Loading...
Searching...
No Matches
Boolean Operations
For a detailed description of Boolean operations refer to this document. It provides a general review of the Partition and Boolean operations algorithms, describes the usage methodology and highlights major limitations of these operations.
You can use the following boolean operations for construction of more complex geometrical objects (2D & 3D elements):
  • Fuse - creates a shape from a list of shapes.
  • Common - transforms the common part of a list of objects into an independent object.
  • Cut - cuts one shape with a list of others.
  • Intersection - performs an intersection between two shapes.
You can use advanced TUI commands performing these operations independently from each other:
geompy.MakeFuseList(theShapesList, checkSelfInte, rmExtraEdges), where theShapesList is the list of shapes for Fuse operation;
geompy.MakeCommonList(theShapesList, checkSelfInte), where theShapesList is the list of shapes for Common operation;
geompy.MakeCutList(theMainShape, theShapesList, checkSelfInte), where theMainShape is the object of the operation and theShapesList is the list of tools for Cut operation;
geompy.MakeSection(Shape1, Shape2, checkSelfInte), where Shape1 is the first argument and Shape2 is the second argument of Intersection operation;
There are several TUI commands that can be used to perform boolean operations with only two arguments. There is a general TUI command covering these operations, which can be used alongside with separate commands for each operation.
geompy.MakeBoolean(Shape1, Shape2, Operation, checkSelfInte), where Shape1 is the first argument and Shape2 is the second argument of a Boolean operation, Operation is the type of a Boolean operation (1 — Common, 2 — Cut, 3 — Fuse, 4 — Intersection).
Besides, you can use advanced TUI commands performing these operations independently from each other:
geompy.MakeFuse(Shape1, Shape2, checkSelfInte, rmExtraEdges), where Shape1 is the first argument and Shape2 is the second argument of Fuse operation;
geompy.MakeCommon(Shape1, Shape2, checkSelfInte), where Shape1 is the first argument and Shape2 is the second argument of Common operation;
geompy.MakeCut(Shape1, Shape2, checkSelfInte), where Shape1 is the first argument and Shape2 is the second argument of Cut operation;
The flag checkSelfInte indicates whether the arguments should be checked for self-intersection prior to an operation. Its default value is False, which means that there is no need to check it. This option is provided to ensure that an operation is performed on not self-intersected shapes as they are not valid for boolean operations.
This algorithm does not find all types of self-intersections. It is tuned to detect vertex/vertex, vertex/edge, edge/edge, vertex/face and edge/face intersections. Face/face intersections detection is switched off as it is a time-consuming operation that gives an impact on performance. To find all self-intersections use Detect Self-intersection tool.
The flag rmExtraEdges is used for MakeFuseList and MakeFuse operations only. It indicates if Remove Extra Edges operation should be performed during the operation. Its default value is False, which means that there is no need to do it.
rmExtraEdges is not available for MakeBoolean call with operation type 3 (Fuse). MakeBoolean operation doesn't perform Remove Extra Edges. So the call geompy.MakeBoolean(Shape1, Shape2, 3, checkSelfInte) is equivalent to geompy.MakeFuse(Shape1, Shape2, checkSelfInte, False).
Our TUI Scripts provide you with useful examples of the use of Boolean Operations.
