GEOM_ICanonicalRecognition_i Class Reference
#include <GEOM_ICanonicalRecognition_i.hh>
Inheritance diagram for GEOM_ICanonicalRecognition_i:
 GEOM_ICanonicalRecognition_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, ::GEOMImpl_ICanonicalRecognition *theImpl)
 ~GEOM_ICanonicalRecognition_i ()
CORBA::Boolean isPlane (GEOM::GEOM_Object_ptr theShape, CORBA::Double theTolerance, GEOM::ListOfDouble &theNormal, GEOM::ListOfDouble &theOrigin)
 Check if the shape is planar. More...
CORBA::Boolean isSphere (GEOM::GEOM_Object_ptr theShape, CORBA::Double theTolerance, GEOM::ListOfDouble &theOrigin, CORBA::Double &theRadius)
 Check if shape is spherical. More...
CORBA::Boolean isCone (GEOM::GEOM_Object_ptr theShape, CORBA::Double theTolerance, GEOM::ListOfDouble &theAxis, GEOM::ListOfDouble &theApex, CORBA::Double &theHalfAngle)
 Check if shape is conical. More...
CORBA::Boolean isCylinder (GEOM::GEOM_Object_ptr theShape, CORBA::Double theTolerance, GEOM::ListOfDouble &theAxis, GEOM::ListOfDouble &theOrigin, CORBA::Double &theRadius)
 Check if shape is cylinder. More...
CORBA::Boolean isLine (GEOM::GEOM_Object_ptr theEdge, CORBA::Double theTolerance, GEOM::ListOfDouble &theDir, GEOM::ListOfDouble &theOrigin)
 Check if edge / wire is line. More...
CORBA::Boolean isCircle (GEOM::GEOM_Object_ptr theEdge, CORBA::Double theTolerance, GEOM::ListOfDouble &theNormal, GEOM::ListOfDouble &theOrigin, CORBA::Double &theRadius)
 Check if edge / wire is circle. More...
CORBA::Boolean isEllipse (GEOM::GEOM_Object_ptr theEdge, CORBA::Double theTolerance, GEOM::ListOfDouble &theNormal, GEOM::ListOfDouble &theDirX, GEOM::ListOfDouble &theOrigin, CORBA::Double &theMajorRadius, CORBA::Double &theMinorRadius)
 Check if edge / wire is ellipse. More...
::GEOMImpl_ICanonicalRecognition * GetOperation ()
- Public Member Functions inherited from GEOM_IOperations_i
 GEOM_IOperations_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, ::GEOM_IOperations *theImpl)
 ~GEOM_IOperations_i ()
virtual CORBA::Boolean IsDone ()
virtual void SetErrorCode (const char *theErrorCode)
virtual char * GetErrorCode ()
virtual GEOM::GEOM_BaseObject_ptr GetBaseObject (Handle(::GEOM_BaseObject) theObject)
virtual virtual Handle(::GEOM_BaseObject) GetBaseObjectImpl(GEOM GEOM::GEOM_Object_ptr GetObject (Handle(::GEOM_Object) theObject)
virtual virtual Handle(::GEOM_Object) GetObjectImpl(GEOM void StartOperation ()
virtual void FinishOperation ()
virtual void AbortOperation ()
::GEOM_IOperations * GetImpl ()
virtual void UpdateGUIForObject (GEOM::GEOM_Object_ptr theObj)
- Protected Member Functions inherited from GEOM_IOperations_i
Handle(TColStd_HSequenceOfTransient) GetListOfObjectsImpl(const GEOM bool GetListOfObjectsImpl (const GEOM::ListOfGO &theObjects, std::list< Handle(::GEOM_Object) > &theList)
◆ GEOM_ICanonicalRecognition_i()
GEOM_ICanonicalRecognition_i::GEOM_ICanonicalRecognition_i ( PortableServer::POA_ptr  thePOA,
::GEOMImpl_ICanonicalRecognition *  theImpl
◆ ~GEOM_ICanonicalRecognition_i()
GEOM_ICanonicalRecognition_i::~GEOM_ICanonicalRecognition_i ( )
◆ GetOperation()
::GEOMImpl_ICanonicalRecognition * GEOM_ICanonicalRecognition_i::GetOperation ( )
◆ isCircle()
CORBA::Boolean GEOM_ICanonicalRecognition_i::isCircle ( GEOM::GEOM_Object_ptr  theEdge,
GEOM::ListOfDouble &  theNormal,
GEOM::ListOfDouble &  theOrigin,
CORBA::Double &  theRadius
◆ isCone()
CORBA::Boolean GEOM_ICanonicalRecognition_i::isCone ( GEOM::GEOM_Object_ptr  theShape,
GEOM::ListOfDouble &  theAxis,
GEOM::ListOfDouble &  theApex,
CORBA::Double &  theHalfAngle
◆ isCylinder()
CORBA::Boolean GEOM_ICanonicalRecognition_i::isCylinder ( GEOM::GEOM_Object_ptr  theShape,
◆ isEllipse()
CORBA::Boolean GEOM_ICanonicalRecognition_i::isEllipse ( GEOM::GEOM_Object_ptr  theEdge,
GEOM::ListOfDouble &  theDirX,
CORBA::Double &  theMajorRadius,
CORBA::Double &  theMinorRadius
◆ isLine()
CORBA::Boolean GEOM_ICanonicalRecognition_i::isLine ( GEOM::GEOM_Object_ptr  theEdge,
GEOM::ListOfDouble &  theDir,
◆ isPlane()
CORBA::Boolean GEOM_ICanonicalRecognition_i::isPlane ( GEOM::GEOM_Object_ptr  theShape,
◆ isSphere()
CORBA::Boolean GEOM_ICanonicalRecognition_i::isSphere ( GEOM::GEOM_Object_ptr  theShape,
