hit
bool INTERP_KERNEL::Edge::_hit
mutableprotected
◆ _cnt
unsigned char INTERP_KERNEL::Edge::_cnt
mutableprotected
Referenced by decrRef().
◆ _loc
TypeOfEdgeLocInPolygon INTERP_KERNEL::Edge::_loc
mutableprotected
◆ _bounds
◆ _start
◆ _end
◆ OFFSET_FOR_TYPEOFLOCINEDGE
const int INTERP_KERNEL::Edge::OFFSET_FOR_TYPEOFLOCINEDGE = 8
staticprotected
