GEOMUtils::Hatcher Class Reference
#include <GEOMUtils_Hatcher.hxx>
Standard_EXPORT Hatcher (const TopoDS_Face &theFace)
Standard_EXPORT void Init (const Standard_Integer theNbIsos)
 This method initializes the hatcher with hatchings. More...
Standard_EXPORT void Init (const Standard_Integer theNbIsoU, const Standard_Integer theNbIsoV)
Standard_EXPORT void Init (const GeomAbs_IsoType theIsoType, const Standard_Real theParameter)
 This method initializes the hatcher with a hatching. More...
Standard_EXPORT void Perform ()
 Compute hatching domatins. More...
Standard_Boolean IsDone () const
 This method returns true if at least one hatching's domains are computed successfully. More...
const TopoDS_Face & GetFace () const
 This method returns the initial face. More...
Standard_EXPORT Standard_Integer GetNbDomains (const Standard_Integer theHatchingIndex) const
 This method returns the number of domains for a particular hatching. More...
Standard_EXPORT Standard_Boolean GetDomain (const Standard_Integer theHatchingIndex, const Standard_Integer theDomainIndex, Standard_Real &theParam1, Standard_Real &theParam2) const
 This method returns the domputed domain range computed for a particular hatching. More...
Standard_EXPORT Standard_Boolean IsDomainInfinite (const Standard_Integer theHatchingIndex, const Standard_Integer theDomainIndex) const
 This method returns Standard_True if a domain has infinite first or last parameter. More...
Standard_EXPORT const Geom2dHatch_Hatcher & GetHatcher () const
 This method returns the reference to OCCT hatcher. More...
Standard_EXPORT const Handle (TColStd_HArray1OfInteger) &GetUIndices() const
 This method returns the array of indices of U-isoline hatchings. More...
Standard_EXPORT const Handle (TColStd_HArray1OfInteger) &GetVIndices() const
 This method returns the array of indices of V-isoline hatchings. More...
Standard_EXPORT const Handle (TColStd_HArray1OfReal) &GetUParams() const
 This method returns the array of parameters of U-isoline hatchings. More...
Standard_EXPORT const Handle (TColStd_HArray1OfReal) &GetVParams() const
 This method returns the array of parameters of V-isoline hatchings. More...
Standard_EXPORT const Handle (Geom2d_Curve) &GetHatching(const Standard_Integer theHatchingIndex) const
 This method returns a hatching curve by its index. More...
void Clear ()
 This method clears all hatchings data. More...
 Handle (TColStd_HArray1OfReal) myUPrm
 Handle (TColStd_HArray1OfReal) myVPrm
 Handle (TColStd_HArray1OfInteger) myUInd
 Handle (TColStd_HArray1OfInteger) myVInd
Geom2dHatch_Hatcher myHatcher
TopoDS_Face myFace
Standard_Boolean myIsDone
Standard_Real myUMin
Standard_Real myUMax
Standard_Real myVMin
Standard_Real myVMax
◆ Hatcher()
GEOMUtils::Hatcher::Hatcher ( const TopoDS_Face &  theFace)
Initializes the object with the face.
References Handle(), InfiniteValue, myHatcher, myUMax, myUMin, myVMax, and myVMin.
◆ Clear()
void GEOMUtils::Hatcher::Clear ( )
◆ GetDomain()
Standard_Boolean GEOMUtils::Hatcher::GetDomain ( const Standard_Integer  theHatchingIndex,
Standard_Real &  theParam1,
Standard_Real &  theParam2
theDomainIndex should be in the range [1..GetNbDomains].
theHatchingIndexthe hatching index.
theDomainIndexthe domain index for the particular hatching.
theParam1(output) the first parameter of the domain.
theParam2(output) the last parameter of the domain.
Standard_True in case of success; Standard_False otherwise.
References InfiniteValue.
◆ GetFace()
const TopoDS_Face & GEOMUtils::Hatcher::GetFace ( ) const
the initial face.
References myFace.
◆ GetHatcher()
Standard_EXPORT const Geom2dHatch_Hatcher & GEOMUtils::Hatcher::GetHatcher ( ) const
References myHatcher.
◆ GetNbDomains()
Standard_Integer GEOMUtils::Hatcher::GetNbDomains ( const Standard_Integer  theHatchingIndex) const
If the operation is not done or there is no real hatching for a particular index a negative value is returned.
the number of domains computed for the hatching.
References aResult.
◆ Handle() [1/9]
Standard_EXPORT const GEOMUtils::Hatcher::Handle ( Geom2d_Curve  ) const &
If the curve is not found null handle is returned.
theHatchingIndexthe hatching curve index.
◆ Handle() [2/9]
Standard_EXPORT const GEOMUtils::Hatcher::Handle ( TColStd_HArray1OfInteger  ) const &
Can be null if the object is initialized by 0 U-isolines.
the array of U-isoline hatching indices.
◆ Handle() [3/9]
Can be null if the object is initialized by 0 V-isolines.
the array of V-isoline hatching indices.
◆ Handle() [4/9]
◆ Handle() [5/9]
◆ Handle() [6/9]
Standard_EXPORT const GEOMUtils::Hatcher::Handle ( TColStd_HArray1OfReal  ) const &
the array of U-isoline hatching parameters.
◆ Handle() [7/9]
the array of V-isoline hatching parameters.
◆ Handle() [8/9]
◆ Handle() [9/9]
◆ Init() [1/3]
void GEOMUtils::Hatcher::Init ( const GeomAbs_IsoType  theIsoType,
theIsoTypethe isoline type.
theParameterthe isoline parameter.
References Handle().
◆ Init() [2/3]
void GEOMUtils::Hatcher::Init ( const Standard_Integer  theNbIsos)
theNbIsosthe number of U- and V-isolines.
◆ Init() [3/3]
void GEOMUtils::Hatcher::Init ( const Standard_Integer  theNbIsoU,
theNbIsoUthe number of U-isolines.
theNbIsoVthe number of V-isolines.
◆ IsDomainInfinite()
Standard_Boolean GEOMUtils::Hatcher::IsDomainInfinite ( const Standard_Integer  theHatchingIndex,
Standard_True if a domain is infinite; Standard_False otherwise.
◆ IsDone()
Standard_Boolean GEOMUtils::Hatcher::IsDone ( ) const
Standard_True is case of success.
References myIsDone.
◆ Perform()
void GEOMUtils::Hatcher::Perform ( )
◆ myFace
TopoDS_Face GEOMUtils::Hatcher::myFace
◆ myHatcher
Geom2dHatch_Hatcher GEOMUtils::Hatcher::myHatcher
◆ myIsDone
Standard_Boolean GEOMUtils::Hatcher::myIsDone
◆ myUMax
Standard_Real GEOMUtils::Hatcher::myUMax
◆ myUMin
Standard_Real GEOMUtils::Hatcher::myUMin
◆ myVMax
Standard_Real GEOMUtils::Hatcher::myVMax
◆ myVMin
Standard_Real GEOMUtils::Hatcher::myVMin
