Loading...
Searching...
No Matches
Extruded cut
The Extruded cut operation allows you to easily remove material from a solid by extruding a profile along the normal to its plane.
To produce the extruded cut:
  1. Draw the profile of the extrusion. It can be:
    • a Sketch drawn on a planar face of the object you want to cut.
    • any closed edge or wire of the desired shape (circle, ellipse ...).
  2. In the Main Menu select Operations - > Extruded Cut or click on
  3. Fill in the dialog box fields:
The input arguments are:
  • The initial shape you want to cut. It must be a solid or a compound made of a single solid.
  • The profile. It must be a closed edge or wire and it must be planar.
  • The height of extrusion. It's calculated from the base profile along the normal to its plane.
And optionally:
  • A draft angle in degrees. Activated by clicking on
The direction can be reversed by pushing the Change direction button:
This functionality is available via the textual interface with the command:
TUI Command: geompy.MakeExtrudedCut(InitShape, Profile, Height,Angle),
