MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T > Class Template Referenceabstract
#include <MEDCouplingTimeDiscretization.hxx>
Inheritance diagram for MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >:
Collaboration diagram for MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >:
virtual bool areCompatible (const MEDCouplingTimeDiscretizationTemplate< T > *other) const
virtual bool areStrictlyCompatible (const MEDCouplingTimeDiscretizationTemplate< T > *other, std::string &reason) const
virtual bool areStrictlyCompatibleForDiv (const MEDCouplingTimeDiscretizationTemplate< T > *other) const
virtual bool areStrictlyCompatibleForMul (const MEDCouplingTimeDiscretizationTemplate< T > *other) const
virtual void checkConsistencyLight () const
virtual void checkForUnserialization (const std::vector< mcIdType > &tinyInfoI, const std::vector< typename Traits< T >::ArrayType * > &arrays)
virtual void copyTinyAttrFrom (const MEDCouplingTimeDiscretizationTemplate< T > &other)
virtual void copyTinyStringsFrom (const MEDCouplingTimeDiscretizationTemplate< T > &other)
virtual void finishUnserialization (const std::vector< mcIdType > &tinyInfoI, const std::vector< double > &tinyInfoD, const std::vector< std::string > &tinyInfoS)
Traits< T >::ArrayType * getArray ()
const Traits< T >::ArrayType * getArray () const
virtual void getArrays (std::vector< typename Traits< T >::ArrayType * > &arrays) const
virtual std::vector< const BigMemoryObject * > getDirectChildrenWithNull () const
virtual Traits< T >::ArrayType * getEndArray ()
virtual const Traits< T >::ArrayType * getEndArray () const
virtual double getEndTime (int &iteration, int &order) const =0
virtual TypeOfTimeDiscretization getEnum () const =0
virtual std::size_t getHeapMemorySizeWithoutChildren () const
virtual std::string getStringRepr () const =0
double getTimeTolerance () const
virtual void getTinySerializationDbleInformation (std::vector< double > &tinyInfo) const
virtual void getTinySerializationIntInformation (std::vector< mcIdType > &tinyInfo) const
virtual void getTinySerializationStrInformation (std::vector< std::string > &tinyInfo) const
virtual bool isEqualIfNotWhy (const MEDCouplingTimeDiscretizationTemplate< T > *other, T prec, std::string &reason) const =0
virtual bool isEqualWithoutConsideringStr (const MEDCouplingTimeDiscretizationTemplate< T > *other, T prec) const =0
virtual MEDCouplingTimeDiscretizationTemplate< T > * performCopyOrIncrRef (bool deepCopy) const =0
virtual void resizeForUnserialization (const std::vector< mcIdType > &tinyInfoI, std::vector< typename Traits< T >::ArrayType * > &arrays)
virtual void setArray (typename Traits< T >::ArrayType *array, TimeLabel *owner)
virtual void setArrays (const std::vector< typename Traits< T >::ArrayType * > &arrays, TimeLabel *owner)
virtual void setEndArray (typename Traits< T >::ArrayType *array, TimeLabel *owner)
virtual void setEndIteration (int it)=0
virtual void setEndOrder (int order)=0
virtual void setEndTime (double time, int iteration, int order)=0
virtual void setEndTimeValue (double time)=0
void setIteration (int it)
void setOrder (int order)
virtual void setStartIteration (int it)=0
virtual void setStartOrder (int order)=0
virtual void setStartTime (double time, int iteration, int order)=0
virtual void setStartTimeValue (double time)=0
void setTime (double time, int iteration, int order)
void setTimeTolerance (double val)
void setTimeValue (double val)
void updateTime () const
virtual ~MEDCouplingTimeDiscretizationTemplate ()
void declareAsNew () const
virtual ~BigMemoryObject ()
- Public Member Functions inherited from MEDCoupling::TimeHolder
void copyTinyAttrFrom (const TimeHolder &other)
virtual double getStartTime (int &iteration, int &order) const =0
double getTime (int &iteration, int &order) const
std::string getTimeUnit () const
void setTimeUnit (const std::string &unit)
 MEDCouplingTimeDiscretizationTemplate (const MEDCouplingTimeDiscretizationTemplate< T > &other, bool deepCopy)
 TimeLabel ()
virtual ~TimeLabel ()
- Protected Member Functions inherited from MEDCoupling::TimeHolder
 TimeHolder ()
 TimeHolder (const TimeHolder &other)
virtual ~TimeHolder ()
Traits< T >::ArrayType * _array
double _time_tolerance
Static Protected Attributes
static const double TIME_TOLERANCE_DFT = 1.e-12
◆ ~MEDCouplingTimeDiscretizationTemplate()
◆ MEDCouplingTimeDiscretizationTemplate() [1/2]
template<class T >
MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::MEDCouplingTimeDiscretizationTemplate
◆ MEDCouplingTimeDiscretizationTemplate() [2/2]
template<class T >
MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::MEDCouplingTimeDiscretizationTemplate ( const MEDCouplingTimeDiscretizationTemplate< T > &  other,
bool  deepCopy
◆ updateTime()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::updateTime ( ) const
This method should be called on high level classes as Field or Mesh to take into account modifications done in aggregates objects.
Implements MEDCoupling::TimeLabel.
◆ setArray()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::setArray ( typename Traits< T >::ArrayType *  array,
TimeLabel *  owner
References MEDCoupling::TimeLabel::declareAsNew().
Referenced by MEDCoupling::MEDCouplingNoTimeLabel::add(), MEDCoupling::MEDCouplingWithTimeStep::add(), MEDCoupling::MEDCouplingConstOnTimeInterval::add(), MEDCoupling::MEDCouplingLinearTime::add(), MEDCoupling::MEDCouplingNoTimeLabel::aggregate(), MEDCoupling::MEDCouplingWithTimeStep::aggregate(), MEDCoupling::MEDCouplingConstOnTimeInterval::aggregate(), MEDCoupling::MEDCouplingLinearTime::aggregate(), MEDCoupling::MEDCouplingTimeDiscretization::buildNewTimeReprFromThis(), MEDCoupling::MEDCouplingNoTimeLabel::crossProduct(), MEDCoupling::MEDCouplingWithTimeStep::crossProduct(), MEDCoupling::MEDCouplingConstOnTimeInterval::crossProduct(), MEDCoupling::MEDCouplingLinearTime::crossProduct(), MEDCoupling::MEDCouplingNoTimeLabel::divide(), MEDCoupling::MEDCouplingWithTimeStep::divide(), MEDCoupling::MEDCouplingConstOnTimeInterval::divide(), MEDCoupling::MEDCouplingLinearTime::divide(), MEDCoupling::MEDCouplingNoTimeLabel::dot(), MEDCoupling::MEDCouplingWithTimeStep::dot(), MEDCoupling::MEDCouplingConstOnTimeInterval::dot(), MEDCoupling::MEDCouplingLinearTime::dot(), MEDCoupling::MEDCouplingNoTimeLabel::max(), MEDCoupling::MEDCouplingWithTimeStep::max(), MEDCoupling::MEDCouplingConstOnTimeInterval::max(), MEDCoupling::MEDCouplingLinearTime::max(), MEDCoupling::MEDCouplingNoTimeLabel::meld(), MEDCoupling::MEDCouplingWithTimeStep::meld(), MEDCoupling::MEDCouplingConstOnTimeInterval::meld(), MEDCoupling::MEDCouplingLinearTime::meld(), MEDCoupling::MEDCouplingNoTimeLabel::min(), MEDCoupling::MEDCouplingWithTimeStep::min(), MEDCoupling::MEDCouplingConstOnTimeInterval::min(), MEDCoupling::MEDCouplingLinearTime::min(), MEDCoupling::MEDCouplingNoTimeLabel::multiply(), MEDCoupling::MEDCouplingWithTimeStep::multiply(), MEDCoupling::MEDCouplingConstOnTimeInterval::multiply(), MEDCoupling::MEDCouplingLinearTime::multiply(), MEDCoupling::MEDCouplingNoTimeLabel::pow(), MEDCoupling::MEDCouplingWithTimeStep::pow(), MEDCoupling::MEDCouplingConstOnTimeInterval::pow(), MEDCoupling::MEDCouplingLinearTime::pow(), MEDCoupling::MEDCouplingNoTimeLabel::substract(), MEDCoupling::MEDCouplingWithTimeStep::substract(), MEDCoupling::MEDCouplingConstOnTimeInterval::substract(), and MEDCoupling::MEDCouplingLinearTime::substract().
◆ getArray() [1/2]
template<class T >
Traits< T >::ArrayType * MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::getArray ( )
References MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::_array.
Referenced by MEDCoupling::MEDCouplingNoTimeLabel::add(), MEDCoupling::MEDCouplingWithTimeStep::add(), MEDCoupling::MEDCouplingConstOnTimeInterval::add(), MEDCoupling::MEDCouplingLinearTime::add(), MEDCoupling::MEDCouplingNoTimeLabel::addEqual(), MEDCoupling::MEDCouplingWithTimeStep::addEqual(), MEDCoupling::MEDCouplingConstOnTimeInterval::addEqual(), MEDCoupling::MEDCouplingLinearTime::addEqual(), MEDCoupling::MEDCouplingNoTimeLabel::aggregate(), MEDCoupling::MEDCouplingWithTimeStep::aggregate(), MEDCoupling::MEDCouplingConstOnTimeInterval::aggregate(), MEDCoupling::MEDCouplingLinearTime::aggregate(), MEDCoupling::MEDCouplingNoTimeLabel::crossProduct(), MEDCoupling::MEDCouplingWithTimeStep::crossProduct(), MEDCoupling::MEDCouplingConstOnTimeInterval::crossProduct(), MEDCoupling::MEDCouplingLinearTime::crossProduct(), MEDCoupling::MEDCouplingNoTimeLabel::divide(), MEDCoupling::MEDCouplingWithTimeStep::divide(), MEDCoupling::MEDCouplingConstOnTimeInterval::divide(), MEDCoupling::MEDCouplingLinearTime::divide(), MEDCoupling::MEDCouplingNoTimeLabel::divideEqual(), MEDCoupling::MEDCouplingWithTimeStep::divideEqual(), MEDCoupling::MEDCouplingConstOnTimeInterval::divideEqual(), MEDCoupling::MEDCouplingLinearTime::divideEqual(), MEDCoupling::MEDCouplingNoTimeLabel::dot(), MEDCoupling::MEDCouplingWithTimeStep::dot(), MEDCoupling::MEDCouplingConstOnTimeInterval::dot(), MEDCoupling::MEDCouplingLinearTime::dot(), MEDCoupling::MEDCouplingFieldDouble::getValueOn(), MEDCoupling::MEDCouplingFieldDouble::getValueOnMulti(), MEDCoupling::MEDCouplingFieldDouble::getValueOnPos(), MEDCoupling::MEDCouplingTimeDiscretization::isEqualIfNotWhy(), MEDCoupling::MEDCouplingTimeDiscretizationFloat::isEqualIfNotWhy(), MEDCoupling::MEDCouplingTimeDiscretizationInt32::isEqualIfNotWhy(), MEDCoupling::MEDCouplingTimeDiscretizationInt64::isEqualIfNotWhy(), MEDCoupling::MEDCouplingTimeDiscretization::isEqualWithoutConsideringStr(), MEDCoupling::MEDCouplingTimeDiscretizationFloat::isEqualWithoutConsideringStr(), MEDCoupling::MEDCouplingTimeDiscretizationInt32::isEqualWithoutConsideringStr(), MEDCoupling::MEDCouplingTimeDiscretizationInt64::isEqualWithoutConsideringStr(), MEDCoupling::MEDCouplingNoTimeLabel::max(), MEDCoupling::MEDCouplingWithTimeStep::max(), MEDCoupling::MEDCouplingConstOnTimeInterval::max(), MEDCoupling::MEDCouplingLinearTime::max(), MEDCoupling::MEDCouplingNoTimeLabel::meld(), MEDCoupling::MEDCouplingWithTimeStep::meld(), MEDCoupling::MEDCouplingConstOnTimeInterval::meld(), MEDCoupling::MEDCouplingLinearTime::meld(), MEDCoupling::MEDCouplingNoTimeLabel::min(), MEDCoupling::MEDCouplingWithTimeStep::min(), MEDCoupling::MEDCouplingConstOnTimeInterval::min(), MEDCoupling::MEDCouplingLinearTime::min(), MEDCoupling::MEDCouplingNoTimeLabel::multiply(), MEDCoupling::MEDCouplingWithTimeStep::multiply(), MEDCoupling::MEDCouplingConstOnTimeInterval::multiply(), MEDCoupling::MEDCouplingLinearTime::multiply(), MEDCoupling::MEDCouplingNoTimeLabel::multiplyEqual(), MEDCoupling::MEDCouplingWithTimeStep::multiplyEqual(), MEDCoupling::MEDCouplingConstOnTimeInterval::multiplyEqual(), MEDCoupling::MEDCouplingLinearTime::multiplyEqual(), MEDCoupling::MEDCouplingNoTimeLabel::pow(), MEDCoupling::MEDCouplingWithTimeStep::pow(), MEDCoupling::MEDCouplingConstOnTimeInterval::pow(), MEDCoupling::MEDCouplingLinearTime::pow(), MEDCoupling::MEDCouplingNoTimeLabel::powEqual(), MEDCoupling::MEDCouplingWithTimeStep::powEqual(), MEDCoupling::MEDCouplingConstOnTimeInterval::powEqual(), MEDCoupling::MEDCouplingLinearTime::powEqual(), MEDCoupling::MEDCouplingNoTimeLabel::substract(), MEDCoupling::MEDCouplingWithTimeStep::substract(), MEDCoupling::MEDCouplingConstOnTimeInterval::substract(), MEDCoupling::MEDCouplingLinearTime::substract(), MEDCoupling::MEDCouplingNoTimeLabel::substractEqual(), MEDCoupling::MEDCouplingWithTimeStep::substractEqual(), MEDCoupling::MEDCouplingConstOnTimeInterval::substractEqual(), and MEDCoupling::MEDCouplingLinearTime::substractEqual().
◆ getArray() [2/2]
template<class T >
const Traits< T >::ArrayType * MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::getArray ( ) const
◆ setTimeTolerance()
◆ getTimeTolerance()
◆ setTime()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::setTime ( double  time,
int  iteration,
int  order
◆ setIteration()
◆ setOrder()
◆ setTimeValue()
◆ setStartIteration()
◆ setStartOrder()
◆ setStartTime()
◆ setStartTimeValue()
◆ getEndTime()
◆ setEndIteration()
◆ setEndOrder()
◆ setEndTimeValue()
◆ setEndTime()
◆ setEndArray()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::setEndArray ( typename Traits< T >::ArrayType *  array,
TimeLabel *  owner
◆ setArrays()
◆ getEndArray() [1/2]
◆ getEndArray() [2/2]
template<class T >
Traits< T >::ArrayType * MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::getEndArray
◆ getArrays()
◆ getStringRepr()
◆ getEnum()
◆ performCopyOrIncrRef()
◆ copyTinyAttrFrom()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::copyTinyAttrFrom ( const MEDCouplingTimeDiscretizationTemplate< T > &  other)
◆ copyTinyStringsFrom()
◆ checkConsistencyLight()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::checkConsistencyLight
◆ getHeapMemorySizeWithoutChildren()
template<class T >
std::size_t MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::getHeapMemorySizeWithoutChildren
◆ getDirectChildrenWithNull()
template<class T >
std::vector< const BigMemoryObject * > MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::getDirectChildrenWithNull
◆ isEqualIfNotWhy()
◆ isEqualWithoutConsideringStr()
◆ areStrictlyCompatible()
template<class T >
bool MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::areStrictlyCompatible ( const MEDCouplingTimeDiscretizationTemplate< T > *  other,
std::string &  reason
◆ areCompatible()
◆ areStrictlyCompatibleForMul()
◆ areStrictlyCompatibleForDiv()
◆ getTinySerializationIntInformation()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::getTinySerializationIntInformation ( std::vector< mcIdType > &  tinyInfo) const
◆ getTinySerializationDbleInformation()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::getTinySerializationDbleInformation ( std::vector< double > &  tinyInfo) const
◆ getTinySerializationStrInformation()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::getTinySerializationStrInformation ( std::vector< std::string > &  tinyInfo) const
◆ resizeForUnserialization()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::resizeForUnserialization ( const std::vector< mcIdType > &  tinyInfoI,
std::vector< typename Traits< T >::ArrayType * > &  arrays
◆ checkForUnserialization()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::checkForUnserialization ( const std::vector< mcIdType > &  tinyInfoI,
const std::vector< typename Traits< T >::ArrayType * > &  arrays
◆ finishUnserialization()
template<class T >
void MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::finishUnserialization ( const std::vector< mcIdType > &  tinyInfoI,
const std::vector< double > &  tinyInfoD,
const std::vector< std::string > &  tinyInfoS
◆ _time_tolerance
◆ _array
◆ TIME_TOLERANCE_DFT
template<class T >
const double MEDCoupling::MEDCouplingTimeDiscretizationTemplate< T >::TIME_TOLERANCE_DFT = 1.e-12
staticprotected
