INTERP_KERNEL::EdgeIntersector Class Referenceabstract
#include <InterpKernelGeo2DEdge.hxx>
Inheritance diagram for INTERP_KERNEL::EdgeIntersector:
Collaboration diagram for INTERP_KERNEL::EdgeIntersector:
virtual bool areColinears () const =0
virtual void areOverlappedOrOnlyColinears (bool &obviousNoIntersection, bool &areOverlapped)=0
virtual std::list< IntersectElement > getIntersectionsCharacteristicVal () const =0
virtual void getPlacements (Node *start, Node *end, TypeOfLocInEdge &whereStart, TypeOfLocInEdge &whereEnd, MergePoints &commonNode) const =0
virtual bool haveTheySameDirection () const =0
bool intersect (std::vector< Node * > &newNodes, bool &order, MergePoints &commonNode)
virtual bool keepOrder () const =0
virtual ~EdgeIntersector ()
 EdgeIntersector (const Edge &e1, const Edge &e2)
virtual void identifyEarlyIntersection (bool &, bool &, bool &, bool &)
void obviousCaseForCurvAbscisse (Node *node, TypeOfLocInEdge &where, MergePoints &commonNode, bool &obvious) const
const Edge & _e1
const Edge & _e2
IntersectElement * _earlyInter
This abstract interface specifies all the methods to be overloaded of all possibilities edge-intersection.
◆ EdgeIntersector()
INTERP_KERNEL::EdgeIntersector::EdgeIntersector ( const Edge &  e1,
const Edge &  e2
All non symmetric methods are relative to 'e1'.
◆ ~EdgeIntersector()
virtual INTERP_KERNEL::EdgeIntersector::~EdgeIntersector ( )
◆ keepOrder()
virtual bool INTERP_KERNEL::EdgeIntersector::keepOrder ( ) const
pure virtual
◆ areColinears()
virtual bool INTERP_KERNEL::EdgeIntersector::areColinears ( ) const
pure virtual
◆ haveTheySameDirection()
virtual bool INTERP_KERNEL::EdgeIntersector::haveTheySameDirection ( ) const
pure virtual
to call only if 'areOverlapped' have been set to true when areOverlappedOrOnlyColinears was called
Implemented in INTERP_KERNEL::CrossTypeEdgeIntersector, INTERP_KERNEL::ArcCArcCIntersector, and INTERP_KERNEL::SegSegIntersector.
Referenced by INTERP_KERNEL::Edge::IntersectOverlapped().
◆ getPlacements()
virtual void INTERP_KERNEL::EdgeIntersector::getPlacements ( Node *  start,
Node *  end,
TypeOfLocInEdge &  whereStart,
TypeOfLocInEdge &  whereEnd,
MergePoints &  commonNode
pure virtual
Implemented in INTERP_KERNEL::ArcCArcCIntersector, INTERP_KERNEL::ArcCSegIntersector, and INTERP_KERNEL::SegSegIntersector.
◆ intersect()
bool EdgeIntersector::intersect ( std::vector< Node * > &  newNodes,
bool &  order,
When true is returned, newNodes should contains at least 1 element. All merging nodes betw _e1 and _e2 extremities must be done.
References getIntersectionsCharacteristicVal(), INTERP_KERNEL::IntersectElement::LIMIT_ALONE, and INTERP_KERNEL::IntersectElement::LIMIT_ON.
Referenced by INTERP_KERNEL::Edge::Intersect().
◆ areOverlappedOrOnlyColinears()
virtual void INTERP_KERNEL::EdgeIntersector::areOverlappedOrOnlyColinears ( bool &  obviousNoIntersection,
bool &  areOverlapped
pure virtual
◆ getIntersectionsCharacteristicVal()
virtual std::list< IntersectElement > INTERP_KERNEL::EdgeIntersector::getIntersectionsCharacteristicVal ( ) const
pure virtual
The size of returned vector is equal to number of potential intersections point. The values are so that their are interpretable by virtual Edge::isIn method.
Referenced by intersect().
◆ obviousCaseForCurvAbscisse()
void EdgeIntersector::obviousCaseForCurvAbscisse ( Node *  node,
TypeOfLocInEdge &  where,
MergePoints &  commonNode,
bool &  obvious
Locates 'node' regarding edge this->_e1. If node is located close to (with distant lt epsilon) start or end point of _e1, 'node' takes its place. In this case 'obvious' is set to true and 'commonNode' stores information of merge point and finally 'where' is set. Furthermore 'node' is declared as ON LIMIT to indicate in locating process that an absolute location computation will have to be done. If 'node' is not close to start or end point of _e1, 'obvious' is set to false and 'commonNode' and 'where' are let unchanged.
References _e1, INTERP_KERNEL::Edge::changeEndNodeWith(), INTERP_KERNEL::Edge::changeStartNodeWith(), INTERP_KERNEL::Node::declareOnLim(), INTERP_KERNEL::END, INTERP_KERNEL::MergePoints::end1Replaced(), INTERP_KERNEL::Edge::getEndNode(), INTERP_KERNEL::Edge::getStartNode(), INTERP_KERNEL::Node::isEqual(), INTERP_KERNEL::START, and INTERP_KERNEL::MergePoints::start1Replaced().
Referenced by INTERP_KERNEL::ArcCArcCIntersector::getPlacements().
◆ identifyEarlyIntersection()
void EdgeIntersector::identifyEarlyIntersection ( bool &  i1S2S,
bool &  i1E2S,
bool &  i1S2E,
bool &  i1E2E
If the 2 edges share one extremity, we can optimize since we already know where is the intersection. In the case of ArcCSegIntersector, this also helps avoid degenerated cases.
References _e1, _e2, _earlyInter, INTERP_KERNEL::Edge::getCharactValue(), INTERP_KERNEL::Edge::getEndNode(), INTERP_KERNEL::Edge::getStartNode(), INTERP_KERNEL::Node::incrRef(), and keepOrder().
Referenced by INTERP_KERNEL::ArcCSegIntersector::areOverlappedOrOnlyColinears(), and INTERP_KERNEL::SegSegIntersector::areOverlappedOrOnlyColinears().
◆ _e1
◆ _e2
◆ _earlyInter
