The Extruded boss operation allows you to easily add material on a solid by extruding a profile along the normal to its plane.
To produce the extruded boss:
Draw the profile of the extrusion. It can be:
a Sketch drawn on a planar face of the initial shape you want to boss.
In the Main Menu select Operations - > Extruded Boss or click on
li
Fill in the dialog box fields:
li
The input arguments are:
And optionally:
The direction can be reversed by pushing the Change direction button:
This functionality is available via the textual interface with the command:
TUI Command: geompy.MakeExtrudedBoss(InitShape, Profile, Height, Angle),
