GEOM_BaseObject.hxx
23#ifndef _GEOM_BaseObject_HeaderFile
24#define _GEOM_BaseObject_HeaderFile
26#include "GEOM_Function.hxx"
27
28#include <Standard_GUID.hxx>
29#include <TColStd_HSequenceOfTransient.hxx>
30#include <TCollection_AsciiString.hxx>
31#include <TDF_Label.hxx>
32#include <TDataStd_TreeNode.hxx>
33#include <TFunction_Driver.hxx>
34
35#include <vector>
36
37class GEOM_BaseObject;
38class GEOM_Engine;
39
41
43{
44 friend class GEOM_Engine;
45
46protected:
47 Standard_EXPORT GEOM_BaseObject(const TDF_Label& theLabel);
48
49public:
50
51 Standard_EXPORT GEOM_BaseObject(const TDF_Label& theEntry, int theType);
52 Standard_EXPORT ~GEOM_BaseObject();
53
54 //Finds a GEOM_BaseObject on the label theLabel
55 Standard_EXPORT static Handle(GEOM_BaseObject) GetObject(const TDF_Label& theLabel);
56
57 //Finds a GEOM_BaseObject by a reference, stored on the label theLabel
58 Standard_EXPORT static Handle(GEOM_BaseObject) GetReferencedObject(const TDF_Label& theLabel);
59
60 // Returns type of a object (GEOM_POINT, GEOM_VECTOR...) on theLabel, -1 if no object is there
61 Standard_EXPORT static int GetType(const TDF_Label& theLabel);
62
63 //Returns a GEOM_BaseObject common GUID.
64 // This GUID marks the label of any object in GEOM module
65 Standard_EXPORT static const Standard_GUID& GetObjectID();
66
67 //Returns a GUID associated with a sub-shape object
68 // This GUID corresponds to GEOM_SubShapeDriver
69 Standard_EXPORT static const Standard_GUID& GetSubShapeID();
70
71 //###########################################################
72 //Access to properties
73 //###########################################################
74
75 //Returns a TreeNode that presents a root of a function tree for this GEOM_BaseObject
76 Standard_EXPORT Handle(TDataStd_TreeNode) GetRootNode() { return _root; }
77
78 //Returns a label of this GEOM_BaseObject
79 Standard_EXPORT TDF_Label GetEntry() const { return _label; }
80
81 //Returns an entry of this GEOM_BaseObject
82 Standard_EXPORT TCollection_AsciiString GetEntryString();
83
84 //Returns a type of this GEOM_BaseObject (GEOM_POINT, GEOM_VECTOR...)
85 Standard_EXPORT int GetType();
86
87 //Sets the type of this GEOM_BaseObject
88 Standard_EXPORT void SetType(int theType);
89
90 //Modifications counter management
91 Standard_EXPORT int GetTic();
92 Standard_EXPORT void SetTic(int theTic);
93 Standard_EXPORT void IncrementTic();
94
95 //Sets a name of this GEOM_BaseObject
96 Standard_EXPORT void SetName(const char* theName);
97
98 //Returns a name of this GEOM_BaseObject
99 Standard_EXPORT TCollection_AsciiString GetName();
100
101 //Sets an auxiliary data
102 Standard_EXPORT void SetAuxData(const char* theData);
103
104 //Returns an auxiliary data
105 Standard_EXPORT TCollection_AsciiString GetAuxData();
106
107 //Set a notebook variables used for object creation
108 Standard_EXPORT void SetParameters(const TCollection_AsciiString& theParameters);
109
110 //Get a notebook variables used for object creation
111 Standard_EXPORT TCollection_AsciiString GetParameters() const;
112
113 //###########################################################
114 // CORBA related methods
115 //###########################################################
116
117 //Sets an IOR of CORBA GEOM_BaseObject_i which refers to this object
118 Standard_EXPORT void SetIOR(TCollection_AsciiString& theIOR) { _ior = theIOR; }
119
120 //Returns an IOR of CORBA GEOM_BaseObject_i which refers to this object
121 Standard_EXPORT TCollection_AsciiString GetIOR() { return _ior; }
122
123 //###########################################################
124 //Functions methods
125 //###########################################################
126
127 //Adds a function with a driver GUID = theGUID and a type theFunctionType
128 //to the function tree of this GEOM_BaseObject
129 Standard_EXPORT Handle(GEOM_Function) AddFunction(const Standard_GUID& theGUID,
130 int theFunctionType,
131 bool allowSubShape=false);
132
133 //Returns a number of functions of this GEOM_BaseObject
134 Standard_EXPORT int GetNbFunctions();
135
136 //Returns a function with given number theFunctionNumber
137 Standard_EXPORT Handle(GEOM_Function) GetFunction(int theFunctionNumber);
138
139 //Return the last function of this GEOM_BaseObject
140 Standard_EXPORT Handle(GEOM_Function) GetLastFunction();
141
142 //Returns all dependencies of the object
143 Standard_EXPORT Handle(TColStd_HSequenceOfTransient) GetAllDependency();
144
145 //Returns the dependencies of the last function
146 Standard_EXPORT Handle(TColStd_HSequenceOfTransient) GetLastDependency();
147
148 //Returns drivers creators of this object
149 Standard_EXPORT Handle(TFunction_Driver) GetCreationDriver(int funNb);
150
151 //###########################################################
152 // Internal methods
153 //###########################################################
154
155 //Returns a label which could be used to store some additional data
156 Standard_EXPORT TDF_Label GetFreeLabel();
157
158 protected:
159 Handle(TDataStd_TreeNode) _root;
160 TDF_Label _label;
161 TCollection_AsciiString _ior;
162 TCollection_AsciiString _parameters;
163
164public:
165 DEFINE_STANDARD_RTTIEXT(GEOM_BaseObject,Standard_Transient)
166};
167
168#endif
Definition: GEOM_Engine.hxx:91
