MEDCoupling::TimeLabel Class Referenceabstract
#include <MEDCouplingTimeLabel.hxx>
Inheritance diagram for MEDCoupling::TimeLabel:
void declareAsNew () const
 TimeLabel ()
virtual ~TimeLabel ()
Class representing a label of time of the lastely modified part of this. More _time is high more the object has been modified recently.
◆ TimeLabel() [1/2]
MEDCoupling::TimeLabel::TimeLabel ( const TimeLabel &  other)
default
◆ TimeLabel() [2/2]
TimeLabel::TimeLabel ( )
◆ ~TimeLabel()
TimeLabel::~TimeLabel ( )
◆ operator=()
TimeLabel & TimeLabel::operator= ( const TimeLabel &  other)
◆ declareAsNew()
void TimeLabel::declareAsNew ( ) const
This method should be called when write access has been done on this.
Referenced by MEDCoupling::MEDCouplingCartesianAMRMeshGen::addPatch(), MEDCoupling::MEDCoupling1SGTUMesh::allocateCells(), MEDCoupling::MEDCoupling1DGTUMesh::allocateCells(), MEDCoupling::MEDCouplingUMesh::allocateCells(), MEDCoupling::DataArrayDouble::applyFuncFast32(), MEDCoupling::DataArrayDouble::applyFuncFast64(), MEDCoupling::DataArrayDouble::applyInv(), MEDCoupling::DataArrayDouble::applyPow(), MEDCoupling::DataArrayDouble::applyRPow(), MEDCoupling::MEDCouplingIMesh::copyTinyStringsFrom(), MEDCoupling::MEDCouplingCartesianAMRMeshGen::createPatchesFromCriterion(), MEDCoupling::MEDCouplingCartesianAMRMeshSub::detachFromFather(), MEDCoupling::DataArrayDouble::powEqual(), MEDCoupling::MEDCouplingIMesh::refineWithFactor(), MEDCoupling::MEDCouplingCartesianAMRMeshGen::removeAllPatches(), MEDCoupling::MEDCouplingCartesianAMRMeshGen::removePatch(), MEDCoupling::MEDCouplingCurveLinearMesh::rotate(), MEDCoupling::MEDCouplingPointSet::rotate(), MEDCoupling::MEDCouplingCMesh::scale(), MEDCoupling::MEDCouplingCurveLinearMesh::scale(), MEDCoupling::MEDCouplingIMesh::scale(), MEDCoupling::MEDCouplingPointSet::scale(), MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::setArray(), MEDCoupling::MEDCouplingFieldDiscretizationPerCell::setArrayOfDiscIds(), MEDCoupling::MEDCouplingIMesh::setAxisUnit(), MEDCoupling::MEDCouplingUMesh::setConnectivity(), MEDCoupling::MEDCouplingCurveLinearMesh::setCoords(), MEDCoupling::MEDCouplingPointSet::setCoords(), MEDCoupling::MEDCouplingCMesh::setCoords(), MEDCoupling::MEDCouplingCMesh::setCoordsAt(), MEDCoupling::MEDCouplingField::setDiscretization(), MEDCoupling::MEDCouplingIMesh::setDXYZ(), MEDCoupling::MEDCouplingTwoTimeSteps::setEndArray(), MEDCoupling::MEDCouplingCartesianAMRMeshGen::setFactors(), MEDCoupling::MEDCouplingField::setMesh(), MEDCoupling::MEDCouplingUMesh::setMeshDimension(), MEDCoupling::MEDCoupling1SGTUMesh::setNodalConnectivity(), MEDCoupling::MEDCoupling1DGTUMesh::setNodalConnectivity(), MEDCoupling::MEDCouplingIMesh::setNodeStruct(), MEDCoupling::MEDCouplingIMesh::setOrigin(), MEDCoupling::MEDCouplingIMesh::setSpaceDimension(), MEDCoupling::MEDCoupling1SGTUMesh::sortHexa8EachOther(), MEDCoupling::MEDCouplingCurveLinearMesh::translate(), MEDCoupling::MEDCouplingIMesh::translate(), MEDCoupling::MEDCouplingPointSet::translate(), and MEDCoupling::MEDCouplingIMesh::unserialization().
◆ updateTime()
virtual void MEDCoupling::TimeLabel::updateTime ( ) const
pure virtual
This method should be called on high level classes as Field or Mesh to take into account modifications done in aggregates objects.
Implemented in MEDCoupling::MEDCoupling1SGTUMesh, MEDCoupling::MEDCoupling1DGTUMesh, MEDCoupling::MEDCouplingAMRAttribute, MEDCoupling::MEDCouplingCartesianAMRMeshGen, MEDCoupling::MEDCouplingCMesh, MEDCoupling::MEDCouplingCurveLinearMesh, MEDCoupling::MEDCouplingField, MEDCoupling::MEDCouplingFieldDiscretization, MEDCoupling::MEDCouplingFieldDiscretizationPerCell, MEDCoupling::MEDCouplingFieldDouble, MEDCoupling::MEDCouplingIMesh, MEDCoupling::MEDCouplingMappedExtrudedMesh, MEDCoupling::DataArrayTemplate< T >, MEDCoupling::DataArrayTemplate< char >, MEDCoupling::DataArrayTemplate< double >, MEDCoupling::DataArrayTemplate< float >, MEDCoupling::DataArrayTemplate< Int32 >, MEDCoupling::DataArrayTemplate< Int64 >, MEDCoupling::MEDCouplingPointSet, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< double >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< float >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< Int32 >, MEDCoupling::MEDCouplingTimeDiscretizationTemplate< Int64 >, MEDCoupling::MEDCouplingTwoTimeSteps, and MEDCoupling::MEDCouplingUMesh.
Referenced by MEDCoupling::TimeLabelConstOverseer::checkConst(), MEDCoupling::TimeLabelConstOverseer::keepTrackOfNewTL(), MEDCoupling::TimeLabelConstOverseer::resetState(), and MEDCoupling::TimeLabelConstOverseer::TimeLabelConstOverseer().
◆ getTimeOfThis()
◆ updateTimeWith()
◆ forceTimeOfThis()
void TimeLabel::forceTimeOfThis ( const TimeLabel &  other) const
This method has to be called with a lot of care. It set aggressively the time in this with the time in other.
