GEOM_Gen_No_Session_i Member List
This is the complete list of members for GEOM_Gen_No_Session_i, including all inherited members.
_implGEOM_Gen_iprivate
_nameGEOM_Gen_iprivate
AddInStudy(GEOM::GEOM_BaseObject_ptr theObject, const char *theName, GEOM::GEOM_BaseObject_ptr theFather)GEOM_Gen_i
AddSubShape(GEOM::GEOM_Object_ptr theMainShape, const GEOM::ListOfLong &theIndices)GEOM_Gen_ivirtual
BreakLink(const char *)GEOM_Gen_iinlineprivatevirtual
CanCopy(SALOMEDS::SObject_ptr theObject)GEOM_Gen_i
CanPaste(const char *theComponentName, CORBA::Long theObjectID)GEOM_Gen_i
CanPublishInStudy(CORBA::Object_ptr theIOR)GEOM_Gen_i
Close(SALOMEDS::SComponent_ptr theComponent)GEOM_Gen_i
ComponentDataType()GEOM_Gen_i
CopyFrom(SALOMEDS::SObject_ptr theObject, CORBA::Long &theObjectID)GEOM_Gen_i
CreateAndPublishGroup(GEOM::GEOM_Object_var theMainShape, const TopTools_IndexedMapOfShape &anIndices, const TopTools_SequenceOfShape &SeqS, const TColStd_SequenceOfAsciiString &SeqN, const Standard_CString &GrName, GEOM::ListOfGO_var aResList)GEOM_Gen_iprivate
CreateFolder(const char *theName, SALOMEDS::SObject_ptr theFather)GEOM_Gen_i
DumpPython(CORBA::Boolean isPublished, CORBA::Boolean isMultiFile, CORBA::Boolean &isValidScript)GEOM_Gen_ivirtual
findOrCreateComponent()GEOM_Gen_iprivate
GEOM_Gen_i()GEOM_Gen_i
GEOM_Gen_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName, bool withRegistry=true)GEOM_Gen_i
GEOM_Gen_No_Session_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName)GEOM_Gen_No_Session_i
GetAllDumpNames()GEOM_Gen_i
GetDependencyTree(const GEOM::string_array &theObjectEntries)GEOM_Gen_i
getDownwardDependency(GEOM::GEOM_BaseObject_ptr gbo, GEOMUtils::LevelsList &downLevelList, std::map< std::string, std::set< std::string > > &passedEntries, int level=0)GEOM_Gen_iprivate
GetDumpName(const char *theStudyEntry)GEOM_Gen_i
GetEntriesToReduceStudy(GEOM::string_array &theSelectedEntries, GEOM::string_array &theParentEntries, GEOM::string_array &theSubEntries, GEOM::string_array &theOtherEntries)GEOM_Gen_i
GetI3DPrimOperations()GEOM_Gen_ivirtual
GetIBasicOperations()GEOM_Gen_ivirtual
GetIBlocksOperations()GEOM_Gen_ivirtual
GetIBooleanOperations()GEOM_Gen_ivirtual
GetICanonicalRecognition()GEOM_Gen_ivirtual
GetICurvesOperations()GEOM_Gen_ivirtual
GetIFieldOperations()GEOM_Gen_ivirtual
GetIGroupOperations()GEOM_Gen_ivirtual
GetIHealingOperations()GEOM_Gen_ivirtual
GetIInsertOperations()GEOM_Gen_ivirtual
GetILocalOperations()GEOM_Gen_ivirtual
GetIMeasureOperations()GEOM_Gen_ivirtual
GetIORFromString(const char *stringIOR)GEOM_Gen_ivirtual
GetIShapesOperations()GEOM_Gen_ivirtual
GetITestOperations()GEOM_Gen_ivirtual
GetITransformOperations()GEOM_Gen_ivirtual
GetObject(const char *theEntry)GEOM_Gen_ivirtual
getObjectInfo(const char *entry)GEOM_Gen_ivirtual
GetORB()GEOM_Gen_iinline
GetPluginOperations(const char *theLibName)GEOM_Gen_ivirtual
GetStringFromIOR(GEOM::GEOM_Object_ptr theObject)GEOM_Gen_ivirtual
getStudyServant() overrideGEOM_Gen_No_Session_ivirtual
getUpwardDependency(GEOM::GEOM_BaseObject_ptr gbo, GEOMUtils::LevelsList &upLevelList, std::map< std::string, std::set< std::string > > &passedEntries, int level=0)GEOM_Gen_iprivate
getVersion()GEOM_Gen_ivirtual
hasObjectInfo()GEOM_Gen_ivirtual
includeParentDependencies(GEOM::GEOM_BaseObject_ptr gbo, std::set< std::string > &aSelected, std::set< std::string > &aParents, std::set< std::string > &aChildren, std::set< std::string > &anOthers)GEOM_Gen_iprivate
includeSubObjects(const std::string &aSelectedEntry, std::set< std::string > &aSelected, std::set< std::string > &aParents, std::set< std::string > &aChildren, std::set< std::string > &anOthers)GEOM_Gen_iprivate
IORToLocalPersistentID(SALOMEDS::SObject_ptr theSObject, const char *IORString, CORBA::Boolean isMultiFile, CORBA::Boolean isASCII)GEOM_Gen_i
Load(SALOMEDS::SComponent_ptr theComponent, const SALOMEDS::TMPFile &theStream, const char *theURL, bool isMultiFile)GEOM_Gen_i
LoadASCII(SALOMEDS::SComponent_ptr theComponent, const SALOMEDS::TMPFile &theStream, const char *theURL, bool isMultiFile)GEOM_Gen_i
LoadPlugin(const std::string &theLibName)GEOM_Gen_iprivate
LocalPersistentIDToIOR(SALOMEDS::SObject_ptr theSObject, const char *aLocalPersistentID, CORBA::Boolean isMultiFile, CORBA::Boolean isASCII)GEOM_Gen_i
Move(const GEOM::object_list &what, SALOMEDS::SObject_ptr where, CORBA::Long row)GEOM_Gen_i
MoveListToFolder(const GEOM::ListOfGO &theListOfGO, SALOMEDS::SObject_ptr theFolder)GEOM_Gen_i
MoveToFolder(GEOM::GEOM_Object_ptr theObject, SALOMEDS::SObject_ptr theFolder)GEOM_Gen_i
myOpCreatorMapGEOM_Gen_iprivate
PasteInto(const SALOMEDS::TMPFile &theStream, CORBA::Long theObjectID, SALOMEDS::SObject_ptr theObject)GEOM_Gen_i
PublishInStudy(SALOMEDS::SObject_ptr theSObject, CORBA::Object_ptr theObject, const char *theName)GEOM_Gen_i
PublishNamedShapesInStudy(CORBA::Object_ptr theObject)GEOM_Gen_i
Redo()GEOM_Gen_ivirtual
RemoveObject(GEOM::GEOM_BaseObject_ptr theObject)GEOM_Gen_ivirtual
RestoreGivenSubShapes(GEOM::GEOM_Object_ptr theObject, SALOMEDS::SObject_ptr theSObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)GEOM_Gen_iprivate
RestoreGivenSubShapesO(GEOM::GEOM_Object_ptr theObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)GEOM_Gen_i
RestoreGivenSubShapesOneLevel(SALOMEDS::SObject_ptr theOldSO, SALOMEDS::SObject_ptr theNewSO, GEOM::GEOM_Object_ptr theNewO, std::set< std::string > theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theAddPrefix)GEOM_Gen_iprivate
RestoreSubShapes(GEOM::GEOM_Object_ptr theObject, SALOMEDS::SObject_ptr theSObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)GEOM_Gen_iprivate
RestoreSubShapesO(GEOM::GEOM_Object_ptr theObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)GEOM_Gen_i
RestoreSubShapesOneLevel(SALOMEDS::SObject_ptr theOldSO, SALOMEDS::SObject_ptr theNewSO, GEOM::GEOM_Object_ptr theNewO, GEOM::ListOfGO &theOutArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theAddPrefix)GEOM_Gen_iprivate
RestoreSubShapesSO(SALOMEDS::SObject_ptr theSObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)GEOM_Gen_i
Save(SALOMEDS::SComponent_ptr theComponent, const char *theURL, bool isMultiFile)GEOM_Gen_i
SaveASCII(SALOMEDS::SComponent_ptr theComponent, const char *theURL, bool isMultiFile)GEOM_Gen_i
Undo()GEOM_Gen_ivirtual
~GEOM_Gen_i()GEOM_Gen_ivirtual
