GEOM_IOperations.hxx
23#ifndef _GEOM_IOperations_HXX_
24#define _GEOM_IOperations_HXX_
26#include "GEOM_Engine.hxx"
27#include <TDocStd_Document.hxx>
28#include <TCollection_AsciiString.hxx>
29#include "GEOM_Object.hxx"
30#include "GEOM_Solver.hxx"
31
32#define OK "PAL_NO_ERROR"
33#define KO "PAL_NOT_DONE_ERROR"
34#define NOT_FOUND_ANY "NOT_FOUND_ANY"
35#define ALREADY_PRESENT "PAL_ELEMENT_ALREADY_PRESENT"
36#define NOT_EXISTS "PAL_ELEMENT_DOES_NOT_EXISTS"
37#define INVALID_TYPE "INVALID_TYPE_OF_ELEMENT"
38
40{
41 public:
42 Standard_EXPORT GEOM_IOperations(GEOM_Engine* theEngine);
43 Standard_EXPORT ~GEOM_IOperations();
44
45 //Starts a new operation (opens a tansaction)
46 Standard_EXPORT void StartOperation();
47
48 //Finishes the previously started operation (closes the transaction)
49 Standard_EXPORT void FinishOperation();
50
51 //Aborts the operation
52 Standard_EXPORT void AbortOperation();
53
54 //Returns true if the last operation succided
55 Standard_EXPORT bool IsDone();
56
57 //Sets Not done error code
58 Standard_EXPORT void SetNotDone() { _errorCode = KO; }
59
60 //Sets an error code of the operation
61 Standard_EXPORT void SetErrorCode(const TCollection_AsciiString& theErrorCode) {
62 _errorCode = theErrorCode;
63 }
64
65 //Returns an error code of the last operatioin
66 Standard_EXPORT char* GetErrorCode() {
67 return (char*) _errorCode.ToCString();
68 }
69
70 //Returns a pointer to GEOM_Engine which this operation interface is associated
71 Standard_EXPORT GEOM_Engine* GetEngine() { return _engine; }
72
73 //Return a pointer to Solver associated with this operation interface
74 Standard_EXPORT GEOM_Solver* GetSolver() { return _solver; }
75
76 private:
77
78 TCollection_AsciiString _errorCode;
81
82};
83
84#endif
#define KO
Definition: GEOM_IOperations.hxx:33
Definition: GEOM_Engine.hxx:91
Definition: GEOM_IOperations.hxx:40
Definition: GEOM_IOperations.cxx:88
Definition: GEOM_IOperations.cxx:76
Definition: GEOM_IOperations.cxx:100
Standard_EXPORT GEOM_Solver * GetSolver()
Definition: GEOM_IOperations.hxx:74
Definition: GEOM_IOperations.cxx:64
Standard_EXPORT GEOM_Engine * GetEngine()
Definition: GEOM_IOperations.hxx:71
Standard_EXPORT void SetErrorCode(const TCollection_AsciiString &theErrorCode)
Definition: GEOM_IOperations.hxx:61
Standard_EXPORT char * GetErrorCode()
Definition: GEOM_IOperations.hxx:66
Definition: GEOM_IOperations.cxx:52
Definition: GEOM_IOperations.hxx:78
Standard_EXPORT GEOM_IOperations(GEOM_Engine *theEngine)
Definition: GEOM_IOperations.cxx:40
GEOM_Engine * _engine
Definition: GEOM_IOperations.hxx:79
GEOM_Solver * _solver
Definition: GEOM_IOperations.hxx:80
Definition: GEOM_IOperations.hxx:58
Definition: GEOM_Solver.hxx:33
