Version: 9.13.0
GEOMAlgo_BuilderShape Class Reference
Root class for algorithms that has shape as result
#include <GEOMAlgo_BuilderShape.hxx>
Inheritance diagram for GEOMAlgo_BuilderShape:
Standard_EXPORT const TopoDS_Shape & Shape () const
 Returns the result of algorithm
More...
virtual Standard_EXPORT const TopTools_ListOfShape & Generated (const TopoDS_Shape &theS)
 Returns the list of shapes generated from the
shape theS. More...
virtual Standard_EXPORT const TopTools_ListOfShape & Modified (const TopoDS_Shape &theS)
 Returns the list of shapes modified from the
shape theS. More...
virtual Standard_EXPORT Standard_Boolean IsDeleted (const TopoDS_Shape &theS)
 Returns true if the shape theS has been deleted.
More...
Standard_EXPORT Standard_Boolean HasDeleted () const
 Returns true if the at least one shape(or sub-shape)
of arguments has been deleted. More...
Standard_EXPORT Standard_Boolean HasGenerated () const
of arguments has generated shapes. More...
Standard_EXPORT Standard_Boolean HasModified () const
of arguments has modified shapes. More...
Standard_EXPORT const TopTools_IndexedDataMapOfShapeListOfShape & ImagesResult () const
- Public Member Functions inherited from GEOMAlgo_Algo
virtual Standard_EXPORT void Perform ()=0
Standard_EXPORT Standard_Integer ErrorStatus () const
Standard_EXPORT Standard_Integer WarningStatus () const
Standard_EXPORT void ComputeInternalShapes (const Standard_Boolean theFlag)
 Allows to omit of creation of internal shapes (manifold topology). More...
Standard_EXPORT GEOMAlgo_BuilderShape ()
 Empty constructor
More...
virtual Standard_EXPORT ~GEOMAlgo_BuilderShape ()
virtual Standard_EXPORT void PrepareHistory ()
 Prepare information for history support
More...
- Protected Member Functions inherited from GEOMAlgo_Algo
Standard_EXPORT GEOMAlgo_Algo ()
virtual Standard_EXPORT ~GEOMAlgo_Algo ()
virtual Standard_EXPORT void CheckData ()
virtual Standard_EXPORT void CheckResult ()
TopoDS_Shape myShape
TopTools_ListOfShape myHistShapes
TopTools_MapOfShape myMapShape
Standard_Boolean myHasDeleted
Standard_Boolean myHasGenerated
Standard_Boolean myHasModified
TopTools_IndexedDataMapOfShapeListOfShape myImagesResult
- Protected Attributes inherited from GEOMAlgo_Algo
Standard_Integer myErrorStatus
Standard_Integer myWarningStatus
Standard_Boolean myComputeInternalShapes
◆ GEOMAlgo_BuilderShape()
GEOMAlgo_BuilderShape::GEOMAlgo_BuilderShape ( )
◆ ~GEOMAlgo_BuilderShape()
GEOMAlgo_BuilderShape::~GEOMAlgo_BuilderShape ( )
◆ Generated()
const TopTools_ListOfShape & GEOMAlgo_BuilderShape::Generated ( const TopoDS_Shape &  theS)
Reimplemented in GEOMAlgo_Gluer2.
References myHistShapes.
◆ HasDeleted()
Standard_Boolean GEOMAlgo_BuilderShape::HasDeleted ( ) const
References myHasDeleted.
◆ HasGenerated()
Standard_Boolean GEOMAlgo_BuilderShape::HasGenerated ( ) const
References myHasGenerated.
◆ HasModified()
Standard_Boolean GEOMAlgo_BuilderShape::HasModified ( ) const
References myHasModified.
◆ ImagesResult()
const TopTools_IndexedDataMapOfShapeListOfShape & GEOMAlgo_BuilderShape::ImagesResult ( ) const
References myImagesResult.
◆ IsDeleted()
Standard_Boolean GEOMAlgo_BuilderShape::IsDeleted ( const TopoDS_Shape &  theS)
References myMapShape.
◆ Modified()
const TopTools_ListOfShape & GEOMAlgo_BuilderShape::Modified ( const TopoDS_Shape &  theS)
◆ PrepareHistory()
void GEOMAlgo_BuilderShape::PrepareHistory ( )
◆ Shape()
const TopoDS_Shape & GEOMAlgo_BuilderShape::Shape ( ) const
References myShape.
◆ myHasDeleted
Standard_Boolean GEOMAlgo_BuilderShape::myHasDeleted
◆ myHasGenerated
Standard_Boolean GEOMAlgo_BuilderShape::myHasGenerated
◆ myHasModified
Standard_Boolean GEOMAlgo_BuilderShape::myHasModified
◆ myHistShapes
TopTools_ListOfShape GEOMAlgo_BuilderShape::myHistShapes
◆ myImagesResult
TopTools_IndexedDataMapOfShapeListOfShape GEOMAlgo_BuilderShape::myImagesResult
◆ myMapShape
TopTools_MapOfShape GEOMAlgo_BuilderShape::myMapShape
◆ myShape
TopoDS_Shape GEOMAlgo_BuilderShape::myShape
