GEOMGUI_AnnotationMgr Class Reference
A help class to process visualization of annotation presentations. It contains a map of presentations shown in each viewer. and correct 2D position persistent properties of annotations of active viewer. When the viewer is closed, information about the viewer is removed from the manager.
#include <GEOMGUI_AnnotationMgr.h>
Inheritance diagram for GEOMGUI_AnnotationMgr:
 GEOMGUI_AnnotationMgr (SalomeApp_Application *theApplication)
 ~GEOMGUI_AnnotationMgr ()
SALOME_Prs * CreatePresentation (const GEOMGUI_AnnotationAttrs::Properties &theProperty, GEOM::GEOM_Object_ptr theObject, SOCC_Viewer *theView=0, const QString &theEntry=QString())
bool IsDisplayed (const QString &theEntry, const int theIndex, SOCC_Viewer *theView=0) const
void Display (const QString &theEntry, const int theIndex, SOCC_Viewer *theView=0, const bool isStoreViewState=true, const bool isUpdateViewer=true)
void Erase (const QString &theEntry, const int theIndex, SOCC_Viewer *theView=0, const bool isUpdateViewer=true)
void EraseRemovedAnnotation (const QString &theEntry, const int theIndex)
void Redisplay (const QString &theEntry, const int theIndex, const GEOMGUI_AnnotationAttrs::Properties &theProperties)
void Redisplay (const QString &theEntry, const int theIndex, const GEOMGUI_AnnotationAttrs::Properties &theProperties, SOCC_Viewer *theView)
void DisplayVisibleAnnotations (const QString &theEntry, SOCC_Viewer *theView=0, const bool isUpdateViewer=true)
void EraseVisibleAnnotations (const QString &theEntry, SOCC_Viewer *theView=0, const bool isUpdateViewer=true)
void UpdateVisibleAnnotations (const QString &theEntry, SOCC_Viewer *theView=0)
void DisplayAllAnnotations (SOCC_Viewer *theView=0)
void EraseAllAnnotations (SOCC_Viewer *theView=0)
void SetPreviewStyle (const QString &theEntry, const int theIndex, const bool theIsPreview)
void RemoveView (SOCC_Viewer *theView)
int FindAnnotationIndex (Handle(SALOME_InteractiveObject) theIO, SOCC_Viewer *theView=0)
 Handle (SALOME_InteractiveObject) FindInteractiveObject(const QString &theEntry
QString getDisplayedIndicesInfo (const QString &theEntry, SOCC_Viewer *theView) const
void setDisplayedIndicesInfo (const QString &theEntry, SOCC_Viewer *theView, const QString theIndicesInfo)
QString makeAnnotationEntry (const QString &theEntry, const int theIndex)
void storeFixedPosition (const QString &theEntry, SOCC_Viewer *theView)
bool getIndexFromEntry (const QString &theEntry, QString &theObjEntry, int &theIndex)
bool isAnnotationEntry (const QString &theEntry)
static QString GetEntrySeparator ()
Public Attributes
const int theIndex
const int SOCC_Viewer * theView = 0 ) const
SalomeApp_Application * getApplication () const
GEOM_Displayer * getDisplayer () const
SOCC_Viewer * viewOrActiveView (SOCC_Viewer *theView) const
void getObject (const QString &theEntry, const int theIndex, GEOM::GEOM_Object_ptr &anObject, GEOMGUI_AnnotationAttrs::Properties &aProperty)
void storeVisibleState (const QString &theEntry, SOCC_Viewer *theView)
std::string getEntry (const GEOM::GEOM_Object_ptr theObject)
std::string getName (const GEOM::GEOM_Object_ptr theObject)
void setDisplayProperties (const Handle(GEOM_Annotation)&thePrs, SOCC_Viewer *theView=0, const QString &theEntry=QString())
 Handle (GEOM_Annotation) getAISPresentation(const QString &theEntry
Private Types
typedef QMap< int, SALOME_Prs * > AnnotationToPrs
typedef QMap< QString, AnnotationToPrs > EntryToAnnotations
SalomeApp_Application * myApplication
QMap< SOCC_Viewer *, EntryToAnnotations > myVisualized
◆ AnnotationToPrs
typedef QMap<int, SALOME_Prs*> GEOMGUI_AnnotationMgr::AnnotationToPrs
◆ EntryToAnnotations
◆ GEOMGUI_AnnotationMgr()
GEOMGUI_AnnotationMgr::GEOMGUI_AnnotationMgr ( SalomeApp_Application *  theApplication)
◆ ~GEOMGUI_AnnotationMgr()
GEOMGUI_AnnotationMgr::~GEOMGUI_AnnotationMgr ( )
◆ CreatePresentation()
◆ Display()
void GEOMGUI_AnnotationMgr::Display ( const QString &  theEntry,
const int  theIndex,
SOCC_Viewer *  theView = 0,
const bool  isStoreViewState = true,
const bool  isUpdateViewer = true
◆ DisplayAllAnnotations()
◆ DisplayVisibleAnnotations()
void GEOMGUI_AnnotationMgr::DisplayVisibleAnnotations ( const QString &  theEntry,
◆ Erase()
void GEOMGUI_AnnotationMgr::Erase ( const QString &  theEntry,
const int  theIndex,
◆ EraseAllAnnotations()
◆ EraseRemovedAnnotation()
void GEOMGUI_AnnotationMgr::EraseRemovedAnnotation ( const QString &  theEntry,
const int  theIndex
◆ EraseVisibleAnnotations()
void GEOMGUI_AnnotationMgr::EraseVisibleAnnotations ( const QString &  theEntry,
◆ FindAnnotationIndex()
int GEOMGUI_AnnotationMgr::FindAnnotationIndex ( Handle(SALOME_InteractiveObject)  theIO,
◆ getApplication()
SalomeApp_Application * GEOMGUI_AnnotationMgr::getApplication ( ) const
inlineprotected
◆ getDisplayedIndicesInfo()
QString GEOMGUI_AnnotationMgr::getDisplayedIndicesInfo ( const QString &  theEntry,
◆ getDisplayer()
GEOM_Displayer * GEOMGUI_AnnotationMgr::getDisplayer ( ) const
References getApplication().
◆ getEntry()
std::string GEOMGUI_AnnotationMgr::getEntry ( const GEOM::GEOM_Object_ptr  theObject)
◆ GetEntrySeparator()
QString GEOMGUI_AnnotationMgr::GetEntrySeparator ( )
◆ getIndexFromEntry()
bool GEOMGUI_AnnotationMgr::getIndexFromEntry ( const QString &  theEntry,
QString &  theObjEntry,
int &  theIndex
References GetEntrySeparator(), and theIndex.
◆ getName()
std::string GEOMGUI_AnnotationMgr::getName ( const GEOM::GEOM_Object_ptr  theObject)
◆ getObject()
void GEOMGUI_AnnotationMgr::getObject ( const QString &  theEntry,
const int  theIndex,
GEOM::GEOM_Object_ptr &  anObject,
GEOMGUI_AnnotationAttrs::Properties &  aProperty
◆ Handle() [1/2]
GEOMGUI_AnnotationMgr::Handle ( GEOM_Annotation  ) const &
◆ Handle() [2/2]
GEOMGUI_AnnotationMgr::Handle ( SALOME_InteractiveObject  ) const &
◆ isAnnotationEntry()
bool GEOMGUI_AnnotationMgr::isAnnotationEntry ( const QString &  theEntry)
◆ IsDisplayed()
bool GEOMGUI_AnnotationMgr::IsDisplayed ( const QString &  theEntry,
const int  theIndex,
◆ makeAnnotationEntry()
QString GEOMGUI_AnnotationMgr::makeAnnotationEntry ( const QString &  theEntry,
const int  theIndex
◆ Redisplay() [1/2]
void GEOMGUI_AnnotationMgr::Redisplay ( const QString &  theEntry,
const int  theIndex,
const GEOMGUI_AnnotationAttrs::Properties &  theProperties
References Redisplay(), and theIndex.
◆ Redisplay() [2/2]
const int  theIndex,
const GEOMGUI_AnnotationAttrs::Properties &  theProperties,
◆ RemoveView()
void GEOMGUI_AnnotationMgr::RemoveView ( SOCC_Viewer *  theView)
References myVisualized, and theView.
◆ setDisplayedIndicesInfo()
void GEOMGUI_AnnotationMgr::setDisplayedIndicesInfo ( const QString &  theEntry,
SOCC_Viewer *  theView,
References Display(), and theView.
◆ setDisplayProperties()
◆ SetPreviewStyle()
void GEOMGUI_AnnotationMgr::SetPreviewStyle ( const QString &  theEntry,
const int  theIndex,
◆ storeFixedPosition()
void GEOMGUI_AnnotationMgr::storeFixedPosition ( const QString &  theEntry,
◆ storeVisibleState()
void GEOMGUI_AnnotationMgr::storeVisibleState ( const QString &  theEntry,
◆ UpdateVisibleAnnotations()
◆ viewOrActiveView()
SOCC_Viewer * GEOMGUI_AnnotationMgr::viewOrActiveView ( SOCC_Viewer *  theView) const
References getApplication(), and theView.
◆ myApplication
SalomeApp_Application* GEOMGUI_AnnotationMgr::myApplication
◆ myVisualized
QMap<SOCC_Viewer*, EntryToAnnotations> GEOMGUI_AnnotationMgr::myVisualized
◆ theIndex
const int GEOMGUI_AnnotationMgr::theIndex
◆ theView
const int SOCC_Viewer * GEOMGUI_AnnotationMgr::theView = 0 ) const
