INTERP_KERNEL::ArcCSegIntersector Class Reference
#include <InterpKernelGeo2DEdgeArcCircle.hxx>
Inheritance diagram for INTERP_KERNEL::ArcCSegIntersector:
Collaboration diagram for INTERP_KERNEL::ArcCSegIntersector:
 ArcCSegIntersector (const EdgeArcCircle &e1, const EdgeLin &e2, bool reverse=true)
bool areColinears () const
void areOverlappedOrOnlyColinears (bool &obviousNoIntersection, bool &areOverlapped)
std::list< IntersectElement > getIntersectionsCharacteristicVal () const
void getPlacements (Node *start, Node *end, TypeOfLocInEdge &whereStart, TypeOfLocInEdge &whereEnd, MergePoints &commonNode) const
- Public Member Functions inherited from INTERP_KERNEL::EdgeIntersector
virtual bool areColinears () const =0
virtual void areOverlappedOrOnlyColinears (bool &obviousNoIntersection, bool &areOverlapped)=0
virtual std::list< IntersectElement > getIntersectionsCharacteristicVal () const =0
virtual void getPlacements (Node *start, Node *end, TypeOfLocInEdge &whereStart, TypeOfLocInEdge &whereEnd, MergePoints &commonNode) const =0
virtual bool haveTheySameDirection () const =0
bool intersect (std::vector< Node * > &newNodes, bool &order, MergePoints &commonNode)
virtual bool keepOrder () const =0
virtual ~EdgeIntersector ()
- Protected Member Functions inherited from INTERP_KERNEL::CrossTypeEdgeIntersector
 CrossTypeEdgeIntersector (const Edge &e1, const Edge &e2, bool reverse)
const Edge * myE1 ()
const Edge * myE2 ()
- Protected Member Functions inherited from INTERP_KERNEL::EdgeIntersector
 EdgeIntersector (const Edge &e1, const Edge &e2)
virtual void identifyEarlyIntersection (bool &, bool &, bool &, bool &)
void obviousCaseForCurvAbscisse (Node *node, TypeOfLocInEdge &where, MergePoints &commonNode, bool &obvious) const
- Protected Attributes inherited from INTERP_KERNEL::CrossTypeEdgeIntersector
bool _reverse
- Protected Attributes inherited from INTERP_KERNEL::EdgeIntersector
const Edge & _e1
const Edge & _e2
IntersectElement * _earlyInter
Cross-type intersector: edge1 is the arc of circle, edge2 is the segment.
◆ ArcCSegIntersector()
ArcCSegIntersector::ArcCSegIntersector ( const EdgeArcCircle &  e1,
const EdgeLin &  e2,
bool  reverse = true
◆ areColinears()
bool ArcCSegIntersector::areColinears ( ) const
By construction, no chance that an arc of circle and line to be colinear.
Implements INTERP_KERNEL::EdgeIntersector.
◆ getPlacements()
void ArcCSegIntersector::getPlacements ( Node *  start,
Node *  end,
TypeOfLocInEdge &  whereStart,
TypeOfLocInEdge &  whereEnd,
MergePoints &  commonNode
to call only if 'areOverlapped' have been set to true when areOverlappedOrOnlyColinears was called
◆ areOverlappedOrOnlyColinears()
void ArcCSegIntersector::areOverlappedOrOnlyColinears ( bool &  obviousNoIntersection,
bool &  areOverlapped
◆ getIntersectionsCharacteristicVal()
