This is the complete list of members for GEOM_Gen_Session_i, including all inherited members.
| _impl | GEOM_Gen_i | private |
| _name | GEOM_Gen_i | private |
| AddInStudy(GEOM::GEOM_BaseObject_ptr theObject, const char *theName, GEOM::GEOM_BaseObject_ptr theFather) | GEOM_Gen_i | |
| AddSubShape(GEOM::GEOM_Object_ptr theMainShape, const GEOM::ListOfLong &theIndices) | GEOM_Gen_i | virtual |
| BreakLink(const char *) | GEOM_Gen_i | inlineprivatevirtual |
| CanCopy(SALOMEDS::SObject_ptr theObject) | GEOM_Gen_i | |
| CanPaste(const char *theComponentName, CORBA::Long theObjectID) | GEOM_Gen_i | |
| CanPublishInStudy(CORBA::Object_ptr theIOR) | GEOM_Gen_i | |
| Close(SALOMEDS::SComponent_ptr theComponent) | GEOM_Gen_i | |
| ComponentDataType() | GEOM_Gen_i | |
| CopyFrom(SALOMEDS::SObject_ptr theObject, CORBA::Long &theObjectID) | GEOM_Gen_i | |
| CreateAndPublishGroup(GEOM::GEOM_Object_var theMainShape, const TopTools_IndexedMapOfShape &anIndices, const TopTools_SequenceOfShape &SeqS, const TColStd_SequenceOfAsciiString &SeqN, const Standard_CString &GrName, GEOM::ListOfGO_var aResList) | GEOM_Gen_i | private |
| CreateFolder(const char *theName, SALOMEDS::SObject_ptr theFather) | GEOM_Gen_i | |
| DumpPython(CORBA::Boolean isPublished, CORBA::Boolean isMultiFile, CORBA::Boolean &isValidScript) | GEOM_Gen_i | virtual |
| findOrCreateComponent() | GEOM_Gen_i | private |
| GEOM_Gen_i() | GEOM_Gen_i | |
| GEOM_Gen_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName, bool withRegistry=true) | GEOM_Gen_i | |
| GEOM_Gen_Session_i(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName) | GEOM_Gen_Session_i | |
| GetAllDumpNames() | GEOM_Gen_i | |
| GetDependencyTree(const GEOM::string_array &theObjectEntries) | GEOM_Gen_i | |
| getDownwardDependency(GEOM::GEOM_BaseObject_ptr gbo, GEOMUtils::LevelsList &downLevelList, std::map< std::string, std::set< std::string > > &passedEntries, int level=0) | GEOM_Gen_i | private |
| GetDumpName(const char *theStudyEntry) | GEOM_Gen_i | |
| GetEntriesToReduceStudy(GEOM::string_array &theSelectedEntries, GEOM::string_array &theParentEntries, GEOM::string_array &theSubEntries, GEOM::string_array &theOtherEntries) | GEOM_Gen_i | |
| GetI3DPrimOperations() | GEOM_Gen_i | virtual |
| GetIBasicOperations() | GEOM_Gen_i | virtual |
| GetIBlocksOperations() | GEOM_Gen_i | virtual |
| GetIBooleanOperations() | GEOM_Gen_i | virtual |
| GetICanonicalRecognition() | GEOM_Gen_i | virtual |
| GetICurvesOperations() | GEOM_Gen_i | virtual |
| GetIFieldOperations() | GEOM_Gen_i | virtual |
| GetIGroupOperations() | GEOM_Gen_i | virtual |
| GetIHealingOperations() | GEOM_Gen_i | virtual |
| GetIInsertOperations() | GEOM_Gen_i | virtual |
| GetILocalOperations() | GEOM_Gen_i | virtual |
| GetIMeasureOperations() | GEOM_Gen_i | virtual |
| GetIORFromString(const char *stringIOR) | GEOM_Gen_i | virtual |
| GetIShapesOperations() | GEOM_Gen_i | virtual |
| GetITestOperations() | GEOM_Gen_i | virtual |
| GetITransformOperations() | GEOM_Gen_i | virtual |
| GetNS() | GEOM_Gen_Session_i | inline |
| GetObject(const char *theEntry) | GEOM_Gen_i | virtual |
| getObjectInfo(const char *entry) | GEOM_Gen_i | virtual |
| GetORB() | GEOM_Gen_i | inline |
| GetPluginOperations(const char *theLibName) | GEOM_Gen_i | virtual |
| GetStringFromIOR(GEOM::GEOM_Object_ptr theObject) | GEOM_Gen_i | virtual |
| getStudyServant() override | GEOM_Gen_Session_i | virtual |
| getUpwardDependency(GEOM::GEOM_BaseObject_ptr gbo, GEOMUtils::LevelsList &upLevelList, std::map< std::string, std::set< std::string > > &passedEntries, int level=0) | GEOM_Gen_i | private |
| getVersion() | GEOM_Gen_i | virtual |
| hasObjectInfo() | GEOM_Gen_i | virtual |
| includeParentDependencies(GEOM::GEOM_BaseObject_ptr gbo, std::set< std::string > &aSelected, std::set< std::string > &aParents, std::set< std::string > &aChildren, std::set< std::string > &anOthers) | GEOM_Gen_i | private |
| includeSubObjects(const std::string &aSelectedEntry, std::set< std::string > &aSelected, std::set< std::string > &aParents, std::set< std::string > &aChildren, std::set< std::string > &anOthers) | GEOM_Gen_i | private |
| IORToLocalPersistentID(SALOMEDS::SObject_ptr theSObject, const char *IORString, CORBA::Boolean isMultiFile, CORBA::Boolean isASCII) | GEOM_Gen_i | |
| Load(SALOMEDS::SComponent_ptr theComponent, const SALOMEDS::TMPFile &theStream, const char *theURL, bool isMultiFile) | GEOM_Gen_i | |
| LoadASCII(SALOMEDS::SComponent_ptr theComponent, const SALOMEDS::TMPFile &theStream, const char *theURL, bool isMultiFile) | GEOM_Gen_i | |
| LoadPlugin(const std::string &theLibName) | GEOM_Gen_i | private |
| LocalPersistentIDToIOR(SALOMEDS::SObject_ptr theSObject, const char *aLocalPersistentID, CORBA::Boolean isMultiFile, CORBA::Boolean isASCII) | GEOM_Gen_i | |
| Move(const GEOM::object_list &what, SALOMEDS::SObject_ptr where, CORBA::Long row) | GEOM_Gen_i | |
| MoveListToFolder(const GEOM::ListOfGO &theListOfGO, SALOMEDS::SObject_ptr theFolder) | GEOM_Gen_i | |
| MoveToFolder(GEOM::GEOM_Object_ptr theObject, SALOMEDS::SObject_ptr theFolder) | GEOM_Gen_i | |
| myOpCreatorMap | GEOM_Gen_i | private |
| name_service | GEOM_Gen_Session_i | private |
| PasteInto(const SALOMEDS::TMPFile &theStream, CORBA::Long theObjectID, SALOMEDS::SObject_ptr theObject) | GEOM_Gen_i | |
| PublishInStudy(SALOMEDS::SObject_ptr theSObject, CORBA::Object_ptr theObject, const char *theName) | GEOM_Gen_i | |
| PublishNamedShapesInStudy(CORBA::Object_ptr theObject) | GEOM_Gen_i | |
| Redo() | GEOM_Gen_i | virtual |
| register_name(char *name) | GEOM_Gen_Session_i | |
| RemoveObject(GEOM::GEOM_BaseObject_ptr theObject) | GEOM_Gen_i | virtual |
| RestoreGivenSubShapes(GEOM::GEOM_Object_ptr theObject, SALOMEDS::SObject_ptr theSObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix) | GEOM_Gen_i | private |
| RestoreGivenSubShapesO(GEOM::GEOM_Object_ptr theObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix) | GEOM_Gen_i | |
| RestoreGivenSubShapesOneLevel(SALOMEDS::SObject_ptr theOldSO, SALOMEDS::SObject_ptr theNewSO, GEOM::GEOM_Object_ptr theNewO, std::set< std::string > theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theAddPrefix) | GEOM_Gen_i | private |
| RestoreSubShapes(GEOM::GEOM_Object_ptr theObject, SALOMEDS::SObject_ptr theSObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix) | GEOM_Gen_i | private |
| RestoreSubShapesO(GEOM::GEOM_Object_ptr theObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix) | GEOM_Gen_i | |
| RestoreSubShapesOneLevel(SALOMEDS::SObject_ptr theOldSO, SALOMEDS::SObject_ptr theNewSO, GEOM::GEOM_Object_ptr theNewO, GEOM::ListOfGO &theOutArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theAddPrefix) | GEOM_Gen_i | private |
| RestoreSubShapesSO(SALOMEDS::SObject_ptr theSObject, const GEOM::ListOfGO &theArgs, GEOM::find_shape_method theFindMethod, CORBA::Boolean theInheritFirstArg, CORBA::Boolean theAddPrefix) | GEOM_Gen_i | |
| Save(SALOMEDS::SComponent_ptr theComponent, const char *theURL, bool isMultiFile) | GEOM_Gen_i | |
| SaveASCII(SALOMEDS::SComponent_ptr theComponent, const char *theURL, bool isMultiFile) | GEOM_Gen_i | |
| Undo() | GEOM_Gen_i | virtual |
| ~GEOM_Gen_i() | GEOM_Gen_i | virtual |
| ~GEOM_Gen_Session_i() | GEOM_Gen_Session_i |
