| _description | MEDCoupling::MEDFileFieldNameScope | protected |
| _dt_unit | MEDCoupling::MEDFileFieldNameScope | protected |
| _infos | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| _mesh_name | MEDCoupling::MEDFileFieldNameScope | protected |
| _time_steps | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| accept(MEDFileFieldVisitor &visitor) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| appendFieldNoProfileSBT(const MEDCouplingFieldDouble *field, const DataArray *arr, MEDFileFieldGlobsReal &glob) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| appendFieldProfile(const MEDCouplingFieldDouble *field, const DataArray *arr, const MEDFileMesh *mesh, int meshDimRelToMax, const DataArrayIdType *profile, MEDFileFieldGlobsReal &glob, bool smartPflKiller) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| buildFromTimeStepIds(const int *startIds, const int *endIds) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| buildFromTimeStepIds2(int bg, int end, int step) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| changeLocsRefsNamesGen2(const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| changeMeshNames(const std::vector< std::pair< std::string, std::string > > &modifTab) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| changePflsRefsNamesGen2(const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| checkCoherencyOfTinyInfo(const MEDCouplingFieldDouble *field, const DataArray *arr) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| checkCoherencyOfType(const MEDFileAnyTypeField1TSWithoutSDA *f1ts) const | MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | protectedvirtual |
| checkThatComponentsMatch(const std::vector< std::string > &compos) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| checkThatNbOfCompoOfTSMatchThis() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| convertToDouble() const | MEDCoupling::MEDFileNDTemplateFieldMultiTSWithoutSDA< Int32 > | |
| copyNameScope(const MEDFileFieldNameScope &other) | MEDCoupling::MEDFileFieldNameScope | |
| copyTinyInfoFrom(const MEDCouplingFieldDouble *field, const DataArray *arr) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| createNew() const | MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | virtual |
| createNew1TSWithoutSDAEmptyInstance() const | MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | virtual |
| createNewWithSDA() const override | MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA | virtual |
| debugHeapMemorySize() const | MEDCoupling::BigMemoryObject | |
| decrRef() const | MEDCoupling::RefCountObjectOnly | |
| deepCopy() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | virtual |
| eraseEmptyTS() | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| eraseTimeStepIds(const int *startIds, const int *endIds) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| eraseTimeStepIds2(int bg, int end, int step) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getAllTheProgeny() const | MEDCoupling::BigMemoryObject | |
| getClassName() const override | MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA | virtual |
| getDescription() const | MEDCoupling::MEDFileFieldNameScope | |
| getDirectChildren() const | MEDCoupling::BigMemoryObject | |
| getDirectChildrenWithNull() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | virtual |
| getDtUnit() const | MEDCoupling::MEDFileFieldNameScope | |
| getFieldSplitedByType(int iteration, int order, const std::string &mname, std::vector< INTERP_KERNEL::NormalizedCellType > &types, std::vector< std::vector< TypeOfField > > &typesF, std::vector< std::vector< std::string > > &pfls, std::vector< std::vector< std::string > > &locs) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getHeapMemorySize() const | MEDCoupling::BigMemoryObject | |
| GetHeapMemorySizeOfObjs(const std::vector< const BigMemoryObject * > &objs) | MEDCoupling::BigMemoryObject | static |
| getHeapMemorySizeStr() const | MEDCoupling::BigMemoryObject | |
| getHeapMemorySizeWithoutChildren() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | virtual |
| getInfo() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getIterations() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getLocsReallyUsed2() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getLocsReallyUsedMulti2() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getMEDFileFieldType() const | MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA | protectedvirtual |
| getMeshName() const | MEDCoupling::MEDFileFieldNameScope | |
| getMeshSENames(std::vector< std::pair< std::string, std::string > > &ps) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getName() const | MEDCoupling::MEDFileFieldNameScope | |
| getNonEmptyLevels(int iteration, int order, const std::string &mname, std::vector< int > &levs) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getNumberOfTS() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getPflsReallyUsed2() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getPflsReallyUsedMulti2() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getPosGivenTime(double time, double eps=1e-8) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getPosOfTimeStep(int iteration, int order) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getRCValue() const | MEDCoupling::RefCountObjectOnly | |
| getTimeStepAtPos2(int pos) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getTimeStepAtPos2(int pos) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getTimeStepEntry(int iteration, int order) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getTimeStepEntry(int iteration, int order) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getTimeStepPos(int iteration, int order) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getTimeSteps(std::vector< double > &ret1) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getTypesOfFieldAvailable() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getTypeStr() const | MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | virtual |
| getUndergroundDataArray(int iteration, int order) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| getUndergroundDataArrayExt(int iteration, int order, std::vector< std::pair< std::pair< INTERP_KERNEL::NormalizedCellType, int >, std::pair< mcIdType, mcIdType > > > &entries) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| incrRef() const | MEDCoupling::RefCountObjectOnly | |
| isObjectInTheProgeny(const BigMemoryObject *obj) const | MEDCoupling::BigMemoryObject | |
| keepOnlyOnSE(const std::string &seName) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| keepOnlyStructureElements() | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| killStructureElements() | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| loadBigArraysRecursively(med_idt fid, const MEDFileFieldNameScope &nasc) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| loadBigArraysRecursivelyIfNecessary(med_idt fid, const MEDFileFieldNameScope &nasc) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| loadStructureOrStructureAndBigArraysRecursively(med_idt fid, int nbPdt, med_field_type fieldTyp, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| MEDFileAnyTypeFieldMultiTSWithoutSDA() | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| MEDFileAnyTypeFieldMultiTSWithoutSDA(const std::string &fieldName, const std::string &meshName) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| MEDFileAnyTypeFieldMultiTSWithoutSDA(med_idt fid, int fieldId, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| MEDFileAnyTypeFieldMultiTSWithoutSDA(med_idt fid, const std::string &fieldName, const std::string &meshName, med_field_type fieldTyp, const std::vector< std::string > &infos, int nbOfStep, const std::string &dtunit, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | protected |
| MEDFileFieldNameScope() | MEDCoupling::MEDFileFieldNameScope | |
| MEDFileFieldNameScope(const std::string &fieldName, const std::string &meshName) | MEDCoupling::MEDFileFieldNameScope | |
| MEDFileInt32FieldMultiTSWithoutSDA(med_idt fid, int fieldId, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA | |
| MEDFileInt32FieldMultiTSWithoutSDA(const std::string &fieldName, const std::string &meshName) | MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA | protected |
| MEDFileInt32FieldMultiTSWithoutSDA(med_idt fid, const std::string &fieldName, const std::string &meshName, med_field_type fieldTyp, const std::vector< std::string > &infos, int nbOfStep, const std::string &dtunit, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA | protected |
| MEDFileInt32FieldMultiTSWithoutSDA() | MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA | |
| MEDFileNDTemplateFieldMultiTSWithoutSDA() | MEDCoupling::MEDFileNDTemplateFieldMultiTSWithoutSDA< Int32 > | protected |
| MEDFileNDTemplateFieldMultiTSWithoutSDA(med_idt fid, int fieldId, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileNDTemplateFieldMultiTSWithoutSDA< Int32 > | protected |
| MEDFileNDTemplateFieldMultiTSWithoutSDA(const std::string &fieldName, const std::string &meshName) | MEDCoupling::MEDFileNDTemplateFieldMultiTSWithoutSDA< Int32 > | protected |
| MEDFileNDTemplateFieldMultiTSWithoutSDA(med_idt fid, const std::string &fieldName, const std::string &meshName, med_field_type fieldTyp, const std::vector< std::string > &infos, int nbOfStep, const std::string &dtunit, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileNDTemplateFieldMultiTSWithoutSDA< Int32 > | protected |
| MEDFileTemplateFieldMultiTSWithoutSDA() | MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | protected |
| MEDFileTemplateFieldMultiTSWithoutSDA(const std::string &fieldName, const std::string &meshName) | MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | protected |
| MEDFileTemplateFieldMultiTSWithoutSDA(med_idt fid, int fieldId, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | protected |
| MEDFileTemplateFieldMultiTSWithoutSDA(med_idt fid, const std::string &fieldName, const std::string &meshName, med_field_type fieldTyp, const std::vector< std::string > &infos, int nbOfStep, const std::string &dtunit, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | protected |
| MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA | friend |
| New(med_idt fid, const std::string &fieldName, const std::string &meshName, med_field_type fieldTyp, const std::vector< std::string > &infos, int nbOfStep, const std::string &dtunit, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities) | MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 > | static |
| onlyStructureElements() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| operator=(const RefCountObjectOnly &other) | MEDCoupling::RefCountObjectOnly | |
| partOfThisLyingOnSpecifiedTimeSteps(const std::vector< std::pair< int, int > > &timeSteps) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| partOfThisNotLyingOnSpecifiedTimeSteps(const std::vector< std::pair< int, int > > &timeSteps) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| presenceOfMultiDiscPerGeoType() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| presenceOfStructureElements() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| pushBackTimeStep(MCAuto< MEDFileAnyTypeField1TSWithoutSDA > &tse) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| readDescription(med_idt fid, const MEDFileWritable &opts) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| RefCountObject() | MEDCoupling::RefCountObject | protected |
| RefCountObject(const RefCountObject &other) | MEDCoupling::RefCountObject | protected |
| RefCountObjectOnly() | MEDCoupling::RefCountObjectOnly | protected |
| RefCountObjectOnly(const RefCountObjectOnly &other) | MEDCoupling::RefCountObjectOnly | protected |
| renumberEntitiesLyingOnMesh(const std::string &meshName, const std::vector< mcIdType > &oldCode, const std::vector< mcIdType > &newCode, const DataArrayIdType *renumO2N, MEDFileFieldGlobsReal &glob) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| setDescription(const std::string &description) | MEDCoupling::MEDFileFieldNameScope | |
| setDtUnit(const std::string &dtUnit) | MEDCoupling::MEDFileFieldNameScope | |
| setInfo(const std::vector< std::string > &info) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| setIteration(int i, MCAuto< MEDFileAnyTypeField1TSWithoutSDA > ts) | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| setMeshName(const std::string &meshName) | MEDCoupling::MEDFileFieldNameScope | |
| setName(const std::string &fieldName) | MEDCoupling::MEDFileFieldNameScope | |
| shallowCpy() const | MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA | virtual |
| simpleRepr(int bkOffset, std::ostream &oss, int fmtsId) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| splitComponents() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | virtual |
| splitDiscretizations() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | virtual |
| splitMultiDiscrPerGeoTypes() const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | virtual |
| synchronizeNameScope() | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| unloadArrays() | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| writeDescription(med_idt fid, const MEDFileWritable &opts) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| writeLL(med_idt fid, const MEDFileWritable &opts) const | MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA | |
| ~BigMemoryObject() | MEDCoupling::BigMemoryObject | virtual |
| ~RefCountObject() | MEDCoupling::RefCountObject | protectedvirtual |
| ~RefCountObjectOnly() | MEDCoupling::RefCountObjectOnly | protectedvirtual |
