MEDCoupling::BigMemoryObject Class Referenceabstract
#include <MEDCouplingRefCountObject.hxx>
Inheritance diagram for MEDCoupling::BigMemoryObject:
virtual ~BigMemoryObject ()
◆ ~BigMemoryObject()
BigMemoryObject::~BigMemoryObject ( )
◆ getHeapMemorySize()
std::size_t BigMemoryObject::getHeapMemorySize ( ) const
◆ getHeapMemorySizeStr()
std::string BigMemoryObject::getHeapMemorySizeStr ( ) const
References getHeapMemorySize().
◆ getDirectChildren()
std::vector< const BigMemoryObject * > BigMemoryObject::getDirectChildren ( ) const
◆ getAllTheProgeny()
std::vector< const BigMemoryObject * > BigMemoryObject::getAllTheProgeny ( ) const
This method returns all the progeny of this (this is not included in returned vector). All the progeny means all the subobjects (children), subsubobjects (little children), ... of this. The elements in returned array are reported only once even if they appear several times in the progeny of this.
References getDirectChildren().
Referenced by isObjectInTheProgeny().
◆ isObjectInTheProgeny()
bool BigMemoryObject::isObjectInTheProgeny ( const BigMemoryObject *  obj) const
This method scan all the progeny of this (this excluded) to see if obj is part of it. If obj is NULL false is returned.
See also
References getAllTheProgeny().
Referenced by MEDCoupling::MEDCouplingCartesianAMRMeshGen::extractSubTreeFromGlobalFlatten().
◆ GetHeapMemorySizeOfObjs()
std::size_t BigMemoryObject::GetHeapMemorySizeOfObjs ( const std::vector< const BigMemoryObject * > &  objs)
◆ getClassName()
virtual std::string MEDCoupling::BigMemoryObject::getClassName ( ) const
Reimplemented in MEDCoupling::MEDCoupling1SGTUMesh, MEDCoupling::MEDCoupling1DGTUMesh, MEDCoupling::MEDCouplingDataForGodFather, MEDCoupling::MEDCouplingAMRAttribute, MEDCoupling::MEDCouplingCartesianAMRMeshSub, MEDCoupling::MEDCouplingCartesianAMRMesh, MEDCoupling::MEDCouplingCMesh, MEDCoupling::MEDCouplingCurveLinearMesh, MEDCoupling::MEDCouplingFieldDiscretizationP0, MEDCoupling::MEDCouplingFieldDiscretizationP1, MEDCoupling::MEDCouplingFieldDiscretizationGauss, MEDCoupling::MEDCouplingFieldDiscretizationGaussNE, MEDCoupling::MEDCouplingFieldDiscretizationKriging, MEDCoupling::MEDCouplingFieldDouble, MEDCoupling::MEDCouplingFieldTemplate, MEDCoupling::MEDCouplingIMesh, MEDCoupling::MEDCouplingMappedExtrudedMesh, MEDCoupling::DataArrayFloat, MEDCoupling::DataArrayDouble, MEDCoupling::DataArrayInt32, MEDCoupling::DataArrayInt64, MEDCoupling::DataArrayByte, MEDCoupling::DataArrayAsciiChar, MEDCoupling::MEDCouplingTimeDiscretizationInt32, MEDCoupling::MEDCouplingTimeDiscretizationInt64, MEDCoupling::MEDCouplingTimeDiscretizationFloat, MEDCoupling::MEDCouplingNoTimeLabel, MEDCoupling::MEDCouplingWithTimeStep, MEDCoupling::MEDCouplingConstOnTimeInterval, MEDCoupling::MEDCouplingTwoTimeSteps, MEDCoupling::MEDCouplingUMesh, MEDCoupling::MEDFileData, MEDCoupling::MEDFileFields, MEDCoupling::MEDFileAnyTypeField1TSWithoutSDA, MEDCoupling::MEDFileField1TSWithoutSDA, MEDCoupling::MEDFileInt32Field1TSWithoutSDA, MEDCoupling::MEDFileInt64Field1TSWithoutSDA, MEDCoupling::MEDFileFloatField1TSWithoutSDA, MEDCoupling::MEDFileAnyTypeField1TS, MEDCoupling::MEDFileField1TS, MEDCoupling::MEDFileInt32Field1TS, MEDCoupling::MEDFileInt64Field1TS, MEDCoupling::MEDFileFieldGlobs, MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA, MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< T >, MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< double >, MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< float >, MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int32 >, MEDCoupling::MEDFileTemplateFieldMultiTSWithoutSDA< Int64 >, MEDCoupling::MEDFileFieldMultiTSWithoutSDA, MEDCoupling::MEDFileInt32FieldMultiTSWithoutSDA, MEDCoupling::MEDFileInt64FieldMultiTSWithoutSDA, MEDCoupling::MEDFileFloatFieldMultiTSWithoutSDA, MEDCoupling::MEDFileAnyTypeFieldMultiTS, MEDCoupling::MEDFileFieldMultiTS, MEDCoupling::MEDFileInt32FieldMultiTS, MEDCoupling::MEDFileInt64FieldMultiTS, MEDCoupling::MEDFileFloatFieldMultiTS, MEDCoupling::MEDFileUMesh, MEDCoupling::MEDFileCMesh, MEDCoupling::MEDFileCurveLinearMesh, MEDCoupling::MEDFileMeshMultiTS, MEDCoupling::MEDFileMeshes, MEDCoupling::MEDFileParameterDouble1TSWTI, MEDCoupling::MEDFileParameterDouble1TS, MEDCoupling::MEDFileParameterMultiTS, and MEDCoupling::MEDFileParameters.
Referenced by debugHeapMemorySize().
◆ getHeapMemorySizeWithoutChildren()
virtual std::size_t MEDCoupling::BigMemoryObject::getHeapMemorySizeWithoutChildren ( ) const
pure virtual
Implemented in MEDCoupling::MEDCoupling1GTUMesh, MEDCoupling::MEDCoupling1SGTUMesh, MEDCoupling::MEDCoupling1DGTUMesh, MEDCoupling::MEDCouplingAMRAttribute, MEDCoupling::MEDCouplingCartesianAMRMeshGen, MEDCoupling::MEDCouplingCMesh, MEDCoupling::MEDCouplingCurveLinearMesh, MEDCoupling::MEDCouplingField, MEDCoupling::MEDCouplingFieldDiscretization, MEDCoupling::MEDCouplingFieldDiscretizationPerCell, MEDCoupling::MEDCouplingFieldDiscretizationGauss, MEDCoupling::MEDCouplingFieldDouble, MEDCoupling::MEDCouplingIMesh, MEDCoupling::MEDCouplingMappedExtrudedMesh, MEDCoupling::DataArray, MEDCoupling::DataArrayTemplate< T >, MEDCoupling::DataArrayTemplate< char >, MEDCoupling::DataArrayTemplate< double >, MEDCoupling::DataArrayTemplate< float >, MEDCoupling::DataArrayTemplate< Int32 >, MEDCoupling::DataArrayTemplate< Int64 >, MEDCoupling::MEDCouplingMesh, MEDCoupling::MEDCouplingPointSet, MEDCoupling::MEDCouplingStructuredMesh, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< double >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< float >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< Int32 >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< Int64 >, MEDCoupling::MEDCouplingTwoTimeSteps, MEDCoupling::MEDCouplingUMesh, MEDCoupling::MEDFileData, MEDCoupling::MEDFileFields, MEDCoupling::MEDFileAnyTypeField1TSWithoutSDA, MEDCoupling::MEDFileAnyTypeField1TS, MEDCoupling::MEDFileFieldGlobs, MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA, MEDCoupling::MEDFileAnyTypeFieldMultiTS, MEDCoupling::MEDFileMesh, MEDCoupling::MEDFileUMesh, MEDCoupling::MEDFileStructuredMesh, MEDCoupling::MEDFileCMesh, MEDCoupling::MEDFileCurveLinearMesh, MEDCoupling::MEDFileMeshMultiTS, MEDCoupling::MEDFileMeshes, MEDCoupling::MEDFileParameterDouble1TSWTI, MEDCoupling::MEDFileParameterDouble1TS, MEDCoupling::MEDFileParameterMultiTS, and MEDCoupling::MEDFileParameters.
Referenced by debugHeapMemorySize(), and getHeapMemorySize().
◆ getDirectChildrenWithNull()
virtual std::vector< const BigMemoryObject * > MEDCoupling::BigMemoryObject::getDirectChildrenWithNull ( ) const
pure virtual
Implemented in MEDCoupling::MEDCoupling1SGTUMesh, MEDCoupling::MEDCoupling1DGTUMesh, MEDCoupling::MEDCouplingAMRAttribute, MEDCoupling::MEDCouplingCartesianAMRMeshGen, MEDCoupling::MEDCouplingCMesh, MEDCoupling::MEDCouplingCurveLinearMesh, MEDCoupling::MEDCouplingField, MEDCoupling::MEDCouplingFieldDiscretization, MEDCoupling::MEDCouplingFieldDiscretizationPerCell, MEDCoupling::MEDCouplingFieldDouble, MEDCoupling::MEDCouplingIMesh, MEDCoupling::MEDCouplingMappedExtrudedMesh, MEDCoupling::DataArray, MEDCoupling::MEDCouplingPointSet, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< double >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< float >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< Int32 >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< Int64 >, MEDCoupling::MEDCouplingTwoTimeSteps, MEDCoupling::MEDCouplingUMesh, MEDCoupling::MEDFileData, MEDCoupling::MEDFileFields, MEDCoupling::MEDFileAnyTypeField1TSWithoutSDA, MEDCoupling::MEDFileAnyTypeField1TS, MEDCoupling::MEDFileFieldGlobs, MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA, MEDCoupling::MEDFileAnyTypeFieldMultiTS, MEDCoupling::MEDFileMesh, MEDCoupling::MEDFileUMesh, MEDCoupling::MEDFileStructuredMesh, MEDCoupling::MEDFileCMesh, MEDCoupling::MEDFileCurveLinearMesh, MEDCoupling::MEDFileMeshMultiTS, MEDCoupling::MEDFileMeshes, MEDCoupling::MEDFileParameterDouble1TSWTI, MEDCoupling::MEDFileParameterDouble1TS, MEDCoupling::MEDFileParameterMultiTS, and MEDCoupling::MEDFileParameters.
Referenced by getDirectChildren().
◆ debugHeapMemorySize()
std::string BigMemoryObject::debugHeapMemorySize ( ) const
