GEOMImpl_Types.hxx File Reference
#include <TopAbs_ShapeEnum.hxx>
#define GEOM_COPY   0
#define GEOM_IMPORT   1
#define GEOM_POINT   2
#define GEOM_VECTOR   3
#define GEOM_PLANE   4
#define GEOM_LINE   5
#define GEOM_TORUS   6
#define GEOM_BOX   7
#define GEOM_CYLINDER   8
#define GEOM_CONE   9
#define GEOM_SPHERE   10
#define GEOM_PRISM   11
#define GEOM_REVOLUTION   12
#define GEOM_BOOLEAN   13
#define GEOM_PARTITION   14
#define GEOM_POLYLINE   15
#define GEOM_CIRCLE   16
#define GEOM_SPLINE   17
#define GEOM_ELLIPSE   18
#define GEOM_CIRC_ARC   19
#define GEOM_FILLET   20
#define GEOM_CHAMFER   21
#define GEOM_EDGE   22
#define GEOM_WIRE   23
#define GEOM_FACE   24
#define GEOM_SHELL   25
#define GEOM_SOLID   26
#define GEOM_COMPOUND   27
#define GEOM_SUBSHAPE   28
#define GEOM_PIPE   29
#define GEOM_ARCHIMEDE   30
#define GEOM_FILLING   31
#define GEOM_EXPLODE   32
#define GEOM_GLUED   33
#define GEOM_SKETCHER   34
#define GEOM_CDG   35
#define GEOM_FREE_BOUNDS   36
#define GEOM_GROUP   37
#define GEOM_BLOCK   38
#define GEOM_MARKER   39
#define GEOM_THRUSECTIONS   40
#define GEOM_COMPOUNDFILTER   41
#define GEOM_SHAPES_ON_SHAPE   42
#define GEOM_ELLIPSE_ARC   43
#define GEOM_3DSKETCHER   44
#define GEOM_PROJECTION   45
#define GEOM_EXTRUDED_CUT   46
#define GEOM_EXTRUDED_BOSS   47
#define GEOM_PIPE_PATH   48
#define GEOM_THICKENING   49
#define GEOM_FILLET_2D   50
#define GEOM_FILLET_1D   51
#define GEOM_FIELD   52
#define GEOM_FIELD_STEP   53
#define GEOM_ISOLINE   55
#define GEOM_POLYLINE2D   56
#define GEOM_TRANSFER_DATA   57
#define GEOM_EXTRACTION   58
#define GEOM_CURVATURE_VEC   59
#define GEOM_PATCH_FACE   60
#define GEOM_SHAPE_PROXIMITY   61
#define GEOM_CHECKCONFORMITY   62
#define COPY_WITH_REF   1
#define COPY_WITHOUT_REF   2
#define TRANSFER_DATA   3
#define IMPORT_SHAPE   1
#define EXPORT_SHAPE   2
#define POINT_XYZ   1
#define POINT_XYZ_REF   2
#define POINT_CURVE_PAR   3
#define POINT_LINES_INTERSECTION   4
#define POINT_SURFACE_PAR   5
#define POINT_CURVE_COORD   6
#define POINT_SURFACE_COORD   7
#define POINT_CURVE_LENGTH   8
#define POINT_FACE_ANY   9
#define VECTOR_TWO_PNT   1
#define VECTOR_DX_DY_DZ   2
#define VECTOR_TANGENT_CURVE_PAR   3
#define VECTOR_REVERSE   4
#define PLANE_PNT_VEC   1
#define PLANE_FACE   2
#define PLANE_THREE_PNT   3
#define PLANE_TANGENT_FACE   4
#define PLANE_2_VEC   5
#define PLANE_LCS   6
#define LINE_TWO_PNT   1
#define LINE_PNT_DIR   2
#define LINE_TWO_FACES   3
#define TRANSLATE_TWO_POINTS   1
#define TRANSLATE_VECTOR   2
#define TRANSLATE_VECTOR_DISTANCE   9
#define TRANSLATE_TWO_POINTS_COPY   3
#define TRANSLATE_VECTOR_COPY   4
#define TRANSLATE_1D   5
#define TRANSLATE_2D   6
#define TRANSLATE_XYZ   7
#define TRANSLATE_XYZ_COPY   8
#define ROTATE   1
#define ROTATE_COPY   2
#define ROTATE_1D   3
#define ROTATE_2D   4
#define ROTATE_THREE_POINTS   5
#define ROTATE_THREE_POINTS_COPY   6
#define ROTATE_1D_STEP   7
#define MIRROR_PLANE   1
#define MIRROR_PLANE_COPY   2
#define MIRROR_AXIS   3
#define MIRROR_AXIS_COPY   4
#define MIRROR_POINT   5
#define MIRROR_POINT_COPY   6
#define OFFSET_SHAPE   1
#define OFFSET_SHAPE_COPY   2
#define OFFSET_THICKENING   3
#define OFFSET_THICKENING_COPY   4
#define PROJECTION_COPY   1
#define PROJECTION_ON_WIRE   2
#define PROJECTION_ON_CYLINDER   3
#define SCALE_SHAPE   1
#define SCALE_SHAPE_COPY   2
#define SCALE_SHAPE_AXES   3
#define SCALE_SHAPE_AXES_COPY   4
#define POSITION_SHAPE   1
#define POSITION_SHAPE_COPY   2
#define POSITION_SHAPE_FROM_GLOBAL   3
#define POSITION_SHAPE_FROM_GLOBAL_COPY   4
#define POSITION_ALONG_PATH   5
#define TORUS_RR   1
#define TORUS_PNT_VEC_RR   2
#define BOX_DX_DY_DZ   1
#define BOX_TWO_PNT   2
#define FACE_OBJ_H_W   1
#define FACE_H_W   2
#define DISK_PNT_VEC_R   1
#define DISK_THREE_PNT   2
#define DISK_R   3
#define CYLINDER_R_H   1
#define CYLINDER_PNT_VEC_R_H   2
#define CYLINDER_R_H_A   3
#define CYLINDER_PNT_VEC_R_H_A   4
#define CONE_R1_R2_H   1
#define CONE_PNT_VEC_R1_R2_H   2
#define SPHERE_R   1
#define SPHERE_PNT_R   2
#define PRISM_BASE_VEC_H   1
#define PRISM_BASE_TWO_PNT   2
#define PRISM_BASE_VEC_H_2WAYS   3
#define PRISM_BASE_TWO_PNT_2WAYS   4
#define PRISM_BASE_DXDYDZ   5
#define PRISM_BASE_DXDYDZ_2WAYS   6
#define DRAFT_PRISM_FEATURE   7
#define REVOLUTION_BASE_AXIS_ANGLE   1
#define REVOLUTION_BASE_AXIS_ANGLE_2WAYS   2
#define PIPE_BASE_PATH   1
#define PIPE_DIFFERENT_SECTIONS   2
#define PIPE_SHELL_SECTIONS   3
#define PIPE_SHELLS_WITHOUT_PATH   4
#define PIPE_BI_NORMAL_ALONG_VECTOR   5
#define PIPE_PATH_TWO_BASES   1
#define PIPE_PATH_TWO_SEQS   2
#define THRUSECTIONS_RULED   1
#define THRUSECTIONS_SMOOTHED   2
#define BOOLEAN_COMMON   1
#define BOOLEAN_CUT   2
#define BOOLEAN_FUSE   3
#define BOOLEAN_SECTION   4
#define BOOLEAN_COMMON_LIST   5
#define BOOLEAN_CUT_LIST   6
#define BOOLEAN_FUSE_LIST   7
#define PARTITION_PARTITION   1
#define PARTITION_HALF   2
#define PARTITION_NO_SELF_INTERSECTIONS   3
#define PARTITION_GENERAL_FUSE   4
#define POLYLINE_POINTS   1
#define POLYLINE2D_PLN_COORDS   2
#define POLYLINE2D_PLN_OBJECT   3
#define SPLINE_BEZIER   1
#define SPLINE_INTERPOLATION   2
#define SPLINE_INTERPOL_TANGENTS   3
#define CIRCLE_THREE_PNT   1
#define CIRCLE_PNT_VEC_R   2
#define CIRCLE_CENTER_TWO_PNT   3
#define ELLIPSE_PNT_VEC_RR   1
#define CIRC_ARC_THREE_PNT   1
#define CIRC_ARC_CENTER   2
#define ELLIPSE_ARC_CENTER_TWO_PNT   3
#define FILLET_SHAPE_ALL   1
#define FILLET_SHAPE_EDGES   2
#define FILLET_SHAPE_FACES   3
#define FILLET_SHAPE_EDGES_2R   4
#define FILLET_SHAPE_FACES_2R   5
#define FILLET_2D_SHAPE_VERTEXES   1
#define FILLET_1D_SHAPE_VERTEXES   1
#define CHAMFER_SHAPE_ALL   1
#define CHAMFER_SHAPE_EDGE   2
#define CHAMFER_SHAPE_FACES   3
#define CHAMFER_SHAPE_EDGES   4
#define CHAMFER_SHAPE_EDGE_AD   5
#define CHAMFER_SHAPE_FACES_AD   6
#define CHAMFER_SHAPE_EDGES_AD   7
#define WIRE_EDGES   1
#define FACE_WIRE   2
#define SHELL_FACES   3
#define SOLID_SHELLS   5
#define COMPOUND_SHAPES   6
#define SUBSHAPE_SORTED   7
#define SUBSHAPE_NOT_SORTED   8
#define FACE_WIRES   9
#define EDGE_WIRE   11
#define EDGE_CURVE_LENGTH   12
#define SHAPES_ON_SHAPE   13
#define SHAPE_ISOLINE   14
#define FACE_FROM_SURFACE   15
#define EDGE_UV   16
#define FACE_UV   17
#define SURFACE_FROM_FACE   18
#define SOLID_FACES   19
#define EXTRACTION   20
#define WRAPPING_FACE   1
#define ARCHIMEDE_TYPE   1
#define SHAPE_PROCESS   1
#define SUPPRESS_FACES   2
#define CLOSE_CONTOUR   3
#define REMOVE_INT_WIRES   4
#define FILL_HOLES   5
#define SEWING   6
#define DIVIDE_EDGE   7
#define CHANGE_ORIENTATION   8
#define LIMIT_TOLERANCE   9
#define FUSE_COLLINEAR_EDGES   10
#define SEWING_NON_MANIFOLD   11
#define REMOVE_INTERNAL_FACES   12
#define DIVIDE_EDGE_BY_POINT   13
#define FUNC_TO_PYTHON_DUMP   13
#define BASIC_FILLING   1
#define FILLING_ON_CONSTRAINTS   2
#define GLUE_FACES   1
#define GLUE_FACES_BY_LIST   2
#define GLUE_EDGES   3
#define GLUE_EDGES_BY_LIST   4
#define SKETCHER_NINE_DOUBLS   1
#define SKETCHER_PLANE   2
#define SKETCHER3D_COORDS   1
#define SKETCHER3D_COMMAND   2
#define CDG_MEASURE   1
#define BND_BOX_MEASURE   2
#define BND_BOX_MEASURE_PRECISE   3
#define VECTOR_FACE_NORMALE   4
#define VERTEX_BY_INDEX   5
#define CURVATURE_VEC_MEASURE   6
#define PROXIMITY_COARSE   1
#define PROXIMITY_PRECISE   2
#define GROUP_FUNCTION   1
#define POINT_CONSTRUCTOR   0
#define COORD_CONSTRUCTOR   1
#define BLOCK_FACE_FOUR_PNT   1
#define BLOCK_FACE_FOUR_EDGES   2
#define BLOCK_FACE_TWO_EDGES   3
#define BLOCK_SIX_FACES   4
#define BLOCK_TWO_FACES   5
#define BLOCK_MULTI_TRANSFORM_1D   6
#define BLOCK_MULTI_TRANSFORM_2D   7
#define BLOCK_COMPOUND_GLUE   8
#define BLOCK_REMOVE_EXTRA   9
#define BLOCK_COMPOUND_IMPROVE   10
#define BLOCK_UNION_FACES   11
#define MARKER_CS   1
#define MARKER_SHAPE   2
#define MARKER_PNT2VEC   3
#define USER_TYPE   200
#define USER_TYPE_EX   1000
#define TD_GET_IN_PLACE   1
#define TD_GET_IN_PLACE_OLD   2
#define TD_GET_IN_PLACE_BY_HISTORY   3
#define CONFORMITY_UPDATE_TOL   2
#define CONFORMITY_CHECK_SHAPE   3
#define PLUGIN_NAME   "Plugin Name"
Enumerations
enum  { TopAbs_FLAT = TopAbs_SHAPE+1 }
◆ ARCHIMEDE_TYPE
◆ BASIC_FILLING
◆ BLOCK_COMPOUND_GLUE
◆ BLOCK_COMPOUND_IMPROVE
◆ BLOCK_FACE_FOUR_EDGES
◆ BLOCK_FACE_FOUR_PNT
◆ BLOCK_FACE_TWO_EDGES
◆ BLOCK_MULTI_TRANSFORM_1D
◆ BLOCK_MULTI_TRANSFORM_2D
◆ BLOCK_REMOVE_EXTRA
◆ BLOCK_SIX_FACES
◆ BLOCK_TWO_FACES
◆ BLOCK_UNION_FACES
◆ BND_BOX_MEASURE
◆ BND_BOX_MEASURE_PRECISE
◆ BOOLEAN_COMMON
◆ BOOLEAN_COMMON_LIST
◆ BOOLEAN_CUT
◆ BOOLEAN_CUT_LIST
◆ BOOLEAN_FUSE
◆ BOOLEAN_FUSE_LIST
◆ BOOLEAN_SECTION
◆ BOX_DX_DY_DZ
◆ BOX_TWO_PNT
◆ CDG_MEASURE
◆ CHAMFER_SHAPE_ALL
◆ CHAMFER_SHAPE_EDGE
◆ CHAMFER_SHAPE_EDGE_AD
◆ CHAMFER_SHAPE_EDGES
◆ CHAMFER_SHAPE_EDGES_AD
◆ CHAMFER_SHAPE_FACES
◆ CHAMFER_SHAPE_FACES_AD
◆ CHANGE_ORIENTATION
◆ CIRC_ARC_CENTER
◆ CIRC_ARC_THREE_PNT
◆ CIRCLE_CENTER_TWO_PNT
◆ CIRCLE_PNT_VEC_R
◆ CIRCLE_THREE_PNT
◆ CLOSE_CONTOUR
◆ COMPOUND_SHAPES
◆ CONE_PNT_VEC_R1_R2_H
◆ CONE_R1_R2_H
◆ CONFORMITY_CHECK_SHAPE
◆ CONFORMITY_UPDATE_TOL
◆ COORD_CONSTRUCTOR
◆ COPY_WITH_REF
◆ COPY_WITHOUT_REF
◆ CURVATURE_VEC_MEASURE
◆ CYLINDER_PNT_VEC_R_H
◆ CYLINDER_PNT_VEC_R_H_A
◆ CYLINDER_R_H
◆ CYLINDER_R_H_A
◆ DISK_PNT_VEC_R
◆ DISK_R
#define DISK_R   3
◆ DISK_THREE_PNT
◆ DIVIDE_EDGE
◆ DIVIDE_EDGE_BY_POINT
◆ DRAFT_PRISM_FEATURE
◆ EDGE_CURVE_LENGTH
◆ EDGE_UV
#define EDGE_UV   16
◆ EDGE_WIRE
◆ ELLIPSE_ARC_CENTER_TWO_PNT
◆ ELLIPSE_PNT_VEC_RR
◆ EXPORT_SHAPE
◆ EXTRACTION
◆ FACE_FROM_SURFACE
◆ FACE_H_W
#define FACE_H_W   2
◆ FACE_OBJ_H_W
◆ FACE_UV
#define FACE_UV   17
◆ FACE_WIRE
#define FACE_WIRE   2
◆ FACE_WIRES
◆ FILL_HOLES
◆ FILLET_1D_SHAPE_VERTEXES
◆ FILLET_2D_SHAPE_VERTEXES
◆ FILLET_SHAPE_ALL
◆ FILLET_SHAPE_EDGES
◆ FILLET_SHAPE_EDGES_2R
◆ FILLET_SHAPE_FACES
◆ FILLET_SHAPE_FACES_2R
◆ FILLING_ON_CONSTRAINTS
◆ FUNC_TO_PYTHON_DUMP
◆ FUSE_COLLINEAR_EDGES
◆ GEOM_3DSKETCHER
◆ GEOM_ARCHIMEDE
◆ GEOM_BLOCK
◆ GEOM_BOOLEAN
◆ GEOM_BOX
#define GEOM_BOX   7
◆ GEOM_CDG
#define GEOM_CDG   35
◆ GEOM_CHAMFER
◆ GEOM_CHECKCONFORMITY
◆ GEOM_CIRC_ARC
◆ GEOM_CIRCLE
◆ GEOM_COMPOUND
◆ GEOM_COMPOUNDFILTER
◆ GEOM_CONE
#define GEOM_CONE   9
◆ GEOM_COPY
#define GEOM_COPY   0
◆ GEOM_CURVATURE_VEC
◆ GEOM_CYLINDER
◆ GEOM_EDGE
◆ GEOM_ELLIPSE
◆ GEOM_ELLIPSE_ARC
◆ GEOM_EXPLODE
◆ GEOM_EXTRACTION
◆ GEOM_EXTRUDED_BOSS
◆ GEOM_EXTRUDED_CUT
◆ GEOM_FACE
◆ GEOM_FIELD
◆ GEOM_FIELD_STEP
◆ GEOM_FILLET
◆ GEOM_FILLET_1D
◆ GEOM_FILLET_2D
◆ GEOM_FILLING
◆ GEOM_FREE_BOUNDS
◆ GEOM_GLUED
◆ GEOM_GROUP
◆ GEOM_IMPORT
◆ GEOM_ISOLINE
◆ GEOM_LINE
#define GEOM_LINE   5
◆ GEOM_MARKER
◆ GEOM_PARTITION
◆ GEOM_PATCH_FACE
◆ GEOM_PIPE
◆ GEOM_PIPE_PATH
◆ GEOM_PLANE
◆ GEOM_POINT
◆ GEOM_POLYLINE
◆ GEOM_POLYLINE2D
◆ GEOM_PRISM
◆ GEOM_PROJECTION
◆ GEOM_REVOLUTION
◆ GEOM_SHAPE_PROXIMITY
◆ GEOM_SHAPES_ON_SHAPE
◆ GEOM_SHELL
◆ GEOM_SKETCHER
◆ GEOM_SOLID
◆ GEOM_SPHERE
◆ GEOM_SPLINE
◆ GEOM_SUBSHAPE
◆ GEOM_THICKENING
◆ GEOM_THRUSECTIONS
◆ GEOM_TORUS
◆ GEOM_TRANSFER_DATA
◆ GEOM_VECTOR
◆ GEOM_WIRE
◆ GLUE_EDGES
◆ GLUE_EDGES_BY_LIST
◆ GLUE_FACES
◆ GLUE_FACES_BY_LIST
◆ GROUP_FUNCTION
◆ IMPORT_SHAPE
◆ LIMIT_TOLERANCE
◆ LINE_PNT_DIR
◆ LINE_TWO_FACES
◆ LINE_TWO_PNT
◆ MARKER_CS
#define MARKER_CS   1
◆ MARKER_PNT2VEC
◆ MARKER_SHAPE
◆ MIRROR_AXIS
◆ MIRROR_AXIS_COPY
◆ MIRROR_PLANE
◆ MIRROR_PLANE_COPY
◆ MIRROR_POINT
◆ MIRROR_POINT_COPY
◆ OFFSET_SHAPE
◆ OFFSET_SHAPE_COPY
◆ OFFSET_THICKENING
◆ OFFSET_THICKENING_COPY
◆ PARTITION_GENERAL_FUSE
◆ PARTITION_HALF
◆ PARTITION_NO_SELF_INTERSECTIONS
◆ PARTITION_PARTITION
◆ PIPE_BASE_PATH
◆ PIPE_BI_NORMAL_ALONG_VECTOR
◆ PIPE_DIFFERENT_SECTIONS
◆ PIPE_PATH_TWO_BASES
◆ PIPE_PATH_TWO_SEQS
◆ PIPE_SHELL_SECTIONS
◆ PIPE_SHELLS_WITHOUT_PATH
◆ PLANE_2_VEC
◆ PLANE_FACE
◆ PLANE_LCS
#define PLANE_LCS   6
◆ PLANE_PNT_VEC
◆ PLANE_TANGENT_FACE
◆ PLANE_THREE_PNT
◆ PLUGIN_NAME
◆ POINT_CONSTRUCTOR
◆ POINT_CURVE_COORD
◆ POINT_CURVE_LENGTH
◆ POINT_CURVE_PAR
◆ POINT_FACE_ANY
◆ POINT_LINES_INTERSECTION
◆ POINT_SURFACE_COORD
◆ POINT_SURFACE_PAR
◆ POINT_XYZ
#define POINT_XYZ   1
◆ POINT_XYZ_REF
◆ POLYLINE2D_PLN_COORDS
◆ POLYLINE2D_PLN_OBJECT
◆ POLYLINE_POINTS
◆ POSITION_ALONG_PATH
◆ POSITION_SHAPE
◆ POSITION_SHAPE_COPY
◆ POSITION_SHAPE_FROM_GLOBAL
◆ POSITION_SHAPE_FROM_GLOBAL_COPY
◆ PRISM_BASE_DXDYDZ
◆ PRISM_BASE_DXDYDZ_2WAYS
◆ PRISM_BASE_TWO_PNT
◆ PRISM_BASE_TWO_PNT_2WAYS
◆ PRISM_BASE_VEC_H
◆ PRISM_BASE_VEC_H_2WAYS
◆ PROJECTION_COPY
◆ PROJECTION_ON_CYLINDER
◆ PROJECTION_ON_WIRE
◆ PROXIMITY_COARSE
◆ PROXIMITY_PRECISE
◆ REMOVE_INT_WIRES
◆ REMOVE_INTERNAL_FACES
◆ REVOLUTION_BASE_AXIS_ANGLE
◆ REVOLUTION_BASE_AXIS_ANGLE_2WAYS
◆ ROTATE
#define ROTATE   1
◆ ROTATE_1D
#define ROTATE_1D   3
◆ ROTATE_1D_STEP
◆ ROTATE_2D
#define ROTATE_2D   4
◆ ROTATE_COPY
◆ ROTATE_THREE_POINTS
◆ ROTATE_THREE_POINTS_COPY
◆ SCALE_SHAPE
◆ SCALE_SHAPE_AXES
◆ SCALE_SHAPE_AXES_COPY
◆ SCALE_SHAPE_COPY
◆ SEWING
#define SEWING   6
◆ SEWING_NON_MANIFOLD
◆ SHAPE_ISOLINE
◆ SHAPE_PROCESS
◆ SHAPES_ON_SHAPE
◆ SHELL_FACES
◆ SKETCHER3D_COMMAND
◆ SKETCHER3D_COORDS
◆ SKETCHER_NINE_DOUBLS
◆ SKETCHER_PLANE
◆ SOLID_FACES
◆ SOLID_SHELLS
◆ SPHERE_PNT_R
◆ SPHERE_R
#define SPHERE_R   1
◆ SPLINE_BEZIER
◆ SPLINE_INTERPOL_TANGENTS
◆ SPLINE_INTERPOLATION
◆ SUBSHAPE_NOT_SORTED
◆ SUBSHAPE_SORTED
◆ SUPPRESS_FACES
◆ SURFACE_FROM_FACE
◆ TD_GET_IN_PLACE
◆ TD_GET_IN_PLACE_BY_HISTORY
◆ TD_GET_IN_PLACE_OLD
◆ THRUSECTIONS_RULED
◆ THRUSECTIONS_SMOOTHED
◆ TORUS_PNT_VEC_RR
◆ TORUS_RR
#define TORUS_RR   1
◆ TRANSFER_DATA
◆ TRANSLATE_1D
◆ TRANSLATE_2D
◆ TRANSLATE_TWO_POINTS
◆ TRANSLATE_TWO_POINTS_COPY
◆ TRANSLATE_VECTOR
◆ TRANSLATE_VECTOR_COPY
◆ TRANSLATE_VECTOR_DISTANCE
◆ TRANSLATE_XYZ
◆ TRANSLATE_XYZ_COPY
◆ USER_TYPE
◆ USER_TYPE_EX
◆ VECTOR_DX_DY_DZ
◆ VECTOR_FACE_NORMALE
◆ VECTOR_REVERSE
◆ VECTOR_TANGENT_CURVE_PAR
◆ VECTOR_TWO_PNT
◆ VERTEX_BY_INDEX
◆ WIRE_EDGES
◆ WRAPPING_FACE
◆ anonymous enum
anonymous enum
TopAbs_FLAT
