INTERP_KERNEL::EdgeArcCircle Class Reference
#include <InterpKernelGeo2DEdgeArcCircle.hxx>
Inheritance diagram for INTERP_KERNEL::EdgeArcCircle:
Collaboration diagram for INTERP_KERNEL::EdgeArcCircle:
void applySimilarity (double xBary, double yBary, double dimChar)
Node * buildRepresentantOfMySelf () const
void changeMiddle (Node *newMiddle)
bool doIHaveSameDirectionAs (const Edge &other) const
void dumpInXfigFile (std::ostream &stream, bool direction, int resolution, const Bounds &box) const
void dynCastFunction (const EdgeLin *&seg, const EdgeArcCircle *&arcSeg) const
 EdgeArcCircle (double sX, double sY, double mX, double mY, double eX, double eY)
 EdgeArcCircle (Node *start, Node *end, const double *center, double radius, double angle0, double deltaAngle, bool direction=true)
 EdgeArcCircle (Node *start, Node *middle, Node *end, bool direction=true)
 EdgeArcCircle (std::istream &lineInXfig)
double getAngle () const
double getAngle0 () const
double getAreaOfZone () const
void getBarycenter (double *bary) const
void getBarycenterOfZone (double *bary) const
const double * getCenter () const
void getCenter (double *center) const
double getCharactValue (const Node &node) const
double getCharactValueBtw0And1 (const Node &node) const
double getCurveLength () const
double getDistanceToPoint (const double *pt) const
void getMiddleOfPoints (const double *p1, const double *p2, double *mid) const
void getMiddleOfPointsOriented (const double *p1, const double *p2, double *mid) const
double getRadius () const
TypeOfFunction getTypeOfFunc () const
bool isIn (double characterVal) const
bool isLower (double val1, double val2) const
bool isNodeLyingOn (const double *coordOfNode) const
void tesselate (const mcIdType *conn, mcIdType offset, double eps, std::vector< mcIdType > &newConn, std::vector< double > &addCoo) const
void unApplySimilarity (double xBary, double yBary, double dimChar)
void update (Node *m)
- Public Member Functions inherited from INTERP_KERNEL::Edge
void addSubEdgeInVector (Node *start, Node *end, ComposedEdge &vec) const
virtual void applySimilarity (double xBary, double yBary, double dimChar)
template<INTERP_KERNEL::TypeOfMod4QuadEdge type>
INTERP_KERNEL::Edge * BuildEdgeFrom (Node *start, Node *middle, Node *end)
virtual Edge * buildEdgeLyingOnMe (Node *start, Node *end, bool direction=true) const =0
virtual Node * buildRepresentantOfMySelf () const =0
bool changeEndNodeWith (Node *otherEndNode) const
bool changeEndNodeWithAndKeepTrack (Node *otherEndNode, std::vector< Node * > &track) const
bool changeStartNodeWith (Node *otherStartNode) const
bool changeStartNodeWithAndKeepTrack (Node *otherStartNode, std::vector< Node * > &track) const
void declareIn () const
void declareOn () const
void declareOut () const
bool decrRef ()
virtual void dumpInXfigFile (std::ostream &stream, bool direction, int resolution, const Bounds &box) const =0
void dumpToCout (const std::map< INTERP_KERNEL::Node *, int > &mapp, int index) const
virtual void dynCastFunction (const EdgeLin *&seg, const EdgeArcCircle *&arcSeg) const =0
 Edge (double sX, double sY, double eX, double eY)
 Edge (Node *start, Node *end, bool direction=true)
void fillGlobalInfoAbs (bool direction, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, std::vector< mcIdType > &edgesThis, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > mapAddCoo) const
void fillGlobalInfoAbs2 (const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, short skipStartOrEnd, std::vector< mcIdType > &edgesOther, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > &mapAddCoo) const
void fillXfigStreamForLoc (std::ostream &stream) const
virtual double getAreaOfZone () const =0
virtual void getBarycenter (double *bary) const =0
virtual void getBarycenterOfZone (double *bary) const =0
const Bounds & getBounds () const
virtual double getCharactValue (const Node &node) const =0
virtual double getCharactValueBtw0And1 (const Node &node) const =0
virtual double getCurveLength () const =0
virtual double getDistanceToPoint (const double *pt) const =0
Node * getEndNode () const
bool getHitStatus () const
TypeOfEdgeLocInPolygon getLoc () const
virtual void getMiddleOfPoints (const double *p1, const double *p2, double *mid) const =0
virtual void getMiddleOfPointsOriented (const double *p1, const double *p2, double *mid) const
Node * getNode (TypeOfLocInEdge where) const
void getNormalVector (double *vectOutput) const
Node * getStartNode () const
virtual TypeOfFunction getTypeOfFunc () const =0
void hitMeAfter (double xBary, double yBary, double dimChar)
void hitMeAlone (double xBary, double yBary, double dimChar)
void incrRef () const
void initHitStatus () const
void initLocs () const
bool intersectWith (const Edge *other, MergePoints &commonNode, ComposedEdge &outVal1, ComposedEdge &outVal2) const
bool isEqual (const Edge &other) const
virtual bool isIn (double characterVal) const =0
virtual bool isLower (double val1, double val2) const =0
virtual bool isNodeLyingOn (const double *coordOfNode) const =0
void setEndNodeWithoutChange (Node *newEnd)
void setStartNodeWithoutChange (Node *newStart)
void sortIdsAbs (const std::vector< INTERP_KERNEL::Node * > &addNodes, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapp1, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapp2, std::vector< mcIdType > &edgesThis)
bool sortSubNodesAbs (const double *coo, std::vector< mcIdType > &subNodes)
virtual void unApplySimilarity (double xBary, double yBary, double dimChar)
void unHitMeAfter (double xBary, double yBary, double dimChar)
void unHitMeAlone (double xBary, double yBary, double dimChar)
virtual void update (Node *m)=0
static EdgeArcCircle * BuildFromNodes (Node *start, Node *middle, Node *end)
static double GetAbsoluteAngle (const double *vect, double &normVect)
static double GetAbsoluteAngleOfNormalizedVect (double ux, double uy)
static void GetArcOfCirclePassingThru (const double *start, const double *middle, const double *end, double *center, double &radius, double &angleInRad, double &angleInRad0)
static bool IsAngleNotIn (double start, double delta, double angleIn)
static bool IsIn2Pi (double start, double delta, double angleIn)
static double NormalizeAngle (double angle)
static double SafeAcos (double cosAngle)
static double SafeAsin (double sinAngle)
static double SafeSqrt (double val)
- Static Public Member Functions inherited from INTERP_KERNEL::Edge
static Edge * BuildEdgeFrom (Node *start, Node *end)
template<TypeOfMod4QuadEdge type>
static Edge * BuildEdgeFrom (Node *start, Node *middle, Node *end)
static Edge * BuildEdgeFrom3Points (const double *start, const double *middle, const double *end)
static Edge * BuildFromXfigLine (std::istream &str)
static EdgeIntersector * BuildIntersectorWith (const Edge *e1, const Edge *e2)
static void Interpolate1DLin (const std::vector< double > &distrib1, const std::vector< double > &distrib2, std::map< int, std::map< int, double > > &result)
static bool IntersectOverlapped (const Edge *f1, const Edge *f2, EdgeIntersector *intersector, MergePoints &commonNode, ComposedEdge &outValForF1, ComposedEdge &outValForF2)
void updateBounds ()
- Protected Member Functions inherited from INTERP_KERNEL::Edge
 Edge ()
virtual ~Edge ()
double _angle
double _angle0
double _center [2]
double _radius
- Protected Attributes inherited from INTERP_KERNEL::Edge
Bounds _bounds
unsigned char _cnt
Node * _end
bool _hit
TypeOfEdgeLocInPolygon _loc
Node * _start
- Static Protected Member Functions inherited from INTERP_KERNEL::Edge
static int CombineCodes (TypeOfLocInEdge code1, TypeOfLocInEdge code2)
static bool Intersect (const Edge *f1, const Edge *f2, EdgeIntersector *intersector, MergePoints &commonNode, ComposedEdge &outValForF1, ComposedEdge &outValForF2)
static bool SplitOverlappedEdges (const Edge *e1, const Edge *e2, Node *nS, Node *nE, bool direction, int code, ComposedEdge &outVal1, ComposedEdge &outVal2)
- Static Protected Attributes inherited from INTERP_KERNEL::Edge
static const int OFFSET_FOR_TYPEOFLOCINEDGE = 8
◆ EdgeArcCircle() [1/4]
◆ EdgeArcCircle() [2/4]
EdgeArcCircle::EdgeArcCircle ( Node *  start,
Node *  middle,
Node *  end,
bool  direction = true
◆ EdgeArcCircle() [3/4]
EdgeArcCircle::EdgeArcCircle ( double  sX,
double  sY,
double  mX,
double  mY,
double  eX,
double  eY
◆ EdgeArcCircle() [4/4]
Node *  end,
const double *  center,
double  radius,
double  angle0,
double  deltaAngle,
angle0in ]-Pi;Pi[
deltaAnglein ]-2.*Pi;2.*Pi[
References _center, and updateBounds().
◆ changeMiddle()
void EdgeArcCircle::changeMiddle ( Node *  newMiddle)
◆ dumpInXfigFile()
void EdgeArcCircle::dumpInXfigFile ( std::ostream &  stream,
bool  direction,
int  resolution,
const Bounds &  box
◆ update()
◆ getAreaOfZone()
double EdgeArcCircle::getAreaOfZone ( ) const
This methods computes :
\int_{Current Edge} -ydx
Implements INTERP_KERNEL::Edge.
References _angle, _radius, and INTERP_KERNEL::Edge::_start.
◆ getCurveLength()
double EdgeArcCircle::getCurveLength ( ) const
return the length of arc. Value is always > 0. !
References _angle, and _radius.
◆ getBarycenter()
void EdgeArcCircle::getBarycenter ( double *  bary) const
References _angle, _angle0, _center, and _radius.
◆ getBarycenterOfZone()
void EdgeArcCircle::getBarycenterOfZone ( double *  bary) const
bary[0]=\int_{Current Edge} -yxdx
bary[1]=\int_{Current Edge} -\frac{y^{2}}{2}dx
To compute these 2 expressions in this class we have :
x=x_{0}+Radius \cdot cos(\theta)
y=y_{0}+Radius \cdot sin(\theta)
dx=-Radius \cdot sin(\theta) \cdot d\theta
◆ getMiddleOfPoints()
void EdgeArcCircle::getMiddleOfPoints ( const double *  p1,
const double *  p2,
double *  mid
Compute the "middle" of two points on the arc of circle. The order (p1,p2) or (p2,p1) doesn't matter. p1 and p2 have to be localized on the edge defined by this.
[out]midthe point located half-way between p1 and p2 on the arc defined by this.
See also
getMiddleOfPointsOriented() a generalisation working also when p1 and p2 are not on the arc.
References _angle, _angle0, _center, _radius, and GetAbsoluteAngleOfNormalizedVect().
◆ getMiddleOfPointsOriented()
void EdgeArcCircle::getMiddleOfPointsOriented ( const double *  p1,
const double *  p2,
double *  mid
Compute the "middle" of two points on the arc of circle. Walk on the circle from p1 to p2 using the rotation direction indicated by this->_angle (i.e. by the orientation of the arc). This function is sensitive to the ordering of p1 and p2.
See also
getMiddleOfPoints() to be used when the order of p1 and p2 is not relevant.
Reimplemented from INTERP_KERNEL::Edge.
References _angle, _center, _radius, and GetAbsoluteAngleOfNormalizedVect().
◆ isIn()
bool EdgeArcCircle::isIn ( double  characterVal) const
Characteristic value used is angle in ]_Pi;Pi[ from axe 0x.
References _angle, _angle0, and IsIn2Pi().
◆ buildRepresentantOfMySelf()
Node * EdgeArcCircle::buildRepresentantOfMySelf ( ) const
Retrieves a point that is owning to this, well placed for IN/OUT detection of this. Typically midlle of this is returned.
Referenced by dumpInXfigFile().
◆ isLower()
bool EdgeArcCircle::isLower ( double  val1,
double  val2
Characteristic value used is angle in ]_Pi;Pi[ from axe 0x. 'val1' and 'val2' have been detected previously as owning to this.
References _angle, _angle0, and _radius.
◆ getCharactValue()
double EdgeArcCircle::getCharactValue ( const Node &  node) const
For Arc circle the caract value is angle with Ox between -Pi and Pi.
References _center, _radius, and GetAbsoluteAngleOfNormalizedVect().
◆ getCharactValueBtw0And1()
double EdgeArcCircle::getCharactValueBtw0And1 ( const Node &  node) const
node is expected to lay on 'this'. It returns a characteristic magnitude between 0 and 1.
◆ getDistanceToPoint()
double EdgeArcCircle::getDistanceToPoint ( const double *  pt) const
retrieves the distance to this : The min distance from pt and any point of this.
References _angle, _angle0, _center, INTERP_KERNEL::Edge::_end, _radius, INTERP_KERNEL::Edge::_start, INTERP_KERNEL::Node::computeAngle(), INTERP_KERNEL::Node::distanceBtw2Pt(), and IsIn2Pi().
◆ isNodeLyingOn()
bool EdgeArcCircle::isNodeLyingOn ( const double *  coordOfNode) const
return if node with coords 'coordOfNode' is on this (with precision).
References _angle, _angle0, _center, _radius, INTERP_KERNEL::Node::areDoubleEquals(), INTERP_KERNEL::Node::computeAngle(), INTERP_KERNEL::Node::distanceBtw2Pt(), and IsIn2Pi().
◆ getTypeOfFunc()
TypeOfFunction INTERP_KERNEL::EdgeArcCircle::getTypeOfFunc ( ) const
◆ dynCastFunction()
void INTERP_KERNEL::EdgeArcCircle::dynCastFunction ( const EdgeLin *&  seg,
const EdgeArcCircle *&  arcSeg
◆ getCenter() [1/2]
◆ getCenter() [2/2]
void INTERP_KERNEL::EdgeArcCircle::getCenter ( double *  center) const
◆ doIHaveSameDirectionAs()
bool INTERP_KERNEL::EdgeArcCircle::doIHaveSameDirectionAs ( const Edge &  other) const
◆ applySimilarity()
void EdgeArcCircle::applySimilarity ( double  xBary,
double  yBary,
double  dimChar
apply a similiraty transformation on 'this'
See Node::applySimilarity to see signification of params.
References _center, _radius, and INTERP_KERNEL::Edge::applySimilarity().
◆ unApplySimilarity()
void EdgeArcCircle::unApplySimilarity ( double  xBary,
double  yBary,
double  dimChar
apply the inverse similiraty transformation on 'this'
References _center, _radius, and INTERP_KERNEL::Edge::unApplySimilarity().
◆ getAngle0()
double INTERP_KERNEL::EdgeArcCircle::getAngle0 ( ) const
◆ getRadius()
◆ getAngle()
double INTERP_KERNEL::EdgeArcCircle::getAngle ( ) const
◆ tesselate()
void EdgeArcCircle::tesselate ( const mcIdType *  conn,
mcIdType  offset,
double  eps,
std::vector< mcIdType > &  newConn,
std::vector< double > &  addCoo
'eps' is expected to be > 0. 'conn' is of size 3. conn[0] is start id, conn[1] is end id and conn[2] is middle id. 'offset' is typically the number of nodes already existing in global 2D curve mesh. Additional coords 'addCoo' ids will be put after the already existing.
◆ BuildFromNodes()
EdgeArcCircle * EdgeArcCircle::BuildFromNodes ( Node *  start,
Node *  middle,
Node *  end
◆ GetAbsoluteAngle()
double EdgeArcCircle::GetAbsoluteAngle ( const double *  vect,
double &  normVect
Given an NON normalized vector 'vect', returns its norm 'normVect' and its angle in ]-Pi,Pi] relative to Ox axe.
References GetAbsoluteAngleOfNormalizedVect(), and INTERP_KERNEL::Node::norm().
Referenced by MEDCoupling::MEDCouplingUMesh::BuildConvexEnvelopOf2DCellJarvis().
◆ GetAbsoluteAngleOfNormalizedVect()
double EdgeArcCircle::GetAbsoluteAngleOfNormalizedVect ( double  ux,
double  uy
Given a normalized vector defined by (ux,uy) returns its angle in ]-Pi;Pi]. Actually in the current implementation, the vector does not even need to be normalized ...
Referenced by buildEdgeLyingOnMe(), INTERP_KERNEL::Node::computeAngle(), GetAbsoluteAngle(), GetArcOfCirclePassingThru(), getCharactValue(), getCharactValueBtw0And1(), INTERP_KERNEL::ArcCArcCIntersector::getIntersectionsCharacteristicVal(), getMiddleOfPoints(), and getMiddleOfPointsOriented().
◆ GetArcOfCirclePassingThru()
void EdgeArcCircle::GetArcOfCirclePassingThru ( const double *  start,
const double *  middle,
const double *  end,
double *  center,
double &  radius,
double &  angleInRad,
double &  angleInRad0
◆ SafeSqrt()
static double INTERP_KERNEL::EdgeArcCircle::SafeSqrt ( double  val)
◆ SafeAcos()
static double INTERP_KERNEL::EdgeArcCircle::SafeAcos ( double  cosAngle)
◆ SafeAsin()
static double INTERP_KERNEL::EdgeArcCircle::SafeAsin ( double  sinAngle)
◆ IsIn2Pi()
bool EdgeArcCircle::IsIn2Pi ( double  start,
double  delta,
double  angleIn
startand
angleInin ]-Pi;Pi] and
deltain ]-2*Pi,2*Pi[
Idem IsAngleNotIn except that here 'start' in ]-Pi;Pi[ and delta in ]-2*Pi;2Pi[.
angleInin ]-Pi;Pi[.
Referenced by getDistanceToPoint(), INTERP_KERNEL::ArcCArcCIntersector::getPlacements(), isIn(), isNodeLyingOn(), and updateBounds().
◆ IsAngleNotIn()
bool EdgeArcCircle::IsAngleNotIn ( double  start,
double  delta,
double  angleIn
'delta' 'start' in ]-Pi;Pi[
Given the arc 'a' defined by 'start' angle and a 'delta' [-Pi;Pi] states for the angle 'angleIn' [-Pi;Pi] if it owns or not 'a'.
Referenced by GetArcOfCirclePassingThru().
◆ NormalizeAngle()
static double INTERP_KERNEL::EdgeArcCircle::NormalizeAngle ( double  angle)
for an angle 'angle' in ]-3*Pi;3*Pi[ returns angle in ]-Pi;Pi[
Referenced by INTERP_KERNEL::ArcCArcCIntersector::getIntersectionsCharacteristicVal().
◆ updateBounds()
void EdgeArcCircle::updateBounds ( )
◆ buildEdgeLyingOnMe()
Edge * EdgeArcCircle::buildEdgeLyingOnMe ( Node *  start,
Node *  end,
◆ _angle0
double INTERP_KERNEL::EdgeArcCircle::_angle0
◆ _angle
◆ _radius
◆ _center
