GEOM_Engine.cxx File Reference
#include "GEOM_Engine.hxx"
#include "GEOM_Field.hxx"
#include "GEOM_Function.hxx"
#include "GEOM_ISubShape.hxx"
#include "GEOM_PythonDump.hxx"
#include "GEOM_Solver.hxx"
#include "GEOM_SubShapeDriver.hxx"
#include "Sketcher_Profile.hxx"
#include "utilities.h"
#include <Basics_Utils.hxx>
#include <Basics_OCCTVersion.hxx>
#include <TDF_Tool.hxx>
#include <TDF_Data.hxx>
#include <TDF_Reference.hxx>
#include <TDF_LabelSequence.hxx>
#include <TDataStd_Integer.hxx>
#include <TDataStd_ChildNodeIterator.hxx>
#include <TFunction_Driver.hxx>
#include <TFunction_DriverTable.hxx>
#include <TDataStd_ByteArray.hxx>
#include <TDataStd_UAttribute.hxx>
#include <TDF_ChildIterator.hxx>
#include <TDataStd_Comment.hxx>
#include <TopExp.hxx>
#include <TCollection_ExtendedString.hxx>
#include <TColStd_SequenceOfAsciiString.hxx>
#include <TColStd_MapOfTransient.hxx>
#include <TColStd_HSequenceOfInteger.hxx>
#include <TColStd_DataMapIteratorOfDataMapOfIntegerTransient.hxx>
#include <Resource_DataMapIteratorOfDataMapOfAsciiStringAsciiString.hxx>
#include <BinDrivers.hxx>
#include <StdDrivers_DocumentRetrievalDriver.hxx>
#include <PCDM_StorageDriver.hxx>
#include <set>
#include <Standard_Failure.hxx>
#define COMMA   ','
#define O_BRACKET   '('
#define C_BRACKET   ')'
#define O_SQR_BRACKET   '['
#define C_SQR_BRACKET   ']'
#define PY_NULL   "None"
#define TEXTURE_LABEL_ID   1
#define TEXTURE_LABEL_FILE   2
#define TEXTURE_LABEL_WIDTH   3
#define TEXTURE_LABEL_HEIGHT   4
#define TEXTURE_LABEL_DATA   5
Typedefs
typedef std::map< TCollection_AsciiString, TCollection_AsciiString > TSting2StringMap
typedef std::map< TCollection_AsciiString, TObjectData > TSting2ObjDataMap
typedef std::map< TCollection_AsciiString, TObjectData * > TSting2ObjDataPtrMap
typedef std::map< int, std::list< int > > TIntToListIntMap
static TCollection_AsciiString BuildIDFromObject (Handle(GEOM_BaseObject)&theObject)
bool ProcessFunction (Handle(GEOM_Function)&theFunction, TCollection_AsciiString &theScript, TCollection_AsciiString &theAfterScript, const TVariablesList &theVariables, const bool, TDF_LabelMap &theProcessed, std::set< TCollection_AsciiString > &theIgnoreObjs, bool &theIsDumpCollected)
static int GetTag (const TCollection_AsciiString &theEntry)
static void FillMapOfRef (const Handle(GEOM_Function) &theFunction, TIntToListIntMap &theRefMap)
void ReplaceVariables (TCollection_AsciiString &theCommand, const TVariablesList &theVariables)
 Handle (TColStd_HSequenceOfInteger) FindEntries(TCollection_AsciiString &theString)
void ReplaceEntriesByNames (TCollection_AsciiString &theScript, TSting2ObjDataMap &aEntry2ObjData, const bool theIsPublished, TColStd_SequenceOfAsciiString &theObjListToPublish, Standard_Integer &objectCounter, Resource_DataMapOfAsciiStringAsciiString &aNameToEntry)
void AddObjectColors (TCollection_AsciiString &theScript, const TSting2ObjDataMap &theEntry2ObjData)
void AddTextures (TCollection_AsciiString &theScript)
void PublishObject (TObjectData &theObjectData, TSting2ObjDataMap &theEntry2ObjData, const TSting2ObjDataPtrMap &theStEntry2ObjDataPtr, Resource_DataMapOfAsciiStringAsciiString &theNameToEntry, std::map< int, TCollection_AsciiString > &theEntryToCmdMap, std::set< TCollection_AsciiString > &theMapOfPublished)
static TCollection_AsciiString GetPublishCommands (const int theTag, const std::map< int, TCollection_AsciiString > &theEntryToCmdMap, const TIntToListIntMap &theMapRefs, std::set< int > &thePublished)
 Returns the string of publishing commands. Take into account that references should be published prior to the objects refer to them. More...
void Prettify (TCollection_AsciiString &theScript)
 Handle (TDocStd_Document) GEOM_Engine
 Handle (GEOM_BaseObject) GEOM_Engine
 Handle (GEOM_Object) GEOM_Engine
 Adds a new object of the type theType in the OCAF document. More...
 Handle (TColStd_HSequenceOfAsciiString) GEOM_Engine
 Handle (TColStd_HArray1OfByte) GEOM_Engine
TCollection_AsciiString MakeCommandfor3DSketcher (const TCollection_AsciiString &theDescr)
static TCollection_AsciiString pack_data (const Handle(TColStd_HArray1OfByte)&aData)
Variables
static GEOM_Engine * TheEngine = NULL
◆ C_BRACKET
◆ C_SQR_BRACKET
◆ COMMA
#define COMMA   ','
◆ O_BRACKET
◆ O_SQR_BRACKET
◆ PY_NULL
◆ TEXTURE_LABEL_DATA
◆ TEXTURE_LABEL_FILE
◆ TEXTURE_LABEL_HEIGHT
◆ TEXTURE_LABEL_ID
◆ TEXTURE_LABEL_WIDTH
Typedef Documentation
◆ TIntToListIntMap
typedef std::map< int, std::list < int > > TIntToListIntMap
◆ TSting2ObjDataMap
◆ TSting2ObjDataPtrMap
typedef std::map< TCollection_AsciiString, TObjectData* > TSting2ObjDataPtrMap
◆ TSting2StringMap
◆ AddObjectColors()
void AddObjectColors ( TCollection_AsciiString &  theScript,
const TSting2ObjDataMap &  theEntry2ObjData
AddObjectColors: Add color to objects
References GEOM::Color, GEOM_Engine::GetEngine(), and Handle().
◆ AddTextures()
void AddTextures ( TCollection_AsciiString &  theScript)
◆ BuildIDFromObject()
static TCollection_AsciiString BuildIDFromObject ( Handle(GEOM_BaseObject)&  theObject)
◆ FillMapOfRef()
void FillMapOfRef ( const Handle(GEOM_Function) &  theFunction,
TIntToListIntMap &  theRefMap
FillMapOfRef: Fill the map of references
References GetTag(), and Handle().
◆ GetPublishCommands()
TCollection_AsciiString GetPublishCommands ( const int  theTag,
const std::map< int, TCollection_AsciiString > &  theEntryToCmdMap,
const TIntToListIntMap &  theMapRefs,
std::set< int > &  thePublished
References aResult, and GetPublishCommands().
◆ GetTag()
int GetTag ( const TCollection_AsciiString &  theEntry)
GetTag: Returns the tag from entry
◆ Handle() [1/6]
◆ Handle() [2/6]
Handle ( GEOM_Object  )
AddSubShape
References GEOM_Engine::Handle().
◆ Handle() [3/6]
◆ Handle() [4/6]
Handle ( TColStd_HSequenceOfAsciiString  )
◆ Handle() [5/6]
Handle ( TColStd_HSequenceOfInteger  ) &
FindEntries: Returns a sequence of start/end positions of entries in the string
References Handle().
◆ Handle() [6/6]
Handle ( TDocStd_Document  )
◆ MakeCommandfor3DSketcher()
TCollection_AsciiString MakeCommandfor3DSketcher ( const TCollection_AsciiString &  theDescr)
MakeCommandfor3DSketcher: Make new command for 3DSketcher
References aResult.
◆ pack_data()
static TCollection_AsciiString pack_data ( const Handle(TColStd_HArray1OfByte)&  aData)
◆ Prettify()
void Prettify ( TCollection_AsciiString &  theScript)
◆ ProcessFunction()
bool ProcessFunction ( Handle(GEOM_Function)&  theFunction,
TCollection_AsciiString &  theAfterScript,
const TVariablesList &  theVariables,
TDF_LabelMap &  theProcessed,
std::set< TCollection_AsciiString > &  theIgnoreObjs,
bool &  theIsDumpCollected
ProcessFunction: Dump function description into script
References Sketcher_Profile::GetDump(), MakeCommandfor3DSketcher(), and ReplaceVariables().
◆ PublishObject()
void PublishObject ( TObjectData &  theObjectData,
TSting2ObjDataMap &  theEntry2ObjData,
const TSting2ObjDataPtrMap &  theStEntry2ObjDataPtr,
Resource_DataMapOfAsciiStringAsciiString &  theNameToEntry,
std::set< TCollection_AsciiString > &  theIgnoreMap
◆ ReplaceEntriesByNames()
void ReplaceEntriesByNames ( TCollection_AsciiString &  theScript,
TSting2ObjDataMap &  aEntry2ObjData,
const bool  ,
TColStd_SequenceOfAsciiString &  theObjListToPublish,
Standard_Integer &  objectCounter,
Resource_DataMapOfAsciiStringAsciiString &  aNameToEntry
ReplaceEntriesByNames: Replace object entries by their names
References TObjectData::_name, TObjectData::_pyName, GEOM_Engine::GetEngine(), Handle(), and GEOM_Engine::healPyName().
◆ ReplaceVariables()
void ReplaceVariables ( TCollection_AsciiString &  theCommand,
ReplaceVariables: Replace parameters of the function by variales from Notebook if need
References C_BRACKET, C_SQR_BRACKET, COMMA, ObjectStates::GetCurrectState(), ObjectStates::IncrementState(), O_BRACKET, O_SQR_BRACKET, and PY_NULL.
Variable Documentation
◆ TheEngine
GEOM_Engine* TheEngine = NULL
