MEDCoupling::ParaFIELD Class Reference
#include <ParaFIELD.hxx>
MEDCouplingFieldDouble * getField () const
double getL2Norm () const
const ProcessorGroup * getProcGroup () const
ParaMESH * getSupport () const
Topology * getTopology () const
TypeOfField getTypeOfField () const
double getVolumeIntegral (int icomp, bool isWAbs) const
int nbComponents () const
 ParaFIELD (MEDCouplingFieldDouble *field, ParaMESH *sup, const ProcessorGroup &group)
 ParaFIELD (TypeOfField type, TypeOfTimeDiscretization td, ParaMESH *mesh, const ComponentTopology &component_topology)
void release ()
DataArrayIdType * returnCumulativeGlobalNumbering () const
DataArrayIdType * returnGlobalNumbering () const
void setGlobalNumbering (DataArrayIdType *globalNum) const
void setOwnSupport (bool v) const
void synchronizeSource (MEDCoupling::ParaFIELD *target_field)
void synchronizeTarget (MEDCoupling::ParaFIELD *source_field)
virtual ~ParaFIELD ()
This class encapsulates parallel fields.
It gathers a MEDCouplingField with some extra information related to the parallel topology.
It is most conveniently created by giving a pointer to a MEDCouplingFieldDouble object and a ProcessorGroup. By default, a ParaFIELD object will be constructed with all field components located on the same processors. In some specific cases, it might be necessary to scatter components over several processors. In this case, the constructor using a ComponentTopology is required.
◆ ParaFIELD() [1/2]
MEDCoupling::ParaFIELD::ParaFIELD ( TypeOfField  type,
ParaMESH *  para_support,
const ComponentTopology &  component_topology
Constructing a ParaFIELD from a ParaMESH and a ComponentTopology.
This constructor creates an empty field based on the ParaMESH description and the partitioning of components described in component_topology. It takes ownership over the _field object that it creates.
Here come the three ComponentTopology constructors :
ComponentTopology c; // one component in the field
ComponentTopology c(6); //six components, all of them on the same processor
ComponentTopology c(6, proc_group); // six components, evenly distributed over the processors of procgroup
References MEDCoupling::DataArrayTemplate< T >::alloc(), MEDCoupling::RefCountObjectOnly::decrRef(), MEDCoupling::ParaMESH::getCellMesh(), MEDCoupling::MEDCouplingFieldDouble::getNumberOfTuples(), MEDCoupling::Topology::getProcGroup(), MEDCoupling::ParaMESH::getTopology(), MEDCoupling::ParaMESH::isStructured(), MEDCoupling::ComponentTopology::nbBlocks(), MEDCoupling::ComponentTopology::nbLocalComponents(), MEDCoupling::DataArrayDouble::New(), MEDCoupling::MEDCouplingFieldDouble::New(), MEDCoupling::MEDCouplingFieldT< T >::setArray(), MEDCoupling::MEDCouplingField::setDescription(), MEDCoupling::MEDCouplingField::setMesh(), MEDCoupling::MEDCouplingField::setName(), and MEDCoupling::ProcessorGroup::size().
◆ ParaFIELD() [2/2]
MEDCoupling::ParaFIELD::ParaFIELD ( MEDCouplingFieldDouble *  subdomain_field,
ParaMESH *  sup,
const ProcessorGroup &  proc_group
Constructor creating the ParaFIELD from a given FIELD and a processor group.
This constructor supposes that support underlying subdomain_field has no ParaMESH attached and it therefore recreates one. It therefore takes ownership over _support. The component topology associated with the field is a basic one (all components on the same processor).
References MEDCoupling::ParaMESH::getTopology(), MEDCoupling::RefCountObjectOnly::incrRef(), and MEDCoupling::ComponentTopology::nbLocalComponents().
◆ ~ParaFIELD()
MEDCoupling::ParaFIELD::~ParaFIELD ( )
References release().
◆ release()
void MEDCoupling::ParaFIELD::release ( )
Destructor involves MPI operations: make sure this is accessible from a proper method for Python wrapping.
References MEDCoupling::RefCountObjectOnly::decrRef().
Referenced by ~ParaFIELD().
◆ synchronizeTarget()
◆ synchronizeSource()
◆ getField()
◆ setOwnSupport()
◆ returnCumulativeGlobalNumbering()
DataArrayIdType * MEDCoupling::ParaFIELD::returnCumulativeGlobalNumbering ( ) const
This method returns, if it exists, an array with only one component and as many as tuples as _field has. This array gives for every element on which this->_field lies, its global number, if this->_field is nodal. For example if _field is a nodal field : returned array will be the nodal global numbers. The content of this method is used to inform Working side to accumulate data received by lazy side.
References MEDCoupling::ParaMESH::getGlobalNumberingNodeDA(), getTypeOfField(), MEDCoupling::ON_CELLS, and MEDCoupling::ON_NODES.
◆ returnGlobalNumbering()
◆ getTopology()
Topology * MEDCoupling::ParaFIELD::getTopology ( ) const
◆ getSupport()
ParaMESH * MEDCoupling::ParaFIELD::getSupport ( ) const
◆ getProcGroup()
const ProcessorGroup * MEDCoupling::ParaFIELD::getProcGroup ( ) const
◆ nbComponents()
int MEDCoupling::ParaFIELD::nbComponents ( ) const
◆ getVolumeIntegral()
double MEDCoupling::ParaFIELD::getVolumeIntegral ( int  icomp,
bool  isWAbs
◆ getL2Norm()
double MEDCoupling::ParaFIELD::getL2Norm ( ) const
◆ getTypeOfField()
◆ setGlobalNumbering()
void MEDCoupling::ParaFIELD::setGlobalNumbering ( DataArrayIdType *  globalNum) const
