INTERP_KERNEL::IntersectElement Class Reference
#include <InterpKernelGeo2DEdge.hxx>
void attachLoc ()
Node * getNodeAndReleaseIt ()
Node * getNodeOnly () const
double getVal1 () const
double getVal2 () const
 IntersectElement (const IntersectElement &other)
 IntersectElement (double val1, double val2, bool start1, bool end1, bool start2, bool end2, Node *node, const Edge &e1, const Edge &e2, bool keepOrder)
bool isIncludedByBoth () const
bool isLowerOnOther (const IntersectElement &other) const
unsigned isOnExtrForAnEdgeAndInForOtherEdge () const
bool isOnMergedExtremity () const
bool operator< (const IntersectElement &other) const
IntersectElement & operator= (const IntersectElement &other)
void performMerging (MergePoints &commonNode) const
void setNode (Node *node) const
 ~IntersectElement ()
Static Public Attributes
static const unsigned LIMIT_ALONE = 22
static const unsigned LIMIT_ON = 73
static const unsigned NO_LIMIT = 19
This class is in charge to store an intersection point as result of non oververlapping edge intersection. This class manages the cases when intersect element is one of the extrimities of edge1 and/or edge2.
◆ IntersectElement() [1/2]
IntersectElement::IntersectElement ( double  val1,
double  val2,
bool  start1,
bool  end1,
bool  start2,
bool  end2,
Node *  node,
const Edge &  e1,
const Edge &  e2,
bool  keepOrder
◆ IntersectElement() [2/2]
IntersectElement::IntersectElement ( const IntersectElement &  other)
◆ ~IntersectElement()
IntersectElement::~IntersectElement ( )
◆ operator<()
bool IntersectElement::operator< ( const IntersectElement &  other) const
The sort operator is done on the edge 1 not edge 2.
References INTERP_KERNEL::Edge::isLower().
◆ operator=()
IntersectElement & IntersectElement::operator= ( const IntersectElement &  other)
References setNode().
◆ getVal1()
double INTERP_KERNEL::IntersectElement::getVal1 ( ) const
◆ getVal2()
double INTERP_KERNEL::IntersectElement::getVal2 ( ) const
◆ isLowerOnOther()
bool IntersectElement::isLowerOnOther ( const IntersectElement &  other) const
idem operator< method except that the orientation is done on edge 2 not edge 1.
◆ isOnExtrForAnEdgeAndInForOtherEdge()
unsigned IntersectElement::isOnExtrForAnEdgeAndInForOtherEdge ( ) const
◆ attachLoc()
void INTERP_KERNEL::IntersectElement::attachLoc ( )
◆ isOnMergedExtremity()
bool IntersectElement::isOnMergedExtremity ( ) const
Returns 0 or 1.
◆ isIncludedByBoth()
bool IntersectElement::isIncludedByBoth ( ) const
◆ setNode()
void IntersectElement::setNode ( Node *  node) const
This method is const because 'node' is supposed to be equal geometrically to _node.
References INTERP_KERNEL::Node::incrRef().
Referenced by isOnExtrForAnEdgeAndInForOtherEdge(), and operator=().
◆ performMerging()
◆ getNodeOnly()
Node * INTERP_KERNEL::IntersectElement::getNodeOnly ( ) const
◆ getNodeAndReleaseIt()
Node * INTERP_KERNEL::IntersectElement::getNodeAndReleaseIt ( )
◆ LIMIT_ALONE
const unsigned INTERP_KERNEL::IntersectElement::LIMIT_ALONE = 22
◆ LIMIT_ON
const unsigned INTERP_KERNEL::IntersectElement::LIMIT_ON = 73
◆ NO_LIMIT
const unsigned INTERP_KERNEL::IntersectElement::NO_LIMIT = 19
