MEDCoupling::InterpolationMatrix Class Reference
#include <InterpolationMatrix.hxx>
Inheritance diagram for MEDCoupling::InterpolationMatrix:
Collaboration diagram for MEDCoupling::InterpolationMatrix:
void addContribution (MEDCouplingPointSet &distant_support, int iproc_distant, const mcIdType *distant_elems, const std::string &srcMeth, const std::string &targetMeth)
void finishContributionL (ElementLocator &elementLocator)
void finishContributionW (ElementLocator &elementLocator)
MPIAccessDEC * getAccessDEC ()
mcIdType getNbRows () const
 InterpolationMatrix (const MEDCoupling::ParaFIELD *source_field, const ProcessorGroup &source_group, const ProcessorGroup &target_group, const DECOptions &dec_opt, const InterpolationOptions &i_opt)
void multiply (MEDCouplingFieldDouble &field) const
void prepare ()
MCAuto< DataArrayIdType > retrieveNonFetchedIdsSource () const
MCAuto< DataArrayIdType > retrieveNonFetchedIdsTarget (mcIdType nbTuples) const
void setDefaultValue (double val)
void transposeMultiply (MEDCouplingFieldDouble &field) const
virtual ~InterpolationMatrix ()
- Public Member Functions inherited from INTERP_KERNEL::InterpolationOptions
void copyOptions (const InterpolationOptions &other)
std::string filterInterpolationMethod (const std::string &meth) const
double getBoundingBoxAdjustment () const
double getBoundingBoxAdjustmentAbs () const
bool getDoRotate () const
const FEInterpolationOptions & getFEOptions () const
IntersectionType getIntersectionType () const
std::string getIntersectionTypeRepr () const
double getMaxDistance3DSurfIntersect () const
bool getMaxDistanceStatus () const override
bool getMeasureAbsStatus () const
double getMedianPlane () const
double getMinDotBtwPlane3DSurfIntersect () const
int getOrientation () const
double getPrecision () const
int getPrintLevel () const
double getProjectionMaxDistance () const override
bool getProjectionOnSurfStatus () const override
SplittingPolicy getSplittingPolicy () const
std::string getSplittingPolicyRepr () const
void init ()
 InterpolationOptions ()
 InterpolationOptions (const InterpolationOptions &other)=default
InterpolationOptions & operator= (const InterpolationOptions &other)=default
std::string printOptions () const
void setBoundingBoxAdjustment (double bba)
void setBoundingBoxAdjustmentAbs (double bba)
void setDoRotate (bool dr)
bool setInterpolationOptions (int print_level, std::string intersection_type, double precision, double median_plane, bool do_rotate, double bounding_box_adjustment, double bounding_box_adjustment_abs, double max_distance_for_3Dsurf_intersect, int orientation, bool measure_abs, std::string splitting_policy)
void setIntersectionType (IntersectionType it)
void setMaxDistance3DSurfIntersect (double bba)
void setMaxDistanceStatus (bool maxDistStatus) override
void setMeasureAbsStatus (bool newStatus)
void setMedianPlane (double mp)
void setMinDotBtwPlane3DSurfIntersect (double v)
bool setOptionDouble (const std::string &key, double value)
bool setOptionInt (const std::string &key, int value)
bool setOptionString (const std::string &key, const std::string &value)
void setOrientation (int o)
void setPrecision (double p)
void setPrintLevel (int pl)
void setProjectionMaxDistance (double projDistMax) override
void setProjectionOnSurfStatus (bool projOnSurfStatus) override
void setSplittingPolicy (SplittingPolicy sp)
 ~InterpolationOptions ()=default
virtual bool getMaxDistanceStatus () const =0
virtual double getProjectionMaxDistance () const =0
virtual bool getProjectionOnSurfStatus () const =0
virtual void setMaxDistanceStatus (bool maxDistStatus)=0
virtual void setProjectionMaxDistance (double projDistMax)=0
virtual void setProjectionOnSurfStatus (bool projOnSurfStatus)=0
- Public Member Functions inherited from MEDCoupling::DECOptions
 DECOptions ()
 DECOptions (const DECOptions &deco)
AllToAllMethod getAllToAllMethod () const
bool getAsynchronous () const
bool getForcedRenormalization () const
const std::string & getMethod () const
TimeInterpolationMethod getTimeInterpolationMethod () const
void setAllToAllMethod (AllToAllMethod sp)
void setAsynchronous (bool dr)
void setForcedRenormalization (bool dr)
void setMethod (const char *m)
void setTimeInterpolationMethod (TimeInterpolationMethod it)
- Static Public Member Functions inherited from INTERP_KERNEL::InterpolationOptions
static void CheckAndSplitInterpolationMethod (const std::string &method, std::string &srcMeth, std::string &trgMeth)
- Static Public Attributes inherited from INTERP_KERNEL::InterpolationOptions
static const char BARYCENTRIC_INTERSECT_STR [] = "Barycentric"
static const char BARYCENTRICGEO2D_INTERSECT_STR [] = "BarycentricGeo2D"
static const char BOUNDING_BOX_ADJ_ABS_STR [] = "BoundingBoxAdjustmentAbs"
static const char BOUNDING_BOX_ADJ_STR [] = "BoundingBoxAdjustment"
static const char CONVEX_INTERSECT2D_STR [] = "Convex"
static const char DO_ROTATE_STR [] = "DoRotate"
static const char GENERAL_SPLIT_24_STR [] = "GENERAL_24"
static const char GENERAL_SPLIT_48_STR [] = "GENERAL_48"
static const char GEOMETRIC_INTERSECT2D_STR [] = "Geometric2D"
static const char INTERSEC_TYPE_STR [] = "IntersectionType"
static const char MAX_DISTANCE_3DSURF_INSECT_STR [] = "MaxDistance3DSurfIntersect"
static const char MEASURE_ABS_STR [] = "MeasureAbs"
static const char MEDIANE_PLANE_STR [] = "MedianPlane"
static const char MIN_DOT_BTW_3DSURF_INSECT_STR [] = "MinDotBetween3DSurfIntersect"
static const char ORIENTATION_STR [] = "Orientation"
static const char PLANAR_SPLIT_FACE_5_STR [] = "PLANAR_FACE_5"
static const char PLANAR_SPLIT_FACE_6_STR [] = "PLANAR_FACE_6"
static const char POINTLOCATOR_INTERSECT_STR [] = "PointLocator"
static const char PRECISION_STR [] = "Precision"
static const char PRINT_LEV_STR [] = "PrintLevel"
static const char SPLITTING_POLICY_STR [] = "SplittingPolicy"
static const char TRIANGULATION_INTERSECT2D_STR [] = "Triangulation"
- Protected Attributes inherited from MEDCoupling::DECOptions
AllToAllMethod _allToAllMethod
bool _asynchronous
bool _forcedRenormalization
std::string _method
TimeInterpolationMethod _timeInterpolationMethod
Internal class, not part of the public API.
This class enables the storage of an interpolation matrix Wij mapping a source field Sj to a target field Ti via Ti=Vi^(-1).Wij.Sj. The matrix is built and stored on the processors belonging to the source group.
◆ InterpolationMatrix()
MEDCoupling::InterpolationMatrix::InterpolationMatrix ( const MEDCoupling::ParaFIELD *  source_field,
const ProcessorGroup &  source_group,
const ProcessorGroup &  target_group,
const DECOptions &  dec_opt,
const InterpolationOptions &  i_opt
! Creates an empty matrix structure linking two distributed supports. The method must be called by all processors belonging to source and target groups.
source_fieldlocal source field
source_groupprocessor group containing the local processors
target_groupprocessor group containing the distant processors
dec_optionsDEC options (including projection method P0, P1)
interp_optionsinterpolation options
References MEDCoupling::ParaFIELD::getField(), and MEDCoupling::MEDCouplingFieldDouble::getNumberOfTuples().
◆ ~InterpolationMatrix()
MEDCoupling::InterpolationMatrix::~InterpolationMatrix ( )
◆ addContribution()
void MEDCoupling::InterpolationMatrix::addContribution ( MEDCouplingPointSet &  distant_support,
int  iproc_distant,
const mcIdType *  distant_elems,
const std::string &  srcMeth,
const std::string &  targetMeth
Adds the contribution of a distant subdomain to the* interpolation matrix. The method adds contribution to the interpolation matrix. For each row of the matrix, elements are added as a (column, coeff) pair in the _coeffs array. This column number refers to an element on the target side via the _col_offsets array. It is made of a series of (iproc, ielem) pairs. The number of elements per row is stored in the row_offsets array.
param distant_support local representation of the distant subdomain param iproc_distant id of the distant subdomain (in the distant group) param distant_elems mapping between the local representation of the subdomain and the actual elem ids on the distant subdomain
References MEDCoupling::RefCountObjectOnly::decrRef(), INTERP_KERNEL::Interpolation< TrueMainInterpolator >::fromIntegralUniform(), INTERP_KERNEL::InterpolationOptions::getMeasureAbsStatus(), MEDCoupling::MEDCouplingMesh::getMeasureField(), MEDCoupling::MEDCouplingUMesh::getMeshDimension(), MEDCoupling::MEDCouplingMesh::getMeshDimension(), MEDCoupling::MEDCouplingPointSet::getSpaceDimension(), INTERP_KERNEL::Interpolation3D::interpolateMeshes(), and INTERP_KERNEL::Interpolation< TrueMainInterpolator >::toIntegralUniform().
Referenced by MEDCoupling::InterpKernelDEC::synchronize().
◆ finishContributionW()
void MEDCoupling::InterpolationMatrix::finishContributionW ( ElementLocator &  elementLocator)
◆ finishContributionL()
void MEDCoupling::InterpolationMatrix::finishContributionL ( ElementLocator &  elementLocator)
◆ retrieveNonFetchedIdsTarget()
MCAuto< DataArrayIdType > MEDCoupling::InterpolationMatrix::retrieveNonFetchedIdsTarget ( mcIdType  nbTuples) const
◆ multiply()
void MEDCoupling::InterpolationMatrix::multiply ( MEDCouplingFieldDouble &  field) const
performs t=Ws, where t is the target field, s is the source field
The call to this method must be called both on the working side and on the idle side. On the working side, the vector T=VT^(-1).(W.S) is computed and sent. On the idle side, no computation is done, but the result from the working side is received and the field is updated.
fieldsource field on processors involved on the source side, target field on processors on the target side
References MEDCoupling::ProcessorGroup::containsMyRank(), MEDCoupling::MEDCouplingFieldT< T >::getArray(), and MEDCoupling::MEDCouplingFieldT< T >::getIJ().
Referenced by MEDCoupling::InterpKernelDEC::recvData(), and MEDCoupling::InterpKernelDEC::sendData().
◆ retrieveNonFetchedIdsSource()
MCAuto< DataArrayIdType > MEDCoupling::InterpolationMatrix::retrieveNonFetchedIdsSource ( ) const
◆ transposeMultiply()
void MEDCoupling::InterpolationMatrix::transposeMultiply ( MEDCouplingFieldDouble &  field) const
performs s=WTt, where t is the target field, s is the source field, WT is the transpose matrix from W
The call to this method must be called both on the working side and on the idle side. On the working side, the target vector T is received and the vector S=VS^(-1).(WT.T) is computed to update the field. On the idle side, no computation is done, but the field is sent.
param field source field on processors involved on the source side, target field on processors on the target side
References MEDCoupling::ProcessorGroup::containsMyRank(), and MEDCoupling::MEDCouplingFieldT< T >::getArray().
◆ prepare()
void MEDCoupling::InterpolationMatrix::prepare ( )
! The call to this method updates the arrays on the target side so that they know which amount of data from which processor they should expect. That call makes actual interpolations via multiply method available.
◆ getNbRows()
mcIdType MEDCoupling::InterpolationMatrix::getNbRows ( ) const
◆ getAccessDEC()
MPIAccessDEC * MEDCoupling::InterpolationMatrix::getAccessDEC ( )
◆ setDefaultValue()
void MEDCoupling::InterpolationMatrix::setDefaultValue ( double  val)
