MEDCoupling::DECOptions Class Reference
#include <DECOptions.hxx>
Inheritance diagram for MEDCoupling::DECOptions:
 DECOptions ()
 DECOptions (const DECOptions &deco)
AllToAllMethod getAllToAllMethod () const
bool getAsynchronous () const
bool getForcedRenormalization () const
const std::string & getMethod () const
TimeInterpolationMethod getTimeInterpolationMethod () const
void setAllToAllMethod (AllToAllMethod sp)
void setAsynchronous (bool dr)
void setForcedRenormalization (bool dr)
void setMethod (const char *m)
void setTimeInterpolationMethod (TimeInterpolationMethod it)
AllToAllMethod _allToAllMethod
bool _asynchronous
bool _forcedRenormalization
std::string _method
TimeInterpolationMethod _timeInterpolationMethod
This class groups the various options accepted by all DECs (which all inherit from DECOptions).
The following code excerpt shows how to set options on a DEC :
InterpKernelDEC dec(source_group,target_group);
dec.setForcedRenormalization(true);
dec.attachLocalField(field);
dec.synchronize();
if (source_group.containsMyRank())
dec.sendData();
else
dec.recvData();
Definition: InterpKernelDEC.hxx:129
◆ DECOptions() [1/2]
MEDCoupling::DECOptions::DECOptions ( )
◆ DECOptions() [2/2]
MEDCoupling::DECOptions::DECOptions ( const DECOptions &  deco)
◆ getMethod()
const std::string & MEDCoupling::DECOptions::getMethod ( ) const
See also
setMethod()
References _method.
◆ setMethod()
void MEDCoupling::DECOptions::setMethod ( const char *  m)
Set interpolation method. Defaults to "P0".
References _method.
◆ getTimeInterpolationMethod()
TimeInterpolationMethod MEDCoupling::DECOptions::getTimeInterpolationMethod ( ) const
◆ setTimeInterpolationMethod()
void MEDCoupling::DECOptions::setTimeInterpolationMethod ( TimeInterpolationMethod  it)
Set time interpolation method. Default to WithoutTimeInterp.
References _timeInterpolationMethod.
◆ getForcedRenormalization()
bool MEDCoupling::DECOptions::getForcedRenormalization ( ) const
◆ setForcedRenormalization()
void MEDCoupling::DECOptions::setForcedRenormalization ( bool  dr)
Force renormalization of the field after it has been received so that the total sum of the field values are the same on both the sending and the receiving side. Defaults to false.
References _forcedRenormalization.
◆ getAsynchronous()
bool MEDCoupling::DECOptions::getAsynchronous ( ) const
See also
setAsynchronous()
References _asynchronous.
◆ setAsynchronous()
void MEDCoupling::DECOptions::setAsynchronous ( bool  dr)
Switch to asynchronous data transfer mode. Default is false.
◆ getAllToAllMethod()
AllToAllMethod MEDCoupling::DECOptions::getAllToAllMethod ( ) const
See also
setAllToAllMethod()
References _allToAllMethod.
◆ setAllToAllMethod()
void MEDCoupling::DECOptions::setAllToAllMethod ( AllToAllMethod  sp)
Set the broadcast method for synchronisation processes. Default to Native.
◆ _method
std::string MEDCoupling::DECOptions::_method
Referenced by DECOptions(), getMethod(), and setMethod().
◆ _asynchronous
bool MEDCoupling::DECOptions::_asynchronous
◆ _timeInterpolationMethod
TimeInterpolationMethod MEDCoupling::DECOptions::_timeInterpolationMethod
◆ _allToAllMethod
AllToAllMethod MEDCoupling::DECOptions::_allToAllMethod
◆ _forcedRenormalization
bool MEDCoupling::DECOptions::_forcedRenormalization
