GEOM_IHealingOperations_i.hh
23#ifndef _GEOM_IHealingOperations_i_HeaderFile
24#define _GEOM_IHealingOperations_i_HeaderFile
26#include "GEOMImpl_Gen.hxx"
27
28#include <SALOMEconfig.h>
30#include CORBA_SERVER_HEADER(GEOM_Gen)
31#include "GEOM_IOperations_i.hh"
32#include "GEOM_Object_i.hh"
33
35
37 public virtual POA_GEOM::GEOM_IHealingOperations,
38 public virtual GEOM_IOperations_i
39{
40 public:
41 GEOM_IHealingOperations_i(PortableServer::POA_ptr thePOA,
42 GEOM::GEOM_Gen_ptr theEngine,
45
46 GEOM::GEOM_Object_ptr ProcessShape(GEOM::GEOM_Object_ptr theObject,
47 const GEOM::string_array& theOperations,
48 const GEOM::string_array& theParams,
49 const GEOM::string_array& theValues);
50
51 void GetShapeProcessParameters(GEOM::string_array_out theOperations,
52 GEOM::string_array_out theParams,
53 GEOM::string_array_out theValues);
54
55 void GetOperatorParameters (const char* theOperator,
56 GEOM::string_array_out theParams,
57 GEOM::string_array_out theValues);
58
59 GEOM::GEOM_Object_ptr SuppressFaces(GEOM::GEOM_Object_ptr theObject,
60 const GEOM::short_array& theFaces);
61
62 GEOM::GEOM_Object_ptr CloseContour (GEOM::GEOM_Object_ptr theObject,
63 const GEOM::short_array& theWires,
64 CORBA::Boolean isCommonVertex);
65
66 GEOM::GEOM_Object_ptr RemoveIntWires (GEOM::GEOM_Object_ptr theObject,
67 const GEOM::short_array& theWires);
68
69 GEOM::GEOM_Object_ptr FillHoles (GEOM::GEOM_Object_ptr theObject,
70 const GEOM::short_array& theWires);
71
72 GEOM::GEOM_Object_ptr Sew (const GEOM::ListOfGO & theObject,
73 CORBA::Double theTolerance);
74
75 GEOM::GEOM_Object_ptr SewAllowNonManifold (const GEOM::ListOfGO & theObject,
76 CORBA::Double theTolerance);
77
78 GEOM::GEOM_Object_ptr RemoveInternalFaces (const GEOM::ListOfGO& theSolids);
79
80 GEOM::GEOM_Object_ptr DivideEdge (GEOM::GEOM_Object_ptr theObject,
81 CORBA::Short theIndex,
82 CORBA::Double theValue,
83 CORBA::Boolean isByParameter);
84
85 GEOM::GEOM_Object_ptr DivideEdgeByPoint (GEOM::GEOM_Object_ptr theObject,
86 CORBA::Short theIndex,
87 const GEOM::ListOfGO& thePoints);
88
89 GEOM::GEOM_Object_ptr FuseCollinearEdgesWithinWire (GEOM::GEOM_Object_ptr theWire,
90 const GEOM::ListOfGO& theVertices);
91
92 CORBA::Boolean GetFreeBoundary(const GEOM::ListOfGO& theObjects,
93 GEOM::ListOfGO_out theClosedWires,
94 GEOM::ListOfGO_out theOpenWires );
95
96 GEOM::GEOM_Object_ptr ChangeOrientation (GEOM::GEOM_Object_ptr theObject);
97 GEOM::GEOM_Object_ptr ChangeOrientationCopy (GEOM::GEOM_Object_ptr theObject);
98
99 GEOM::GEOM_Object_ptr LimitTolerance (GEOM::GEOM_Object_ptr theObject,
100 CORBA::Double theTolerance,
101 CORBA::Boolean theExactAdjust);
102
103 // The only goal is to provide Python dump functionality for
104 // algorithms entirely implemented in Python.
105 void FuncToPythonDump(
106 GEOM::GEOM_Object_ptr theObject,
107 GEOM::GEOM_Object_ptr result,
108 const char* imports,
109 const char* funcName,
110 const char* args
111 );
112
114
115 GEOM::ModifStatistics* GetStatistics();
116
117private:
118 Handle(TColStd_HArray1OfInteger) Convert( const GEOM::short_array& );
119
120};
121
122#endif
#define GEOM_I_EXPORT
Definition: GEOM_GEOM_I.hxx:33
Definition: GEOMImpl_IHealingOperations.hxx:38
Definition: GEOM_IHealingOperations_i.hh:39
::GEOMImpl_IHealingOperations * GetOperations()
Definition: GEOM_IHealingOperations_i.hh:113
Definition: GEOM_IOperations_i.hh:37
::GEOM_IOperations * GetImpl()
Definition: GEOM_IOperations_i.hh:60
sequence< GEOM_Object > ListOfGO
Definition: GEOM_Gen.idl:290
sequence< short > short_array
Definition: GEOM_Gen.idl:277
sequence< string > string_array
Definition: GEOM_Gen.idl:276
sequence< ModifInfo > ModifStatistics
Definition: GEOM_Gen.idl:273
