GEOMImpl_IHealing Class Reference
#include <GEOMImpl_IHealing.hxx>
enum  {
  ARG_SHAPE_PROCESS_OPERATORS = 1 , ARG_SHAPE_PROCESS_PARAMS = 2 , ARG_SHAPE_PROCESS_VALUES = 3 , ARG_ORIGINAL = 4 ,
  ARG_LIST_ARGUMENTS = 5 , ARG_IS_COMMON_VERTEX = 6 , ARG_TOLERANCE = 7 , ARG_DEV_EDGE_VALUE = 8 ,
  ARG_IS_BY_PARAMETER = 9 , ARG_SUBSHAPE_INDEX = 10 , ARG_LIST_SHAPES = 11 , ARG_EXACT_ADJUST = 12
 GEOMImpl_IHealing (Handle(GEOM_Function) theFunction)
void SetOperators (const Handle(TColStd_HArray1OfExtendedString)&arr)
 Handle (TColStd_HArray1OfExtendedString) GetOperators()
void SetParameters (const Handle(TColStd_HArray1OfExtendedString)&arr)
 Handle (TColStd_HArray1OfExtendedString) GetParameters()
void SetValues (const Handle(TColStd_HArray1OfExtendedString)&arr)
 Handle (TColStd_HArray1OfExtendedString) GetValues()
void SetOriginal (Handle(GEOM_Function) f)
 Handle (GEOM_Function) GetOriginal()
void SetFaces (const Handle(TColStd_HArray1OfInteger)&arr)
 Handle (TColStd_HArray1OfInteger) GetFaces()
void SetWires (const Handle(TColStd_HArray1OfInteger)&arr)
 Handle (TColStd_HArray1OfInteger) GetWires()
void SetIsCommonVertex (Standard_Boolean val)
Standard_Boolean GetIsCommonVertex ()
void SetIsByParameter (Standard_Boolean val)
Standard_Boolean GetIsByParameter ()
void SetTolerance (Standard_Real val)
Standard_Real GetTolerance ()
void SetExactAdjust (Standard_Boolean val)
Standard_Boolean GetExactAdjust ()
void SetDevideEdgeValue (Standard_Real val)
Standard_Real GetDevideEdgeValue ()
void SetIndex (Standard_Integer val)
Standard_Integer GetIndex ()
void SetShapes (const Handle(TColStd_HSequenceOfTransient)&theShapes)
 Handle (TColStd_HSequenceOfTransient) GetShapes()
 Handle (TColStd_HSequenceOfTransient) GetOriginalAndShapes()
void SetStatistics (ShHealOper_ModifStats *ms)
ShHealOper_ModifStats * GetStatistics ()
 Handle (GEOM_Function) _func
◆ anonymous enum
anonymous enum
ARG_ORIGINAL
ARG_LIST_ARGUMENTS
ARG_TOLERANCE
ARG_DEV_EDGE_VALUE
ARG_IS_BY_PARAMETER
ARG_SUBSHAPE_INDEX
ARG_LIST_SHAPES
ARG_EXACT_ADJUST
◆ GEOMImpl_IHealing()
GEOMImpl_IHealing::GEOMImpl_IHealing ( Handle(GEOM_Function)  theFunction)
◆ GetDevideEdgeValue()
Standard_Real GEOMImpl_IHealing::GetDevideEdgeValue ( )
References ARG_DEV_EDGE_VALUE.
◆ GetExactAdjust()
Standard_Boolean GEOMImpl_IHealing::GetExactAdjust ( )
References ARG_EXACT_ADJUST.
◆ GetIndex()
Standard_Integer GEOMImpl_IHealing::GetIndex ( )
References ARG_SUBSHAPE_INDEX.
◆ GetIsByParameter()
Standard_Boolean GEOMImpl_IHealing::GetIsByParameter ( )
References ARG_IS_BY_PARAMETER.
◆ GetIsCommonVertex()
Standard_Boolean GEOMImpl_IHealing::GetIsCommonVertex ( )
References ARG_IS_COMMON_VERTEX.
◆ GetStatistics()
ShHealOper_ModifStats * GEOMImpl_IHealing::GetStatistics ( )
◆ GetTolerance()
Standard_Real GEOMImpl_IHealing::GetTolerance ( )
References ARG_TOLERANCE.
◆ Handle() [1/9]
GEOMImpl_IHealing::Handle ( GEOM_Function  )
◆ Handle() [2/9]
References ARG_ORIGINAL.
◆ Handle() [3/9]
GEOMImpl_IHealing::Handle ( TColStd_HArray1OfExtendedString  )
◆ Handle() [4/9]
◆ Handle() [5/9]
◆ Handle() [6/9]
GEOMImpl_IHealing::Handle ( TColStd_HArray1OfInteger  )
References ARG_LIST_ARGUMENTS.
◆ Handle() [7/9]
◆ Handle() [8/9]
GEOMImpl_IHealing::Handle ( TColStd_HSequenceOfTransient  )
References Handle().
◆ Handle() [9/9]
References ARG_LIST_SHAPES.
◆ SetDevideEdgeValue()
void GEOMImpl_IHealing::SetDevideEdgeValue ( Standard_Real  val)
◆ SetExactAdjust()
void GEOMImpl_IHealing::SetExactAdjust ( Standard_Boolean  val)
◆ SetFaces()
void GEOMImpl_IHealing::SetFaces ( const Handle(TColStd_HArray1OfInteger)&  arr)
◆ SetIndex()
void GEOMImpl_IHealing::SetIndex ( Standard_Integer  val)
◆ SetIsByParameter()
void GEOMImpl_IHealing::SetIsByParameter ( Standard_Boolean  val)
◆ SetIsCommonVertex()
void GEOMImpl_IHealing::SetIsCommonVertex ( Standard_Boolean  val)
◆ SetOperators()
void GEOMImpl_IHealing::SetOperators ( const Handle(TColStd_HArray1OfExtendedString)&  arr)
◆ SetOriginal()
void GEOMImpl_IHealing::SetOriginal ( Handle(GEOM_Function)  f)
◆ SetParameters()
void GEOMImpl_IHealing::SetParameters ( const Handle(TColStd_HArray1OfExtendedString)&  arr)
◆ SetShapes()
void GEOMImpl_IHealing::SetShapes ( const Handle(TColStd_HSequenceOfTransient)&  theShapes)
◆ SetStatistics()
void GEOMImpl_IHealing::SetStatistics ( ShHealOper_ModifStats *  ms)
◆ SetTolerance()
void GEOMImpl_IHealing::SetTolerance ( Standard_Real  val)
◆ SetValues()
void GEOMImpl_IHealing::SetValues ( const Handle(TColStd_HArray1OfExtendedString)&  arr)
◆ SetWires()
void GEOMImpl_IHealing::SetWires ( const Handle(TColStd_HArray1OfInteger)&  arr)
