INTERP_KERNEL::ElementaryEdge Member List
This is the complete list of members for INTERP_KERNEL::ElementaryEdge, including all inherited members.
applySimilarity(double xBary, double yBary, double dimChar)INTERP_KERNEL::ElementaryEdge
BuildEdgeFromStartEndDir(bool direction, INTERP_KERNEL::Node *start, INTERP_KERNEL::Node *end)INTERP_KERNEL::ElementaryEdgestatic
changeEndNodeWith(Node *node) constINTERP_KERNEL::ElementaryEdge
changeStartNodeWith(Node *node) constINTERP_KERNEL::ElementaryEdge
clone() constINTERP_KERNEL::ElementaryEdge
completed() constINTERP_KERNEL::ElementaryEdge
declareIn() constINTERP_KERNEL::ElementaryEdge
declareOn() constINTERP_KERNEL::ElementaryEdge
declareOut() constINTERP_KERNEL::ElementaryEdge
dumpInXfigFile(std::ostream &stream, int resolution, const Bounds &box) constINTERP_KERNEL::ElementaryEdge
dumpToCout(const std::map< INTERP_KERNEL::Node *, int > &mapp, int index) constINTERP_KERNEL::ElementaryEdge
ElementaryEdge(Edge *ptr, bool direction)INTERP_KERNEL::ElementaryEdge
ElementaryEdge(const ElementaryEdge &other)INTERP_KERNEL::ElementaryEdge
fillBounds(Bounds &output) constINTERP_KERNEL::ElementaryEdge
fillGlobalInfoAbs(const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, std::vector< mcIdType > &edgesThis, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > mapAddCoo) constINTERP_KERNEL::ElementaryEdge
fillGlobalInfoAbs2(const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, short skipStartOrEnd, std::vector< mcIdType > &edgesOther, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > &mapAddCoo) constINTERP_KERNEL::ElementaryEdge
getAllNodes(std::set< Node * > &output) constINTERP_KERNEL::ElementaryEdge
getAreaOfZone() constINTERP_KERNEL::ElementaryEdge
getBarycenter(double *bary, double &weigh) constINTERP_KERNEL::ElementaryEdge
getBarycenterOfZone(double *bary) constINTERP_KERNEL::ElementaryEdge
getCurveLength() constINTERP_KERNEL::ElementaryEdge
getDirection() constINTERP_KERNEL::ElementaryEdge
getEndNode() constINTERP_KERNEL::ElementaryEdge
getIterator()INTERP_KERNEL::ElementaryEdge
getLoc() constINTERP_KERNEL::ElementaryEdge
getPtr() constINTERP_KERNEL::ElementaryEdge
getStartNode() constINTERP_KERNEL::ElementaryEdge
hasSameExtremities(const ElementaryEdge &other) constINTERP_KERNEL::ElementaryEdge
initLocations() constINTERP_KERNEL::ElementaryEdge
intresicEqual(const ElementaryEdge *other) constINTERP_KERNEL::ElementaryEdge
intresicEqualDirSensitive(const ElementaryEdge *other) constINTERP_KERNEL::ElementaryEdge
intresincEqCoarse(const Edge *other) constINTERP_KERNEL::ElementaryEdge
isEqual(const ElementaryEdge &other) constINTERP_KERNEL::ElementaryEdge
isNodeIn(Node *n) constINTERP_KERNEL::ElementaryEdge
isThereStartPoint() constINTERP_KERNEL::ElementaryEdge
locateFullyMySelf(const ComposedEdge &pol, TypeOfEdgeLocInPolygon precEdgeLoc) constINTERP_KERNEL::ElementaryEdge
locateFullyMySelfAbsolute(const ComposedEdge &pol) constINTERP_KERNEL::ElementaryEdge
reverse()INTERP_KERNEL::ElementaryEdge
size() constINTERP_KERNEL::ElementaryEdge
unApplySimilarity(double xBary, double yBary, double dimChar)INTERP_KERNEL::ElementaryEdge
~ElementaryEdge()INTERP_KERNEL::ElementaryEdge
