MEDCoupling::MEDFileFloatFieldMultiTS Class Reference
#include <MEDFileFieldMultiTS.hxx>
Inheritance diagram for MEDCoupling::MEDFileFloatFieldMultiTS:
Collaboration diagram for MEDCoupling::MEDFileFloatFieldMultiTS:
MEDFileFloatFieldMultiTS * buildNewEmpty () const
MEDFileAnyTypeFieldMultiTS * shallowCpy () const
- Public Member Functions inherited from MEDCoupling::MEDFileNDTemplateFieldMultiTS< float >
MEDFileFieldMultiTS * convertToDouble (bool isDeepCpyGlobs=true) const
- Public Member Functions inherited from MEDCoupling::MEDFileTemplateFieldMultiTS< float >
void appendFieldNoProfileSBT (const typename Traits< float >::FieldType *field)
void appendFieldProfile (const typename Traits< float >::FieldType *field, const MEDFileMesh *mesh, int meshDimRelToMax, const DataArrayIdType *profile)
void appendFieldProfileFlatly (const typename Traits< float >::FieldType *field, const MEDFileMesh *mesh, int meshDimRelToMax, const DataArrayIdType *profile)
MLFieldTraits< float >::FMTSType * buildNewEmptyImpl () const
void checkCoherencyOfType (const MEDFileAnyTypeField1TS *f1ts) const
MEDFileAnyTypeFieldMultiTS * extractPart (const std::map< int, MCAuto< DataArrayIdType > > &extractDef, MEDFileMesh *mm) const
MLFieldTraits< float >::FMTSType * extractPartImpl (const std::map< int, MCAuto< DataArrayIdType > > &extractDef, MEDFileMesh *mm) const
Traits< float >::FieldType * field (int iteration, int order, const MEDFileMesh *mesh) const
Traits< float >::FieldType * getFieldAtLevel (TypeOfField type, int iteration, int order, int meshDimRelToMax, int renumPol=0) const
Traits< float >::FieldType * getFieldAtLevelOld (TypeOfField type, int iteration, int order, const std::string &mname, int meshDimRelToMax, int renumPol=0) const
Traits< float >::FieldType * getFieldAtTopLevel (TypeOfField type, int iteration, int order, int renumPol=0) const
Traits< float >::FieldType * getFieldOnMeshAtLevel (TypeOfField type, int iteration, int order, const MEDCouplingMesh *mesh, int renumPol=0) const
Traits< float >::FieldType * getFieldOnMeshAtLevel (TypeOfField type, int iteration, int order, int meshDimRelToMax, const MEDFileMesh *mesh, int renumPol=0) const
Traits< float >::ArrayType * getFieldWithProfile (TypeOfField type, int iteration, int order, int meshDimRelToMax, const MEDFileMesh *mesh, DataArrayIdType *&pfl) const
MLFieldTraits< float >::F1TSType * getTimeStepAtPos (int pos) const
Traits< float >::ArrayType * getUndergroundDataArray (int iteration, int order) const
Traits< float >::ArrayType * getUndergroundDataArrayExt (int iteration, int order, std::vector< std::pair< std::pair< INTERP_KERNEL::NormalizedCellType, int >, std::pair< mcIdType, mcIdType > > > &entries) const
- Public Member Functions inherited from MEDCoupling::MEDFileAnyTypeFieldMultiTS
virtual MEDFileAnyTypeFieldMultiTS * buildNewEmpty () const =0
MEDFileAnyTypeFieldMultiTS * buildSubPart (const int *startIds, const int *endIds) const
MEDFileAnyTypeFieldMultiTS * buildSubPartSlice (int bg, int end, int step) const
void changeLocsRefsNamesGen (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
bool changeMeshNames (const std::vector< std::pair< std::string, std::string > > &modifTab)
void changePflsRefsNamesGen (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
virtual void checkCoherencyOfType (const MEDFileAnyTypeField1TS *f1ts) const =0
virtual MEDFileAnyTypeFieldMultiTS * deepCopy () const
void eraseEmptyTS ()
void eraseTimeStepIds (const int *startIds, const int *endIds)
void eraseTimeStepIds2 (int bg, int end, int step)
virtual MEDFileAnyTypeFieldMultiTS * extractPart (const std::map< int, MCAuto< DataArrayIdType > > &extractDef, MEDFileMesh *mm) const =0
MCAuto< MEDFileAnyTypeFieldMultiTSWithoutSDA > getContent ()
std::string getDtUnit () const
std::vector< std::vector< std::pair< mcIdType, mcIdType > > > getFieldSplitedByType (int iteration, int order, const std::string &mname, std::vector< INTERP_KERNEL::NormalizedCellType > &types, std::vector< std::vector< TypeOfField > > &typesF, std::vector< std::vector< std::string > > &pfls, std::vector< std::vector< std::string > > &locs) const
const std::vector< std::string > & getInfo () const
std::vector< std::pair< int, int > > getIterations () const
std::vector< std::string > getLocsReallyUsed () const
std::vector< std::string > getLocsReallyUsedMulti () const
std::string getMeshName () const
std::string getName () const
int getNonEmptyLevels (int iteration, int order, const std::string &mname, std::vector< int > &levs) const
int getNumberOfComponents () const
int getNumberOfTS () const
std::vector< std::string > getPflsReallyUsed () const
std::vector< std::string > getPflsReallyUsedMulti () const
int getPosGivenTime (double time, double eps=1e-8) const
int getPosOfTimeStep (int iteration, int order) const
MEDFileAnyTypeField1TS * getTimeStep (int iteration, int order) const
virtual MEDFileAnyTypeField1TS * getTimeStepAtPos (int pos) const =0
MEDFileAnyTypeField1TS * getTimeStepGivenTime (double time, double eps=1e-8) const
std::vector< std::pair< int, int > > getTimeSteps (std::vector< double > &ret1) const
std::vector< std::vector< TypeOfField > > getTypesOfFieldAvailable () const
MEDFileAnyTypeFieldMultiTSIterator * iterator ()
void loadArrays ()
void loadArraysIfNecessary ()
bool presenceOfMultiDiscPerGeoType () const
void pushBackTimeStep (MEDFileAnyTypeField1TS *f1ts)
void pushBackTimeSteps (const std::vector< MEDFileAnyTypeField1TS * > &f1ts)
void pushBackTimeSteps (MEDFileAnyTypeFieldMultiTS *fmts)
void setDtUnit (const std::string &dtUnit)
void setInfo (const std::vector< std::string > &info)
void setMeshName (const std::string &newMeshName)
virtual MEDFileAnyTypeFieldMultiTS * shallowCpy () const =0
std::string simpleRepr () const
void simpleRepr (int bkOffset, std::ostream &oss, int fmtsId) const
std::vector< MCAuto< MEDFileAnyTypeFieldMultiTS > > splitComponents () const
std::vector< MCAuto< MEDFileAnyTypeFieldMultiTS > > splitDiscretizations () const
std::vector< MCAuto< MEDFileAnyTypeFieldMultiTS > > splitMultiDiscrPerGeoTypes () const
void synchronizeNameScope ()
void unloadArrays ()
void unloadArraysWithoutDataLoss ()
void writeLL (med_idt fid) const
bool decrRef () const
int getRCValue () const
void incrRef () const
virtual ~BigMemoryObject ()
- Public Member Functions inherited from MEDCoupling::MEDFileFieldGlobsReal
void appendGlobs (const MEDFileFieldGlobsReal &other, double eps)
void appendLoc (const std::string &locName, INTERP_KERNEL::NormalizedCellType geoType, const std::vector< double > &refCoo, const std::vector< double > &gsCoo, const std::vector< double > &w)
void appendProfile (DataArrayIdType *pfl)
void changeLocName (const std::string &oldName, const std::string &newName)
void changeLocsNames (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
void changeLocsNamesInStruct (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
virtual void changeLocsRefsNamesGen (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)=0
void changePflName (const std::string &oldName, const std::string &newName)
void changePflsNames (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
void changePflsNamesInStruct (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
virtual void changePflsRefsNamesGen (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)=0
void checkGlobsCoherency () const
void checkGlobsLocsPartCoherency () const
void checkGlobsPflsPartCoherency () const
std::string createNewNameOfLoc () const
std::string createNewNameOfPfl () const
void deepCpyGlobs (const MEDFileFieldGlobsReal &other)
void deepCpyOnlyUsedGlobs (const MEDFileFieldGlobsReal &other)
bool existsLoc (const std::string &locName) const
bool existsPfl (const std::string &pflName) const
std::string getFileName () const
MEDFileFieldLoc & getLocalization (const std::string &locName)
const MEDFileFieldLoc & getLocalization (const std::string &locName) const
MEDFileFieldLoc & getLocalizationFromId (int locId)
const MEDFileFieldLoc & getLocalizationFromId (int locId) const
int getLocalizationId (const std::string &loc) const
std::vector< std::string > getLocs () const
virtual std::vector< std::string > getLocsReallyUsed () const =0
virtual std::vector< std::string > getLocsReallyUsedMulti () const =0
int getNbOfGaussPtPerCell (int locId) const
std::vector< std::string > getPfls () const
virtual std::vector< std::string > getPflsReallyUsed () const =0
virtual std::vector< std::string > getPflsReallyUsedMulti () const =0
DataArrayIdType * getProfile (const std::string &pflName)
const DataArrayIdType * getProfile (const std::string &pflName) const
DataArrayIdType * getProfileFromId (int pflId)
const DataArrayIdType * getProfileFromId (int pflId) const
int getProfileId (const std::string &pfl) const
void killLocalizationIds (const std::vector< int > &locIds)
void killProfileIds (const std::vector< int > &pflIds)
void killStructureElementsInGlobs ()
void loadAllGlobals (med_idt fid, const MEDFileEntities *entities=0)
void loadGlobals (med_idt fid)
void loadProfileInFile (med_idt fid, int id)
void loadProfileInFile (med_idt fid, int id, const std::string &pflName)
 MEDFileFieldGlobsReal ()
 MEDFileFieldGlobsReal (med_idt fid)
void resetContent ()
void setFileName (const std::string &fileName)
void shallowCpyGlobs (const MEDFileFieldGlobsReal &other)
void shallowCpyOnlyUsedGlobs (const MEDFileFieldGlobsReal &other)
void simpleReprGlobs (std::ostream &oss) const
std::vector< std::vector< int > > whichAreEqualLocs (double eps) const
std::vector< std::vector< int > > whichAreEqualProfiles () const
void writeGlobals (med_idt fid, const MEDFileWritable &opt) const
std::vector< std::pair< std::vector< std::string >, std::string > > zipLocsNames (double eps)
std::vector< std::pair< std::vector< std::string >, std::string > > zipPflsNames ()
virtual ~MEDFileFieldGlobsReal ()
Friends
class MEDFileTemplateFieldMultiTS< float >
- Static Public Member Functions inherited from MEDCoupling::MEDFileTemplateFieldMultiTS< float >
static MLFieldTraits< float >::FMTSType * LoadSpecificEntities (const std::string &fileName, const std::string &fieldName, const std::vector< std::pair< TypeOfField, INTERP_KERNEL::NormalizedCellType > > &entities, bool loadAll=true)
static MLFieldTraits< float >::FMTSType * New ()
static MLFieldTraits< float >::FMTSType * New (const std::string &fileName, bool loadAll=true)
static MLFieldTraits< float >::FMTSType * New (const std::string &fileName, const std::string &fieldName, bool loadAll=true)
static MLFieldTraits< float >::FMTSType * New (const typename MLFieldTraits< float >::FMTSWSDAType &other, bool shallowCopyOfContent)
static MLFieldTraits< float >::FMTSType * New (DataArrayByte *db)
static MLFieldTraits< float >::FMTSType * New (med_idt fid, bool loadAll=true)
static MLFieldTraits< float >::FMTSType * New (med_idt fid, const std::string &fieldName, bool loadAll=true)
- Static Public Member Functions inherited from MEDCoupling::MEDFileAnyTypeFieldMultiTS
static MCAuto< MEDFileAnyTypeFieldMultiTS > Aggregate (const std::vector< const MEDFileAnyTypeFieldMultiTS * > &fmtss, const std::vector< std::vector< std::pair< int, mcIdType > > > &dts)
static MEDFileAnyTypeFieldMultiTS * BuildNewInstanceFromContent (MEDFileAnyTypeFieldMultiTSWithoutSDA *c)
static int CheckSupportAcrossTime (MEDFileAnyTypeFieldMultiTS *f0, MEDFileAnyTypeFieldMultiTS *f1, const MEDFileMesh *mesh, TypeOfField &tof0, TypeOfField &tof1)
static MEDFileAnyTypeFieldMultiTS * New (const std::string &fileName, bool loadAll=true)
static MEDFileAnyTypeFieldMultiTS * New (const std::string &fileName, const std::string &fieldName, bool loadAll=true)
static MEDFileAnyTypeFieldMultiTS * New (med_idt fid, bool loadAll=true)
static MEDFileAnyTypeFieldMultiTS * New (med_idt fid, const std::string &fieldName, bool loadAll=true)
static std::vector< std::vector< MEDFileAnyTypeFieldMultiTS * > > SplitIntoCommonTimeSeries (const std::vector< MEDFileAnyTypeFieldMultiTS * > &vectFMTS)
static std::vector< std::vector< MEDFileAnyTypeFieldMultiTS * > > SplitPerCommonSupport (const std::vector< MEDFileAnyTypeFieldMultiTS * > &vectFMTS, const MEDFileMesh *mesh, std::vector< MCAuto< MEDFileFastCellSupportComparator > > &fsc)
- Protected Member Functions inherited from MEDCoupling::MEDFileNDTemplateFieldMultiTS< float >
 MEDFileNDTemplateFieldMultiTS ()
 MEDFileNDTemplateFieldMultiTS (const typename MLFieldTraits< float >::FMTSWSDAType &other, bool shallowCopyOfContent)
 MEDFileNDTemplateFieldMultiTS (med_idt fid, bool loadAll, const MEDFileMeshes *ms)
 MEDFileNDTemplateFieldMultiTS (med_idt fid, const std::string &fieldName, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities)
 ~MEDFileNDTemplateFieldMultiTS ()
- Protected Member Functions inherited from MEDCoupling::MEDFileTemplateFieldMultiTS< float >
void appendFieldProfileGeneral (const typename Traits< float >::FieldType *field, const MEDFileMesh *mesh, int meshDimRelToMax, const DataArrayIdType *profile, bool smartPflKiller)
MLFieldTraits< float >::FMTSWSDAType * contentNotNull ()
const MLFieldTraits< float >::FMTSWSDAType * contentNotNull () const
 MEDFileTemplateFieldMultiTS ()
 MEDFileTemplateFieldMultiTS (const typename MLFieldTraits< float >::FMTSWSDAType &other, bool shallowCopyOfContent)
 MEDFileTemplateFieldMultiTS (med_idt fid, bool loadAll, const MEDFileMeshes *ms)
 MEDFileTemplateFieldMultiTS (med_idt fid, const std::string &fieldName, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities=0)
 ~MEDFileTemplateFieldMultiTS ()
- Protected Member Functions inherited from MEDCoupling::MEDFileAnyTypeFieldMultiTS
MEDFileAnyTypeFieldMultiTSWithoutSDA * contentNotNullBase ()
const MEDFileAnyTypeFieldMultiTSWithoutSDA * contentNotNullBase () const
 MEDFileAnyTypeFieldMultiTS ()
 MEDFileAnyTypeFieldMultiTS (const MEDFileAnyTypeFieldMultiTSWithoutSDA &other, bool shallowCopyOfContent)
 MEDFileAnyTypeFieldMultiTS (med_idt fid, bool loadAll, const MEDFileMeshes *ms)
 MEDFileAnyTypeFieldMultiTS (med_idt fid, const std::string &fieldName, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities=0)
 RefCountObject ()
virtual ~RefCountObject ()
 RefCountObjectOnly ()
- Protected Member Functions inherited from MEDCoupling::MEDFileFieldGlobsReal
MEDFileFieldGlobs * contentNotNull ()
const MEDFileFieldGlobs * contentNotNull () const
- Static Protected Member Functions inherited from MEDCoupling::MEDFileAnyTypeFieldMultiTS
static MEDFileAnyTypeFieldMultiTSWithoutSDA * BuildContentFrom (med_idt fid, bool loadAll, const MEDFileMeshes *ms)
static MEDFileAnyTypeFieldMultiTSWithoutSDA * BuildContentFrom (med_idt fid, const std::string &fieldName, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities)
static MEDFileAnyTypeFieldMultiTS * BuildNewInstanceFromContent (MEDFileAnyTypeFieldMultiTSWithoutSDA *c, med_idt fid)
- Protected Attributes inherited from MEDCoupling::MEDFileAnyTypeFieldMultiTS
MCAuto< MEDFileAnyTypeFieldMultiTSWithoutSDA > _content
- Protected Attributes inherited from MEDCoupling::MEDFileFieldGlobsReal
MCAuto< MEDFileFieldGlobs > _globals
User class.
◆ shallowCpy()
MEDFileAnyTypeFieldMultiTS * MEDCoupling::MEDFileFloatFieldMultiTS::shallowCpy ( ) const
◆ buildNewEmpty()
MEDFileFloatFieldMultiTS * MEDCoupling::MEDFileFloatFieldMultiTS::buildNewEmpty ( ) const
◆ getClassName()
std::string MEDCoupling::MEDFileFloatFieldMultiTS::getClassName ( ) const
overridevirtual
◆ MEDFileTemplateFieldMultiTS< float >
friend class MEDFileTemplateFieldMultiTS< float >
friend
