GEOM_Engine Class Reference
#include <GEOM_Engine.hxx>
Inheritance diagram for GEOM_Engine:
Standard_EXPORT GEOM_Engine ()
virtual Standard_EXPORT ~GEOM_Engine ()
Standard_EXPORT Handle (TDocStd_Document) GetDocument(bool force
Standard_EXPORT Handle (TDocStd_Application) GetApplication()
Standard_EXPORT Handle (GEOM_BaseObject) GetObject(const char *theEntry
Standard_EXPORT Handle (GEOM_BaseObject) AddBaseObject(int theType)
Standard_EXPORT Handle (GEOM_Object) AddObject(int theType)
Standard_EXPORT bool RemoveObject (Handle(GEOM_BaseObject)&theObject)
Standard_EXPORT bool Save (const char *theFileName)
Standard_EXPORT bool Load (const char *theFileName)
Standard_EXPORT void Close ()
Standard_EXPORT void SetUndoLimit (int theLimit)
Standard_EXPORT void Undo ()
Standard_EXPORT void Redo ()
Standard_EXPORT Handle (GEOM_Object) AddSubShape(Handle(GEOM_Object) theMainShape
Standard_EXPORT Handle (TColStd_HArray1OfInteger) theIndices
Standard_EXPORT TCollection_AsciiString DumpPython (std::vector< TObjectData > &theObjectData, TVariablesList theVariables, bool isPublished, bool isMultiFile, bool &aValidScript)
Standard_EXPORT const char * GetDumpName (const char *theStudyEntry) const
Standard_EXPORT Handle (TColStd_HSequenceOfAsciiString) GetAllDumpNames() const
Standard_EXPORT int addTexture (int theWidth, int theHeight, const Handle(TColStd_HArray1OfByte)&theTexture, const TCollection_AsciiString &theFileName="")
Standard_EXPORT Handle (TColStd_HArray1OfByte) getTexture(int theTextureID
Standard_EXPORT std::list< int > getAllTextures ()
Standard_EXPORT void healPyName (TCollection_AsciiString &pyName, const TCollection_AsciiString &anEntry, Resource_DataMapOfAsciiStringAsciiString &aNameToEntry)
 Fix up the name of python variable. More...
static Standard_EXPORT GEOM_Engine * GetEngine ()
static const Standard_GUID & GetTextureGUID ()
Public Attributes
Standard_EXPORT bool force =true)
Standard_EXPORT bool isStandaloneOperation = false)
Standard_EXPORT int & theWidth
Standard_EXPORT int int & theHeight
Standard_EXPORT int int TCollection_AsciiString & theFileName
static Standard_EXPORT void SetEngine (GEOM_Engine *theEngine)
 Handle (GEOM_Application) _OCAFApp
 Handle (TDocStd_Document) _document
int _UndoLimit
GEOM_DataMapOfAsciiStringTransient _objects
Resource_DataMapOfAsciiStringAsciiString _studyEntry2NameMap
std::list< TDF_Label > _freeLabels
◆ GEOM_Engine()
GEOM_Engine::GEOM_Engine ( )
Constructor
References _UndoLimit.
◆ ~GEOM_Engine()
GEOM_Engine::~GEOM_Engine ( )
Destructor
References _objects, Close(), Handle(), and RemoveObject().
◆ addTexture()
Standard_EXPORT int GEOM_Engine::addTexture ( int  theWidth,
int  theHeight,
const Handle(TColStd_HArray1OfByte)&  theTexture,
const TCollection_AsciiString &  theFileName = ""
◆ Close()
void GEOM_Engine::Close ( )
Close
References _freeLabels, and _objects.
◆ DumpPython()
TCollection_AsciiString GEOM_Engine::DumpPython ( std::vector< TObjectData > &  theObjectData,
bool  isPublished,
bool  isMultiFile,
bool &  aValidScript
◆ getAllTextures()
std::list< int > GEOM_Engine::getAllTextures ( )
◆ GetDumpName()
const char * GEOM_Engine::GetDumpName ( const char *  theStudyEntry) const
References _studyEntry2NameMap.
◆ GetEngine()
GEOM_Engine * GEOM_Engine::GetEngine ( )
GetEngine
References TheEngine.
◆ GetTextureGUID()
const Standard_GUID & GEOM_Engine::GetTextureGUID ( )
◆ Handle() [1/11]
GEOM_Engine::Handle ( GEOM_Application  )
◆ Handle() [2/11]
Standard_EXPORT GEOM_Engine::Handle ( GEOM_BaseObject  )
◆ Handle() [3/11]
Standard_EXPORT GEOM_Engine::Handle ( GEOM_BaseObject  ) const
◆ Handle() [4/11]
Standard_EXPORT GEOM_Engine::Handle ( GEOM_Object  )
◆ Handle() [5/11]
◆ Handle() [6/11]
Standard_EXPORT GEOM_Engine::Handle ( TColStd_HArray1OfByte  )
◆ Handle() [7/11]
Standard_EXPORT GEOM_Engine::Handle ( TColStd_HArray1OfInteger  )
◆ Handle() [8/11]
Standard_EXPORT GEOM_Engine::Handle ( TColStd_HSequenceOfAsciiString  ) const
◆ Handle() [9/11]
Standard_EXPORT GEOM_Engine::Handle ( TDocStd_Application  )
◆ Handle() [10/11]
GEOM_Engine::Handle ( TDocStd_Document  )
◆ Handle() [11/11]
Standard_EXPORT GEOM_Engine::Handle ( TDocStd_Document  )
◆ healPyName()
void GEOM_Engine::healPyName ( TCollection_AsciiString &  pyName,
const TCollection_AsciiString &  anEntry,
Resource_DataMapOfAsciiStringAsciiString &  aNameToEntry
◆ Load()
bool GEOM_Engine::Load ( const char *  theFileName)
Load
References _UndoLimit, Handle(), and theFileName.
◆ Redo()
void GEOM_Engine::Redo ( )
Redo
◆ RemoveObject()
bool GEOM_Engine::RemoveObject ( Handle(GEOM_BaseObject)&  theObject)
RemoveObject
References _freeLabels, _objects, BuildIDFromObject(), and Handle().
◆ Save()
bool GEOM_Engine::Save ( const char *  theFileName)
Save
References theFileName.
◆ SetEngine()
void GEOM_Engine::SetEngine ( GEOM_Engine *  theEngine)
staticprotected
SetEngine
◆ SetUndoLimit()
Standard_EXPORT void GEOM_Engine::SetUndoLimit ( int  theLimit)
◆ Undo()
void GEOM_Engine::Undo ( )
Undo
◆ _freeLabels
std::list<TDF_Label> GEOM_Engine::_freeLabels
◆ _objects
GEOM_DataMapOfAsciiStringTransient GEOM_Engine::_objects
◆ _studyEntry2NameMap
Resource_DataMapOfAsciiStringAsciiString GEOM_Engine::_studyEntry2NameMap
◆ _UndoLimit
int GEOM_Engine::_UndoLimit
◆ force
Standard_EXPORT bool GEOM_Engine::force =true)
◆ isStandaloneOperation
Standard_EXPORT bool GEOM_Engine::isStandaloneOperation = false)
◆ theFileName
Standard_EXPORT int int TCollection_AsciiString& GEOM_Engine::theFileName
◆ theHeight
Standard_EXPORT int int& GEOM_Engine::theHeight
◆ theWidth
Standard_EXPORT int& GEOM_Engine::theWidth
