GEOMUtils::TrsfCurve2d Class Reference
#include <GEOMUtils_TrsfCurve2d.hxx>
Inheritance diagram for GEOMUtils::TrsfCurve2d:
Standard_EXPORT TrsfCurve2d (const Handle(Geom2d_Curve) &theCurve, const Trsf2d &theTrsf)
Standard_EXPORT TrsfCurve2d (const Handle(Geom2d_Curve) &theCurve, const Standard_Real theUFirst, const Standard_Real theULast, const Trsf2d &theTrsf)
Standard_EXPORT Standard_Real FirstParameter () const
 Redefined method from the base class. More...
Standard_EXPORT Standard_Real LastParameter () const
Standard_EXPORT const Handle (Geom2d_Curve) &Curve() const
Standard_EXPORT GeomAbs_CurveType GetType () const
Standard_EXPORT void Load (const Handle(Geom2d_Curve) &C)
Standard_EXPORT void Load (const Handle(Geom2d_Curve) &C, const Standard_Real UFirst, const Standard_Real ULast)
Standard_EXPORT GeomAbs_Shape Continuity () const
Standard_EXPORT Standard_Integer NbIntervals (const GeomAbs_Shape S) const
Standard_EXPORT void Intervals (TColStd_Array1OfReal &T, const GeomAbs_Shape S) const
Standard_EXPORT Handle (Adaptor2d_HCurve2d) Trim(const Standard_Real First
Standard_EXPORT Standard_Boolean IsClosed () const
Standard_EXPORT Standard_Boolean IsPeriodic () const
Standard_EXPORT Standard_Real Period () const
Standard_EXPORT gp_Pnt2d Value (const Standard_Real U) const
Standard_EXPORT void D0 (const Standard_Real U, gp_Pnt2d &P) const
Standard_EXPORT void D1 (const Standard_Real U, gp_Pnt2d &P, gp_Vec2d &V) const
Standard_EXPORT void D2 (const Standard_Real U, gp_Pnt2d &P, gp_Vec2d &V1, gp_Vec2d &V2) const
Standard_EXPORT void D3 (const Standard_Real U, gp_Pnt2d &P, gp_Vec2d &V1, gp_Vec2d &V2, gp_Vec2d &V3) const
Standard_EXPORT gp_Vec2d DN (const Standard_Real U, const Standard_Integer N) const
Standard_EXPORT Standard_Real Resolution (const Standard_Real Ruv) const
Standard_EXPORT gp_Lin2d Line () const
Standard_EXPORT gp_Circ2d Circle () const
Standard_EXPORT gp_Elips2d Ellipse () const
Standard_EXPORT gp_Hypr2d Hyperbola () const
Standard_EXPORT gp_Parab2d Parabola () const
Standard_EXPORT Standard_Integer Degree () const
Standard_EXPORT Standard_Boolean IsRational () const
Standard_EXPORT Standard_Integer NbPoles () const
Standard_EXPORT Standard_Integer NbKnots () const
Standard_EXPORT Handle (Geom2d_BezierCurve) Bezier() const
Standard_EXPORT Handle (Geom2d_BSplineCurve) BSpline() const
Standard_EXPORT Standard_Integer NbSamples () const
Public Attributes
Standard_EXPORT const Standard_Real Last
Standard_EXPORT const Standard_Real const Standard_Real const
Geom2dAdaptor_Curve myCurve
Trsf2d myTrsf
This class represents an adaptor curve that represents an original curve transformed by an anisotropic transformation.
◆ TrsfCurve2d() [1/2]
GEOMUtils::TrsfCurve2d::TrsfCurve2d ( const Handle(Geom2d_Curve) &  theCurve,
const Trsf2d &  theTrsf
Initializes the object with the transformation parameters. Input parameters are not checked for validity. It is under responsibility of the caller.
◆ TrsfCurve2d() [2/2]
Initializes the object with the curve, first and last parameters and transformation. Input parameters are not checked for validity. It is under responsibility of the caller.
◆ Circle()
Standard_EXPORT gp_Circ2d GEOMUtils::TrsfCurve2d::Circle ( ) const
◆ Continuity()
GeomAbs_Shape GEOMUtils::TrsfCurve2d::Continuity ( ) const
◆ D0()
Standard_EXPORT void GEOMUtils::TrsfCurve2d::D0 ( const Standard_Real  U,
gp_Pnt2d &  P
◆ D1()
Standard_EXPORT void GEOMUtils::TrsfCurve2d::D1 ( const Standard_Real  U,
gp_Pnt2d &  P,
gp_Vec2d &  V
◆ D2()
Standard_EXPORT void GEOMUtils::TrsfCurve2d::D2 ( const Standard_Real  U,
gp_Pnt2d &  P,
gp_Vec2d &  V1,
gp_Vec2d &  V2
◆ D3()
Standard_EXPORT void GEOMUtils::TrsfCurve2d::D3 ( const Standard_Real  U,
gp_Pnt2d &  P,
gp_Vec2d &  V1,
gp_Vec2d &  V2,
gp_Vec2d &  V3
◆ Degree()
Standard_EXPORT Standard_Integer GEOMUtils::TrsfCurve2d::Degree ( ) const
◆ DN()
Standard_EXPORT gp_Vec2d GEOMUtils::TrsfCurve2d::DN ( const Standard_Real  U,
◆ Ellipse()
Standard_EXPORT gp_Elips2d GEOMUtils::TrsfCurve2d::Ellipse ( ) const
◆ FirstParameter()
Standard_Real GEOMUtils::TrsfCurve2d::FirstParameter ( ) const
◆ GetType()
Standard_EXPORT GeomAbs_CurveType GEOMUtils::TrsfCurve2d::GetType ( ) const
◆ Handle() [1/4]
Standard_EXPORT GEOMUtils::TrsfCurve2d::Handle ( Adaptor2d_HCurve2d  ) const
◆ Handle() [2/4]
Standard_EXPORT GEOMUtils::TrsfCurve2d::Handle ( Geom2d_BezierCurve  ) const
◆ Handle() [3/4]
Standard_EXPORT GEOMUtils::TrsfCurve2d::Handle ( Geom2d_BSplineCurve  ) const
◆ Handle() [4/4]
Standard_EXPORT const GEOMUtils::TrsfCurve2d::Handle ( Geom2d_Curve  ) const &
◆ Hyperbola()
Standard_EXPORT gp_Hypr2d GEOMUtils::TrsfCurve2d::Hyperbola ( ) const
◆ Intervals()
void GEOMUtils::TrsfCurve2d::Intervals ( TColStd_Array1OfReal &  T,
◆ IsClosed()
Standard_EXPORT Standard_Boolean GEOMUtils::TrsfCurve2d::IsClosed ( ) const
◆ IsPeriodic()
Standard_EXPORT Standard_Boolean GEOMUtils::TrsfCurve2d::IsPeriodic ( ) const
◆ IsRational()
Standard_EXPORT Standard_Boolean GEOMUtils::TrsfCurve2d::IsRational ( ) const
◆ LastParameter()
Standard_Real GEOMUtils::TrsfCurve2d::LastParameter ( ) const
◆ Line()
Standard_EXPORT gp_Lin2d GEOMUtils::TrsfCurve2d::Line ( ) const
◆ Load() [1/2]
Standard_EXPORT void GEOMUtils::TrsfCurve2d::Load ( const Handle(Geom2d_Curve) &  C)
◆ Load() [2/2]
void GEOMUtils::TrsfCurve2d::Load ( const Handle(Geom2d_Curve) &  C,
◆ NbIntervals()
Standard_Integer GEOMUtils::TrsfCurve2d::NbIntervals ( const GeomAbs_Shape  S) const
◆ NbKnots()
Standard_EXPORT Standard_Integer GEOMUtils::TrsfCurve2d::NbKnots ( ) const
◆ NbPoles()
Standard_EXPORT Standard_Integer GEOMUtils::TrsfCurve2d::NbPoles ( ) const
◆ NbSamples()
Standard_EXPORT Standard_Integer GEOMUtils::TrsfCurve2d::NbSamples ( ) const
◆ Parabola()
Standard_EXPORT gp_Parab2d GEOMUtils::TrsfCurve2d::Parabola ( ) const
◆ Period()
Standard_EXPORT Standard_Real GEOMUtils::TrsfCurve2d::Period ( ) const
◆ Resolution()
Standard_EXPORT Standard_Real GEOMUtils::TrsfCurve2d::Resolution ( const Standard_Real  Ruv) const
◆ Value()
Standard_EXPORT gp_Pnt2d GEOMUtils::TrsfCurve2d::Value ( const Standard_Real  U) const
◆ const
Standard_EXPORT const Standard_Real const Standard_Real GEOMUtils::TrsfCurve2d::const
◆ Last
Standard_EXPORT const Standard_Real GEOMUtils::TrsfCurve2d::Last
◆ myCurve
Geom2dAdaptor_Curve GEOMUtils::TrsfCurve2d::myCurve
◆ myTrsf
Trsf2d GEOMUtils::TrsfCurve2d::myTrsf
