MEDCoupling::MEDCouplingGaussLocalization Class Reference
#include <MEDCouplingGaussLocalization.hxx>
MCAuto< MEDCouplingUMesh > buildRefCell () const
void checkConsistencyLight () const
const double * fillWithValues (const double *vals)
MCAuto< DataArrayDouble > getDerivativeOfShapeFunctionValues () const
int getDimension () const
double getGaussCoord (int gaussPtIdInCell, int comp) const
const std::vector< double > & getGaussCoords () const
std::size_t getMemorySize () const
int getNumberOfGaussPt () const
int getNumberOfPtsInRefCell () const
double getRefCoord (int ptIdInCell, int comp) const
const std::vector< double > & getRefCoords () const
MCAuto< DataArrayDouble > getShapeFunctionValues () const
std::string getStringRepr () const
INTERP_KERNEL::NormalizedCellType getType () const
double getWeight (int gaussPtIdInCell) const
const std::vector< double > & getWeights () const
bool isEqual (const MEDCouplingGaussLocalization &other, double eps) const
MCAuto< DataArrayDouble > localizePtsInRefCooForEachCell (const DataArrayDouble *ptsInRefCoo, const MEDCouplingUMesh *mesh) const
 MEDCouplingGaussLocalization (INTERP_KERNEL::NormalizedCellType typ)
 MEDCouplingGaussLocalization (INTERP_KERNEL::NormalizedCellType type, const std::vector< double > &refCoo, const std::vector< double > &gsCoo, const std::vector< double > &w)
void pushTinySerializationDblInfo (std::vector< double > &tinyInfo) const
void pushTinySerializationIntInfo (std::vector< mcIdType > &tinyInfo) const
void setGaussCoord (int gaussPtIdInCell, int comp, double newVal)
void setGaussCoords (const std::vector< double > &gsCoo)
void setRefCoord (int ptIdInCell, int comp, double newVal)
void setRefCoords (const std::vector< double > &refCoo)
void setType (INTERP_KERNEL::NormalizedCellType typ)
void setWeight (int gaussPtIdInCell, double newVal)
void setWeights (const std::vector< double > &w)
static bool AreAlmostEqual (const std::vector< double > &v1, const std::vector< double > &v2, double eps)
static MEDCouplingGaussLocalization BuildNewInstanceFromTinyInfo (mcIdType dim, const std::vector< mcIdType > &tinyData)
static MCAuto< DataArrayDouble > GetDefaultReferenceCoordinatesOf (INTERP_KERNEL::NormalizedCellType type)
◆ MEDCouplingGaussLocalization() [1/2]
MEDCouplingGaussLocalization::MEDCouplingGaussLocalization ( INTERP_KERNEL::NormalizedCellType  type,
const std::vector< double > &  refCoo,
const std::vector< double > &  gsCoo,
const std::vector< double > &  w
◆ MEDCouplingGaussLocalization() [2/2]
MEDCouplingGaussLocalization::MEDCouplingGaussLocalization ( INTERP_KERNEL::NormalizedCellType  typ)
◆ getType()
INTERP_KERNEL::NormalizedCellType MEDCoupling::MEDCouplingGaussLocalization::getType ( ) const
◆ setType()
void MEDCouplingGaussLocalization::setType ( INTERP_KERNEL::NormalizedCellType  typ)
◆ getNumberOfGaussPt()
◆ getDimension()
◆ getNumberOfPtsInRefCell()
◆ getStringRepr()
std::string MEDCouplingGaussLocalization::getStringRepr ( ) const
◆ getMemorySize()
std::size_t MEDCouplingGaussLocalization::getMemorySize ( ) const
◆ checkConsistencyLight()
void MEDCouplingGaussLocalization::checkConsistencyLight ( ) const
◆ isEqual()
bool MEDCouplingGaussLocalization::isEqual ( const MEDCouplingGaussLocalization &  other,
double  eps
References AreAlmostEqual().
◆ pushTinySerializationIntInfo()
void MEDCouplingGaussLocalization::pushTinySerializationIntInfo ( std::vector< mcIdType > &  tinyInfo) const
Completely useless method for end user. Only for CORBA MPI serialization/unserialization. push at the end of tinyInfo its basic serialization info. The size of pushed data is always the same.
tinyInfoinout parameter.
References getNumberOfGaussPt(), and getNumberOfPtsInRefCell().
◆ pushTinySerializationDblInfo()
void MEDCouplingGaussLocalization::pushTinySerializationDblInfo ( std::vector< double > &  tinyInfo) const
Completely useless method for end user. Only for CORBA MPI serialization/unserialization. push at the end of tinyInfo its basic serialization info. The size of pushed data is NOT always the same contrary to pushTinySerializationIntInfo.
◆ fillWithValues()
const double * MEDCouplingGaussLocalization::fillWithValues ( const double *  vals)
This method operates the exact inverse operation than MEDCouplingGaussLocalization::pushTinySerializationDblInfo method. This is one of the last step of unserialization process. This method should be called on an object resized by buildNewInstanceFromTinyInfo static method. This method takes in argument a pointer 'vals' that point to the begin of double data pushed remotely by pushTinySerializationDblInfo method. This method returns the pointer 'vals' with an offset of size what it has been read in this method.
◆ localizePtsInRefCooForEachCell()
MCAuto< DataArrayDouble > MEDCouplingGaussLocalization::localizePtsInRefCooForEachCell ( const DataArrayDouble *  ptsInRefCoo,
const MEDCouplingUMesh *  mesh
Given points in ptsInRefCoo in the reference coordinates of this (in _ref_coord attribute) this method computes their coordinates in real world for each cells in mesh. So the returned array will contain nbCells* ptsInRefCoo->getNumberOfTuples() tuples and the number of component will be equal to the dimension of this.
This method ignores Gauss points in this and only those in ptsInRefCoo are considered here.
References MEDCoupling::DataArrayTemplate< T >::begin(), MEDCoupling::DataArrayTemplate< T >::checkAllocated(), MEDCoupling::MEDCouplingUMesh::checkConsistencyLight(), MEDCoupling::MEDCouplingPointSet::getCoords(), getDimension(), MEDCoupling::MEDCouplingUMesh::getNodalConnectivity(), MEDCoupling::MEDCouplingUMesh::getNodalConnectivityIndex(), MEDCoupling::MEDCouplingUMesh::getNumberOfCells(), MEDCoupling::DataArray::getNumberOfComponents(), getNumberOfPtsInRefCell(), MEDCoupling::DataArrayTemplate< T >::getNumberOfTuples(), MEDCoupling::MEDCouplingPointSet::getSpaceDimension(), getType(), and MEDCoupling::DataArrayDouble::New().
◆ buildRefCell()
MCAuto< MEDCouplingUMesh > MEDCouplingGaussLocalization::buildRefCell ( ) const
This method returns an unstructured mesh that represents the reference cell.
References getDimension(), getType(), MEDCoupling::MEDCoupling1SGTUMesh::New(), and MEDCoupling::DataArrayDouble::New().
◆ getShapeFunctionValues()
MCAuto< DataArrayDouble > MEDCouplingGaussLocalization::getShapeFunctionValues ( ) const
This method returns an array containing for each Gauss Points in this, function values relative to the points of the reference cell. Number of components of returned array is equal to the number of points of the reference cell.
References getDimension(), getNumberOfGaussPt(), getNumberOfPtsInRefCell(), and MEDCoupling::DataArrayDouble::New().
◆ getDerivativeOfShapeFunctionValues()
MCAuto< DataArrayDouble > MEDCouplingGaussLocalization::getDerivativeOfShapeFunctionValues ( ) const
◆ getRefCoords()
const std::vector< double > & MEDCoupling::MEDCouplingGaussLocalization::getRefCoords ( ) const
◆ getRefCoord()
double MEDCouplingGaussLocalization::getRefCoord ( int  ptIdInCell,
int  comp
◆ getGaussCoords()
const std::vector< double > & MEDCoupling::MEDCouplingGaussLocalization::getGaussCoords ( ) const
◆ getGaussCoord()
double MEDCouplingGaussLocalization::getGaussCoord ( int  gaussPtIdInCell,
int  comp
◆ getWeights()
const std::vector< double > & MEDCoupling::MEDCouplingGaussLocalization::getWeights ( ) const
◆ getWeight()
double MEDCouplingGaussLocalization::getWeight ( int  gaussPtIdInCell) const
◆ setRefCoord()
void MEDCouplingGaussLocalization::setRefCoord ( int  ptIdInCell,
int  comp,
double  newVal
This method sets the comp_th component of ptIdInCell_th point coordinate of reference element of type this->_type.
Exceptions
ifnot 0<=ptIdInCell<nbOfNodePerCell or if not 0<=comp<dim
◆ setGaussCoord()
void MEDCouplingGaussLocalization::setGaussCoord ( int  gaussPtIdInCell,
int  comp,
double  newVal
◆ setWeight()
void MEDCouplingGaussLocalization::setWeight ( int  gaussPtIdInCell,
double  newVal
◆ setRefCoords()
void MEDCouplingGaussLocalization::setRefCoords ( const std::vector< double > &  refCoo)
◆ setGaussCoords()
void MEDCouplingGaussLocalization::setGaussCoords ( const std::vector< double > &  gsCoo)
◆ setWeights()
void MEDCouplingGaussLocalization::setWeights ( const std::vector< double > &  w)
◆ BuildNewInstanceFromTinyInfo()
MEDCouplingGaussLocalization MEDCouplingGaussLocalization::BuildNewInstanceFromTinyInfo ( mcIdType  dim,
const std::vector< mcIdType > &  tinyData
◆ AreAlmostEqual()
bool MEDCouplingGaussLocalization::AreAlmostEqual ( const std::vector< double > &  v1,
const std::vector< double > &  v2,
double  eps
Referenced by isEqual().
◆ GetDefaultReferenceCoordinatesOf()
MCAuto< DataArrayDouble > MEDCouplingGaussLocalization::GetDefaultReferenceCoordinatesOf ( INTERP_KERNEL::NormalizedCellType  type)
