INTERP_KERNEL::ElementaryEdge Class Reference
#include <InterpKernelGeo2DElementaryEdge.hxx>
void applySimilarity (double xBary, double yBary, double dimChar)
INTERPKERNEL_EXPORT bool changeEndNodeWith (Node *node) const
INTERPKERNEL_EXPORT bool changeStartNodeWith (Node *node) const
INTERPKERNEL_EXPORT ElementaryEdge * clone () const
bool completed () const
void declareIn () const
void declareOn () const
void declareOut () const
INTERPKERNEL_EXPORT void dumpInXfigFile (std::ostream &stream, int resolution, const Bounds &box) const
INTERPKERNEL_EXPORT void dumpToCout (const std::map< INTERP_KERNEL::Node *, int > &mapp, int index) const
INTERPKERNEL_EXPORT ElementaryEdge (const ElementaryEdge &other)
 ElementaryEdge (Edge *ptr, bool direction)
INTERPKERNEL_EXPORT void fillBounds (Bounds &output) const
INTERPKERNEL_EXPORT void fillGlobalInfoAbs (const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, std::vector< mcIdType > &edgesThis, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > mapAddCoo) const
INTERPKERNEL_EXPORT void fillGlobalInfoAbs2 (const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, short skipStartOrEnd, std::vector< mcIdType > &edgesOther, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > &mapAddCoo) const
INTERPKERNEL_EXPORT void getAllNodes (std::set< Node * > &output) const
double getAreaOfZone () const
INTERPKERNEL_EXPORT void getBarycenter (double *bary, double &weigh) const
INTERPKERNEL_EXPORT void getBarycenterOfZone (double *bary) const
double getCurveLength () const
bool getDirection () const
INTERPKERNEL_EXPORT Node * getEndNode () const
IteratorOnComposedEdge & getIterator ()
TypeOfEdgeLocInPolygon getLoc () const
Edge * getPtr () const
INTERPKERNEL_EXPORT Node * getStartNode () const
INTERPKERNEL_EXPORT bool hasSameExtremities (const ElementaryEdge &other) const
INTERPKERNEL_EXPORT void initLocations () const
INTERPKERNEL_EXPORT bool intresicEqual (const ElementaryEdge *other) const
INTERPKERNEL_EXPORT bool intresicEqualDirSensitive (const ElementaryEdge *other) const
INTERPKERNEL_EXPORT bool intresincEqCoarse (const Edge *other) const
INTERPKERNEL_EXPORT bool isEqual (const ElementaryEdge &other) const
INTERPKERNEL_EXPORT bool isNodeIn (Node *n) const
bool isThereStartPoint () const
INTERPKERNEL_EXPORT TypeOfEdgeLocInPolygon locateFullyMySelf (const ComposedEdge &pol, TypeOfEdgeLocInPolygon precEdgeLoc) const
INTERPKERNEL_EXPORT TypeOfEdgeLocInPolygon locateFullyMySelfAbsolute (const ComposedEdge &pol) const
void reverse ()
INTERPKERNEL_EXPORT int size () const
void unApplySimilarity (double xBary, double yBary, double dimChar)
INTERPKERNEL_EXPORT ~ElementaryEdge ()
static INTERPKERNEL_EXPORT ElementaryEdge * BuildEdgeFromStartEndDir (bool direction, INTERP_KERNEL::Node *start, INTERP_KERNEL::Node *end)
◆ ElementaryEdge() [1/2]
INTERP_KERNEL::ElementaryEdge::ElementaryEdge ( Edge *  ptr,
bool  direction
Referenced by BuildEdgeFromStartEndDir(), and clone().
◆ ElementaryEdge() [2/2]
ElementaryEdge::ElementaryEdge ( const ElementaryEdge &  other)
◆ ~ElementaryEdge()
ElementaryEdge::~ElementaryEdge ( )
◆ isThereStartPoint()
bool INTERP_KERNEL::ElementaryEdge::isThereStartPoint ( ) const
◆ getIterator()
◆ completed()
bool INTERP_KERNEL::ElementaryEdge::completed ( ) const
◆ declareOn()
void INTERP_KERNEL::ElementaryEdge::declareOn ( ) const
◆ declareIn()
void INTERP_KERNEL::ElementaryEdge::declareIn ( ) const
◆ declareOut()
void INTERP_KERNEL::ElementaryEdge::declareOut ( ) const
◆ getLoc()
◆ getPtr()
◆ reverse()
void INTERP_KERNEL::ElementaryEdge::reverse ( )
◆ isNodeIn()
bool ElementaryEdge::isNodeIn ( Node *  n) const
◆ getAreaOfZone()
double INTERP_KERNEL::ElementaryEdge::getAreaOfZone ( ) const
◆ getBarycenterOfZone()
void ElementaryEdge::getBarycenterOfZone ( double *  bary) const
WARNING contrary to INTERP_KERNEL::Edge::getBarycenterOfZone method called, this one is cumulative.
References INTERP_KERNEL::Edge::getBarycenterOfZone().
◆ fillBounds()
void ElementaryEdge::fillBounds ( Bounds &  output) const
◆ applySimilarity()
void INTERP_KERNEL::ElementaryEdge::applySimilarity ( double  xBary,
double  yBary,
double  dimChar
◆ unApplySimilarity()
void INTERP_KERNEL::ElementaryEdge::unApplySimilarity ( double  xBary,
double  yBary,
double  dimChar
◆ getAllNodes()
void ElementaryEdge::getAllNodes ( std::set< Node * > &  output) const
◆ hasSameExtremities()
bool ElementaryEdge::hasSameExtremities ( const ElementaryEdge &  other) const
◆ getBarycenter()
void ElementaryEdge::getBarycenter ( double *  bary,
double &  weigh
◆ clone()
◆ initLocations()
void ElementaryEdge::initLocations ( ) const
◆ size()
INTERPKERNEL_EXPORT int INTERP_KERNEL::ElementaryEdge::size ( ) const
◆ locateFullyMySelfAbsolute()
◆ locateFullyMySelf()
◆ getEndNode()
◆ getStartNode()
◆ getCurveLength()
double INTERP_KERNEL::ElementaryEdge::getCurveLength ( ) const
◆ changeEndNodeWith()
bool ElementaryEdge::changeEndNodeWith ( Node *  node) const
◆ changeStartNodeWith()
◆ intresicEqual()
bool ElementaryEdge::intresicEqual ( const ElementaryEdge *  other) const
◆ intresicEqualDirSensitive()
bool ElementaryEdge::intresicEqualDirSensitive ( const ElementaryEdge *  other) const
◆ dumpInXfigFile()
void ElementaryEdge::dumpInXfigFile ( std::ostream &  stream,
int  resolution,
const Bounds &  box
◆ dumpToCout()
void ElementaryEdge::dumpToCout ( const std::map< INTERP_KERNEL::Node *, int > &  mapp,
int  index
◆ getDirection()
◆ intresincEqCoarse()
bool ElementaryEdge::intresincEqCoarse ( const Edge *  other) const
◆ isEqual()
bool ElementaryEdge::isEqual ( const ElementaryEdge &  other) const
◆ fillGlobalInfoAbs()
void ElementaryEdge::fillGlobalInfoAbs ( const std::map< INTERP_KERNEL::Node *, mcIdType > &  mapThis,
const std::map< INTERP_KERNEL::Node *, mcIdType > &  mapOther,
mcIdType  offset1,
mcIdType  offset2,
double  fact,
double  baryX,
double  baryY,
std::vector< mcIdType > &  edgesThis,
std::vector< double > &  addCoo,
◆ fillGlobalInfoAbs2()
void ElementaryEdge::fillGlobalInfoAbs2 ( const std::map< INTERP_KERNEL::Node *, mcIdType > &  mapThis,
mcIdType  offset1,
mcIdType  offset2,
double  fact,
double  baryX,
double  baryY,
std::vector< mcIdType > &  edgesOther,
std::map< INTERP_KERNEL::Node *, mcIdType > &  mapAddCoo
Called by QuadraticPolygon::splitAbs method. Close to ElementaryEdge::fillGlobalInfoAbs method expect that here edgesOther (that replace edgesThis) is here an in/out parameter that only contains nodes unsorted because the "other" mesh is not subdivided yet.
References INTERP_KERNEL::Edge::fillGlobalInfoAbs2().
◆ BuildEdgeFromStartEndDir()
ElementaryEdge * ElementaryEdge::BuildEdgeFromStartEndDir ( bool  direction,
INTERP_KERNEL::Node *  start,
INTERP_KERNEL::Node *  end
