GEOMUtils_Hatcher.hxx
23#ifndef _GEOMUtils_Hatcher_HXX_
24#define _GEOMUtils_Hatcher_HXX_
26
27#include <Geom2dHatch_Hatcher.hxx>
28#include <GeomAbs_IsoType.hxx>
29#include <TColStd_HArray1OfInteger.hxx>
30#include <TColStd_HArray1OfReal.hxx>
31#include <TopoDS_Face.hxx>
32
33
37namespace GEOMUtils
38{
39 class Hatcher
40 {
41 public:
42
46 Standard_EXPORT Hatcher(const TopoDS_Face &theFace);
47
53 Standard_EXPORT void Init(const Standard_Integer theNbIsos);
54
61 Standard_EXPORT void Init(const Standard_Integer theNbIsoU,
62 const Standard_Integer theNbIsoV);
63
70 Standard_EXPORT void Init(const GeomAbs_IsoType theIsoType,
71 const Standard_Real theParameter);
72
76 Standard_EXPORT void Perform();
77
84 Standard_Boolean IsDone() const
85 { return myIsDone; }
86
92 const TopoDS_Face &GetFace() const
93 { return myFace; }
94
103 Standard_EXPORT Standard_Integer GetNbDomains
104 (const Standard_Integer theHatchingIndex) const;
105
116 Standard_EXPORT Standard_Boolean GetDomain
117 (const Standard_Integer theHatchingIndex,
118 const Standard_Integer theDomainIndex,
119 Standard_Real &theParam1,
120 Standard_Real &theParam2) const;
121
130 Standard_EXPORT Standard_Boolean IsDomainInfinite
131 (const Standard_Integer theHatchingIndex,
132 const Standard_Integer theDomainIndex) const;
133
139 Standard_EXPORT const Geom2dHatch_Hatcher &GetHatcher() const
140 { return myHatcher; }
141
148 Standard_EXPORT const Handle(TColStd_HArray1OfInteger) &GetUIndices() const
149 { return myUInd; }
150
157 Standard_EXPORT const Handle(TColStd_HArray1OfInteger) &GetVIndices() const
158 { return myVInd; }
159
166 Standard_EXPORT const Handle(TColStd_HArray1OfReal) &GetUParams() const
167 { return myUPrm; }
168
175 Standard_EXPORT const Handle(TColStd_HArray1OfReal) &GetVParams() const
176 { return myVPrm; }
177
184 Standard_EXPORT const Handle(Geom2d_Curve) &GetHatching
185 (const Standard_Integer theHatchingIndex) const;
186
187 protected:
188
192 void Clear();
193
194 private:
195
196 Geom2dHatch_Hatcher myHatcher;
197 TopoDS_Face myFace;
198 Standard_Boolean myIsDone;
199 Standard_Real myUMin;
200 Standard_Real myUMax;
201 Standard_Real myVMin;
202 Standard_Real myVMax;
203 Handle(TColStd_HArray1OfReal) myUPrm;
204 Handle(TColStd_HArray1OfReal) myVPrm;
205 Handle(TColStd_HArray1OfInteger) myUInd;
206 Handle(TColStd_HArray1OfInteger) myVInd;
207
208 };
209}
210
211#endif
Definition: GEOMUtils_Hatcher.hxx:40
This method returns the array of parameters of V-isoline hatchings.
Definition: GEOMUtils_Hatcher.hxx:175
Definition: GEOMUtils_Hatcher.hxx:198
Standard_EXPORT const Geom2dHatch_Hatcher & GetHatcher() const
This method returns the reference to OCCT hatcher.
Definition: GEOMUtils_Hatcher.hxx:139
Definition: GEOMUtils_Hatcher.hxx:202
Definition: GEOMUtils_Hatcher.hxx:196
Standard_EXPORT const Handle(Geom2d_Curve) &GetHatching(const Standard_Integer theHatchingIndex) const
This method returns a hatching curve by its index.
Definition: GEOMUtils_Hatcher.cxx:49
void Clear()
This method clears all hatchings data.
Definition: GEOMUtils_Hatcher.hxx:199
This method returns the array of indices of U-isoline hatchings.
Definition: GEOMUtils_Hatcher.hxx:148
Compute hatching domatins.
Definition: GEOMUtils_Hatcher.cxx:252
Definition: GEOMUtils_Hatcher.hxx:200
Standard_EXPORT Standard_Integer GetNbDomains(const Standard_Integer theHatchingIndex) const
This method returns the number of domains for a particular hatching.
Definition: GEOMUtils_Hatcher.cxx:298
This method returns true if at least one hatching's domains are computed successfully.
Definition: GEOMUtils_Hatcher.hxx:84
const TopoDS_Face & GetFace() const
This method returns the initial face.
Definition: GEOMUtils_Hatcher.hxx:92
Standard_EXPORT Standard_Boolean IsDomainInfinite(const Standard_Integer theHatchingIndex, const Standard_Integer theDomainIndex) const
This method returns Standard_True if a domain has infinite first or last parameter.
Definition: GEOMUtils_Hatcher.cxx:352
Definition: GEOMUtils_Hatcher.hxx:201
This method returns the array of parameters of U-isoline hatchings.
Definition: GEOMUtils_Hatcher.hxx:166
Standard_EXPORT Standard_Boolean GetDomain(const Standard_Integer theHatchingIndex, const Standard_Integer theDomainIndex, Standard_Real &theParam1, Standard_Real &theParam2) const
This method returns the domputed domain range computed for a particular hatching.
Definition: GEOMUtils_Hatcher.cxx:314
TopoDS_Face myFace
Definition: GEOMUtils_Hatcher.hxx:197
This method initializes the hatcher with hatchings.
Definition: GEOMUtils_Hatcher.cxx:143
This method returns the array of indices of V-isoline hatchings.
Definition: GEOMUtils_Hatcher.hxx:157
Definition: GEOMUtils.hxx:56
