MEDCoupling::MEDFileParameterMultiTS Class Reference
#include <MEDFileParameter.hxx>
Inheritance diagram for MEDCoupling::MEDFileParameterMultiTS:
Collaboration diagram for MEDCoupling::MEDFileParameterMultiTS:
void appendValue (int dt, int it, double time, double val)
MEDFileParameterMultiTS * deepCopy () const
void eraseTimeStepIds (const int *startIds, const int *endIds)
double getDoubleValue (int iteration, int order) const
std::vector< std::pair< int, int > > getIterations () const
std::string getName () const
int getNumberOfTS () const
int getPosGivenTime (double time, double eps=1e-8) const
int getPosOfTimeStep (int iteration, int order) const
MEDFileParameter1TS * getTimeStepAtPos (int posId) const
std::vector< std::pair< int, int > > getTimeSteps (std::vector< double > &ret1) const
bool isEqual (const MEDFileParameterMultiTS *other, double eps, std::string &what) const
std::string simpleRepr () const
void simpleRepr2 (int bkOffset, std::ostream &oss) const
void write (const std::string &fileName, int mode) const
void writeAdvanced (med_idt fid, const MEDFileWritable &mw) const
bool decrRef () const
int getRCValue () const
void incrRef () const
virtual ~BigMemoryObject ()
- Public Member Functions inherited from MEDCoupling::MEDFileParameterTinyInfo
std::string getDescription () const
std::size_t getHeapMemSizeOfStrings () const
std::string getTimeUnit () const
bool isEqualStrings (const MEDFileParameterTinyInfo &other, std::string &what) const
void setDescription (const std::string &name)
void setTimeUnit (const std::string &unit)
static MEDFileParameterMultiTS * New ()
static MEDFileParameterMultiTS * New (const std::string &fileName)
static MEDFileParameterMultiTS * New (const std::string &fileName, const std::string &paramName)
static MEDFileParameterMultiTS * New (med_idt fid)
static MEDFileParameterMultiTS * New (med_idt fid, const std::string &paramName)
void finishLoading (med_idt fid, med_parameter_type typ, int nbOfSteps)
 MEDFileParameterMultiTS ()
 MEDFileParameterMultiTS (const MEDFileParameterMultiTS &other, bool deepCopy)
 MEDFileParameterMultiTS (med_idt fid)
 MEDFileParameterMultiTS (med_idt fid, const std::string &paramName)
 RefCountObject ()
virtual ~RefCountObject ()
 RefCountObjectOnly ()
- Protected Member Functions inherited from MEDCoupling::MEDFileParameterTinyInfo
void mainRepr (int bkOffset, std::ostream &oss) const
void writeLLHeader (med_idt fid, med_parameter_type typ) const
std::vector< MCAuto< MEDFileParameter1TS > > _param_per_ts
- Protected Attributes inherited from MEDCoupling::MEDFileParameterTinyInfo
std::string _desc_name
std::string _dt_unit
◆ MEDFileParameterMultiTS() [1/4]
MEDFileParameterMultiTS::MEDFileParameterMultiTS ( )
Referenced by deepCopy(), and New().
◆ MEDFileParameterMultiTS() [2/4]
MEDFileParameterMultiTS::MEDFileParameterMultiTS ( const MEDFileParameterMultiTS &  other,
bool  deepCopy
◆ MEDFileParameterMultiTS() [3/4]
◆ MEDFileParameterMultiTS() [4/4]
MEDFileParameterMultiTS::MEDFileParameterMultiTS ( med_idt  fid,
const std::string &  paramName
◆ New() [1/5]
MEDFileParameterMultiTS * MEDFileParameterMultiTS::New ( )
◆ New() [2/5]
MEDFileParameterMultiTS * MEDFileParameterMultiTS::New ( const std::string &  fileName)
References New().
◆ New() [3/5]
MEDFileParameterMultiTS * MEDFileParameterMultiTS::New ( med_idt  fid)
◆ New() [4/5]
MEDFileParameterMultiTS * MEDFileParameterMultiTS::New ( const std::string &  fileName,
References New().
◆ New() [5/5]
MEDFileParameterMultiTS * MEDFileParameterMultiTS::New ( med_idt  fid,
◆ getClassName()
std::string MEDCoupling::MEDFileParameterMultiTS::getClassName ( ) const
overridevirtual
Reimplemented from MEDCoupling::BigMemoryObject.
◆ getName()
std::string MEDCoupling::MEDFileParameterMultiTS::getName ( ) const
◆ setName()
void MEDCoupling::MEDFileParameterMultiTS::setName ( const std::string &  name)
◆ getHeapMemorySizeWithoutChildren()
std::size_t MEDFileParameterMultiTS::getHeapMemorySizeWithoutChildren ( ) const
◆ getDirectChildrenWithNull()
std::vector< const BigMemoryObject * > MEDFileParameterMultiTS::getDirectChildrenWithNull ( ) const
◆ deepCopy()
MEDFileParameterMultiTS * MEDFileParameterMultiTS::deepCopy ( ) const
◆ isEqual()
bool MEDFileParameterMultiTS::isEqual ( const MEDFileParameterMultiTS *  other,
double  eps,
std::string &  what
References _param_per_ts.
◆ write()
void MEDFileParameterMultiTS::write ( const std::string &  fileName,
int  mode
References writeAdvanced().
◆ writeAdvanced()
void MEDFileParameterMultiTS::writeAdvanced ( med_idt  fid,
const MEDFileWritable &  mw
◆ simpleRepr()
std::string MEDFileParameterMultiTS::simpleRepr ( ) const
References simpleRepr2().
◆ appendValue()
void MEDFileParameterMultiTS::appendValue ( int  dt,
int  it,
double  time,
double  val
◆ getDoubleValue()
double MEDFileParameterMultiTS::getDoubleValue ( int  iteration,
int  order
◆ getPosOfTimeStep()
int MEDFileParameterMultiTS::getPosOfTimeStep ( int  iteration,
int  order
◆ getPosGivenTime()
int MEDFileParameterMultiTS::getPosGivenTime ( double  time,
double  eps = 1e-8
◆ getTimeStepAtPos()
MEDFileParameter1TS * MEDFileParameterMultiTS::getTimeStepAtPos ( int  posId) const
an internal pointer that can be null. Warning the caller is not responsible of the returned pointer.
◆ eraseTimeStepIds()
void MEDFileParameterMultiTS::eraseTimeStepIds ( const int *  startIds,
const int *  endIds
◆ getNumberOfTS()
int MEDFileParameterMultiTS::getNumberOfTS ( ) const
References getIterations().
◆ getIterations()
std::vector< std::pair< int, int > > MEDFileParameterMultiTS::getIterations ( ) const
◆ getTimeSteps()
std::vector< std::pair< int, int > > MEDFileParameterMultiTS::getTimeSteps ( std::vector< double > &  ret1) const
◆ simpleRepr2()
void MEDFileParameterMultiTS::simpleRepr2 ( int  bkOffset,
std::ostream &  oss
◆ finishLoading()
void MEDFileParameterMultiTS::finishLoading ( med_idt  fid,
int  nbOfSteps
◆ _param_per_ts
