MEDCoupling::OverlapDEC Class Reference
#include <OverlapDEC.hxx>
Inheritance diagram for MEDCoupling::OverlapDEC:
Collaboration diagram for MEDCoupling::OverlapDEC:
void attachSourceLocalField (ICoCo::MEDDoubleField *field)
void attachSourceLocalField (MEDCouplingFieldDouble *field)
void attachSourceLocalField (ParaFIELD *field, bool ownPt=false)
void attachTargetLocalField (ICoCo::MEDDoubleField *field)
void attachTargetLocalField (MEDCouplingFieldDouble *field)
void attachTargetLocalField (ParaFIELD *field, bool ownPt=false)
void debugPrintWorkSharing (std::ostream &ostr) const
ProcessorGroup * getGroup ()
ParaFIELD * getSourceLocalField ()
ParaFIELD * getTargetLocalField ()
bool isInGroup () const
 OverlapDEC (const std::set< int > &procIds, const MPI_Comm &world_comm=MPI_COMM_WORLD)
void recvData ()
void release ()
void sendData ()
void sendRecvData (bool way=true)
void setDefaultValue (double val)
void setWorkSharingAlgo (int method)
void synchronize ()
virtual ~OverlapDEC ()
- Public Member Functions inherited from MEDCoupling::DEC
void copyFrom (const DEC &other)
 DEC ()
virtual void sendRecvData (bool way=true)=0
virtual void synchronize ()=0
virtual ~DEC ()
- Public Member Functions inherited from MEDCoupling::DECOptions
 DECOptions ()
 DECOptions (const DECOptions &deco)
AllToAllMethod getAllToAllMethod () const
bool getAsynchronous () const
bool getForcedRenormalization () const
const std::string & getMethod () const
TimeInterpolationMethod getTimeInterpolationMethod () const
void setAllToAllMethod (AllToAllMethod sp)
void setAsynchronous (bool dr)
void setForcedRenormalization (bool dr)
void setMethod (const char *m)
void setTimeInterpolationMethod (TimeInterpolationMethod it)
- Public Member Functions inherited from INTERP_KERNEL::InterpolationOptions
void copyOptions (const InterpolationOptions &other)
std::string filterInterpolationMethod (const std::string &meth) const
double getBoundingBoxAdjustment () const
double getBoundingBoxAdjustmentAbs () const
bool getDoRotate () const
const FEInterpolationOptions & getFEOptions () const
IntersectionType getIntersectionType () const
std::string getIntersectionTypeRepr () const
double getMaxDistance3DSurfIntersect () const
bool getMaxDistanceStatus () const override
bool getMeasureAbsStatus () const
double getMedianPlane () const
double getMinDotBtwPlane3DSurfIntersect () const
int getOrientation () const
double getPrecision () const
int getPrintLevel () const
double getProjectionMaxDistance () const override
bool getProjectionOnSurfStatus () const override
SplittingPolicy getSplittingPolicy () const
std::string getSplittingPolicyRepr () const
void init ()
 InterpolationOptions ()
 InterpolationOptions (const InterpolationOptions &other)=default
InterpolationOptions & operator= (const InterpolationOptions &other)=default
std::string printOptions () const
void setBoundingBoxAdjustment (double bba)
void setBoundingBoxAdjustmentAbs (double bba)
void setDoRotate (bool dr)
bool setInterpolationOptions (int print_level, std::string intersection_type, double precision, double median_plane, bool do_rotate, double bounding_box_adjustment, double bounding_box_adjustment_abs, double max_distance_for_3Dsurf_intersect, int orientation, bool measure_abs, std::string splitting_policy)
void setIntersectionType (IntersectionType it)
void setMaxDistance3DSurfIntersect (double bba)
void setMaxDistanceStatus (bool maxDistStatus) override
void setMeasureAbsStatus (bool newStatus)
void setMedianPlane (double mp)
void setMinDotBtwPlane3DSurfIntersect (double v)
bool setOptionDouble (const std::string &key, double value)
bool setOptionInt (const std::string &key, int value)
bool setOptionString (const std::string &key, const std::string &value)
void setOrientation (int o)
void setPrecision (double p)
void setPrintLevel (int pl)
void setProjectionMaxDistance (double projDistMax) override
void setProjectionOnSurfStatus (bool projOnSurfStatus) override
void setSplittingPolicy (SplittingPolicy sp)
 ~InterpolationOptions ()=default
virtual bool getMaxDistanceStatus () const =0
virtual double getProjectionMaxDistance () const =0
virtual bool getProjectionOnSurfStatus () const =0
virtual void setMaxDistanceStatus (bool maxDistStatus)=0
virtual void setProjectionMaxDistance (double projDistMax)=0
virtual void setProjectionOnSurfStatus (bool projOnSurfStatus)=0
- Static Public Member Functions inherited from INTERP_KERNEL::InterpolationOptions
static void CheckAndSplitInterpolationMethod (const std::string &method, std::string &srcMeth, std::string &trgMeth)
- Static Public Attributes inherited from INTERP_KERNEL::InterpolationOptions
static const char BARYCENTRIC_INTERSECT_STR [] = "Barycentric"
static const char BARYCENTRICGEO2D_INTERSECT_STR [] = "BarycentricGeo2D"
static const char BOUNDING_BOX_ADJ_ABS_STR [] = "BoundingBoxAdjustmentAbs"
static const char BOUNDING_BOX_ADJ_STR [] = "BoundingBoxAdjustment"
static const char CONVEX_INTERSECT2D_STR [] = "Convex"
static const char DO_ROTATE_STR [] = "DoRotate"
static const char GENERAL_SPLIT_24_STR [] = "GENERAL_24"
static const char GENERAL_SPLIT_48_STR [] = "GENERAL_48"
static const char GEOMETRIC_INTERSECT2D_STR [] = "Geometric2D"
static const char INTERSEC_TYPE_STR [] = "IntersectionType"
static const char MAX_DISTANCE_3DSURF_INSECT_STR [] = "MaxDistance3DSurfIntersect"
static const char MEASURE_ABS_STR [] = "MeasureAbs"
static const char MEDIANE_PLANE_STR [] = "MedianPlane"
static const char MIN_DOT_BTW_3DSURF_INSECT_STR [] = "MinDotBetween3DSurfIntersect"
static const char ORIENTATION_STR [] = "Orientation"
static const char PLANAR_SPLIT_FACE_5_STR [] = "PLANAR_FACE_5"
static const char PLANAR_SPLIT_FACE_6_STR [] = "PLANAR_FACE_6"
static const char POINTLOCATOR_INTERSECT_STR [] = "PointLocator"
static const char PRECISION_STR [] = "Precision"
static const char PRINT_LEV_STR [] = "PrintLevel"
static const char SPLITTING_POLICY_STR [] = "SplittingPolicy"
static const char TRIANGULATION_INTERSECT2D_STR [] = "Triangulation"
- Protected Attributes inherited from MEDCoupling::DEC
const CommInterface * _comm_interface
- Protected Attributes inherited from MEDCoupling::DECOptions
AllToAllMethod _allToAllMethod
bool _asynchronous
bool _forcedRenormalization
std::string _method
TimeInterpolationMethod _timeInterpolationMethod
Overview
The OverlapDEC enables the conservative remapping of fields between two parallel codes. This remapping is based on the computation of intersection volumes on a single processor group. On this processor group are defined two field-templates called A and B. The computation is possible for 3D meshes, 2D meshes, 3D-surface meshes, 1D meshes and 2D-curve meshes. Dimensions must be similar for the distribution templates A and B.
The main difference with InterpKernelDEC is that this DEC works with a single processor group, in which processors will share the work. Consequently each processor manages two field templates (A and B) called source and target. Furthermore all processors in the processor group cooperate in the global interpolation matrix computation. In this respect InterpKernelDEC is a specialization of OverlapDEC.
Algorithm description
Let's consider the following use case that is ran in ParaMEDMEMTest_OverlapDEC.cxx to describes the different steps of the computation. The processor group contains 3 processors.
Example split of the source and target mesh among the 3 procs
Step 1 : Bounding box exchange and global interaction between procs
computation.
In order to reduce as much as possible the amount of communications between distant processors, every processor computes a bounding box for A and B. Then a AllToAll communication is performed so that every processor can compute the global interactions between processors. This computation leads every processor to compute the same global TODO list expressed as a list of pair. A pair ( x, y ) means that proc x fieldtemplate A can interact with field-template B of proc y because the two bounding boxes interact. In the example above this computation leads to the following global TODO list :
(0,0), (0,1), (1,0), (1,2), (2,0), (2,1), (2,2)
Here the pair (0,2) does not appear because the bounding box of fieldtemplateA of proc#2 does not intersect that of fieldtemplate B on proc#0. Notice that this pairing is not symmetric! (0,2) is not the same as (2,0) since source and target can not be swapped.
Stage performed by MEDCoupling::OverlapElementLocator::computeBoundingBoxesAndInteractionList.
Step 2 : Computation of local TODO list
Starting from the global interaction previously computed in Step 1, each proc computes the TODO list per proc. A pair (x,y) can be treated by either proc #x or proc #y, in order to reduce the amount of data transfers among processors.
Several strategies are possible. Historically (setWorkSharingAlgo(0)) the following was implemented:
The algorithm chosen for load balancing is the following : Each processor has an empty local TODO list at the beginning. Then for each pair (k,m) in global TODO list, if proc#k has less temporary local list than proc#m pair, (k,m) is added to temporary local TODO list of proc#k. If proc#m has less temporary local TODO list than proc#k pair, (k,m) is added to temporary local TODO list of proc#m. If proc#k and proc#m have the same amount of temporary local TODO list pair, (k,m) is added to temporary local TODO list of proc#k.
In the example above this computation leads to the following local TODO list :
  • proc#0 : (0,0)
  • proc#1 : (0,1),(1,0)
  • proc#2 : (1,2),(2,0),(2,1),(2,2)
This algo is coded in OverlapElementLocator::computeTodoList_original.
Another version of the work sharing algorithm (setWorkSharingAlgo(1), the default now) is provided in OverlapElementLocator::computeTodoList_new and hopes to be more efficient:
  • a job (i,j) is assigned initially to both proc#i and proc#j.
  • we then scan all the procs, identify the one with the biggest load
  • on this proc, we scan all the pairs (i,j) and remove the one corresponding to the less loaded remote proc
  • doing so, we have reduced the load of the most loaded proc
  • the process is repeated until no more duplicate job is found on each proc.
At the end of this stage each proc knows precisely its local TODO list (with regard to interpolation). The local TODO list of other procs than local is kept for future computations.
Step 3 : Matrix echange between procs
The aim now is to exchange (source and target) field-templates between processors. Knowing for every processor the local TODO list, each proc computes the exchange TODO list :
In the example above (using the first load balancing algorithm described) the exchange TODO list looks like this:
Sending TODO list per proc :
  • proc #0 : Send fieldtemplate A to Proc#1, Send fieldtemplate B to Proc#1, Send fieldtemplate B to Proc#2
  • Proc #1 : Send fieldtemplate A to Proc#2, Send fieldtemplate B to Proc#2
  • Proc #2 : No send.
For example, initial TODO list was indicating (0,1) on proc#1 meaning that proc#1 will be in charge of computing the intersection between part of the source (A) detained on proc#0 with part of the target (B) located on proc#1. Hence proc#0 needs to send A to proc#1.
Similarly here it the receiving TODO list per proc :
  • proc #0 : No receiving
  • proc #1 : receiving fieldtemplate A from Proc#0, receiving fieldtemplate B from Proc#0
  • proc #2 : receiving fieldtemplate B from Proc#0, receiving fieldtemplate A from Proc#1, receiving fieldtemplate B from Proc#1
To avoid as much as possible large volumes of transfers between procs, only relevant parts of the meshes are sent. In order for proc#k to send fieldtemplate A to fieldtemplate B of proc #m, proc#k computes the part of mesh A contained in the boundingbox B of proc#m. It implies that the corresponding cellIds or nodeIds of the corresponding part are sent to proc #m too.
Let's consider the couple (k,m) in the TODO list. This couple is treated by either k or m as seen in here in Step2.
As will be dealt in Step 6, for final matrix-vector computations, the resulting matrix of the couple (k,m) wherever it is computed (proc #k or proc #m) will be stored in proc#m (target side).
  • If proc #k is in charge (performs the matrix computation) for this couple (k,m), target ids (cells or nodes) of the mesh in proc#m are renumbered, because proc#m has selected a sub mesh of the target mesh to avoid large amounts of data to transfer. In this case, as proc#m is ultimately in charge of the matrix, proc#k must keep preciously the source ids needed to be sent to proc#m. No problem will appear for matrix assembling in proc#m for source ids because no restriction was done. Concerning source ids to be sent for the matrix-vector computation, proc#k will know precisely which source ids field values to send to proc#m. This is embodied by OverlapMapping::keepTracksOfTargetIds in proc#m.
  • If proc #m is in charge (performs matrix computation) for this couple (k,m), source ids (cells or nodes) of the mesh in proc #k are renumbered, because proc #k has selected a sub mesh of the source mesh to avoid large amounts of data to transfer. In this case as proc #k is ultimately in charge of the matrix, proc #m receives the source ids from remote proc #k, and thus the matrix is directly correct, no need for renumbering as in Step 5. However proc #k must keep track of the ids sent to proc #m for the matrix-vector computation. This is incarnated by OverlapMapping::keepTracksOfSourceIds in proc#k.
This step is performed in MEDCoupling::OverlapElementLocator::exchangeMeshes method.
Step 4 : Computation of the interpolation matrix
After mesh exchange in Step3 each processor has all the required information to treat its local TODO list computed in Step2. This step is potentially CPU costly, which is why the local TODO list per proc is expected to be as well balanced as possible.
The interpolation is performed as the remapper does.
This operation is performed by OverlapInterpolationMatrix::addContribution method.
Step 5 : Global matrix construction.
After having performed the TODO list at the end of Step4 we need to assemble the final matrix.
The final aim is to have a distributed matrix $ M_k $ on each proc#k. In order to reduce data exchange during the matrix product process, $ M_k $ is built using sizeof(Proc group) std::vector< std::map<int,double> >.
For a proc#k, it is necessary to fetch info of all matrices built in Step4 where the first element in pair (i,j) is equal to k.
After this step, the matrix repartition is the following after a call to MEDCoupling::OverlapMapping::prepare :
  • proc#0 : (0,0),(1,0),(2,0)
  • proc#1 : (0,1),(2,1)
  • proc#2 : (1,2),(2,2)
Tuple (2,1) computed on proc 2 is stored in proc 1 after execution of the function "prepare". This is an example of item 0 in Step2. Tuple (0,1) computed on proc 1 is stored in proc 1 too. This is an example of item 1 in Step2.
In the end MEDCoupling::OverlapMapping::_proc_ids_to_send_vector_st will contain :
  • Proc#0 : 0,1
  • Proc#1 : 0,2
  • Proc#2 : 0,1,2
In the end MEDCoupling::OverlapMapping::_proc_ids_to_recv_vector_st will contain :
  • Proc#0 : 0,1,2
  • Proc#1 : 0,2
  • Proc#2 : 1,2
The method in charge to perform this is : MEDCoupling::OverlapMapping::prepare.
◆ OverlapDEC()
MEDCoupling::OverlapDEC::OverlapDEC ( const std::set< int > &  procIds,
const MPI_Comm &  world_comm = MPI_COMM_WORLD
◆ ~OverlapDEC()
MEDCoupling::OverlapDEC::~OverlapDEC ( )
References release().
◆ release()
void MEDCoupling::OverlapDEC::release ( )
Destructor involves MPI operations: make sure this is accessible from a proper method for Python wrapping.
References MEDCoupling::CommInterface::commFree().
Referenced by ~OverlapDEC().
◆ sendRecvData()
void MEDCoupling::OverlapDEC::sendRecvData ( bool  way = true)
Implements MEDCoupling::DEC.
References recvData(), and sendData().
◆ sendData()
void MEDCoupling::OverlapDEC::sendData ( )
Referenced by sendRecvData().
◆ recvData()
void MEDCoupling::OverlapDEC::recvData ( )
◆ synchronize()
◆ attachSourceLocalField() [1/3]
void MEDCoupling::OverlapDEC::attachSourceLocalField ( ParaFIELD *  field,
bool  ownPt = false
References isInGroup().
Referenced by attachSourceLocalField().
◆ attachTargetLocalField() [1/3]
void MEDCoupling::OverlapDEC::attachTargetLocalField ( ParaFIELD *  field,
bool  ownPt = false
Referenced by attachTargetLocalField().
◆ attachSourceLocalField() [2/3]
◆ attachTargetLocalField() [2/3]
◆ attachSourceLocalField() [3/3]
void MEDCoupling::OverlapDEC::attachSourceLocalField ( ICoCo::MEDDoubleField *  field)
◆ attachTargetLocalField() [3/3]
void MEDCoupling::OverlapDEC::attachTargetLocalField ( ICoCo::MEDDoubleField *  field)
◆ getSourceLocalField()
ParaFIELD * MEDCoupling::OverlapDEC::getSourceLocalField ( )
◆ getTargetLocalField()
ParaFIELD * MEDCoupling::OverlapDEC::getTargetLocalField ( )
◆ getGroup()
ProcessorGroup * MEDCoupling::OverlapDEC::getGroup ( )
◆ isInGroup()
bool MEDCoupling::OverlapDEC::isInGroup ( ) const
◆ setDefaultValue()
void MEDCoupling::OverlapDEC::setDefaultValue ( double  val)
◆ setWorkSharingAlgo()
void MEDCoupling::OverlapDEC::setWorkSharingAlgo ( int  method)
0 means initial algo from Antho, 1 or 2 means Adrien's algo (2 should be better). Make your choice :-))
◆ debugPrintWorkSharing()
void MEDCoupling::OverlapDEC::debugPrintWorkSharing ( std::ostream &  ostr) const
