MEDCoupling::MEDCouplingFieldTemplate Class Reference
#include <MEDCouplingFieldTemplate.hxx>
Inheritance diagram for MEDCoupling::MEDCouplingFieldTemplate:
Collaboration diagram for MEDCoupling::MEDCouplingFieldTemplate:
std::string advancedRepr () const
void checkConsistencyLight () const
MCAuto< MEDCouplingFieldTemplate > clone (bool recDeepCpy) const
void finishUnserialization (const std::vector< mcIdType > &tinyInfoI, const std::vector< double > &tinyInfoD, const std::vector< std::string > &tinyInfoS)
void getTinySerializationDbleInformation (std::vector< double > &tinyInfo) const
void getTinySerializationIntInformation (std::vector< mcIdType > &tinyInfo) const
void getTinySerializationStrInformation (std::vector< std::string > &tinyInfo) const
bool isEqual (const MEDCouplingFieldTemplate *other, double meshPrec) const
bool isEqualIfNotWhy (const MEDCouplingFieldTemplate *other, double meshPrec, std::string &reason) const
bool isEqualWithoutConsideringStr (const MEDCouplingFieldTemplate *other, double meshPrec) const
void reprQuickOverview (std::ostream &stream) const
void resizeForUnserialization (const std::vector< mcIdType > &tinyInfoI, DataArrayIdType *&dataInt)
void serialize (DataArrayIdType *&dataInt) const
std::string simpleRepr () const
- Public Member Functions inherited from MEDCoupling::MEDCouplingField
virtual bool areCompatibleForMerge (const MEDCouplingField *other) const
virtual bool areStrictlyCompatible (const MEDCouplingField *other) const
virtual bool areStrictlyCompatibleForMulDiv (const MEDCouplingField *other) const
MEDCouplingFieldDouble * buildMeasureField (bool isAbs) const
MEDCouplingMesh * buildSubMeshData (const mcIdType *start, const mcIdType *end, DataArrayIdType *&di) const
MEDCouplingMesh * buildSubMeshDataRange (mcIdType begin, mcIdType end, mcIdType step, mcIdType &beginOut, mcIdType &endOut, mcIdType &stepOut, DataArrayIdType *&di) const
virtual void checkConsistencyLight () const
void clearGaussLocalizations ()
DataArrayIdType * computeTupleIdsToSelectFromCellIds (const mcIdType *startCellIds, const mcIdType *endCellIds) const
virtual void copyTinyStringsFrom (const MEDCouplingField *other)
void getCellIdsHavingGaussLocalization (int locId, std::vector< mcIdType > &cellIds) const
std::string getDescription () const
MEDCouplingFieldDiscretization * getDiscretization ()
const MEDCouplingFieldDiscretization * getDiscretization () const
MEDCouplingGaussLocalization & getGaussLocalization (int locId)
const MEDCouplingGaussLocalization & getGaussLocalization (int locId) const
mcIdType getGaussLocalizationIdOfOneCell (mcIdType cellId) const
mcIdType getGaussLocalizationIdOfOneType (INTERP_KERNEL::NormalizedCellType type) const
std::set< mcIdType > getGaussLocalizationIdsOfOneType (INTERP_KERNEL::NormalizedCellType type) const
DataArrayDouble * getLocalizationOfDiscr () const
MEDCoupling::MEDCouplingMesh * getMesh ()
const MEDCoupling::MEDCouplingMesh * getMesh () const
std::string getName () const
NatureOfField getNature () const
mcIdType getNbOfGaussLocalization () const
mcIdType getNumberOfMeshPlacesExpected () const
mcIdType getNumberOfTuplesExpected () const
mcIdType getNumberOfTuplesExpectedRegardingCode (const std::vector< mcIdType > &code, const std::vector< const DataArrayIdType * > &idsPerType) const
TypeOfField getTypeOfField () const
virtual void reprQuickOverview (std::ostream &stream) const =0
void setDescription (const std::string &desc)
void setDiscretization (MEDCouplingFieldDiscretization *newDisc)
void setGaussLocalizationOnCells (const mcIdType *begin, const mcIdType *end, const std::vector< double > &refCoo, const std::vector< double > &gsCoo, const std::vector< double > &wg)
void setGaussLocalizationOnType (INTERP_KERNEL::NormalizedCellType type, const std::vector< double > &refCoo, const std::vector< double > &gsCoo, const std::vector< double > &wg)
void setMesh (const MEDCoupling::MEDCouplingMesh *mesh)
virtual void setNature (NatureOfField nat)
void updateTime () const
bool decrRef () const
int getRCValue () const
void incrRef () const
virtual ~BigMemoryObject ()
void declareAsNew () const
static MEDCouplingFieldTemplate * New (const MEDCouplingFieldDouble &f)
static MEDCouplingFieldTemplate * New (const MEDCouplingFieldFloat &f)
static MEDCouplingFieldTemplate * New (const MEDCouplingFieldInt32 &f)
static MEDCouplingFieldTemplate * New (const MEDCouplingFieldInt64 &f)
static MEDCouplingFieldTemplate * New (TypeOfField type)
static MEDCouplingFieldTemplate * NewWithoutCheck (const MEDCouplingFieldDouble &f)
static MEDCouplingFieldTemplate * NewWithoutCheck (const MEDCouplingFieldFloat &f)
static MEDCouplingFieldTemplate * NewWithoutCheck (const MEDCouplingFieldInt32 &f)
static MEDCouplingFieldTemplate * NewWithoutCheck (const MEDCouplingFieldInt64 &f)
- Protected Member Functions inherited from MEDCoupling::MEDCouplingField
bool isEqualIfNotWhyProtected (const MEDCouplingField *other, double meshPrec, std::string &reason) const
bool isEqualWithoutConsideringStrProtected (const MEDCouplingField *other, double meshPrec) const
 MEDCouplingField (const MEDCouplingField &other, bool deepCopy=true)
 MEDCouplingField (MEDCouplingFieldDiscretization *type, NatureOfField nature=NoNature)
 MEDCouplingField (TypeOfField type)
virtual ~MEDCouplingField ()
 RefCountObject ()
virtual ~RefCountObject ()
 RefCountObjectOnly ()
 TimeLabel ()
virtual ~TimeLabel ()
- Protected Attributes inherited from MEDCoupling::MEDCouplingField
std::string _desc
const MEDCouplingMesh * _mesh
NatureOfField _nature
MCAuto< MEDCouplingFieldDiscretization > _type
A field template can be seen as a field without the array of values.
A field template aggregates a MEDCouplingMesh and a spatial discretization object (instance of MEDCouplingFieldDiscretization).
MEDCouplingFieldTemplate is the most appropriate type for the preparation of matrix using MEDCouplingRemapper::prepareEx, since it contains the minimal information requireds to prepare the interpolation matrix.
◆ New() [1/5]
◆ New() [2/5]
MEDCouplingFieldTemplate * MEDCouplingFieldTemplate::New ( const MEDCouplingFieldFloat &  f)
◆ New() [3/5]
MEDCouplingFieldTemplate * MEDCouplingFieldTemplate::New ( const MEDCouplingFieldInt32 &  f)
◆ New() [4/5]
MEDCouplingFieldTemplate * MEDCouplingFieldTemplate::New ( const MEDCouplingFieldInt64 &  f)
◆ New() [5/5]
MEDCouplingFieldTemplate * MEDCouplingFieldTemplate::New ( TypeOfField  type)
The user should not use this method. Only useful for CORBA serialization/unserialization.
◆ NewWithoutCheck() [1/4]
◆ NewWithoutCheck() [2/4]
MEDCouplingFieldTemplate * MEDCouplingFieldTemplate::NewWithoutCheck ( const MEDCouplingFieldFloat &  f)
◆ NewWithoutCheck() [3/4]
MEDCouplingFieldTemplate * MEDCouplingFieldTemplate::NewWithoutCheck ( const MEDCouplingFieldInt32 &  f)
◆ NewWithoutCheck() [4/4]
MEDCouplingFieldTemplate * MEDCouplingFieldTemplate::NewWithoutCheck ( const MEDCouplingFieldInt64 &  f)
◆ getClassName()
std::string MEDCoupling::MEDCouplingFieldTemplate::getClassName ( ) const
overridevirtual
Reimplemented from MEDCoupling::BigMemoryObject.
◆ isEqualIfNotWhy()
bool MEDCouplingFieldTemplate::isEqualIfNotWhy ( const MEDCouplingFieldTemplate *  other,
double  meshPrec,
std::string &  reason
◆ isEqual()
bool MEDCouplingFieldTemplate::isEqual ( const MEDCouplingFieldTemplate *  other,
double  meshPrec
◆ isEqualWithoutConsideringStr()
bool MEDCouplingFieldTemplate::isEqualWithoutConsideringStr ( const MEDCouplingFieldTemplate *  other,
double  meshPrec
◆ simpleRepr()
◆ advancedRepr()
std::string MEDCouplingFieldTemplate::advancedRepr ( ) const
References simpleRepr().
◆ checkConsistencyLight()
void MEDCouplingFieldTemplate::checkConsistencyLight ( ) const
◆ clone()
MCAuto< MEDCouplingFieldTemplate > MEDCouplingFieldTemplate::clone ( bool  recDeepCpy) const
◆ getTinySerializationIntInformation()
void MEDCouplingFieldTemplate::getTinySerializationIntInformation ( std::vector< mcIdType > &  tinyInfo) const
◆ getTinySerializationDbleInformation()
void MEDCouplingFieldTemplate::getTinySerializationDbleInformation ( std::vector< double > &  tinyInfo) const
◆ getTinySerializationStrInformation()
void MEDCouplingFieldTemplate::getTinySerializationStrInformation ( std::vector< std::string > &  tinyInfo) const
◆ resizeForUnserialization()
void MEDCouplingFieldTemplate::resizeForUnserialization ( const std::vector< mcIdType > &  tinyInfoI,
DataArrayIdType *&  dataInt
◆ finishUnserialization()
void MEDCouplingFieldTemplate::finishUnserialization ( const std::vector< mcIdType > &  tinyInfoI,
const std::vector< double > &  tinyInfoD,
const std::vector< std::string > &  tinyInfoS
◆ serialize()
void MEDCouplingFieldTemplate::serialize ( DataArrayIdType *&  dataInt) const
◆ reprQuickOverview()
