GEOM_Field.hxx
23#ifndef _GEOM_Field_HeaderFile
24#define _GEOM_Field_HeaderFile
26#include "GEOM_Object.hxx"
27
28#include <list>
30
31const int GEOM_FIELD_OBJTYPE = 52; // same value #defined in GEOMImpl_Types.hxx
33
34class GEOM_Field;
35class GEOM_FieldStep;
38
40{
41 GEOM_Field(const TDF_Label& theLabel);
42 friend class GEOM_Engine;
43
44 public:
45
46 // Function types
47 enum { FUN_ADD_FIELD = 1,
50 //FUN_REMOVE_STEP,
52 FUN_CHANGE_VALUE
53 };
54
55 // Creates a GEOM_Field on an empty Label
56 Standard_EXPORT GEOM_Field(const TDF_Label& theLabel, int );
57 Standard_EXPORT ~GEOM_Field();
58
59 // Finds a GEOM_Field on theLabel
60 Standard_EXPORT static Handle(GEOM_Field) GetField(const TDF_Label& theLabel);
61
62 // Returns a GUID associated with a field object (GEOM_Field or GEOM_FieldStep)
63 // This GUID corresponds to GEOMImpl_FieldDriver::GetID() and
64 // it also marks TDataStd_TreeNode on a label of GEOM_FieldStep
65 Standard_EXPORT static const Standard_GUID& GetFieldID();
66
67 // Sets the basic data that do not change (except compNames?)
68 Standard_EXPORT void Init(const Handle(GEOM_Object)& theShape,
69 const char* theName,
70 const int theDataType,
71 const int theDimension,
72 const Handle(TColStd_HArray1OfExtendedString)& theCompNames);
73
74 // Returns a shape this GEOM_Field lies on
75 Standard_EXPORT Handle(GEOM_Object) GetShape();
76
77 // Returns a data type of this GEOM_Field
78 // 0 - bool, 1 - int, 2 - double, 3 - string
79 Standard_EXPORT int GetDataType();
80
81 // Returns one of "Bool","Int","Double","String"
82 Standard_EXPORT static TCollection_AsciiString GetDataTypeString(int type);
83
84 // Returns dimension of the shape the field lies on:
85 // 0 - VERTEX, 1 - EDGE, 2 - FACE, 3 - SOLID, -1 - whole shape
86 Standard_EXPORT int GetDimension();
87
88 // Sets names of components
89 Standard_EXPORT void SetComponents( const Handle(TColStd_HArray1OfExtendedString)& compNames );
90
91 // Returns names of components
92 Standard_EXPORT Handle(TColStd_HArray1OfExtendedString) GetComponents();
93
94 // Returns names of components in a python syntax
95 Standard_EXPORT TCollection_AsciiString GetComponentsForPython();
96
97 // Returns number of components
98 Standard_EXPORT int GetNbComponents();
99
100 // Returns number of sub-shapes.
101 // Size of data arrays == GetNbSubShapes() * GetComponents()->Extent()
102 Standard_EXPORT int GetNbSubShapes();
103
104 // Returns number of sub-shapes of given dimension
105 Standard_EXPORT static int GetNbSubShapes(const Handle(GEOM_Object)& shape,
106 const int dim);
107
108 // Returns size of data array == GetNbSubShapes() * GetComponents()->Extent()
109 Standard_EXPORT int GetArrayLength();
110
111 // Removes a component. Number counts from one.
112 //Standard_EXPORT void RemoveComponent(const int number);
113
114 // Adds a step
115 Standard_EXPORT Handle(GEOM_FieldStep) AddStep(const int stepID, const int stamp);
116
117 // Removes a step
118 Standard_EXPORT void RemoveStep(const int stepID);
119
120 // Returns a step
121 Standard_EXPORT Handle(GEOM_FieldStep) GetStep(const int stepID);
122
123 // Returns all steps
124 Standard_EXPORT std::list< Handle(GEOM_FieldStep)> GetSteps();
125
126 DEFINE_STANDARD_RTTIEXT(GEOM_Field,GEOM_BaseObject)
127
128private:
129
130 int nbSubShapes; // not to explode the shape each time nbSubShapes is needed
131};
132
133
135{
136 GEOM_FieldStep(const TDF_Label& theLabel);
137 friend class GEOM_Engine;
138
139public:
140 // Creates a GEOM_FieldStep on an empty Label
141 Standard_EXPORT GEOM_FieldStep(const TDF_Label& theLabel, int );
142 Standard_EXPORT ~GEOM_FieldStep();
143
144 // Sets the basic data
145 Standard_EXPORT void Init(const Handle(GEOM_Field)& theField,
146 const int theID,
147 const int theStamp);
148
149 // Finds a GEOM_FieldStep on the label theLabel
150 Standard_EXPORT static Handle(GEOM_FieldStep) GetFieldStep(const TDF_Label& theLabel);
151
152 // Returns the Field this GEOM_FieldStep belongs to
153 Standard_EXPORT Handle(GEOM_Field) GetField();
154
155 // Returns the stamp step id
156 Standard_EXPORT int GetID();
157
158 // Removes a component. Number counts from one.
159 //Standard_EXPORT void RemoveComponent(const int number);
160
161 // Sets the stamp of the step
162 Standard_EXPORT void SetStamp(const int stamp);
163
164 // Returns the stamp of the step
165 Standard_EXPORT int GetStamp();
166
167 // Sets int or bool values. Returns false if number of values is wrong
168 Standard_EXPORT bool SetValues( const Handle(TColStd_HArray1OfInteger)& values );
169
170 // Sets double values. Returns false if number of values is wrong
171 Standard_EXPORT bool SetValues( const Handle(TColStd_HArray1OfReal)& values );
172
173 // Sets string values. Returns false if number of values is wrong
174 Standard_EXPORT bool SetValues( const Handle(TColStd_HArray1OfExtendedString)& values );
175
176 // Returns int or bool values
177 Standard_EXPORT Handle(TColStd_HArray1OfInteger) GetIntValues();
178
179 // Returns double values
180 Standard_EXPORT Handle(TColStd_HArray1OfReal) GetDoubleValues();
181
182 // Returns string values
183 Standard_EXPORT Handle(TColStd_HArray1OfExtendedString) GetStringValues();
184
185 // Returns GUID of CAF data array
186 const Standard_GUID& GetDataID();
187
188 DEFINE_STANDARD_RTTIEXT(GEOM_FieldStep,GEOM_BaseObject)
189
190private:
191
192 Handle(GEOM_Function) getFunctionToSetValuesAndDump(const TCollection_AsciiString& valueStr);
193
194};
195
196
197#endif
const int GEOM_FIELD_STEP_OBJTYPE
Definition: GEOM_Field.hxx:32
Definition: GEOM_Field.hxx:31
Definition: GEOM_Engine.hxx:91
Definition: GEOM_Field.hxx:135
Standard_EXPORT void Init(const Handle(GEOM_Field)&theField, const int theID, const int theStamp)
Sets the basic data.
Definition: GEOM_Field.cxx:495
const Standard_GUID & GetDataID()
Definition: GEOM_Field.cxx:741
Definition: GEOM_Field.cxx:529
GEOM_FieldStep(const TDF_Label &theLabel)
Definition: GEOM_Field.cxx:571
static Standard_EXPORT Handle(GEOM_FieldStep) GetFieldStep(const TDF_Label &theLabel)
Standard_EXPORT bool SetValues(const Handle(TColStd_HArray1OfInteger)&values)
Definition: GEOM_Field.cxx:634
Definition: GEOM_Field.hxx:40
@ FUN_ADD_STEP
Definition: GEOM_Field.hxx:48
@ FUN_CHANGE_STEP_STAMP
Definition: GEOM_Field.hxx:51
@ FUN_CHANGE_COMP_NAMES
Definition: GEOM_Field.hxx:49
static Standard_EXPORT int GetNbSubShapes(const Handle(GEOM_Object)&shape, const int dim)
static Standard_EXPORT Handle(GEOM_Field) GetField(const TDF_Label &theLabel)
GEOM_Field(const TDF_Label &theLabel)
Standard_EXPORT GEOM_Field(const TDF_Label &theLabel, int)
