GEOM_Gen_i Class Referenceabstract
#include <GEOM_Gen_i.hh>
Inheritance diagram for GEOM_Gen_i:
 GEOM_Gen_i ()
 GEOM_Gen_i (CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName, bool withRegistry=true)
virtual ~GEOM_Gen_i ()
CORBA::ORB_ptr GetORB ()
virtual SALOMEDS::Study_var getStudyServant ()=0
SALOMEDS::TMPFile * Save (SALOMEDS::SComponent_ptr theComponent, const char *theURL, bool isMultiFile)
SALOMEDS::TMPFile * SaveASCII (SALOMEDS::SComponent_ptr theComponent, const char *theURL, bool isMultiFile)
CORBA::Boolean Load (SALOMEDS::SComponent_ptr theComponent, const SALOMEDS::TMPFile &theStream, const char *theURL, bool isMultiFile)
CORBA::Boolean LoadASCII (SALOMEDS::SComponent_ptr theComponent, const SALOMEDS::TMPFile &theStream, const char *theURL, bool isMultiFile)
void Close (SALOMEDS::SComponent_ptr theComponent)
char * ComponentDataType ()
char * IORToLocalPersistentID (SALOMEDS::SObject_ptr theSObject, const char *IORString, CORBA::Boolean isMultiFile, CORBA::Boolean isASCII)
char * LocalPersistentIDToIOR (SALOMEDS::SObject_ptr theSObject, const char *aLocalPersistentID, CORBA::Boolean isMultiFile, CORBA::Boolean isASCII)
bool CanPublishInStudy (CORBA::Object_ptr theIOR)
SALOMEDS::SObject_ptr PublishInStudy (SALOMEDS::SObject_ptr theSObject, CORBA::Object_ptr theObject, const char *theName)
GEOM::ListOfGO * PublishNamedShapesInStudy (CORBA::Object_ptr theObject)
CORBA::Boolean CanCopy (SALOMEDS::SObject_ptr theObject)
SALOMEDS::TMPFile * CopyFrom (SALOMEDS::SObject_ptr theObject, CORBA::Long &theObjectID)
CORBA::Boolean CanPaste (const char *theComponentName, CORBA::Long theObjectID)
SALOMEDS::SObject_ptr PasteInto (const SALOMEDS::TMPFile &theStream, CORBA::Long theObjectID, SALOMEDS::SObject_ptr theObject)
SALOMEDS::SObject_ptr AddInStudy (GEOM::GEOM_BaseObject_ptr theObject, const char *theName, GEOM::GEOM_BaseObject_ptr theFather)
 Adds theObject in the study with a name = theName, if theFather is not null the object is placed under theFather. More...
GEOM::ListOfGO * RestoreSubShapesO (GEOM::GEOM_Object_ptr theObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)
 Publish sub-shapes, standing for arguments and sub-shapes of arguments. To be used from python scripts out of geompy.addToStudy (non-default usage) More...
GEOM::ListOfGO * RestoreGivenSubShapesO (GEOM::GEOM_Object_ptr theObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)
 Publish sub-shapes, standing for given in theArgs arguments and sub-shapes. To be used from python scripts, generated by Dump Python. More...
GEOM::ListOfGO * RestoreSubShapesSO (SALOMEDS::SObject_ptr theSObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)
 Publish sub-shapes, standing for arguments and sub-shapes of arguments. To be used from GUI and from geompy.addToStudy. More...
SALOMEDS::TMPFile * GetDependencyTree (const GEOM::string_array &theObjectEntries)
virtual void Undo ()
virtual void Redo ()
virtual GEOM::GEOM_IBasicOperations_ptr GetIBasicOperations ()
virtual GEOM::GEOM_ITransformOperations_ptr GetITransformOperations ()
virtual GEOM::GEOM_I3DPrimOperations_ptr GetI3DPrimOperations ()
virtual GEOM::GEOM_IShapesOperations_ptr GetIShapesOperations ()
virtual GEOM::GEOM_IBlocksOperations_ptr GetIBlocksOperations ()
virtual GEOM::GEOM_IBooleanOperations_ptr GetIBooleanOperations ()
virtual GEOM::GEOM_ICurvesOperations_ptr GetICurvesOperations ()
virtual GEOM::GEOM_ILocalOperations_ptr GetILocalOperations ()
virtual GEOM::GEOM_IHealingOperations_ptr GetIHealingOperations ()
virtual GEOM::GEOM_IInsertOperations_ptr GetIInsertOperations ()
virtual GEOM::GEOM_IMeasureOperations_ptr GetIMeasureOperations ()
virtual GEOM::GEOM_IGroupOperations_ptr GetIGroupOperations ()
virtual GEOM::GEOM_IFieldOperations_ptr GetIFieldOperations ()
virtual GEOM::GEOM_ITestOperations_ptr GetITestOperations ()
virtual GEOM::GEOM_ICanonicalRecognition_ptr GetICanonicalRecognition ()
virtual GEOM::GEOM_IOperations_ptr GetPluginOperations (const char *theLibName)
virtual GEOM::GEOM_Object_ptr AddSubShape (GEOM::GEOM_Object_ptr theMainShape, const GEOM::ListOfLong &theIndices)
virtual void RemoveObject (GEOM::GEOM_BaseObject_ptr theObject)
virtual char * GetStringFromIOR (GEOM::GEOM_Object_ptr theObject)
virtual GEOM::GEOM_Object_ptr GetIORFromString (const char *stringIOR)
char * GetDumpName (const char *theStudyEntry)
GEOM::string_array * GetAllDumpNames ()
virtual bool hasObjectInfo ()
virtual char * getObjectInfo (const char *entry)
virtual char * getVersion ()
SALOMEDS::SObject_ptr CreateFolder (const char *theName, SALOMEDS::SObject_ptr theFather)
void MoveToFolder (GEOM::GEOM_Object_ptr theObject, SALOMEDS::SObject_ptr theFolder)
void MoveListToFolder (const GEOM::ListOfGO &theListOfGO, SALOMEDS::SObject_ptr theFolder)
void Move (const GEOM::object_list &what, SALOMEDS::SObject_ptr where, CORBA::Long row)
void GetEntriesToReduceStudy (GEOM::string_array &theSelectedEntries, GEOM::string_array &theParentEntries, GEOM::string_array &theSubEntries, GEOM::string_array &theOtherEntries)
 Fills 3 lists that is used to clean study of redundant objects. To be used from GUI. More...
virtual GEOM::GEOM_BaseObject_ptr GetObject (const char *theEntry)
SALOMEDS::SComponent_var findOrCreateComponent ()
GEOM::ListOfGO * RestoreSubShapes (GEOM::GEOM_Object_ptr theObject, SALOMEDS::SObject_ptr theSObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)
GEOM::ListOfGO * RestoreSubShapesOneLevel (SALOMEDS::SObject_ptr theOldSO, SALOMEDS::SObject_ptr theNewSO, GEOM::GEOM_Object_ptr theNewO, GEOM::ListOfGO &theOutArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theAddPrefix)
GEOM::ListOfGO * RestoreGivenSubShapes (GEOM::GEOM_Object_ptr theObject, SALOMEDS::SObject_ptr theSObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix)
GEOM::ListOfGO * RestoreGivenSubShapesOneLevel (SALOMEDS::SObject_ptr theOldSO, SALOMEDS::SObject_ptr theNewSO, GEOM::GEOM_Object_ptr theNewO, std::set< std::string > theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theAddPrefix)
void CreateAndPublishGroup (GEOM::GEOM_Object_var theMainShape, const TopTools_IndexedMapOfShape &anIndices, const TopTools_SequenceOfShape &SeqS, const TColStd_SequenceOfAsciiString &SeqN, const Standard_CString &GrName, GEOM::ListOfGO_var aResList)
void getUpwardDependency (GEOM::GEOM_BaseObject_ptr gbo, GEOMUtils::LevelsList &upLevelList, std::map< std::string, std::set< std::string > > &passedEntries, int level=0)
void getDownwardDependency (GEOM::GEOM_BaseObject_ptr gbo, GEOMUtils::LevelsList &downLevelList, std::map< std::string, std::set< std::string > > &passedEntries, int level=0)
void includeParentDependencies (GEOM::GEOM_BaseObject_ptr gbo, std::set< std::string > &aSelected, std::set< std::string > &aParents, std::set< std::string > &aChildren, std::set< std::string > &anOthers)
void includeSubObjects (const std::string &aSelectedEntry, std::set< std::string > &aSelected, std::set< std::string > &aParents, std::set< std::string > &aChildren, std::set< std::string > &anOthers)
void LoadPlugin (const std::string &theLibName)
virtual void BreakLink (const char *)
::GEOMImpl_Gen * _impl
char * _name
std::map< std::string, GEOM_GenericOperationsCreator * > myOpCreatorMap
◆ GEOM_Gen_i() [1/2]
GEOM_Gen_i::GEOM_Gen_i ( )
◆ GEOM_Gen_i() [2/2]
GEOM_Gen_i::GEOM_Gen_i ( CORBA::ORB_ptr  orb,
const char *  instanceName,
const char *  interfaceName,
bool  withRegistry = true
◆ ~GEOM_Gen_i()
GEOM_Gen_i::~GEOM_Gen_i ( )
References _impl, and myOpCreatorMap.
◆ AddInStudy()
SALOMEDS::SObject_ptr GEOM_Gen_i::AddInStudy ( GEOM::GEOM_BaseObject_ptr  theObject,
const char *  theName,
◆ AddSubShape()
GEOM::GEOM_Object_ptr GEOM_Gen_i::AddSubShape ( GEOM::GEOM_Object_ptr  theMainShape,
const GEOM::ListOfLong &  theIndices
AddSubShape
References _impl, GetObject(), Handle(), and theIndices.
◆ BreakLink()
virtual void GEOM_Gen_i::BreakLink ( const char *  )
inlineprivatevirtual
◆ CanCopy()
CORBA::Boolean GEOM_Gen_i::CanCopy ( SALOMEDS::SObject_ptr  theObject)
◆ CanPaste()
CORBA::Boolean GEOM_Gen_i::CanPaste ( const char *  theComponentName,
References ComponentDataType().
◆ CanPublishInStudy()
bool GEOM_Gen_i::CanPublishInStudy ( CORBA::Object_ptr  theIOR)
◆ Close()
void GEOM_Gen_i::Close ( SALOMEDS::SComponent_ptr  theComponent)
References _impl, and GEOM_Engine::Close().
◆ ComponentDataType()
char * GEOM_Gen_i::ComponentDataType ( )
◆ CopyFrom()
SALOMEDS::TMPFile * GEOM_Gen_i::CopyFrom ( SALOMEDS::SObject_ptr  theObject,
CORBA::Long &  theObjectID
◆ CreateAndPublishGroup()
void GEOM_Gen_i::CreateAndPublishGroup ( GEOM::GEOM_Object_var  theMainShape,
const TopTools_IndexedMapOfShape &  anIndices,
const TopTools_SequenceOfShape &  SeqS,
const TColStd_SequenceOfAsciiString &  SeqN,
const Standard_CString &  GrName,
◆ CreateFolder()
SALOMEDS::SObject_ptr GEOM_Gen_i::CreateFolder ( const char *  theName,
◆ DumpPython()
Engines::TMPFile * GEOM_Gen_i::DumpPython ( CORBA::Boolean  isPublished,
◆ findOrCreateComponent()
SALOMEDS::SComponent_var GEOM_Gen_i::findOrCreateComponent ( )
◆ GetAllDumpNames()
GEOM::string_array * GEOM_Gen_i::GetAllDumpNames ( )
References _impl, and Handle().
◆ GetDependencyTree()
SALOMEDS::TMPFile * GEOM_Gen_i::GetDependencyTree ( const GEOM::string_array &  theObjectEntries)
◆ getDownwardDependency()
void GEOM_Gen_i::getDownwardDependency ( GEOM::GEOM_BaseObject_ptr  gbo,
GEOMUtils::LevelsList &  downLevelList,
std::map< std::string, std::set< std::string > > &  passedEntries,
int  level = 0
◆ GetDumpName()
char * GEOM_Gen_i::GetDumpName ( const char *  theStudyEntry)
◆ GetEntriesToReduceStudy()
void GEOM_Gen_i::GetEntriesToReduceStudy ( GEOM::string_array &  theSelectedEntries,
GEOM::string_array &  theParentEntries,
GEOM::string_array &  theSubEntries,
GEOM::string_array &  theOtherEntries
◆ GetI3DPrimOperations()
GEOM::GEOM_I3DPrimOperations_ptr GEOM_Gen_i::GetI3DPrimOperations ( )
◆ GetIBasicOperations()
GEOM::GEOM_IBasicOperations_ptr GEOM_Gen_i::GetIBasicOperations ( )
◆ GetIBlocksOperations()
GEOM::GEOM_IBlocksOperations_ptr GEOM_Gen_i::GetIBlocksOperations ( )
◆ GetIBooleanOperations()
GEOM::GEOM_IBooleanOperations_ptr GEOM_Gen_i::GetIBooleanOperations ( )
◆ GetICanonicalRecognition()
GEOM::GEOM_ICanonicalRecognition_ptr GEOM_Gen_i::GetICanonicalRecognition ( )
◆ GetICurvesOperations()
GEOM::GEOM_ICurvesOperations_ptr GEOM_Gen_i::GetICurvesOperations ( )
◆ GetIFieldOperations()
GEOM::GEOM_IFieldOperations_ptr GEOM_Gen_i::GetIFieldOperations ( )
◆ GetIGroupOperations()
GEOM::GEOM_IGroupOperations_ptr GEOM_Gen_i::GetIGroupOperations ( )
◆ GetIHealingOperations()
GEOM::GEOM_IHealingOperations_ptr GEOM_Gen_i::GetIHealingOperations ( )
◆ GetIInsertOperations()
GEOM::GEOM_IInsertOperations_ptr GEOM_Gen_i::GetIInsertOperations ( )
◆ GetILocalOperations()
GEOM::GEOM_ILocalOperations_ptr GEOM_Gen_i::GetILocalOperations ( )
◆ GetIMeasureOperations()
GEOM::GEOM_IMeasureOperations_ptr GEOM_Gen_i::GetIMeasureOperations ( )
◆ GetIORFromString()
GEOM::GEOM_Object_ptr GEOM_Gen_i::GetIORFromString ( const char *  stringIOR)
◆ GetIShapesOperations()
GEOM::GEOM_IShapesOperations_ptr GEOM_Gen_i::GetIShapesOperations ( )
◆ GetITestOperations()
GEOM::GEOM_ITestOperations_ptr GEOM_Gen_i::GetITestOperations ( )
◆ GetITransformOperations()
GEOM::GEOM_ITransformOperations_ptr GEOM_Gen_i::GetITransformOperations ( )
◆ GetObject()
GEOM::GEOM_BaseObject_ptr GEOM_Gen_i::GetObject ( const char *  theEntry)
◆ getObjectInfo()
◆ GetORB()
CORBA::ORB_ptr GEOM_Gen_i::GetORB ( )
◆ GetPluginOperations()
GEOM::GEOM_IOperations_ptr GEOM_Gen_i::GetPluginOperations ( const char *  theLibName)
References _impl, LoadPlugin(), and myOpCreatorMap.
◆ GetStringFromIOR()
char * GEOM_Gen_i::GetStringFromIOR ( GEOM::GEOM_Object_ptr  theObject)
◆ getStudyServant()
virtual SALOMEDS::Study_var GEOM_Gen_i::getStudyServant ( )
pure virtual
◆ getUpwardDependency()
void GEOM_Gen_i::getUpwardDependency ( GEOM::GEOM_BaseObject_ptr  gbo,
GEOMUtils::LevelsList &  upLevelList,
int  level = 0
References getUpwardDependency().
◆ getVersion()
char * GEOM_Gen_i::getVersion ( )
◆ hasObjectInfo()
bool GEOM_Gen_i::hasObjectInfo ( )
◆ includeParentDependencies()
void GEOM_Gen_i::includeParentDependencies ( GEOM::GEOM_BaseObject_ptr  gbo,
std::set< std::string > &  aSelected,
std::set< std::string > &  aParents,
std::set< std::string > &  aChildren,
std::set< std::string > &  anOthers
◆ includeSubObjects()
void GEOM_Gen_i::includeSubObjects ( const std::string &  aSelectedEntry,
References _impl, Handle(), and includeSubObjects().
◆ IORToLocalPersistentID()
char * GEOM_Gen_i::IORToLocalPersistentID ( SALOMEDS::SObject_ptr  theSObject,
const char *  IORString,
◆ Load()
CORBA::Boolean GEOM_Gen_i::Load ( SALOMEDS::SComponent_ptr  theComponent,
const SALOMEDS::TMPFile &  theStream,
const char *  theURL,
bool  isMultiFile
◆ LoadASCII()
CORBA::Boolean GEOM_Gen_i::LoadASCII ( SALOMEDS::SComponent_ptr  theComponent,
bool  isMultiFile
References Load().
◆ LoadPlugin()
void GEOM_Gen_i::LoadPlugin ( const std::string &  theLibName)
◆ LocalPersistentIDToIOR()
char * GEOM_Gen_i::LocalPersistentIDToIOR ( SALOMEDS::SObject_ptr  theSObject,
const char *  aLocalPersistentID,
References _impl, GetObject(), and Handle().
◆ Move()
void GEOM_Gen_i::Move ( const GEOM::object_list &  what,
CORBA::Long  row
References getStudyServant().
◆ MoveListToFolder()
void GEOM_Gen_i::MoveListToFolder ( const GEOM::ListOfGO &  theListOfGO,
References getStudyServant(), and Move().
◆ MoveToFolder()
void GEOM_Gen_i::MoveToFolder ( GEOM::GEOM_Object_ptr  theObject,
◆ PasteInto()
SALOMEDS::SObject_ptr GEOM_Gen_i::PasteInto ( const SALOMEDS::TMPFile &  theStream,
◆ PublishInStudy()
SALOMEDS::SObject_ptr GEOM_Gen_i::PublishInStudy ( SALOMEDS::SObject_ptr  theSObject,
◆ PublishNamedShapesInStudy()
GEOM::ListOfGO * GEOM_Gen_i::PublishNamedShapesInStudy ( CORBA::Object_ptr  theObject)
◆ Redo()
void GEOM_Gen_i::Redo ( )
References _impl, and GEOM_Engine::Redo().
◆ RemoveObject()
void GEOM_Gen_i::RemoveObject ( GEOM::GEOM_BaseObject_ptr  theObject)
RemoveObject
References _impl, Handle(), and GEOM_Engine::RemoveObject().
◆ RestoreGivenSubShapes()
◆ RestoreGivenSubShapesO()
GEOM::ListOfGO * GEOM_Gen_i::RestoreGivenSubShapesO ( GEOM::GEOM_Object_ptr  theObject,
const GEOM::ListOfGO &  theArgs,
◆ RestoreGivenSubShapesOneLevel()
GEOM::ListOfGO * GEOM_Gen_i::RestoreGivenSubShapesOneLevel ( SALOMEDS::SObject_ptr  theOldSO,
◆ RestoreSubShapes()
◆ RestoreSubShapesO()
GEOM::ListOfGO * GEOM_Gen_i::RestoreSubShapesO ( GEOM::GEOM_Object_ptr  theObject,
◆ RestoreSubShapesOneLevel()
◆ RestoreSubShapesSO()
GEOM::ListOfGO * GEOM_Gen_i::RestoreSubShapesSO ( SALOMEDS::SObject_ptr  theSObject,
◆ Save()
SALOMEDS::TMPFile * GEOM_Gen_i::Save ( SALOMEDS::SComponent_ptr  theComponent,
bool  isMultiFile
◆ SaveASCII()
SALOMEDS::TMPFile * GEOM_Gen_i::SaveASCII ( SALOMEDS::SComponent_ptr  theComponent,
bool  isMultiFile
References Save().
◆ Undo()
void GEOM_Gen_i::Undo ( )
References _impl, and GEOM_Engine::Undo().
◆ _impl
::GEOMImpl_Gen* GEOM_Gen_i::_impl
◆ _name
char* GEOM_Gen_i::_name
◆ myOpCreatorMap
std::map<std::string, GEOM_GenericOperationsCreator*> GEOM_Gen_i::myOpCreatorMap
