MEDCoupling::MEDCouplingField Class Referenceabstract
#include <MEDCouplingField.hxx>
Inheritance diagram for MEDCoupling::MEDCouplingField:
Collaboration diagram for MEDCoupling::MEDCouplingField:
virtual bool areCompatibleForMerge (const MEDCouplingField *other) const
virtual bool areStrictlyCompatible (const MEDCouplingField *other) const
virtual bool areStrictlyCompatibleForMulDiv (const MEDCouplingField *other) const
MEDCouplingFieldDouble * buildMeasureField (bool isAbs) const
MEDCouplingMesh * buildSubMeshData (const mcIdType *start, const mcIdType *end, DataArrayIdType *&di) const
MEDCouplingMesh * buildSubMeshDataRange (mcIdType begin, mcIdType end, mcIdType step, mcIdType &beginOut, mcIdType &endOut, mcIdType &stepOut, DataArrayIdType *&di) const
virtual void checkConsistencyLight () const
void clearGaussLocalizations ()
DataArrayIdType * computeTupleIdsToSelectFromCellIds (const mcIdType *startCellIds, const mcIdType *endCellIds) const
virtual void copyTinyStringsFrom (const MEDCouplingField *other)
void getCellIdsHavingGaussLocalization (int locId, std::vector< mcIdType > &cellIds) const
std::string getDescription () const
MEDCouplingFieldDiscretization * getDiscretization ()
const MEDCouplingFieldDiscretization * getDiscretization () const
MEDCouplingGaussLocalization & getGaussLocalization (int locId)
const MEDCouplingGaussLocalization & getGaussLocalization (int locId) const
mcIdType getGaussLocalizationIdOfOneCell (mcIdType cellId) const
mcIdType getGaussLocalizationIdOfOneType (INTERP_KERNEL::NormalizedCellType type) const
std::set< mcIdType > getGaussLocalizationIdsOfOneType (INTERP_KERNEL::NormalizedCellType type) const
DataArrayDouble * getLocalizationOfDiscr () const
MEDCoupling::MEDCouplingMesh * getMesh ()
const MEDCoupling::MEDCouplingMesh * getMesh () const
std::string getName () const
NatureOfField getNature () const
mcIdType getNbOfGaussLocalization () const
mcIdType getNumberOfMeshPlacesExpected () const
mcIdType getNumberOfTuplesExpected () const
mcIdType getNumberOfTuplesExpectedRegardingCode (const std::vector< mcIdType > &code, const std::vector< const DataArrayIdType * > &idsPerType) const
TypeOfField getTypeOfField () const
virtual void reprQuickOverview (std::ostream &stream) const =0
void setDescription (const std::string &desc)
void setDiscretization (MEDCouplingFieldDiscretization *newDisc)
void setGaussLocalizationOnCells (const mcIdType *begin, const mcIdType *end, const std::vector< double > &refCoo, const std::vector< double > &gsCoo, const std::vector< double > &wg)
void setGaussLocalizationOnType (INTERP_KERNEL::NormalizedCellType type, const std::vector< double > &refCoo, const std::vector< double > &gsCoo, const std::vector< double > &wg)
void setMesh (const MEDCoupling::MEDCouplingMesh *mesh)
virtual void setNature (NatureOfField nat)
void updateTime () const
bool decrRef () const
int getRCValue () const
void incrRef () const
virtual ~BigMemoryObject ()
void declareAsNew () const
bool isEqualIfNotWhyProtected (const MEDCouplingField *other, double meshPrec, std::string &reason) const
bool isEqualWithoutConsideringStrProtected (const MEDCouplingField *other, double meshPrec) const
 MEDCouplingField (const MEDCouplingField &other, bool deepCopy=true)
 MEDCouplingField (MEDCouplingFieldDiscretization *type, NatureOfField nature=NoNature)
 MEDCouplingField (TypeOfField type)
virtual ~MEDCouplingField ()
 RefCountObject ()
virtual ~RefCountObject ()
 RefCountObjectOnly ()
 TimeLabel ()
virtual ~TimeLabel ()
std::string _desc
const MEDCouplingMesh * _mesh
NatureOfField _nature
MCAuto< MEDCouplingFieldDiscretization > _type
◆ MEDCouplingField() [1/3]
MEDCouplingField::MEDCouplingField ( TypeOfField  type)
◆ MEDCouplingField() [2/3]
MEDCouplingField::MEDCouplingField ( const MEDCouplingField &  other,
bool  deepCopy = true
◆ MEDCouplingField() [3/3]
MEDCouplingField::MEDCouplingField ( MEDCouplingFieldDiscretization *  type,
NatureOfField  nature = NoNature
◆ ~MEDCouplingField()
MEDCouplingField::~MEDCouplingField ( )
◆ checkConsistencyLight()
void MEDCouplingField::checkConsistencyLight ( ) const
◆ areCompatibleForMerge()
bool MEDCouplingField::areCompatibleForMerge ( const MEDCouplingField *  other) const
This method states if 'this' and 'other' are compatibles each other before performing any treatment. This method is good for methods like : mergeFields. This method is not very demanding compared to areStrictlyCompatible that is better for operation on fields.
Reimplemented in MEDCoupling::MEDCouplingFieldDouble.
References _mesh, _nature, _type, and MEDCoupling::MEDCouplingMesh::areCompatibleForMerge().
Referenced by MEDCoupling::MEDCouplingFieldDouble::areCompatibleForMerge().
◆ areStrictlyCompatible()
bool MEDCouplingField::areStrictlyCompatible ( const MEDCouplingField *  other) const
This method is more strict than MEDCouplingField::areCompatibleForMerge method. This method is used for operation on fields to operate a first check before attempting operation.
Reimplemented in MEDCoupling::MEDCouplingFieldT< T >, and MEDCoupling::MEDCouplingFieldT< double >.
References _mesh, _nature, and _type.
Referenced by MEDCoupling::MEDCouplingFieldDouble::areCompatibleForMeld(), and MEDCoupling::MEDCouplingFieldT< T >::areStrictlyCompatible().
◆ areStrictlyCompatibleForMulDiv()
bool MEDCouplingField::areStrictlyCompatibleForMulDiv ( const MEDCouplingField *  other) const
This method is less strict than MEDCouplingField::areStrictlyCompatible method. The difference is that the nature is not checked. This method is used for multiplication and division on fields to operate a first check before attempting operation.
References _mesh, and _type.
Referenced by MEDCoupling::MEDCouplingFieldT< T >::areCompatibleForDiv(), MEDCoupling::MEDCouplingFieldT< T >::areCompatibleForMul(), and MEDCoupling::MEDCouplingFieldT< T >::areStrictlyCompatibleForMulDiv().
◆ copyTinyStringsFrom()
void MEDCouplingField::copyTinyStringsFrom ( const MEDCouplingField *  other)
Copy tiny info (component names, name, description) but warning the underlying mesh is not renamed (for safety reason).
References _desc, _name, setDescription(), and setName().
Referenced by MEDCoupling::MEDCouplingFieldT< T >::copyTinyStringsFrom().
◆ setMesh()
◆ getMesh() [1/2]
const MEDCoupling::MEDCouplingMesh * MEDCoupling::MEDCouplingField::getMesh ( ) const
References _mesh.
Referenced by MEDCoupling::MEDCouplingFieldDouble::AddFields(), MEDCoupling::DisjointDEC::attachLocalField(), MEDCoupling::OverlapDEC::attachSourceLocalField(), MEDCoupling::OverlapDEC::attachTargetLocalField(), MEDCoupling::MEDCouplingFieldDouble::buildNewTimeReprFromThis(), MEDCoupling::MEDCouplingFieldDouble::cellToNodeDiscretization(), MEDCoupling::MEDCouplingFieldDouble::computeVectorFieldCyl(), MEDCoupling::MEDCouplingFieldDouble::convertQuadraticCellsToLinear(), MEDCoupling::MEDFileAnyTypeFieldMultiTSWithoutSDA::copyTinyInfoFrom(), MEDCoupling::MEDFileAnyTypeField1TSWithoutSDA::copyTinyInfoFrom(), MEDCoupling::MEDCouplingFieldDouble::CrossProductFields(), MEDCoupling::MEDCouplingFieldDouble::determinant(), MEDCoupling::MEDCouplingFieldDouble::deviator(), MEDCoupling::MEDCouplingFieldDouble::DivideFields(), MEDCoupling::MEDCouplingFieldDouble::DotFields(), MEDCoupling::MEDCouplingFieldDouble::doublyContractedProduct(), MEDCoupling::MEDCouplingFieldDouble::eigenValues(), MEDCoupling::MEDCouplingFieldDouble::eigenVectors(), MEDCoupling::MEDCouplingFieldDouble::extractSlice3D(), MEDCoupling::MEDCouplingFieldDouble::inverse(), MEDCoupling::MEDCouplingFieldDouble::keepSelectedComponents(), MEDCoupling::MEDCouplingFieldDouble::locateDotSignChangeFor(), MEDCoupling::MEDCouplingFieldDouble::magnitude(), MEDCoupling::MEDCouplingFieldDouble::MaxFields(), MEDCoupling::MEDCouplingFieldDouble::maxPerTuple(), MEDCoupling::MEDCouplingFieldDouble::MeldFields(), MEDCoupling::MEDCouplingFieldDouble::MergeFields(), MEDCoupling::MEDCouplingFieldDouble::MinFields(), MEDCoupling::MEDCouplingFieldDouble::MultiplyFields(), MEDCoupling::MEDCouplingFieldDouble::negate(), MEDCoupling::MEDCouplingFieldDouble::nodeToCellDiscretization(), MEDCoupling::MEDCouplingFieldDouble::PowFields(), MEDCoupling::MEDFileAnyTypeField1TSWithoutSDA::setFieldNoProfileSBT(), MEDCoupling::MEDCouplingFieldDouble::SubstractFields(), MEDCoupling::MEDCouplingFieldDouble::substractInPlaceDM(), MEDCoupling::MEDCouplingFieldDouble::trace(), MEDCoupling::MEDCouplingFieldDouble::voronoize(), and MEDCoupling::MEDCouplingFieldDouble::WriteVTK().
◆ getMesh() [2/2]
References _mesh.
◆ setName()
void MEDCoupling::MEDCouplingField::setName ( const std::string &  name)
◆ getDescription()
◆ setDescription()
void MEDCoupling::MEDCouplingField::setDescription ( const std::string &  desc)
◆ getName()
◆ getTypeOfField()
◆ getNature()
NatureOfField MEDCouplingField::getNature ( ) const
Returns the nature of this field. This information is very important during interpolation process using MEDCoupling::MEDCouplingRemapper or MEDCoupling::InterpKernelDEC. In other context than the two mentioned above, this attribute is unimportant. This attribute is not stored in the MED file. For more information of the semantics and the influence of this attribute to the result of interpolation, see
References _nature.
Referenced by MEDCoupling::MEDCouplingFieldDouble::AddFields(), MEDCoupling::MEDCouplingFieldDouble::buildNewTimeReprFromThis(), MEDCoupling::MEDCouplingFieldDouble::computeVectorFieldCyl(), MEDCoupling::MEDCouplingFieldDouble::determinant(), MEDCoupling::MEDCouplingFieldDouble::deviator(), MEDCoupling::MEDCouplingFieldDouble::doublyContractedProduct(), MEDCoupling::MEDCouplingFieldDouble::eigenValues(), MEDCoupling::MEDCouplingFieldDouble::eigenVectors(), MEDCoupling::MEDCouplingFieldDouble::inverse(), MEDCoupling::MEDCouplingFieldDouble::keepSelectedComponents(), MEDCoupling::MEDCouplingFieldDouble::magnitude(), MEDCoupling::MEDCouplingFieldDouble::MaxFields(), MEDCoupling::MEDCouplingFieldDouble::maxPerTuple(), MEDCoupling::MEDCouplingFieldDouble::MeldFields(), MEDCoupling::MEDCouplingFieldDouble::MergeFields(), MEDCoupling::MEDCouplingFieldDouble::MinFields(), MEDCoupling::MEDCouplingFieldDouble::negate(), MEDCoupling::MEDCouplingRemapper::reverseTransfer(), MEDCoupling::MEDCouplingRemapper::reverseTransferField(), MEDCoupling::MEDCouplingFieldDouble::SubstractFields(), MEDCoupling::MEDCouplingFieldDouble::trace(), and MEDCoupling::MEDCouplingRemapper::transferField().
◆ setNature()
void MEDCouplingField::setNature ( NatureOfField  nat)
Sets the nature of this field. This information is very important during interpolation process using MEDCoupling::MEDCouplingRemapper or MEDCoupling::InterpKernelDEC. In other context than the two mentioned above, this attribute is unimportant. This attribute is not stored in the MED file. For more information of the semantics and the influence of this attribute to the result of interpolation, see
[in]nat- the nature of this field.
Exceptions
Ifnat has an invalid value.
References _nature, _type, and MEDCoupling::MEDCouplingNatureOfField::GetRepr().
Referenced by MEDCoupling::MEDCouplingRemapper::reverseTransferField(), and MEDCoupling::DisjointDEC::setNature().
◆ getLocalizationOfDiscr()
DataArrayDouble * MEDCouplingField::getLocalizationOfDiscr ( ) const
Returns coordinates of field location points that depend on spatial discretization of this field.
  • For a field on nodes, returns coordinates of nodes.
  • For a field on cells, returns barycenters of cells.
  • For a field on gauss points, returns coordinates of gauss points.
    DataArrayDouble * - a new instance of DataArrayDouble. The caller is to delete this array using decrRef() as it is no more needed.
    Exceptions
    Ifthe spatial discretization of this field is NULL.
    Ifthe mesh is not set.
◆ buildMeasureField()
MEDCouplingFieldDouble * MEDCouplingField::buildMeasureField ( bool  isAbs) const
Returns a new MEDCouplingFieldDouble containing volumes of cells of a dual mesh whose cells are constructed around field location points (getLocalizationOfDiscr()) of this field. (In case of a field on cells, the dual mesh coincides with the underlying mesh).
For 1D cells, the returned field contains lengths.
For 2D cells, the returned field contains areas.
For 3D cells, the returned field contains volumes.
[in]isAbs- if true, the computed cell volume does not reflect cell orientation, i.e. the volume is always positive.
MEDCouplingFieldDouble * - a new instance of MEDCouplingFieldDouble. The caller is to delete this array using decrRef() as it is no more needed.
Exceptions
Ifthe spatial discretization of this field is not well defined.
Referenced by MEDCoupling::MEDCouplingFieldDouble::getWeightedAverageValue().
◆ buildSubMeshData()
MEDCouplingMesh * MEDCouplingField::buildSubMeshData ( const mcIdType *  start,
const mcIdType *  end,
DataArrayIdType *&  di
Returns a new MEDCouplingMesh constituted by some cells of the underlying mesh of this field, and returns ids of entities (nodes, cells, Gauss points) lying on the specified cells. The cells to include to the result mesh are specified by an array of cell ids. The new mesh shares the coordinates array with the underlying mesh.
[in]start- an array of cell ids to include to the result mesh.
[in]end- specifies the end of the array start, so that the last value of start is end[ -1 ].
[out]di- a new instance of DataArrayIdType holding the ids of entities (nodes, cells, Gauss points). The caller is to delete this array using decrRef() as it is no more needed.
MEDCouplingMesh * - a new instance of MEDCouplingMesh. The caller is to delete this mesh using decrRef() as it is no more needed.
Exceptions
See also
buildSubMeshDataRange()
◆ buildSubMeshDataRange()
MEDCouplingMesh * MEDCouplingField::buildSubMeshDataRange ( mcIdType  begin,
mcIdType  end,
mcIdType  step,
mcIdType &  beginOut,
mcIdType &  endOut,
mcIdType &  stepOut,
This method returns a submesh of 'mesh' instance constituting cell ids defined by a range given by the 3 following inputs begin, end and step.
[out]beginOutValid only if di is NULL
[out]endOutValid only if di is NULL
[out]stepOutValid only if di is NULL
[out]diis an array returned that specifies entity ids (nodes, cells, Gauss points... ) in array if no output range is foundable.
See also
◆ computeTupleIdsToSelectFromCellIds()
DataArrayIdType * MEDCouplingField::computeTupleIdsToSelectFromCellIds ( const mcIdType *  startCellIds,
const mcIdType *  endCellIds
This method returns tuples ids implied by the mesh selection of the cell ids contained in array defined as an interval [start;end).
a newly allocated DataArrayIdType instance containing tuples ids.
Referenced by MEDCoupling::MEDCouplingFieldDouble::extractSlice3D().
◆ getDiscretization() [1/2]
◆ getDiscretization() [2/2]
MEDCouplingFieldDiscretization * MEDCoupling::MEDCouplingField::getDiscretization ( )
References _type.
◆ setDiscretization()
void MEDCouplingField::setDiscretization ( MEDCouplingFieldDiscretization *  newDisc)
◆ getNumberOfTuplesExpected()
mcIdType MEDCouplingField::getNumberOfTuplesExpected ( ) const
Returns number of tuples expected regarding the spatial discretization of this field and number of entities in the underlying mesh. This method behaves exactly as MEDCouplingFieldDouble::getNumberOfTuples.
mcIdType - the number of expected tuples.
Exceptions
Referenced by MEDCoupling::MEDCouplingRemapper::reverseTransfer(), and MEDCoupling::MEDCouplingRemapper::setCrudeMatrixEx().
◆ getNumberOfMeshPlacesExpected()
mcIdType MEDCouplingField::getNumberOfMeshPlacesExpected ( ) const
Returns number of mesh entities in the underlying mesh of this field regarding the spatial discretization.
mcIdType - the number of mesh entities porting the field values.
Exceptions
◆ setGaussLocalizationOnType()
void MEDCouplingField::setGaussLocalizationOnType ( INTERP_KERNEL::NormalizedCellType  type,
const std::vector< double > &  refCoo,
const std::vector< double > &  gsCoo,
const std::vector< double > &  wg
Sets localization of Gauss points for a given geometric type of cell.
[in]type- the geometric type of cell for which the Gauss localization is set.
[in]refCoo- coordinates of points of the reference cell. Size of this vector must be nbOfNodesPerCell * dimOfType.
[in]gsCoo- coordinates of Gauss points on the reference cell. Size of this vector must be wg.size() * dimOfType.
[in]wg- the weights of Gauss points.
Exceptions
Ifthis field is not on Gauss points.
Ifsize of any vector do not match the type.
◆ setGaussLocalizationOnCells()
void MEDCouplingField::setGaussLocalizationOnCells ( const mcIdType *  begin,
Sets localization of Gauss points for given cells specified by their ids.
[in]begin- an array of cell ids of interest.
[in]end- the end of begin, i.e. a pointer to its (last+1)-th element.
Exceptions
Ifsize of any vector do not match the type of cell # begin[0].
Iftype of any cell in begin differs from that of cell # begin[0].
Ifthe range [begin,end) is empty.
◆ clearGaussLocalizations()
void MEDCouplingField::clearGaussLocalizations ( )
Clears data on Gauss points localization.
Exceptions
References _type.
◆ getGaussLocalization() [1/2]
MEDCouplingGaussLocalization & MEDCouplingField::getGaussLocalization ( int  locId)
Returns a reference to the Gauss localization object by its id.
Warning
This method is not const, so the returned object can be modified without any problem.
[in]locId- the id of the Gauss localization object of interest. It must be in range 0 <= locId < getNbOfGaussLocalization() .
the Gauss localization object as a MEDCouplingGaussLocalization &. Gauss localization object.
Exceptions
IflocId is not within the valid range.
References _type.
◆ getGaussLocalizationIdOfOneType()
mcIdType MEDCouplingField::getGaussLocalizationIdOfOneType ( INTERP_KERNEL::NormalizedCellType  type) const
Returns an id of the Gauss localization object corresponding to a given cell type.
[in]type- the cell type of interest.
mcIdType - the id of the Gauss localization object.
Exceptions
Ifno Gauss localization object found for the given cell type.
Ifmore than one Gauss localization object found for the given cell type.
References _type.
◆ getGaussLocalizationIdsOfOneType()
std::set< mcIdType > MEDCouplingField::getGaussLocalizationIdsOfOneType ( INTERP_KERNEL::NormalizedCellType  type) const
Returns ids of Gauss localization objects corresponding to a given cell type.
std::set<mcIdType> - ids of the Gauss localization object.
Exceptions
References _type.
◆ getNbOfGaussLocalization()
mcIdType MEDCouplingField::getNbOfGaussLocalization ( ) const
Returns number of Gauss localization objects available. Implicitly all ids in [0,getNbOfGaussLocalization()) are valid Gauss localization ids.
mcIdType - the number of available Gauss localization objects.
Exceptions
References _type.
◆ getGaussLocalizationIdOfOneCell()
mcIdType MEDCouplingField::getGaussLocalizationIdOfOneCell ( mcIdType  cellId) const
Returns an id of the Gauss localization object corresponding to a type of a given cell.
[in]cellId- an id of the cell of interest.
Exceptions
Ifno Gauss localization object found for the given cell.
References _type.
◆ getCellIdsHavingGaussLocalization()
void MEDCouplingField::getCellIdsHavingGaussLocalization ( int  locId,
std::vector< mcIdType > &  cellIds
Returns ids of cells that share the same Gauss localization given by its id.
[in,out]cellIds- a vector returning ids of found cells. It is cleared before filling in. It remains empty if no cells found.
Exceptions
References _type.
◆ getGaussLocalization() [2/2]
const MEDCouplingGaussLocalization & MEDCouplingField::getGaussLocalization ( int  locId) const
Warning
This method is const, so the returned object is not apt for modification.
const MEDCouplingGaussLocalization & - the Gauss localization object.
Exceptions
References _type.
◆ updateTime()
void MEDCouplingField::updateTime ( ) const
This method should be called on high level classes as Field or Mesh to take into account modifications done in aggregates objects.
Implements MEDCoupling::TimeLabel.
References _mesh, _type, and MEDCoupling::TimeLabel::updateTimeWith().
Referenced by MEDCoupling::MEDCouplingFieldDouble::updateTime().
◆ getHeapMemorySizeWithoutChildren()
std::size_t MEDCouplingField::getHeapMemorySizeWithoutChildren ( ) const
◆ getDirectChildrenWithNull()
std::vector< const BigMemoryObject * > MEDCouplingField::getDirectChildrenWithNull ( ) const
◆ getNumberOfTuplesExpectedRegardingCode()
mcIdType MEDCouplingField::getNumberOfTuplesExpectedRegardingCode ( const std::vector< mcIdType > &  code,
const std::vector< const DataArrayIdType * > &  idsPerType
This method computes the number of tuples a DataArrayDouble instance should have to build a correct MEDCouplingFieldDouble instance starting from a submesh of a virtual mesh on which a substraction per type had been applied regarding the spatial discretization in this.
For spatial discretization not equal to ON_GAUSS_NE this method will make the hypothesis that any positive entity id in code idsPerType is valid. So in those cases attribute _mesh of this is ignored.
For spatial discretization equal to ON_GAUSS_NE _mesh attribute will be taken into account.
The input code is those implemented in MEDCouplingUMesh::splitProfilePerType.
[in]code- a code with format described above.
[in]idsPerType- a list of subparts
Exceptions
Ifthis has no spatial discretization set.
Ifinput code point to invalid zones in spatial discretization.
Ifspatial discretization in this requires a mesh and those mesh is invalid (null,...)
References _type, and MEDCoupling::MEDCouplingFieldDiscretization::getNumberOfTuplesExpectedRegardingCode().
Referenced by MEDCoupling::MEDFileAnyTypeField1TSWithoutSDA::setFieldProfile().
◆ reprQuickOverview()
virtual void MEDCoupling::MEDCouplingField::reprQuickOverview ( std::ostream &  stream) const
pure virtual
◆ isEqualIfNotWhyProtected()
bool MEDCouplingField::isEqualIfNotWhyProtected ( const MEDCouplingField *  other,
double  meshPrec,
std::string &  reason
◆ isEqualWithoutConsideringStrProtected()
bool MEDCouplingField::isEqualWithoutConsideringStrProtected ( const MEDCouplingField *  other,
double  meshPrec
Checks if this and another MEDCouplingField are equal. The textual information like names etc. is not considered.
[in]other- the field to compare with this one.
[in]meshPrec- precision used to compare node coordinates of the underlying mesh.
bool - true if the two fields are equal, false else.
Exceptions
Ifother is NULL.
References _mesh, _nature, _type, and MEDCoupling::MEDCouplingMesh::isEqualWithoutConsideringStr().
Referenced by MEDCoupling::MEDCouplingFieldTemplate::isEqualWithoutConsideringStr().
◆ _name
◆ _desc
◆ _nature
◆ _mesh
const MEDCouplingMesh* MEDCoupling::MEDCouplingField::_mesh
Referenced by MEDCoupling::MEDCouplingFieldDouble::advancedRepr(), MEDCoupling::MEDCouplingFieldDouble::applyFunc(), areCompatibleForMerge(), areStrictlyCompatible(), areStrictlyCompatibleForMulDiv(), buildMeasureField(), buildSubMeshData(), buildSubMeshDataRange(), MEDCoupling::MEDCouplingFieldDouble::changeUnderlyingMesh(), checkConsistencyLight(), MEDCoupling::MEDCouplingFieldTemplate::checkConsistencyLight(), computeTupleIdsToSelectFromCellIds(), MEDCoupling::MEDCouplingFieldDouble::fillFromAnalytic(), MEDCoupling::MEDCouplingFieldDouble::fillFromAnalyticCompo(), MEDCoupling::MEDCouplingFieldDouble::fillFromAnalyticNamedCompo(), getDirectChildrenWithNull(), MEDCoupling::MEDCouplingFieldDouble::getIJK(), getLocalizationOfDiscr(), getMesh(), getNumberOfMeshPlacesExpected(), MEDCoupling::MEDCouplingFieldDouble::getNumberOfTuples(), getNumberOfTuplesExpected(), MEDCoupling::MEDCouplingFieldDouble::getValueOn(), MEDCoupling::MEDCouplingFieldDouble::getValueOnMulti(), MEDCoupling::MEDCouplingFieldDouble::getValueOnPos(), MEDCoupling::MEDCouplingFieldDouble::integral(), isEqualIfNotWhyProtected(), isEqualWithoutConsideringStrProtected(), MEDCouplingField(), MEDCoupling::MEDCouplingFieldDouble::mergeNodes(), MEDCoupling::MEDCouplingFieldDouble::mergeNodesCenter(), MEDCoupling::MEDCouplingFieldDouble::normL1(), MEDCoupling::MEDCouplingFieldDouble::normL2(), MEDCoupling::MEDCouplingFieldDouble::operator=(), MEDCoupling::MEDCouplingFieldDouble::renumberNodes(), MEDCoupling::MEDCouplingFieldTemplate::reprQuickOverview(), setGaussLocalizationOnCells(), setGaussLocalizationOnType(), setMesh(), MEDCoupling::MEDCouplingFieldTemplate::simpleRepr(), MEDCoupling::MEDCouplingFieldDouble::simplexize(), MEDCoupling::MEDCouplingFieldDouble::synchronizeTimeWithSupport(), updateTime(), MEDCoupling::MEDCouplingFieldDouble::zipConnectivity(), MEDCoupling::MEDCouplingFieldDouble::zipCoords(), and ~MEDCouplingField().
◆ _type
MCAuto<MEDCouplingFieldDiscretization> MEDCoupling::MEDCouplingField::_type
Referenced by MEDCoupling::MEDCouplingFieldDouble::AddFields(), MEDCoupling::MEDCouplingFieldDouble::advancedRepr(), MEDCoupling::MEDCouplingFieldDouble::applyFunc(), areCompatibleForMerge(), areStrictlyCompatible(), areStrictlyCompatibleForMulDiv(), buildMeasureField(), MEDCoupling::MEDCouplingFieldDouble::buildNewTimeReprFromThis(), buildSubMeshData(), buildSubMeshDataRange(), checkConsistencyLight(), clearGaussLocalizations(), computeTupleIdsToSelectFromCellIds(), MEDCoupling::MEDCouplingFieldDouble::computeVectorFieldCyl(), MEDCoupling::MEDCouplingFieldDouble::CrossProductFields(), MEDCoupling::MEDCouplingFieldDouble::determinant(), MEDCoupling::MEDCouplingFieldDouble::deviator(), MEDCoupling::MEDCouplingFieldDouble::DivideFields(), MEDCoupling::MEDCouplingFieldDouble::DotFields(), MEDCoupling::MEDCouplingFieldDouble::doublyContractedProduct(), MEDCoupling::MEDCouplingFieldDouble::eigenValues(), MEDCoupling::MEDCouplingFieldDouble::eigenVectors(), MEDCoupling::MEDCouplingFieldDouble::fillFromAnalytic(), MEDCoupling::MEDCouplingFieldDouble::fillFromAnalyticCompo(), MEDCoupling::MEDCouplingFieldDouble::fillFromAnalyticNamedCompo(), MEDCoupling::MEDCouplingFieldTemplate::finishUnserialization(), getCellIdsHavingGaussLocalization(), getDirectChildrenWithNull(), getDiscretization(), getGaussLocalization(), getGaussLocalizationIdOfOneCell(), getGaussLocalizationIdOfOneType(), getGaussLocalizationIdsOfOneType(), MEDCoupling::MEDCouplingFieldDouble::getIJK(), getLocalizationOfDiscr(), getNbOfGaussLocalization(), getNumberOfMeshPlacesExpected(), MEDCoupling::MEDCouplingFieldDouble::getNumberOfTuples(), getNumberOfTuplesExpected(), getNumberOfTuplesExpectedRegardingCode(), MEDCoupling::MEDCouplingFieldTemplate::getTinySerializationDbleInformation(), MEDCoupling::MEDCouplingFieldTemplate::getTinySerializationIntInformation(), getTypeOfField(), MEDCoupling::MEDCouplingFieldDouble::getValueOn(), MEDCoupling::MEDCouplingFieldDouble::getValueOnMulti(), MEDCoupling::MEDCouplingFieldDouble::getValueOnPos(), MEDCoupling::MEDCouplingFieldDouble::integral(), MEDCoupling::MEDCouplingFieldDouble::inverse(), isEqualIfNotWhyProtected(), isEqualWithoutConsideringStrProtected(), MEDCoupling::MEDCouplingFieldDouble::keepSelectedComponents(), MEDCoupling::MEDCouplingFieldDouble::magnitude(), MEDCoupling::MEDCouplingFieldDouble::MaxFields(), MEDCoupling::MEDCouplingFieldDouble::maxPerTuple(), MEDCouplingField(), MEDCoupling::MEDCouplingFieldDouble::MeldFields(), MEDCoupling::MEDCouplingFieldDouble::mergeNodes(), MEDCoupling::MEDCouplingFieldDouble::mergeNodesCenter(), MEDCoupling::MEDCouplingFieldDouble::MinFields(), MEDCoupling::MEDCouplingFieldDouble::MultiplyFields(), MEDCoupling::MEDCouplingFieldDouble::negate(), MEDCoupling::MEDCouplingFieldDouble::normL1(), MEDCoupling::MEDCouplingFieldDouble::normL2(), MEDCoupling::MEDCouplingFieldDouble::operator=(), MEDCoupling::MEDCouplingFieldDouble::PowFields(), MEDCoupling::MEDCouplingFieldDouble::renumberNodesWithoutMesh(), MEDCoupling::MEDCouplingFieldTemplate::reprQuickOverview(), MEDCoupling::MEDCouplingFieldTemplate::resizeForUnserialization(), MEDCoupling::MEDCouplingFieldTemplate::serialize(), setDiscretization(), setGaussLocalizationOnCells(), setGaussLocalizationOnType(), setNature(), MEDCoupling::MEDCouplingFieldTemplate::simpleRepr(), MEDCoupling::MEDCouplingFieldDouble::simplexize(), MEDCoupling::MEDCouplingFieldDouble::SubstractFields(), MEDCoupling::MEDCouplingFieldDouble::trace(), updateTime(), MEDCoupling::MEDCouplingFieldDouble::zipConnectivity(), and MEDCoupling::MEDCouplingFieldDouble::zipCoords().
