INTERP_KERNEL::EdgeLin Class Reference
#include <InterpKernelGeo2DEdgeLin.hxx>
Inheritance diagram for INTERP_KERNEL::EdgeLin:
Collaboration diagram for INTERP_KERNEL::EdgeLin:
Node * buildRepresentantOfMySelf () const
bool doIHaveSameDirectionAs (const Edge &other) const
void dumpInXfigFile (std::ostream &stream, bool direction, int resolution, const Bounds &box) const
void dynCastFunction (const EdgeLin *&seg, const EdgeArcCircle *&arcSeg) const
 EdgeLin (double sX, double sY, double eX, double eY)
 EdgeLin (Node *start, Node *end, bool direction=true)
 EdgeLin (std::istream &lineInXfig)
double getAreaOfZone () const
void getBarycenter (double *bary) const
void getBarycenterOfZone (double *bary) const
double getCharactValue (const Node &node) const
double getCharactValueBtw0And1 (const Node &node) const
double getCharactValueEng (const double *node) const
double getCurveLength () const
double getDistanceToPoint (const double *pt) const
void getMiddleOfPoints (const double *p1, const double *p2, double *mid) const
double getNormSq () const
TypeOfFunction getTypeOfFunc () const
bool isIn (double characterVal) const
bool isLower (double val1, double val2) const
bool isNodeLyingOn (const double *coordOfNode) const
void update (Node *m)
 ~EdgeLin ()
- Public Member Functions inherited from INTERP_KERNEL::Edge
void addSubEdgeInVector (Node *start, Node *end, ComposedEdge &vec) const
virtual void applySimilarity (double xBary, double yBary, double dimChar)
template<INTERP_KERNEL::TypeOfMod4QuadEdge type>
INTERP_KERNEL::Edge * BuildEdgeFrom (Node *start, Node *middle, Node *end)
virtual Edge * buildEdgeLyingOnMe (Node *start, Node *end, bool direction=true) const =0
virtual Node * buildRepresentantOfMySelf () const =0
bool changeEndNodeWith (Node *otherEndNode) const
bool changeEndNodeWithAndKeepTrack (Node *otherEndNode, std::vector< Node * > &track) const
bool changeStartNodeWith (Node *otherStartNode) const
bool changeStartNodeWithAndKeepTrack (Node *otherStartNode, std::vector< Node * > &track) const
void declareIn () const
void declareOn () const
void declareOut () const
bool decrRef ()
virtual void dumpInXfigFile (std::ostream &stream, bool direction, int resolution, const Bounds &box) const =0
void dumpToCout (const std::map< INTERP_KERNEL::Node *, int > &mapp, int index) const
virtual void dynCastFunction (const EdgeLin *&seg, const EdgeArcCircle *&arcSeg) const =0
 Edge (double sX, double sY, double eX, double eY)
 Edge (Node *start, Node *end, bool direction=true)
void fillGlobalInfoAbs (bool direction, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, std::vector< mcIdType > &edgesThis, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > mapAddCoo) const
void fillGlobalInfoAbs2 (const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, short skipStartOrEnd, std::vector< mcIdType > &edgesOther, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > &mapAddCoo) const
void fillXfigStreamForLoc (std::ostream &stream) const
virtual double getAreaOfZone () const =0
virtual void getBarycenter (double *bary) const =0
virtual void getBarycenterOfZone (double *bary) const =0
const Bounds & getBounds () const
virtual double getCharactValue (const Node &node) const =0
virtual double getCharactValueBtw0And1 (const Node &node) const =0
virtual double getCurveLength () const =0
virtual double getDistanceToPoint (const double *pt) const =0
Node * getEndNode () const
bool getHitStatus () const
TypeOfEdgeLocInPolygon getLoc () const
virtual void getMiddleOfPoints (const double *p1, const double *p2, double *mid) const =0
virtual void getMiddleOfPointsOriented (const double *p1, const double *p2, double *mid) const
Node * getNode (TypeOfLocInEdge where) const
void getNormalVector (double *vectOutput) const
Node * getStartNode () const
virtual TypeOfFunction getTypeOfFunc () const =0
void hitMeAfter (double xBary, double yBary, double dimChar)
void hitMeAlone (double xBary, double yBary, double dimChar)
void incrRef () const
void initHitStatus () const
void initLocs () const
bool intersectWith (const Edge *other, MergePoints &commonNode, ComposedEdge &outVal1, ComposedEdge &outVal2) const
bool isEqual (const Edge &other) const
virtual bool isIn (double characterVal) const =0
virtual bool isLower (double val1, double val2) const =0
virtual bool isNodeLyingOn (const double *coordOfNode) const =0
void setEndNodeWithoutChange (Node *newEnd)
void setStartNodeWithoutChange (Node *newStart)
void sortIdsAbs (const std::vector< INTERP_KERNEL::Node * > &addNodes, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapp1, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapp2, std::vector< mcIdType > &edgesThis)
bool sortSubNodesAbs (const double *coo, std::vector< mcIdType > &subNodes)
virtual void unApplySimilarity (double xBary, double yBary, double dimChar)
void unHitMeAfter (double xBary, double yBary, double dimChar)
void unHitMeAlone (double xBary, double yBary, double dimChar)
virtual void update (Node *m)=0
Edge * buildEdgeLyingOnMe (Node *start, Node *end, bool direction) const
 EdgeLin ()
void updateBounds ()
- Protected Member Functions inherited from INTERP_KERNEL::Edge
 Edge ()
virtual ~Edge ()
Friends
class SegSegIntersector
- Static Public Member Functions inherited from INTERP_KERNEL::Edge
static Edge * BuildEdgeFrom (Node *start, Node *end)
template<TypeOfMod4QuadEdge type>
static Edge * BuildEdgeFrom (Node *start, Node *middle, Node *end)
static Edge * BuildEdgeFrom3Points (const double *start, const double *middle, const double *end)
static Edge * BuildFromXfigLine (std::istream &str)
static EdgeIntersector * BuildIntersectorWith (const Edge *e1, const Edge *e2)
static void Interpolate1DLin (const std::vector< double > &distrib1, const std::vector< double > &distrib2, std::map< int, std::map< int, double > > &result)
static bool IntersectOverlapped (const Edge *f1, const Edge *f2, EdgeIntersector *intersector, MergePoints &commonNode, ComposedEdge &outValForF1, ComposedEdge &outValForF2)
- Static Protected Member Functions inherited from INTERP_KERNEL::Edge
static int CombineCodes (TypeOfLocInEdge code1, TypeOfLocInEdge code2)
static bool Intersect (const Edge *f1, const Edge *f2, EdgeIntersector *intersector, MergePoints &commonNode, ComposedEdge &outValForF1, ComposedEdge &outValForF2)
static bool SplitOverlappedEdges (const Edge *e1, const Edge *e2, Node *nS, Node *nE, bool direction, int code, ComposedEdge &outVal1, ComposedEdge &outVal2)
- Protected Attributes inherited from INTERP_KERNEL::Edge
Bounds _bounds
unsigned char _cnt
Node * _end
bool _hit
TypeOfEdgeLocInPolygon _loc
Node * _start
- Static Protected Attributes inherited from INTERP_KERNEL::Edge
static const int OFFSET_FOR_TYPEOFLOCINEDGE = 8
◆ EdgeLin() [1/4]
EdgeLin::EdgeLin ( std::istream &  lineInXfig)
◆ EdgeLin() [2/4]
EdgeLin::EdgeLin ( Node *  start,
Node *  end,
bool  direction = true
References updateBounds().
◆ EdgeLin() [3/4]
EdgeLin::EdgeLin ( double  sX,
double  sY,
double  eX,
double  eY
◆ ~EdgeLin()
EdgeLin::~EdgeLin ( )
◆ EdgeLin() [4/4]
INTERP_KERNEL::EdgeLin::EdgeLin ( )
Referenced by buildEdgeLyingOnMe().
◆ getTypeOfFunc()
TypeOfFunction INTERP_KERNEL::EdgeLin::getTypeOfFunc ( ) const
Implements INTERP_KERNEL::Edge.
References INTERP_KERNEL::SEG.
◆ dumpInXfigFile()
void EdgeLin::dumpInXfigFile ( std::ostream &  stream,
bool  direction,
int  resolution,
const Bounds &  box
◆ update()
void EdgeLin::update ( Node *  m)
◆ getNormSq()
◆ getAreaOfZone()
double EdgeLin::getAreaOfZone ( ) const
This methods computes :
\int_{Current Edge} -ydx
References INTERP_KERNEL::Edge::_end, and INTERP_KERNEL::Edge::_start.
◆ getCurveLength()
double EdgeLin::getCurveLength ( ) const
return the length of arc. Value is always > 0. !
Referenced by INTERP_KERNEL::Edge::Interpolate1DLin().
◆ getBarycenter()
void EdgeLin::getBarycenter ( double *  bary) const
◆ getBarycenterOfZone()
void EdgeLin::getBarycenterOfZone ( double *  bary) const
bary[0]=\int_{Current Edge} -yxdx
bary[1]=\int_{Current Edge} -\frac{y^{2}}{2}dx
To compute these 2 expressions in this class we have :
y=y_{1}+\frac{y_{2}-y_{1}}{x_{2}-x_{1}}(x-x_{1})
◆ getMiddleOfPoints()
void EdgeLin::getMiddleOfPoints ( const double *  p1,
const double *  p2,
double *  mid
Here this is not used (contrary to EdgeArcCircle class).
◆ isIn()
bool EdgeLin::isIn ( double  characterVal) const
Characteristic for edges is relative position btw 0.;1.
◆ buildRepresentantOfMySelf()
Node * EdgeLin::buildRepresentantOfMySelf ( ) const
Retrieves a point that is owning to this, well placed for IN/OUT detection of this. Typically midlle of this is returned.
◆ getCharactValue()
double EdgeLin::getCharactValue ( const Node &  node) const
node is expected to lay on 'this'. It returns a characteristic magnitude usable by isIn method.
References getCharactValueEng().
◆ getCharactValueBtw0And1()
double EdgeLin::getCharactValueBtw0And1 ( const Node &  node) const
node is expected to lay on 'this'. It returns a characteristic magnitude between 0 and 1.
◆ getDistanceToPoint()
double EdgeLin::getDistanceToPoint ( const double *  pt) const
retrieves the distance to this : The min distance from pt and any point of this.
References INTERP_KERNEL::Edge::_end, INTERP_KERNEL::Edge::_start, INTERP_KERNEL::Node::distanceBtw2Pt(), and getCharactValueEng().
◆ isNodeLyingOn()
bool EdgeLin::isNodeLyingOn ( const double *  coordOfNode) const
◆ isLower()
bool INTERP_KERNEL::EdgeLin::isLower ( double  val1,
double  val2
With the same magnitude as defined in 'isIn' method perform a compararison. Precondition : val1 and val2 are different and exactly INSIDE this.
◆ getCharactValueEng()
double EdgeLin::getCharactValueEng ( const double *  node) const
◆ doIHaveSameDirectionAs()
bool INTERP_KERNEL::EdgeLin::doIHaveSameDirectionAs ( const Edge &  other) const
◆ dynCastFunction()
void INTERP_KERNEL::EdgeLin::dynCastFunction ( const EdgeLin *&  seg,
const EdgeArcCircle *&  arcSeg
◆ updateBounds()
void EdgeLin::updateBounds ( )
No precision should be introduced here. Just think as if precision was perfect.
References INTERP_KERNEL::Edge::_bounds, INTERP_KERNEL::Edge::_end, and INTERP_KERNEL::Edge::_start.
Referenced by EdgeLin(), and update().
◆ buildEdgeLyingOnMe()
Edge * EdgeLin::buildEdgeLyingOnMe ( Node *  start,
Node *  end,
bool  direction
References EdgeLin().
◆ SegSegIntersector
friend class SegSegIntersector
friend
