INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix > Class Template Referenceabstract
#include <TargetIntersector.hxx>
Inheritance diagram for INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >:
typedef MyMeshType::MyConnType ConnType
void adjustBoundingBoxes (double *bbox, std::size_t sz, double adjustmentEps, double adjustmentEpsAbs)
void adjustBoundingBoxes (std::vector< double > &bbox, double adjustmentEps, double adjustmentEpsAbs)
virtual ConnType getNumberOfColsOfResMatrix () const =0
virtual ConnType getNumberOfRowsOfResMatrix () const =0
virtual void intersectCells (ConnType targetCell, const std::vector< ConnType > &srcCells, MyMatrix &res)=0
virtual ~TargetIntersector ()
Static Public Attributes
static const int SPACEDIM = MyMeshType::MY_SPACEDIM
template<class MyMeshType, class MyMatrix>
class INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >
Abstract base class of Intersector classes. These classes represent a target element and calculate its intersection with the source elements.
◆ ConnType
template<class MyMeshType , class MyMatrix >
typedef MyMeshType::MyConnType INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >::ConnType
◆ ~TargetIntersector()
virtual INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >::~TargetIntersector ( )
◆ intersectCells()
virtual void INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >::intersectCells ( ConnType  targetCell,
const std::vector< ConnType > &  srcCells,
MyMatrix &  res
pure virtual
Tool for cell intersection, result is always positive.
targetCellid of cell in target mesh in C mode.
srcCellsids of cells in source mesh in C mode.
resis an IN/OUT parameter that represents the icellTth row in final matrix, fed with at most icellsS elements.
◆ getNumberOfRowsOfResMatrix()
virtual ConnType INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >::getNumberOfRowsOfResMatrix ( ) const
pure virtual
◆ getNumberOfColsOfResMatrix()
virtual ConnType INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >::getNumberOfColsOfResMatrix ( ) const
pure virtual
◆ adjustBoundingBoxes() [1/2]
void INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >::adjustBoundingBoxes ( std::vector< double > &  bbox,
◆ adjustBoundingBoxes() [2/2]
void INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >::adjustBoundingBoxes ( double *  bbox,
std::size_t  sz,
Readjusts a set of bounding boxes so that they are extended in all dimensions for avoiding missing interesting intersections
bboxvector containing the bounding boxes
adjustmentEpsrelative adjustment value (a percentage of the maximal BBox dimension)
adjustmentEpsAbsabsolute adjustment value (added on each side of the BBox in each dimension)
◆ SPACEDIM
const int INTERP_KERNEL::TargetIntersector< MyMeshType, MyMatrix >::SPACEDIM = MyMeshType::MY_SPACEDIM
