MEDCoupling::MEDCouplingAMRAttribute Class Reference
#include <MEDCouplingAMRAttribute.hxx>
Inheritance diagram for MEDCoupling::MEDCouplingAMRAttribute:
Collaboration diagram for MEDCoupling::MEDCouplingAMRAttribute:
void alloc ()
MEDCouplingFieldDouble * buildCellFieldOnRecurseWithoutOverlapWithoutGhost (MEDCouplingCartesianAMRMeshGen *mesh, const std::string &fieldName) const
MEDCouplingFieldDouble * buildCellFieldOnWithGhost (MEDCouplingCartesianAMRMeshGen *mesh, const std::string &fieldName) const
MEDCouplingFieldDouble * buildCellFieldOnWithoutGhost (MEDCouplingCartesianAMRMeshGen *mesh, const std::string &fieldName) const
bool changeGodFather (MEDCouplingCartesianAMRMesh *gf)
void dealloc ()
MEDCouplingAMRAttribute * deepCopy () const
MEDCouplingAMRAttribute * deepCpyWithoutGodFather () const
DataArrayDouble * getFieldOn (MEDCouplingCartesianAMRMeshGen *mesh, const std::string &fieldName)
const DataArrayDouble * getFieldOn (MEDCouplingCartesianAMRMeshGen *mesh, const std::string &fieldName) const
mcIdType getNumberOfLevels () const
MEDCouplingAMRAttribute * projectTo (MEDCouplingCartesianAMRMesh *targetGF) const
std::vector< DataArrayDouble * > retrieveFieldsOn (MEDCouplingCartesianAMRMeshGen *mesh) const
void spillInfoOnComponents (const std::vector< std::vector< std::string > > &compNames)
void spillNatures (const std::vector< NatureOfField > &nfs)
void synchronizeAllGhostZones ()
void synchronizeAllGhostZonesAtASpecifiedLevel (mcIdType level)
void synchronizeAllGhostZonesAtASpecifiedLevelUsingOnlyFather (mcIdType level)
void synchronizeAllGhostZonesOfDirectChidrenOf (const MEDCouplingCartesianAMRMeshGen *mesh)
void synchronizeCoarseToFine ()
void synchronizeCoarseToFineBetween (mcIdType fromLev, mcIdType toLev)
void synchronizeFineToCoarse ()
void synchronizeFineToCoarseBetween (mcIdType fromLev, mcIdType toLev)
void updateTime () const
std::string writeVTHB (const std::string &fileName) const
- Public Member Functions inherited from MEDCoupling::MEDCouplingDataForGodFather
virtual void alloc ()=0
virtual void dealloc ()=0
MEDCouplingCartesianAMRMesh * getMyGodFather ()
const MEDCouplingCartesianAMRMesh * getMyGodFather () const
virtual void synchronizeAllGhostZones ()=0
virtual void synchronizeAllGhostZonesAtASpecifiedLevel (mcIdType level)=0
virtual void synchronizeAllGhostZonesAtASpecifiedLevelUsingOnlyFather (mcIdType level)=0
virtual void synchronizeAllGhostZonesOfDirectChidrenOf (const MEDCouplingCartesianAMRMeshGen *mesh)=0
virtual void synchronizeCoarseToFine ()=0
virtual void synchronizeCoarseToFineBetween (mcIdType fromLev, mcIdType toLev)=0
virtual void synchronizeFineToCoarse ()=0
virtual void synchronizeFineToCoarseBetween (mcIdType fromLev, mcIdType toLev)=0
bool decrRef () const
int getRCValue () const
void incrRef () const
virtual ~BigMemoryObject ()
void declareAsNew () const
static MEDCouplingAMRAttribute * New (MEDCouplingCartesianAMRMesh *gf, const std::vector< std::pair< std::string, int > > &fieldNames, mcIdType ghostLev)
static MEDCouplingAMRAttribute * New (MEDCouplingCartesianAMRMesh *gf, const std::vector< std::pair< std::string, std::vector< std::string > > > &fieldNames, mcIdType ghostLev)
- Protected Member Functions inherited from MEDCoupling::MEDCouplingDataForGodFather
virtual bool changeGodFather (MEDCouplingCartesianAMRMesh *gf)
void checkGodFatherFrozen () const
 MEDCouplingDataForGodFather (const MEDCouplingDataForGodFather &other, bool deepCpyGF)
 MEDCouplingDataForGodFather (MEDCouplingCartesianAMRMesh *gf)
 RefCountObject ()
virtual ~RefCountObject ()
 RefCountObjectOnly ()
 TimeLabel ()
virtual ~TimeLabel ()
- Protected Attributes inherited from MEDCoupling::MEDCouplingDataForGodFather
MCAuto< MEDCouplingCartesianAMRMesh > _gf
TimeLabelConstOverseer _tlc
◆ New() [1/2]
MEDCouplingAMRAttribute * MEDCouplingAMRAttribute::New ( MEDCouplingCartesianAMRMesh *  gf,
const std::vector< std::pair< std::string, int > > &  fieldNames,
mcIdType  ghostLev
This method creates, attach to a main AMR mesh gf ( called god father :-) ) and returns a data linked to gf ready for the computation.
Referenced by MEDCoupling::MEDCouplingCartesianAMRMesh::createPatchesFromCriterionML(), New(), and projectTo().
◆ New() [2/2]
const std::vector< std::pair< std::string, std::vector< std::string > > > &  fieldNames,
mcIdType  ghostLev
References New().
◆ getClassName()
std::string MEDCoupling::MEDCouplingAMRAttribute::getClassName ( ) const
overridevirtual
◆ spillInfoOnComponents()
void MEDCouplingAMRAttribute::spillInfoOnComponents ( const std::vector< std::vector< std::string > > &  compNames)
Assign the info on components for all DataArrayDouble instance recursively stored in this. The first dim of input compNames is the field id in the same order than those implicitly specified in fieldNames parameter of MEDCouplingAMRAttribute::New. The second dim of compNames represent the component names component per component corresponding to the field. The size of this 2nd dimension has to perfectly fit with those specified in MEDCouplingAMRAttribute::New.
References MEDCoupling::MEDCouplingDataForGodFather::_tlc, and MEDCoupling::TimeLabelConstOverseer::checkConst().
◆ spillNatures()
void MEDCouplingAMRAttribute::spillNatures ( const std::vector< NatureOfField > &  nfs)
Assign nature for each fields in this.
[in]nfsvector of field natures.
◆ deepCopy()
MEDCouplingAMRAttribute * MEDCouplingAMRAttribute::deepCopy ( ) const
◆ deepCpyWithoutGodFather()
MEDCouplingAMRAttribute * MEDCouplingAMRAttribute::deepCpyWithoutGodFather ( ) const
◆ getNumberOfLevels()
mcIdType MEDCouplingAMRAttribute::getNumberOfLevels ( ) const
◆ retrieveFieldsOn()
std::vector< DataArrayDouble * > MEDCouplingAMRAttribute::retrieveFieldsOn ( MEDCouplingCartesianAMRMeshGen *  mesh) const
This method returns all DataArrayDouble instances lying on the specified mesh mesh. If mesh is not part of the progeny of god father object given at construction of this an exception will be thrown.
std::vector<DataArrayDouble *> - DataArrayDouble instances to be deallocated by the caller (using decrRef).
See also
retrieveFieldOn
◆ getFieldOn() [1/2]
const DataArrayDouble * MEDCouplingAMRAttribute::getFieldOn ( MEDCouplingCartesianAMRMeshGen *  mesh,
const std::string &  fieldName
◆ getFieldOn() [2/2]
◆ buildCellFieldOnRecurseWithoutOverlapWithoutGhost()
MEDCouplingFieldDouble * MEDCouplingAMRAttribute::buildCellFieldOnRecurseWithoutOverlapWithoutGhost ( MEDCouplingCartesianAMRMeshGen *  mesh,
This method returns a field on an unstructured mesh the most refined as possible without overlap. Ghost part are not visible here.
MEDCouplingFieldDouble * - a field on cells that the caller has to deal with (deallocate it).
References MEDCoupling::MEDCouplingCartesianAMRMeshGen::buildCellFieldOnRecurseWithoutOverlapWithoutGhost().
◆ buildCellFieldOnWithGhost()
MEDCouplingFieldDouble * MEDCouplingAMRAttribute::buildCellFieldOnWithGhost ( MEDCouplingCartesianAMRMeshGen *  mesh,
This method builds a newly created field on cell just lying on mesh mesh without its eventual refinement. The output field also displays ghost cells.
See also
References MEDCoupling::MEDCouplingIMesh::buildWithGhost(), MEDCoupling::MEDCouplingCartesianAMRMeshGen::getImageMesh(), MEDCoupling::DataArray::getName(), MEDCoupling::MEDCouplingFieldDouble::New(), and MEDCoupling::ON_CELLS.
◆ buildCellFieldOnWithoutGhost()
◆ writeVTHB()
◆ projectTo()
MEDCouplingAMRAttribute * MEDCouplingAMRAttribute::projectTo ( MEDCouplingCartesianAMRMesh *  targetGF) const
This method is useful just after a remesh after a time step computation to project values in this to the new mesh targetGF.
This method performs a projection from this to a target AMR mesh targetGF. This method performs the projection by trying to transfer the finest information to targetGF. WARNING this method does not update the ghost zone, if any. The level0 of this god father must have the same structure than those of targetGF.
This method makes checks that ghost size of this and targetGF are the same, and that the number of levels in this and in targetGF are also the same.
References MEDCoupling::MEDCouplingStructuredMesh::getCellGridStructure(), MEDCoupling::MEDCouplingCartesianAMRMeshGen::getImageMesh(), MEDCoupling::MEDCouplingCartesianAMRMeshGen::getMaxNumberOfLevelsRelativeToThis(), MEDCoupling::MEDCouplingDataForGodFather::getMyGodFather(), getNumberOfLevels(), and New().
◆ synchronizeFineToCoarse()
void MEDCouplingAMRAttribute::synchronizeFineToCoarse ( )
This method synchronizes from fine to coarse direction arrays. This method makes the hypothesis that this has been allocated before using MEDCouplingAMRAttribute::alloc method. This method DOES NOT UPDATE the ghost zones (neither the fine not the coarse)
See also
Implements MEDCoupling::MEDCouplingDataForGodFather.
◆ synchronizeFineToCoarseBetween()
void MEDCouplingAMRAttribute::synchronizeFineToCoarseBetween ( mcIdType  fromLev,
mcIdType  toLev
This method allows to synchronizes fields on fine patches on level fromLev to coarser patches at toLev level. This method operates step by step performing the synchronization the fromLev to fromLev - 1, then fromLev -1 to fromLev - 2 ... until reaching toLev level. This method DOES NOT UPDATE the ghost zones (neither the fine not the coarse).
[in]fromLev- an existing level considered as fine so bigger than toLev
[in]toLev- an existing level considered as the target level to reach.
References getNumberOfLevels().
◆ synchronizeCoarseToFine()
void MEDCouplingAMRAttribute::synchronizeCoarseToFine ( )
This method synchronizes from coarse to fine arrays and fine to fine each other (if _ghost_lev is >0). This method makes the hypothesis that this has been allocated before using MEDCouplingAMRAttribute::alloc method. This method DOES UPDATE the ghost zone (contrary to synchronizeFineToCoarse method)
◆ synchronizeCoarseToFineBetween()
void MEDCouplingAMRAttribute::synchronizeCoarseToFineBetween ( mcIdType  fromLev,
mcIdType  toLev
This method allows to synchronizes fields on coarse patches on level fromLev to their respective refined patches at toLev level. This method operates step by step performing the synchronization the fromLev to fromLev + 1, then fromLev + 1 to fromLev + 2 ... until reaching toLev level. This method DOES UPDATE the ghost zone (contrary to synchronizeFineToCoarseBetween method)
[in]fromLev- an existing level considered as coarse so lower than toLev
◆ synchronizeAllGhostZones()
void MEDCouplingAMRAttribute::synchronizeAllGhostZones ( )
This method synchronizes the ghost zone of all patches (excepted the god father one). This method operates in 4 steps. Larger is the number of steps more accurate is the information in the ghost zone.
  • firstly coarse to fine with no interactions between brother patches.
  • secondly connected brother patches in a same master patch are updated.
  • thirdly connected nephew patches are updated each other.
  • forthly nth generation cousin patches are updated each other.
This method makes the hypothesis that this has been allocated before using MEDCouplingAMRAttribute::alloc method. So if _ghost_lev == 0 this method has no effect.
◆ synchronizeAllGhostZonesOfDirectChidrenOf()
void MEDCouplingAMRAttribute::synchronizeAllGhostZonesOfDirectChidrenOf ( const MEDCouplingCartesianAMRMeshGen *  mesh)
This method works ONLY ON DIRECT SONS OF mesh. So only a part of patches at a given level is updated here. The ghost zone of all of these sons of mesh are updated using the brother patches (the patches sharing the SAME mesh). It is sometimes possible that a ghost zone of some sons of mesh are covered by a patch of same level but different father. For such cases, the ghost zones are NOT updated. If you need a more thorough (but more costly) ghost zone update use synchronizeAllGhostZonesAtASpecifiedLevel method instead.
[in]mesh- an element in the progeny of god father in this, which the ghost zone of its sons will be updated each other.
References MEDCoupling::MEDCouplingDataForGodFather::_gf, MEDCoupling::MEDCouplingCartesianAMRMeshGen::getAbsoluteLevelRelativeTo(), MEDCoupling::MEDCouplingCartesianAMRMeshGen::getFather(), and getNumberOfLevels().
◆ synchronizeAllGhostZonesAtASpecifiedLevel()
void MEDCouplingAMRAttribute::synchronizeAllGhostZonesAtASpecifiedLevel ( mcIdType  level)
This method updates all the patches at level level each other without consideration of their father. So this method is more time consuming than synchronizeAllGhostZonesOfDirectChidrenOf.
◆ synchronizeAllGhostZonesAtASpecifiedLevelUsingOnlyFather()
void MEDCouplingAMRAttribute::synchronizeAllGhostZonesAtASpecifiedLevelUsingOnlyFather ( mcIdType  level)
This method updates ghost zones of patches at level level whatever their father using father patches ONLY (at level level - 1). This method is useful to propagate to the ghost zone of childhood the modification.
◆ alloc()
void MEDCouplingAMRAttribute::alloc ( )
This method allocates all DataArrayDouble instances stored recursively in this.
See also
dealloc
References MEDCoupling::MEDCouplingDataForGodFather::_tlc, and MEDCoupling::TimeLabelConstOverseer::resetState().
◆ dealloc()
void MEDCouplingAMRAttribute::dealloc ( )
This method deallocates all DataArrayDouble instances stored recursively in this.
See also
alloc
◆ changeGodFather()
bool MEDCouplingAMRAttribute::changeGodFather ( MEDCouplingCartesianAMRMesh *  gf)
◆ getHeapMemorySizeWithoutChildren()
std::size_t MEDCouplingAMRAttribute::getHeapMemorySizeWithoutChildren ( ) const
◆ getDirectChildrenWithNull()
std::vector< const BigMemoryObject * > MEDCouplingAMRAttribute::getDirectChildrenWithNull ( ) const
◆ updateTime()
void MEDCouplingAMRAttribute::updateTime ( ) const
This method should be called on high level classes as Field or Mesh to take into account modifications done in aggregates objects.
Implements MEDCoupling::TimeLabel.
