GEOM_Annotation::OpenGl_Annotation Class Reference
Custom element implementing dynamic rendering of 3D annotation and invoking dynamic callback in presentation class.
Inheritance diagram for GEOM_Annotation::OpenGl_Annotation:
struct  TextSize
 OpenGl_Annotation (GEOM_Annotation *theAnnotation, const Standard_Integer theTextHeight, const OpenGl_GraphicDriver *theDriver)
virtual ~OpenGl_Annotation ()
 Destructor. Releases GL resources with NULL context. More...
virtual void Release (OpenGl_Context *theCtx) Standard_OVERRIDE
 Releases GL resources with the given GL context. More...
virtual void Render (const Handle(OpenGl_Workspace)&theWorkspace) const Standard_OVERRIDE
 Renders the annotation graphical elements. More...
void SetDepthMode (const int theMode)
GEOM_Annotation * myAISObject
 Instance of presentation class. More...
NCollection_String myText
 Text string of annotation label. More...
OpenGl_TextParam myTextParams
 Text draw parameters. More...
OpenGl_Text * myTextDraw
 Text draw element. More...
OpenGl_PrimitiveArray * myTextLineDraw
 Text underline draw element. More...
OpenGl_PrimitiveArray * myExtLineDraw
 Extension line draw element. More...
OpenGl_PrimitiveArray * myExtMarkerDraw
 Extension marker draw element. More...
int myDepthMode
 Depth mode for drawing hidden line presentation. More...
float myTextLineY
 Text's underlines relative position. More...
TextSize myTextSize
 Text's size parameters. More...
Graphic3d_Vec2 myTextUnderline
 Text's underline position. More...
unsigned int myTextDPI
 Text's DPI scale used for last rendering. More...
◆ OpenGl_Annotation()
GEOM_Annotation::OpenGl_Annotation::OpenGl_Annotation ( GEOM_Annotation *  theAnnotation,
const OpenGl_GraphicDriver *  theDriver
Some of the input properties are assigned by reference for dynamic draw (it is not likely that GL element will ever outlive the interactive object).
theAnnotation[in] the instance of interactive presentation class.
theTextHeight[in] the height of the text label.
theDriver[in] the instance of graphical driver required for initialization.
References Handle(), myExtLineDraw, myExtMarkerDraw, myText, myTextDraw, myTextLineDraw, and myTextParams.
◆ ~OpenGl_Annotation()
GEOM_Annotation::OpenGl_Annotation::~OpenGl_Annotation ( )
◆ Release()
void GEOM_Annotation::OpenGl_Annotation::Release ( OpenGl_Context *  theCtx)
◆ Render()
void GEOM_Annotation::OpenGl_Annotation::Render ( const Handle(OpenGl_Workspace)&  theWorkspace) const
◆ SetDepthMode()
void GEOM_Annotation::OpenGl_Annotation::SetDepthMode ( const int  theMode)
References myDepthMode.
◆ myAISObject
GEOM_Annotation* GEOM_Annotation::OpenGl_Annotation::myAISObject
◆ myDepthMode
int GEOM_Annotation::OpenGl_Annotation::myDepthMode
◆ myExtLineDraw
OpenGl_PrimitiveArray* GEOM_Annotation::OpenGl_Annotation::myExtLineDraw
◆ myExtMarkerDraw
OpenGl_PrimitiveArray* GEOM_Annotation::OpenGl_Annotation::myExtMarkerDraw
◆ myText
NCollection_String GEOM_Annotation::OpenGl_Annotation::myText
◆ myTextDPI
unsigned int GEOM_Annotation::OpenGl_Annotation::myTextDPI
mutableprivate
◆ myTextDraw
OpenGl_Text* GEOM_Annotation::OpenGl_Annotation::myTextDraw
◆ myTextLineDraw
OpenGl_PrimitiveArray* GEOM_Annotation::OpenGl_Annotation::myTextLineDraw
◆ myTextLineY
float GEOM_Annotation::OpenGl_Annotation::myTextLineY
mutableprivate
◆ myTextParams
OpenGl_TextParam GEOM_Annotation::OpenGl_Annotation::myTextParams
◆ myTextSize
TextSize GEOM_Annotation::OpenGl_Annotation::myTextSize
mutableprivate
◆ myTextUnderline
Graphic3d_Vec2 GEOM_Annotation::OpenGl_Annotation::myTextUnderline
mutableprivate
