GEOMUtils_TrsfCurve2d.hxx
1// Copyright (C) 2015-2026 CEA, EDF, OPEN CASCADE
20#ifndef _GEOMUtils_TrsfCurve2d_HXX_
21#define _GEOMUtils_TrsfCurve2d_HXX_
23#include <GEOMUtils_Trsf2d.hxx>
24
25#include <Geom2dHatch_Hatcher.hxx>
26#include <GeomAbs_IsoType.hxx>
27#include <TColStd_HArray1OfInteger.hxx>
28#include <TColStd_HArray1OfReal.hxx>
29#include <TopoDS_Face.hxx>
30
31#include <Basics_OCCTVersion.hxx>
32
33
34namespace GEOMUtils
35{
41 {
42#if OCC_VERSION_LARGE >= 0x07070000
43 DEFINE_STANDARD_RTTIEXT(TrsfCurve2d, Adaptor2d_Curve2d)
44#endif
45
46 public:
47
53 Standard_EXPORT TrsfCurve2d(const Handle(Geom2d_Curve) &theCurve,
54 const Trsf2d &theTrsf);
55
61 Standard_EXPORT TrsfCurve2d(const Handle(Geom2d_Curve) &theCurve,
62 const Standard_Real theUFirst,
63 const Standard_Real theULast,
64 const Trsf2d &theTrsf);
65
69 Standard_EXPORT Standard_Real FirstParameter() const;
70
74 Standard_EXPORT Standard_Real LastParameter() const;
75
79 Standard_EXPORT const Handle(Geom2d_Curve)& Curve() const;
80
84 Standard_EXPORT GeomAbs_CurveType GetType() const;
85
89 Standard_EXPORT void Load(const Handle(Geom2d_Curve) &C);
90
94 Standard_EXPORT void Load(const Handle(Geom2d_Curve) &C,
95 const Standard_Real UFirst,
96 const Standard_Real ULast);
97
101 Standard_EXPORT GeomAbs_Shape Continuity() const;
102
106 Standard_EXPORT Standard_Integer NbIntervals(const GeomAbs_Shape S) const;
107
111 Standard_EXPORT void Intervals(TColStd_Array1OfReal &T,
112 const GeomAbs_Shape S) const;
113
117#if OCC_VERSION_LARGE < 0x07070000
118 Standard_EXPORT Handle(Adaptor2d_HCurve2d) Trim
119#else
120 Standard_EXPORT Handle(Adaptor2d_Curve2d) Trim
121#endif
122 (const Standard_Real First, const Standard_Real Last,
123 const Standard_Real ) const;
124
128 Standard_EXPORT Standard_Boolean IsClosed() const;
129
133 Standard_EXPORT Standard_Boolean IsPeriodic() const;
134
138 Standard_EXPORT Standard_Real Period() const;
139
143 Standard_EXPORT gp_Pnt2d Value(const Standard_Real U) const;
144
148 Standard_EXPORT void D0(const Standard_Real U, gp_Pnt2d &P) const;
149
153 Standard_EXPORT void D1(const Standard_Real U,
154 gp_Pnt2d &P, gp_Vec2d &V) const;
155
159 Standard_EXPORT void D2(const Standard_Real U, gp_Pnt2d &P,
160 gp_Vec2d &V1, gp_Vec2d &V2) const;
161
165 Standard_EXPORT void D3(const Standard_Real U, gp_Pnt2d &P,
166 gp_Vec2d &V1, gp_Vec2d &V2, gp_Vec2d &V3) const;
167
171 Standard_EXPORT gp_Vec2d DN(const Standard_Real U,
172 const Standard_Integer N) const;
173
177 Standard_EXPORT Standard_Real Resolution(const Standard_Real Ruv) const;
178
182 Standard_EXPORT gp_Lin2d Line() const;
183
187 Standard_EXPORT gp_Circ2d Circle() const;
188
192 Standard_EXPORT gp_Elips2d Ellipse() const;
193
197 Standard_EXPORT gp_Hypr2d Hyperbola() const;
198
202 Standard_EXPORT gp_Parab2d Parabola() const;
203
207 Standard_EXPORT Standard_Integer Degree() const;
208
212 Standard_EXPORT Standard_Boolean IsRational() const;
213
217 Standard_EXPORT Standard_Integer NbPoles() const;
218
222 Standard_EXPORT Standard_Integer NbKnots() const;
223
227 Standard_EXPORT Handle(Geom2d_BezierCurve) Bezier() const;
228
232 Standard_EXPORT Handle(Geom2d_BSplineCurve) BSpline() const;
233
237 Standard_EXPORT Standard_Integer NbSamples() const;
238
239 private:
240
241 Geom2dAdaptor_Curve myCurve;
243
244 };
245
246#if OCC_VERSION_LARGE >= 0x07070000
248#endif
249
250}
251
252#endif
Definition: GEOMUtils_Trsf2d.hxx:48
Definition: GEOMUtils_TrsfCurve2d.hxx:41
Redefined method from the base class.
Standard_EXPORT const Handle(Geom2d_Curve) &Curve() const
Definition: GEOMUtils_TrsfCurve2d.cxx:60
Standard_EXPORT void D3(const Standard_Real U, gp_Pnt2d &P, gp_Vec2d &V1, gp_Vec2d &V2, gp_Vec2d &V3) const
Standard_EXPORT TrsfCurve2d(const Handle(Geom2d_Curve) &theCurve, const Trsf2d &theTrsf)
Definition: GEOMUtils_TrsfCurve2d.cxx:36
Definition: GEOMUtils_TrsfCurve2d.cxx:69
Definition: GEOMUtils_TrsfCurve2d.hxx:241
Trsf2d myTrsf
Definition: GEOMUtils_TrsfCurve2d.hxx:242
Definition: GEOMUtils_TrsfCurve2d.cxx:126
Standard_EXPORT void D1(const Standard_Real U, gp_Pnt2d &P, gp_Vec2d &V) const
Standard_EXPORT gp_Vec2d DN(const Standard_Real U, const Standard_Integer N) const
Standard_EXPORT void Intervals(TColStd_Array1OfReal &T, const GeomAbs_Shape S) const
Definition: GEOMUtils_TrsfCurve2d.cxx:135
Standard_EXPORT Handle(Adaptor2d_HCurve2d) Trim(const Standard_Real First
Standard_EXPORT const Standard_Real Last
Definition: GEOMUtils_TrsfCurve2d.hxx:122
Definition: GEOMUtils_TrsfCurve2d.cxx:116
Standard_EXPORT void D2(const Standard_Real U, gp_Pnt2d &P, gp_Vec2d &V1, gp_Vec2d &V2) const
Definition: GEOMUtils.hxx:56
@ Bezier
Definition: GEOM_Gen.idl:182
