INTERP_KERNEL::Interpolation3D Class Reference
#include <Interpolation3D.hxx>
Inheritance diagram for INTERP_KERNEL::Interpolation3D:
Collaboration diagram for INTERP_KERNEL::Interpolation3D:
template<class MyMeshType , class MatrixType >
MyMeshType::MyConnType interpolateMeshes (const MyMeshType &srcMesh, const MyMeshType &targetMesh, MatrixType &result, const std::string &method)
 Interpolation3D ()
 Interpolation3D (const InterpolationOptions &io)
- Public Member Functions inherited from INTERP_KERNEL::Interpolation< Interpolation3D >
MyMeshType::MyConnType fromIntegralUniform (const MyMeshType &meshT, MatrixType &result, const std::string &method)
MyMeshType::MyConnType interpolateMeshes (const MyMeshType &meshS, const MyMeshType &meshT, MatrixType &result)
 Interpolation ()
 Interpolation (const InterpolationOptions &io)
MyMeshType::MyConnType toIntegralUniform (const MyMeshType &meshS, MatrixType &result, const std::string &method)
- Public Member Functions inherited from INTERP_KERNEL::InterpolationOptions
void copyOptions (const InterpolationOptions &other)
std::string filterInterpolationMethod (const std::string &meth) const
double getBoundingBoxAdjustment () const
double getBoundingBoxAdjustmentAbs () const
bool getDoRotate () const
const FEInterpolationOptions & getFEOptions () const
IntersectionType getIntersectionType () const
std::string getIntersectionTypeRepr () const
double getMaxDistance3DSurfIntersect () const
bool getMaxDistanceStatus () const override
bool getMeasureAbsStatus () const
double getMedianPlane () const
double getMinDotBtwPlane3DSurfIntersect () const
int getOrientation () const
double getPrecision () const
int getPrintLevel () const
double getProjectionMaxDistance () const override
bool getProjectionOnSurfStatus () const override
SplittingPolicy getSplittingPolicy () const
std::string getSplittingPolicyRepr () const
void init ()
 InterpolationOptions ()
 InterpolationOptions (const InterpolationOptions &other)=default
InterpolationOptions & operator= (const InterpolationOptions &other)=default
std::string printOptions () const
void setBoundingBoxAdjustment (double bba)
void setBoundingBoxAdjustmentAbs (double bba)
void setDoRotate (bool dr)
bool setInterpolationOptions (int print_level, std::string intersection_type, double precision, double median_plane, bool do_rotate, double bounding_box_adjustment, double bounding_box_adjustment_abs, double max_distance_for_3Dsurf_intersect, int orientation, bool measure_abs, std::string splitting_policy)
void setIntersectionType (IntersectionType it)
void setMaxDistance3DSurfIntersect (double bba)
void setMaxDistanceStatus (bool maxDistStatus) override
void setMeasureAbsStatus (bool newStatus)
void setMedianPlane (double mp)
void setMinDotBtwPlane3DSurfIntersect (double v)
bool setOptionDouble (const std::string &key, double value)
bool setOptionInt (const std::string &key, int value)
bool setOptionString (const std::string &key, const std::string &value)
void setOrientation (int o)
void setPrecision (double p)
void setPrintLevel (int pl)
void setProjectionMaxDistance (double projDistMax) override
void setProjectionOnSurfStatus (bool projOnSurfStatus) override
void setSplittingPolicy (SplittingPolicy sp)
 ~InterpolationOptions ()=default
virtual bool getMaxDistanceStatus () const =0
virtual double getProjectionMaxDistance () const =0
virtual bool getProjectionOnSurfStatus () const =0
virtual void setMaxDistanceStatus (bool maxDistStatus)=0
virtual void setProjectionMaxDistance (double projDistMax)=0
virtual void setProjectionOnSurfStatus (bool projOnSurfStatus)=0
- Static Public Member Functions inherited from INTERP_KERNEL::Interpolation< Interpolation3D >
static double CalculateCharacteristicSizeOfMeshes (const MyMeshType &myMeshS, const MyMeshType &myMeshT, const int printLevel)
- Static Public Member Functions inherited from INTERP_KERNEL::InterpolationOptions
static void CheckAndSplitInterpolationMethod (const std::string &method, std::string &srcMeth, std::string &trgMeth)
- Static Public Attributes inherited from INTERP_KERNEL::InterpolationOptions
static const char BARYCENTRIC_INTERSECT_STR [] = "Barycentric"
static const char BARYCENTRICGEO2D_INTERSECT_STR [] = "BarycentricGeo2D"
static const char BOUNDING_BOX_ADJ_ABS_STR [] = "BoundingBoxAdjustmentAbs"
static const char BOUNDING_BOX_ADJ_STR [] = "BoundingBoxAdjustment"
static const char CONVEX_INTERSECT2D_STR [] = "Convex"
static const char DO_ROTATE_STR [] = "DoRotate"
static const char GENERAL_SPLIT_24_STR [] = "GENERAL_24"
static const char GENERAL_SPLIT_48_STR [] = "GENERAL_48"
static const char GEOMETRIC_INTERSECT2D_STR [] = "Geometric2D"
static const char INTERSEC_TYPE_STR [] = "IntersectionType"
static const char MAX_DISTANCE_3DSURF_INSECT_STR [] = "MaxDistance3DSurfIntersect"
static const char MEASURE_ABS_STR [] = "MeasureAbs"
static const char MEDIANE_PLANE_STR [] = "MedianPlane"
static const char MIN_DOT_BTW_3DSURF_INSECT_STR [] = "MinDotBetween3DSurfIntersect"
static const char ORIENTATION_STR [] = "Orientation"
static const char PLANAR_SPLIT_FACE_5_STR [] = "PLANAR_FACE_5"
static const char PLANAR_SPLIT_FACE_6_STR [] = "PLANAR_FACE_6"
static const char POINTLOCATOR_INTERSECT_STR [] = "PointLocator"
static const char PRECISION_STR [] = "Precision"
static const char PRINT_LEV_STR [] = "PrintLevel"
static const char SPLITTING_POLICY_STR [] = "SplittingPolicy"
static const char TRIANGULATION_INTERSECT2D_STR [] = "Triangulation"
- Protected Member Functions inherited from INTERP_KERNEL::Interpolation< Interpolation3D >
Interpolation3D & asLeaf ()
MyMeshType::MyConnType fromToIntegralUniform (bool fromTo, const MyMeshType &mesh, MatrixType &result, const std::string &method)
Class used to calculate the volumes of intersection between the elements of two 3D meshes.
◆ Interpolation3D() [1/2]
INTERP_KERNEL::Interpolation3D::Interpolation3D ( )
Default constructor
◆ Interpolation3D() [2/2]
INTERP_KERNEL::Interpolation3D::Interpolation3D ( const InterpolationOptions &  io)
◆ interpolateMeshes()
MyMeshType::MyConnType INTERP_KERNEL::Interpolation3D::interpolateMeshes ( const MyMeshType &  srcMesh,
const MyMeshType &  targetMesh,
MatrixType &  result,
const std::string &  method
Calculates the matrix of volumes of intersection between the elements of srcMesh and the elements of targetMesh. The calculation is done in two steps. First a filtering process reduces the number of pairs of elements for which the calculation must be carried out by eliminating pairs that do not intersect based on their bounding boxes. Then, the volume of intersection is calculated by an object of type Intersector3D for the remaining pairs, and entered into the intersection matrix.
The matrix is partially sparse : it is a vector of maps of integer - double pairs. It can also be an INTERP_KERNEL::Matrix object. The length of the vector is equal to the number of target elements - for each target element there is a map, regardless of whether the element intersects any source elements or not. But in the maps there are only entries for those source elements which have a non-zero intersection volume with the target element. The vector has indices running from 0 to (nb target elements - 1), meaning that the map for target element i is stored at index i - 1. In the maps, however, the indexing is more natural : the intersection volume of the target element i with source element j is found at matrix[i-1][j].
srcMesh3-dimensional source mesh
targetMesh3-dimesional target mesh, containing only tetraedra
resultmatrix in which the result is stored
References INTERP_KERNEL::Barycentric, INTERP_KERNEL::InterpolationOptions::filterInterpolationMethod(), INTERP_KERNEL::InterpolationOptions::getIntersectionType(), INTERP_KERNEL::InterpolationOptions::getPrecision(), INTERP_KERNEL::InterpolationOptions::getSplittingPolicy(), INTERP_KERNEL::MappedBarycentric, INTERP_KERNEL::PointLocator, and INTERP_KERNEL::Triangulation.
Referenced by MEDCoupling::InterpolationMatrix::addContribution().
