Loading...
Searching...
No Matches
Suppress Faces
To produce a Suppress Faces operation in the Main Menu select Repair - > Suppress Faces.
This operation suppresses a face of a shape. This operation is available in OCC Viewer only.
The Result will be a GEOM_Object (ListOfGeomShapes).
TUI Command: geompy.SuppressFaces(Shape, ListOfID), where Shape is a shape to be processed, ListOfID is a list of faces ID's to be removed.
Arguments: Name + 1 shape + Faces which should be removed (you can select them in the 3D viewer).
Example:
The initial box
The box with suppressed faces
Our TUI Scripts provide you with useful examples of the use of Repairing Operations.
