MEDCoupling::MEDFileParameterDouble1TS Class Reference
#include <MEDFileParameter.hxx>
Inheritance diagram for MEDCoupling::MEDFileParameterDouble1TS:
Collaboration diagram for MEDCoupling::MEDFileParameterDouble1TS:
virtual MEDFileParameter1TS * deepCopy () const
std::string getName () const
virtual bool isEqual (const MEDFileParameter1TS *other, double eps, std::string &what) const
virtual std::string simpleRepr () const
void write (const std::string &fileName, int mode) const
- Public Member Functions inherited from MEDCoupling::MEDFileParameterDouble1TSWTI
double getValue () const
void readValue (med_idt fid, const std::string &name)
void setValue (double val)
- Public Member Functions inherited from MEDCoupling::MEDFileParameter1TS
virtual MEDFileParameter1TS * deepCopy () const =0
int getIteration () const
int getOrder () const
double getTime (int &dt, int &it)
double getTimeValue () const
virtual void readValue (med_idt fid, const std::string &name)=0
void setIteration (int it)
void setOrder (int order)
void setTime (int dt, int it, double time)
void setTimeValue (double time)
virtual void simpleRepr2 (int bkOffset, std::ostream &oss) const =0
virtual void writeAdvanced (med_idt fid, const std::string &name, const MEDFileWritable &mw) const =0
bool decrRef () const
int getRCValue () const
void incrRef () const
virtual ~BigMemoryObject ()
- Public Member Functions inherited from MEDCoupling::MEDFileParameterTinyInfo
std::string getDescription () const
std::size_t getHeapMemSizeOfStrings () const
std::string getTimeUnit () const
bool isEqualStrings (const MEDFileParameterTinyInfo &other, std::string &what) const
void setDescription (const std::string &name)
void setTimeUnit (const std::string &unit)
static MEDFileParameterDouble1TS * New ()
static MEDFileParameterDouble1TS * New (const std::string &fileName)
static MEDFileParameterDouble1TS * New (const std::string &fileName, const std::string &paramName)
static MEDFileParameterDouble1TS * New (const std::string &fileName, const std::string &paramName, int dt, int it)
- Static Public Member Functions inherited from MEDCoupling::MEDFileParameterDouble1TSWTI
static MEDFileParameterDouble1TSWTI * New (int iteration, int order, double time)
- Protected Member Functions inherited from MEDCoupling::MEDFileParameterDouble1TSWTI
void finishLoading (med_idt fid, const std::string &name, int dt, int it, int nbOfSteps)
void finishLoading (med_idt fid, const std::string &name, int timeStepId)
 MEDFileParameterDouble1TSWTI ()
 MEDFileParameterDouble1TSWTI (int iteration, int order, double time)
- Protected Member Functions inherited from MEDCoupling::MEDFileParameter1TS
 MEDFileParameter1TS ()
 MEDFileParameter1TS (int iteration, int order, double time)
 RefCountObject ()
virtual ~RefCountObject ()
 RefCountObjectOnly ()
- Protected Member Functions inherited from MEDCoupling::MEDFileParameterTinyInfo
void mainRepr (int bkOffset, std::ostream &oss) const
void writeLLHeader (med_idt fid, med_parameter_type typ) const
- Protected Attributes inherited from MEDCoupling::MEDFileParameterDouble1TSWTI
double _arr
- Protected Attributes inherited from MEDCoupling::MEDFileParameter1TS
int _iteration
int _order
double _time
- Protected Attributes inherited from MEDCoupling::MEDFileParameterTinyInfo
std::string _desc_name
std::string _dt_unit
◆ New() [1/4]
MEDFileParameterDouble1TS * MEDFileParameterDouble1TS::New ( )
◆ New() [2/4]
MEDFileParameterDouble1TS * MEDFileParameterDouble1TS::New ( const std::string &  fileName)
◆ New() [3/4]
MEDFileParameterDouble1TS * MEDFileParameterDouble1TS::New ( const std::string &  fileName,
const std::string &  paramName
◆ New() [4/4]
const std::string &  paramName,
int  dt,
int  it
◆ getClassName()
std::string MEDCoupling::MEDFileParameterDouble1TS::getClassName ( ) const
overridevirtual
◆ deepCopy()
MEDFileParameter1TS * MEDFileParameterDouble1TS::deepCopy ( ) const
◆ isEqual()
bool MEDFileParameterDouble1TS::isEqual ( const MEDFileParameter1TS *  other,
double  eps,
std::string &  what
◆ simpleRepr()
std::string MEDFileParameterDouble1TS::simpleRepr ( ) const
◆ getHeapMemorySizeWithoutChildren()
std::size_t MEDFileParameterDouble1TS::getHeapMemorySizeWithoutChildren ( ) const
◆ getDirectChildrenWithNull()
std::vector< const BigMemoryObject * > MEDFileParameterDouble1TS::getDirectChildrenWithNull ( ) const
◆ setName()
void MEDCoupling::MEDFileParameterDouble1TS::setName ( const std::string &  name)
◆ getName()
std::string MEDCoupling::MEDFileParameterDouble1TS::getName ( ) const
◆ write()
void MEDFileParameterDouble1TS::write ( const std::string &  fileName,
int  mode
