GEOM_IHealingOperations_i Class Reference
#include <GEOM_IHealingOperations_i.hh>
Inheritance diagram for GEOM_IHealingOperations_i:
 GEOM_IHealingOperations_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, ::GEOMImpl_IHealingOperations *theImpl)
 ~GEOM_IHealingOperations_i ()
GEOM::GEOM_Object_ptr ProcessShape (GEOM::GEOM_Object_ptr theObject, const GEOM::string_array &theOperations, const GEOM::string_array &theParams, const GEOM::string_array &theValues)
void GetShapeProcessParameters (GEOM::string_array_out theOperations, GEOM::string_array_out theParams, GEOM::string_array_out theValues)
void GetOperatorParameters (const char *theOperator, GEOM::string_array_out theParams, GEOM::string_array_out theValues)
GEOM::GEOM_Object_ptr SuppressFaces (GEOM::GEOM_Object_ptr theObject, const GEOM::short_array &theFaces)
GEOM::GEOM_Object_ptr CloseContour (GEOM::GEOM_Object_ptr theObject, const GEOM::short_array &theWires, CORBA::Boolean isCommonVertex)
GEOM::GEOM_Object_ptr RemoveIntWires (GEOM::GEOM_Object_ptr theObject, const GEOM::short_array &theWires)
GEOM::GEOM_Object_ptr FillHoles (GEOM::GEOM_Object_ptr theObject, const GEOM::short_array &theWires)
GEOM::GEOM_Object_ptr Sew (const GEOM::ListOfGO &theObject, CORBA::Double theTolerance)
GEOM::GEOM_Object_ptr SewAllowNonManifold (const GEOM::ListOfGO &theObject, CORBA::Double theTolerance)
GEOM::GEOM_Object_ptr RemoveInternalFaces (const GEOM::ListOfGO &theSolids)
GEOM::GEOM_Object_ptr DivideEdge (GEOM::GEOM_Object_ptr theObject, CORBA::Short theIndex, CORBA::Double theValue, CORBA::Boolean isByParameter)
GEOM::GEOM_Object_ptr DivideEdgeByPoint (GEOM::GEOM_Object_ptr theObject, CORBA::Short theIndex, const GEOM::ListOfGO &thePoints)
GEOM::GEOM_Object_ptr FuseCollinearEdgesWithinWire (GEOM::GEOM_Object_ptr theWire, const GEOM::ListOfGO &theVertices)
CORBA::Boolean GetFreeBoundary (const GEOM::ListOfGO &theObjects, GEOM::ListOfGO_out theClosedWires, GEOM::ListOfGO_out theOpenWires)
GEOM::GEOM_Object_ptr ChangeOrientation (GEOM::GEOM_Object_ptr theObject)
GEOM::GEOM_Object_ptr ChangeOrientationCopy (GEOM::GEOM_Object_ptr theObject)
GEOM::GEOM_Object_ptr LimitTolerance (GEOM::GEOM_Object_ptr theObject, CORBA::Double theTolerance, CORBA::Boolean theExactAdjust)
void FuncToPythonDump (GEOM::GEOM_Object_ptr theObject, GEOM::GEOM_Object_ptr result, const char *imports, const char *funcName, const char *args)
::GEOMImpl_IHealingOperations * GetOperations ()
GEOM::ModifStatistics * GetStatistics ()
 Return information on what has been done by the last called healing method. More...
- Public Member Functions inherited from GEOM_IOperations_i
 GEOM_IOperations_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, ::GEOM_IOperations *theImpl)
 ~GEOM_IOperations_i ()
virtual CORBA::Boolean IsDone ()
virtual void SetErrorCode (const char *theErrorCode)
virtual char * GetErrorCode ()
virtual GEOM::GEOM_BaseObject_ptr GetBaseObject (Handle(::GEOM_BaseObject) theObject)
virtual virtual Handle(::GEOM_BaseObject) GetBaseObjectImpl(GEOM GEOM::GEOM_Object_ptr GetObject (Handle(::GEOM_Object) theObject)
virtual virtual Handle(::GEOM_Object) GetObjectImpl(GEOM void StartOperation ()
virtual void FinishOperation ()
virtual void AbortOperation ()
::GEOM_IOperations * GetImpl ()
virtual void UpdateGUIForObject (GEOM::GEOM_Object_ptr theObj)
- Protected Member Functions inherited from GEOM_IOperations_i
Handle(TColStd_HSequenceOfTransient) GetListOfObjectsImpl(const GEOM bool GetListOfObjectsImpl (const GEOM::ListOfGO &theObjects, std::list< Handle(::GEOM_Object) > &theList)
◆ GEOM_IHealingOperations_i()
GEOM_IHealingOperations_i::GEOM_IHealingOperations_i ( PortableServer::POA_ptr  thePOA,
::GEOMImpl_IHealingOperations *  theImpl
constructor:
◆ ~GEOM_IHealingOperations_i()
GEOM_IHealingOperations_i::~GEOM_IHealingOperations_i ( )
destructor
◆ ChangeOrientation()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::ChangeOrientation ( GEOM::GEOM_Object_ptr  theObject)
ChangeOrientation
References GetOperations(), Handle(), and GEOM_IOperations::SetNotDone().
◆ ChangeOrientationCopy()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::ChangeOrientationCopy ( GEOM::GEOM_Object_ptr  theObject)
◆ CloseContour()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::CloseContour ( GEOM::GEOM_Object_ptr  theObject,
const GEOM::short_array &  theWires,
◆ DivideEdge()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::DivideEdge ( GEOM::GEOM_Object_ptr  theObject,
◆ DivideEdgeByPoint()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::DivideEdgeByPoint ( GEOM::GEOM_Object_ptr  theObject,
const GEOM::ListOfGO &  thePoints
◆ FillHoles()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::FillHoles ( GEOM::GEOM_Object_ptr  theObject,
◆ FuncToPythonDump()
void GEOM_IHealingOperations_i::FuncToPythonDump ( GEOM::GEOM_Object_ptr  theObject,
const char *  imports,
const char *  funcName,
const char *  args
◆ FuseCollinearEdgesWithinWire()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::FuseCollinearEdgesWithinWire ( GEOM::GEOM_Object_ptr  theWire,
const GEOM::ListOfGO &  theVertices
◆ GetFreeBoundary()
CORBA::Boolean GEOM_IHealingOperations_i::GetFreeBoundary ( const GEOM::ListOfGO &  theObjects,
◆ GetOperations()
::GEOMImpl_IHealingOperations * GEOM_IHealingOperations_i::GetOperations ( )
◆ GetOperatorParameters()
void GEOM_IHealingOperations_i::GetOperatorParameters ( const char *  theOperator,
References GetOperations(), and GetOperatorParameters().
◆ GetShapeProcessParameters()
void GEOM_IHealingOperations_i::GetShapeProcessParameters ( GEOM::string_array_out  theOperations,
◆ GetStatistics()
◆ LimitTolerance()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::LimitTolerance ( GEOM::GEOM_Object_ptr  theObject,
◆ ProcessShape()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::ProcessShape ( GEOM::GEOM_Object_ptr  theObject,
const GEOM::string_array &  theOperations,
const GEOM::string_array &  theParams,
const GEOM::string_array &  theValues
◆ RemoveInternalFaces()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::RemoveInternalFaces ( const GEOM::ListOfGO &  theSolids)
◆ RemoveIntWires()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::RemoveIntWires ( GEOM::GEOM_Object_ptr  theObject,
◆ Sew()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::Sew ( const GEOM::ListOfGO &  theObjects,
◆ SewAllowNonManifold()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::SewAllowNonManifold ( const GEOM::ListOfGO &  theObjects,
◆ SuppressFaces()
GEOM::GEOM_Object_ptr GEOM_IHealingOperations_i::SuppressFaces ( GEOM::GEOM_Object_ptr  theObject,
const GEOM::short_array &  theFaces
